Isn't that just nausiating to look at?
(Yes, it's Saturday Night, and I'm playing with SketchUp while listening
to Jesus on Es.)
http://blog.orphi.me.uk/
Download 'a02.png' (16 KB)
Preview of image 'a02.png'
No
"Orchid XP v8" <voi### [at] dev null> wrote in message
news:4ad0da07@news.povray.org...
> to Jesus on Es.)
No
> to Jesus on Es.)
certainly not for not using the right tool, right?
The right tool for designing product electronics is NURBS, like in
Rhinoceros. Polygons don't quite cut.
> to Jesus on Es.)
So it's sounds like you're bored .... right?
Know anything about LaTex markup? I'm struggling with one or two LaTex
markup issue's over on the Wiki. Curious enough to give it a go?
Jim
What issues? And what Wiki, for that matter?
news:4ad1eb2c$1@news.povray.org...
Having trouble getting a formula or two to render like in the documention is
the issue .....
and http://wiki.povray.org/content/Main_Page is where the POV-Wiki is
located. Without too much digging you should be able to find the
Documentation project.
I won't go into the rest of the details unless you are interested!
> the issue .....
OK. Which formulas?
news:4ad20183@news.povray.org...
> OK. Which formulas?
First check out the thread in povray.documentation.inbuilt posted by SharkD
... titled "Problem with formula in blob ..." for background, then go to the
Wiki section here:
http://wiki.povray.org/content/Documentation:Reference_Section_4#Blob
I've isolated the formula in question on a talk page so you can fiddle with
it if you like. There are two ways to get to the talk page. Either use the
"Discussion" link (lower left of each page header) or the "talk" link in the
box just below that .... have at 'er!
BTW: might need to get a wiki login if you haven't already done so!
Thanks
Jim
>> OK. Which formulas?
All it seems to say is that there should be a "min" in there. What do
you actually want to change in the formula?
> then go to the
> Wiki section here:
> it if you like.
I notice the brackets around the fraction aren't tall enough to enclose
it properly. You can fix it like so:
( \frac{...}{...} )
becomes
\left( \frac{...}{...} \right)
I should perhaps also point out that, technically, when TeX sees
<math>cat</math>, it interprets it as "c * a * t", which probably isn't
what you want. Use <math>\text{\it cat}</math> instead. (There's a
subtle difference in the letter spacing - and also the typeface is
slightly different.)
> to Jesus on Es.)
Hehe, this is on level with someone using Paint to draw a reflective sphere
over a checkered plane, and ending up with a red circle over a green
rectangle :-)
> sphere over a checkered plane, and ending up with a red circle over a
> green rectangle :-)
Why thank you. I feel much better now. :-P
Meh, the tutorial videos feature all kinds of intricate models, and
YouTube has a few people drawing highly complex stuff, but I don't see
how it's possible...
Don't feel bad, you're using totally the wrong tool to try and do something
like you attempted. There's a reason why Nokia don't use SketchUp to design
their phones :-)
> YouTube has a few people drawing highly complex stuff, but I don't see how
> it's possible...
Apart from showing off, I never understood people using a tool for something
it really isn't designed for. If you really want to design stuff like that
phone with nice smooth surfaces then put the effort in to learning something
like Blender rather than SketchUp.
> something like you attempted. There's a reason why Nokia don't use
> SketchUp to design their phones :-)
> something it really isn't designed for. If you really want to design
> stuff like that phone with nice smooth surfaces then put the effort in
> to learning something like Blender rather than SketchUp.
I wonder - is there anything that SketchUp *is* the right tool for?
Every single time I mention it, everybody says I should use Blender
instead...
> I wonder - is there anything that SketchUp *is* the right tool for? Every
> single time I mention it, everybody says I should use Blender instead...
AIUI (I only tried it once ages ago when it first came out) it is meant for
quickly designing simple, straight-lined 3D objects. Like simplified
versions of buildings that mostly consist of cuboids or angled parts.
Wasn't it originally released to allow people to add 3D versions of
buildings to Google Earth?
>> instead...
> for quickly designing simple, straight-lined 3D objects. Like
> simplified versions of buildings that mostly consist of cuboids or
> angled parts. Wasn't it originally released to allow people to add 3D
> versions of buildings to Google Earth?
Indeed, there's a big 3-part tutorial showing somebody importing a plan
from a CAD program, tracing the walls, and cutting all the doors and
windows. The result is pretty impressive, actually...
My own attempts to do something similar are far less convincing.
news:4ad228ec$1@news.povray.org...
> All it seems to say is that there should be a "min" in there. What do you
Exactly ...
> I notice the brackets around the fraction aren't tall enough to enclose it
> ( \frac{...}{...} )
> becomes
OK ... this was helpful ... thanks
> what you want. Use <math>\text{\it cat}</math> instead. (There's a subtle
> difference in the letter spacing - and also the typeface is slightly
> different.)
The \it tag (italics?) was causing me grief. It gave a lexing error ...
failed to parse. With the \text tag alone I get normal typeface, without it
I get the italics typeface. it doesn't seem to be behaving as you suggest.
Here's what it looks like now:
http://wiki.povray.org/content/Documentation_Talk:Reference_Section_4
I think it looks like what Mike was getting at ... correct?
Jim
>> ( \frac{...}{...} )
>> becomes
> OK ... this was helpful ... thanks.
Works with any delimiter, by the way:
\left[ ... \right]
\left| ... \right|
etc.
If you wanted to be flashy, you could replace min(...) with those funny
bent-angle brackets - but I don't suppose anybody except a mathematician
would understand what the hell that means, so leave it.
>> different.)
It's quite possible the Wiki doesn't support arbitrary TeX markup, but
only supports a specific subset of commands. You could try
\text{\emph{distance}} or something. That should typeset it in text
italics, which is subtly different from math italics (especially
spacing). The AMS-LaTeX \text{} command also adjusts the spacing subtly.
I will admit that all of this makes a fairly subtle difference to the
final output though.
Change "min" to "\min" to have it typeset correctly. (I.e., in Roman
type, like all function names. It might even fix the spacing on the
brackets following...)
The spacing of the superscripts looks slightly odd, but I couldn't tell
you why...
"Invisible" <voi### [at] dev null> wrote in message
news:4ad31c78$1@news.povray.org...
> \left[ ... \right]
> \left| ... \right|
another nugget ... thanks
you are probably correct ...
> You could try \text{\emph{distance}} or something. That should typeset it
> in text italics, which is subtly different from math italics
no joy with this markup either ....
> Change "min" to "\min" to have it typeset correctly. (I.e., in Roman type,
> like all function names. It might even fix the spacing on the brackets
> following...)
worked ... thanks for the assist!
>> \left[ ... \right]
>> \left| ... \right|
This method makes the brackets just big enough to contain the interior
text. You can also set the bracket size manually (e.g., if you want the
outer brackets big and the nested brackets smaller, to aid visibility),
but we won't worry about that. In this specific case, the brackets come
out reasonable sizes, so no need to fiddle.
You can also do stuff like this:
| -1 if x < 0
sign x = < 0 if x = 0
| 1 if x > 0
Use "\left\{" to get the stretched symbol (you have to balance it with
"\right."), and then use an array environment to typeset the multiple rows.
I don't suppose for 13ms that there's any *documentation* for what the
wiki actually supports though...
Really? That's odd. Well, I guess the difference is quite small.
>> following...)
In general, any function name (sin, cos, tan, min, max, lim, etc.) wants
to be handled this way (\sin, \cos, etc.)
Now, in LaTeX there's a way to define new function names - but you have
to write the declaration in the document preamble. Not sure if you can
access this particular feature from the wiki...
Any further questions? :-D
>> what you want. Use<math>\text{\it cat}</math> instead. (There's a subtle
>> different.)
In math mode, if you want text to appear in italics, and not be treated
like a formula, use \textit{...}.
There's also \textrm if you want it to be nonitalicized. Bunch of
others - see the links below.
Check out the page now - the 2nd formula is using \textit
Ever been to the LaTeX Wikibook:
http://en.wikibooks.org/wiki/LaTeX
I don't know how good it is for learning LaTeX, but it's fairly good
for either quick lookups or for "recipes" to achieve certain effects:
http://en.wikibooks.org/wiki/LaTeX/Mathematics#Adding_text_to_equations
http://en.wikibooks.org/wiki/LaTeX/Formatting#Font_Styles_and_size
A tautology is a thing which is tautological.
Getting people to talk about how cool Google is.
"Neeum Zawan" <m.n### [at] ieee org> wrote in message
news:4ad35232$1@news.povray.org...
Jackpot! Exactly what I was going for, with them next to each other it's
easy to see the difference in font spacing.
> I don't know how good it is for learning LaTeX, but it's fairly good for
Yes .... there is a lot of good stuff on Wiki's .... bookmarking links ....
Thanks
Jim
> treated like a formula, use \textit{...}.
Ah. I knew about \textrm, but \textit wasn't mentioned anywhere. (I know
it works in text mode, but I wasn't sure about math mode.)
Good work.
Does anybody else detect a subtle hint of cynicism here? ;-)
That looks exactly like the decade old Mitel phone in my office.
Excellent work!
~Mike
> Excellent work!
Please tell me it doesn't use those colours. o_O
For me it was the opposite.<G> I thought they were meant primarily for
math mode, and only found out they work in regular mode when I posted
the Wikibook links...
An unbreakable toy is useful for breaking other toys.
Welcome to my humble home.
This took 11 minutes to draw. And no, the house isn't *really* that
God-awful colour...
[And no, technically it's my mum's house.]
Download 'a01.png' (47 KB)
Preview of image 'a01.png'
Why does this remind me vividly of The Sims 2?
I don't know. Does The Sims 2 feature horrific colour schemes and badly
drawn stairs?
Well, no. It's not as fancy as yours. It comes in a nice shade of beige.
~Mike
Ah, OK.
I was actually purposefully going for a retro look, if only because back
in the old days straight lines were cool.
(The colours were so I can tell WTF I'm looking at while I model it.
SketchUp isn't very easy to navigate...)
Invisible escreveu:
> instead...
It's much better at architectural creations than Blender. Blender and
other polygonal-based modellers are not the right tool for product
design either. That truly demands fine and precise NURBS tools.
a game sig: http://tinyurl.com/d3rxz9
http://www.wonderhowto.com/how-to/video/how-to-model-a-house-in-blender-3d-242095/
Which is not to say Blender makes it easy, but it's not *too* bad.
Darren New escreveu:
I've learned to use that technique too. Sketchup still has a large edge
over it.
> over it.
I see what you did there. ;-)
