I wanted to look into this C# and XNA malarkey so downloaded the free
express edition of C# and XNA from MS. Yes I know this should go in a blog
but I don't have one and don't plan to write much like this.
Firstly, the code auto-complete and general "text editor" part of the IDE is
amazing, a big step forward from the C++ Express edition I had been using.
The auto-complete list remembers multiple things at multiple levels that you
have typed before and jumps to them first as you type, this saves *a lot* of
time when you have lots of "using" statements (ie the auto-complete list is
quite long). Also it seems to dynamically compile (or at least parse
somehow) your code in realtime, if you mis-spell a variable or use one
without initialising it, it gets underlined in red the same spelling
mistakes do in Word. You can then either hover over the error or look in
the error list window to see what's up *very useful*. Warning are
underlined in green, things like unused variables.
There is some basic code refactoring built in which is pretty handy. You
can select some lines of code and tell it to pull it out in its own
function, parameters and return values will be handled automatically. You
can do the same by just typing in a call to a non-existant function (which
will get underlined in red), then clicking to tell it to make the definition
for that function. Also if you rename one occurrence of a variable
manually, it will get the little "option box" next to it that lets you
rename all other occurrences of it automatically - nice.
About the actual language of C#, I've never used any really expert features
of C++ so can only give a basic comparison, but essentially C# is *way*
easier to program and much less prone to mistakes. Maybe part of the reason
why is that you can instantly see if you've made a mistake. For example I
didn't know the syntax for declaring an array, yet after a few seconds of
trial and error I got something that worked based on what I knew about
C++.net (would have taken longer to open up help and search for array).
Also no need for any pointers or *'s and &'s dotted about, all handled for
you. If you want to pass a variable by reference to a function then just
write "ref" before it, very simple.
Also if you are using multiple source files this is very much simplified in
C#. In C++ you need to mess about with #includes and hacks to stop files
being included more than once when referenced from multiple source files -
not with C#, no need for any include statement, if it's in the project you
have access to it. There is also no concept of "order" when files are
included, every file has visibility of every other source file, so you don't
get circular reference problems. The same applies within files, so you can
write:
struct Line { Point n1 , Point n2 }
struct Point { int x , int y }
And this is fine.
One little niggle I had to start with was that when you define a class, you
need to write the code for all the methods of that class in the definition
too (in C++ I would usually put the actual method code in a separate file).
Actually after a few days of coding it doesn't really bother me now, I got
into the habit of "collapsing" the code in the IDE using the +/- icon so
that there is just a list of methods. If you want to view or edit the code
for a certain method you can just expand it temporarily. I'm even
contemplating that this is actually a better way to manage classes than
always having two separate files for each class that must be kept in sync
(eg to add an extra parameter to a function you always have to change it in
both files).
I've just started to dig the surface of XNA, but it seems to me to be
basically DirectX.net, which is not a bad thing. I got a simple 2D and then
3D program up and running in very little time, I'd say maybe 4 or 5 times
quicker than I ever managed with C++ and DirectX. XNA programs can also be
built to run on the xbox - it almost makes me want to get one just so I can
play some game I wrote on a console! There's a whole host of cool build
tools, like automatically converting images, fonts and mesh data into
optimal formats at compile time - this is genius.
> then 3D program up and running in very little time, I'd say maybe 4 or 5
> times quicker than I ever managed with C++ and DirectX.
I'm just impressed that somebody could write a program with C++ and
DirectX and 1. have it actually work and 2. have it to something nontrivial.
I'm sure you remember my first C++ program. That was a trivial console
application, and it *still* took miles of code. And it didn't even make
any low-level system calls such as DirectX...
I'm not surprised you are impressed by such things.
You simply refuse to actually learn how to program properly in C++ even
if some people try to teach you. I believe you do that on purpose (because
if you actually learned to program efficiently in C++, you would have to
redact some of your stances and opinions about the language). It's not that
you can't understand C++, it's that you won't.
> both files).
You can do pretty much the same thing in C++, by implementing the methods
in the class declaration. Of course this is recommended only for small
classes. With large classes you'll end up with a megaclass which will be
hard to understand and maintain, so it will cause more trouble than it's
worth.
While not very common, sometimes classes become quite large, not necessarily
in the amount of public member functions and private member variables, but
in the sheer amount of code required to implement the class. It becomes even
larger if the class has inner classes and other such types. These inner
classes have to be implemented somewhere as well, naturally.
Sometimes it's useful to be able to separate the implementation of such a
big class into two or even more files. I have done that in practice with
some such classes. This can happen when the class is more like a big module
(which has to be instantiated, perhaps several times, so a simple namespace
won't do) which has quite a large amount of functionality inside (even if
its public interface is relatively small).
For example in one work project I had such a class-module. Internally the
functionality of the class could be divided into separate, more or less
independent parts. Thus it was only logical and natural to implement those
parts in separate files (thus I had one header file and several source files),
which kept the individual source files under manageable sizes. Also inner
classes could be implemented in their own separate files, which helped in
lessening the amount of clutter in the "main" source file for the class.
At the university here they had the rule of thumb that 1000 lines of code
is a good upper limit for a single source file (of course this is a very
soft limit). I have tried to obey that rule of thumb, and I have found it
a rather sound advice. If source files grow significantly larger than that
(eg. 2000 lines or more), they become quite hard to manage.
The only problem with code refactoring is that it really does have to
recompile the code, which means it can't refactor code that doesn't compile.
If you have a half-finished function you're typing in, and you realize you
want to convert something in the middle of an earlier function into a
stand-alone method, you have to clean up what you're working on enough to do
that.
Unless they've fixed that since last I looked.
Be aware C# can do this. It's what they mean by "partial classes". I'm
pretty sure it was originally intended to separate boiler-plate generated
code from real code you write yourself, but it works for big classes too.
Subject: Re: Visual C# .net (and XNA) first impressions
Date: 12 Oct 2009 03:56:58
Message: <4ad2e14a@news.povray.org>
> compile. If you have a half-finished function you're typing in, and you
> realize you want to convert something in the middle of an earlier function
> into a stand-alone method, you have to clean up what you're working on
> enough to do that.
They seem to have fixed that, I tried what you said and it worked fine.
> worth.
Yes, this had always been my mentality with C++ too, in fact it was very
rare I would put any actual code in the class declaration file. With C#
though it kind of forces you to do this (I don't know whether it's possible
not to), which at first I thought was terrible, but once I got used to
"collapsing" the code with the little +/- icons in the margin, I think it
works really well. You can have multiple levels of the collapse tree and
define your own collapse regions in the code if you want (so if you had
several methods implemented all relating to one part, you could collapse all
these together). The result is that the source file *looks* like simply the
class declaration, but when you need to you can expand any part to see the
actual code.
If I went back to using C++ for something, I might be tempted to do this
too. I wonder if the Visual C++ Express edition IDE is the same as the C#
one? Maybe I just have an old version of the C++ one that doesn't contain
some of the newer features.
> works really well.
I'm not completely convinced by having the need of a specialized source
editor in order to understand the source code better. If you ever need to
develop the source in some environment where you don't have that editor
with those fancy features, you are going to find yourself wading through
thousands and thousands of lines of code.
Things like code block collapsing and code coloring are definitely
helpful, but IMO good-quality code shouldn't rely on those editing features
in order to keep itself understandable and maintainable. You never know
when you will have the need to understand the code in an environment
which lacks those features.
Date: 12 Oct 2009 11:01:15
Message: <4ad344bb@news.povray.org>
"scott" <sco### [at] scott com> wrote in message
news:4acf4330$1@news.povray.org...
> you need to write the code for all the methods of that class in the
> definition too (in C++ I would usually put the actual method code in a
> separate file). [...]
In the .NET environment, you could do it that way by writing an interface,
then implementing the interface in a class definition. I wouldn't recommend
doing that just to make C# behave like C++, though. C# is great at what it
does, and C++ is great at what it does, but they're really two different
languages. C# is a front end for the .NET CLR, and is made so that C and C++
programmers have a familiar way in to that environment. C++ is for
programming down to the bare metal, and hopefully always will be.
I use .NET languages when I need to quickly make input modules. You still
can't beat C++ for performance, though. :)
> features
Yes that's a good argument for not always using those features in general,
but for me personally I don't think my C#.net/XNA code will ever be opened
in anything other than the MS IDE :-)
You are perfectly welcome to write a second bit of source code and maintain
it in sync with the main file when using C# also. ;-)
> If you ever need to
It's really not a problem. I actually find it easier to find things in C#
than in C++, exactly because I know where to look. If I want to see how
alpha::beta is implemented, I know where to find it and I know what search
string to put in. In C++, I'm lucky if I can figure out what header file
it's in, let alone where in the class heirarchies it is.
That's one thing I'm finding about trying to figure out this huge
undocumented code base I'm working with - it's almost impossible to actually
track down where the f'ing code *is*. There's way too many things like
typedef enum {
... 300 lines of enums ...
} TYaddaBlow;
OK, now go grep thru half a million lines of code looking for that
declaration to figure out what the possible values for the enum are. Don't
forget that the same name is defined in three different layers of the
architecture, so even when you find it, you need to read the 2000-character
gcc line to try to figure out which .h file containing the declaration gets
included first, so you know which enum definition that particular source
file is using. </rant>
Then you generate the header docs from the source code and you're good to
go. There's no reason to make maintaining two files a manual process. On the
other hand, if you *want* to do so, you certainly can.
>> you realize you want to convert something in the middle of an earlier
>> function into a stand-alone method, you have to clean up what you're
>> working on enough to do that.
Kewl. I remember reading someone's paper about how they figured out (for
example) which brace you had intended to close in something with the wrong
number of closing braces. It was a novel approach to incremental parsing.
> go.
Not everything in a source file is supposed to be part of the public
interface.
>> go.
> interface.
Ah, but it *is*, in C++.[1] In C#, you can tell it to leave the private
functions out of the generated documentation altogether. :)
[1] Which, incidentally, I find highly annoying when it's time to add a
helper function to a class to split up a big file, and I have to go declare
this completely private class in a different file *and* recompile everything
that uses the class, even tho I've just said "nobody outside the class is
allowed to use this anyway." But that's a minor annoyance, just part of the
job, compared to the *CRAP* I'm dealing with lately in this code base. :-)
Date: 12 Oct 2009 13:49:15
Message: <op.u1o7sdl37bxctx@e6600>
On Mon, 12 Oct 2009 18:50:12 +0200, Darren New <dne### [at] san rr com> wrote:
>> public interface.
No.
> In C#, you can tell it to leave the private functions out of the
There is no reason why a C++-capable version of "it" could not do the same.
FE
> >> go.
> > interface.
What do you mean? Ever heard of the nameless namespace? Everything in
a nameless namespace is local to that source file and definitely not part
of the public interface of that module. (In fact, there's no way of
accessing anything inside a nameless namespace from another source file.)
Also an inner class doesn't have to be declared in the public interface
(only its name has to be pre-declared, but that's not very helpful from
the outside).
(In fact, even an inner class in the *public* interface of a class
doesn't have to be declared. It will work as a completely opaque type
from the outside in that case. I think this is an even more important
case where you *don't* want that inner class to become public, except
as an incomplete type, ie. "in type name only".)
Btw, I really don't see a lot of difference between fancy source editor
features and a public interface generator. In both cases you need some fancy
external program to help you clarify the source code.
>>> public interface.
> No.
OK, I'll grant you that you were talking about the bodies of the functions
also. My bad. :-)
Sure. But people are discussing .h files, where there's no such option in
C++. In C, you could make the function static, but that's not the same thing
for a C++ method. Obviously you could write a tool that works almost as
well for sufficiently well-organized C++ code as works for C#, but then
you'd be complaining you might not have that tool elsewhere. :-)
You can't make a private method on a class without exposing that in the
header, can you? (If so, I've been doing it wrong. :-)
> the outside).
You're still exposing its existance in the header file, meaning you get to
recompile stuff, for example. 0
You don't need such a tool in C# any more than you need a tool to generate
the .h files for you in C++.
However, since C# makes the "makefile" structure part of the language, it's
possible to write tools that extract equivalent documentation from C# that
you can't as easily write in a portable way for C++. I.e., even if you have
a complete C++ parser, now you need a whole lot of extra stuff to understand
*which* header files go with *which* source files when you're trying to
parse C++.
That's your argument for dismissing all the private types, functions and
data that can be specified in a source file (and which don't belong to the
header file)?
> > the outside).
I don't understand that sentence.
> parse C++.
I'm not completely following what you are saying.
> for a C++ method.
How would you suggest having support for implementing private functions for
a class without having to declare them in the class declaration *and* without
opening the private parts of the class to any external code that wishes to
access it?
Assume you could do this in C++:
// HeaderFile.hh
class MyClass
public:
void some_public_function();
private:
some_private_data;
// HeaderFile.cc
#include "HeaderFile.hh"
void MyClass::some_public_function() { ... }
// Add a new private function to MyClass:
void MyClass::a_private_function()
// Access some_private_data here
Hey, that's great. I can add new private functions to MyClass without
having to modify the declaration of the class nor the header file. Cool.
Except for one problem:
// SomeOtherFile.cc
void MyClass::bypass_privacy()
Now you have opened your entire class for anyone to access from anywhere
without restriction, making your public/private distinction completely
meaningless.
(You might find that ok, but most OO programmers don't, including most of
the people who know about these things.)
The solution to this is to specify the private functions in the class
declaration.
If you don't care about privacy, then put everything in the public section
of the class and write all the formerly private functions in a nameless
namespace inside the source file. That way you don't have to add anything
to the header file if you want to add a new private function.
Date: 12 Oct 2009 15:58:50
Message: <4ad38a7a@news.povray.org>
> header file)?
Maybe that's just the crap I've run into myself. :-)
>> parse C++.
I'm saying that the argument seems to be "C++ header files are better,
because it's not mixed in with the implementation stuff." When I point out
that you can get documentation out of C# that's just like C++ header files,
people point out you need a tool to do that.
That's an incorrect assertion. You don't need a tool to make that
documentation any more than you need a tool to make C++ header files. C++
header files aren't better because they're C++, but because they're manually
constructed and maintained. If they aren't manually constructed and
maintained, then you need a tool to do that just like you do for C++.
And the tool for C++ will have a harder time of it, *because* there's no
indication of any compilation units bigger than a .cpp file, and so on.
I.e. you can't just give a pile of C++ source files to a tool and have it
understand the code without having it figure out and understand all the
compiler command lines as well. (This goes for C as well, of course.)
I can give you all the source code I'm working on, and there's no way you
could ever figure out how to compile it without trying to compile and run it
against each set of header files to see what works, for example. That's not
the case with C#, because there's a file in a standard format that serves
the purpose of a makefile and which the libraries already have tools to deal
with.
>> for a C++ method.
> access it?
I don't know. C# does it by not having header files. I'm not saying C++'s
solution is a bad one per se. (*I* don't like it as much, but that doesn't
mean it's *bad* universally.)
I'm merely pointing out that it's hypocritical to claim that it's better to
*have* to maintain something manually because then you're not dependent on a
tool to maintain it.
> declaration.
Or not have class declarations at all. If you define it private, then it's
private. You don't need to declare it at all, public or private.
That doesn't work for instance methods, does it? An instance method
actually has to be a member of the class in the class declaration, yes? (I'm
just double-checking I understand that part.)
Well, nothing stops you from implementing everything *in* the class
declaration in C++. (Well, except if you want to keep some degree of
modularity.)
I don't see separate declarations and implementations as such a big problem
as you seem to.
> > declaration.
How do you stop someone from adding a new private function to your class
from the outside, then?
Well, if everything is public, what do you need private methods for?
Private methods are only for access, but if access is already completely
open, then there's no need for private methods. You can replace them with
local functions (ie. local to the compilation unit, ie. in a nameless
namespace).
Date: 12 Oct 2009 17:54:39
Message: <4ad3a59f@news.povray.org>
> modularity.)
Right.
> as you seem to.
I don't either. I'm just pointing out that it's silly to say not *having* to
do that is a *problem.* I'm not bashing C++. I'm saying it's silly to say
that C++ is superior in the aspect that it *makes* you manually maintain a
separate file with the information in it that C# programs can generate
automatically. At least because you can *also* maintain that information
manually in C#.
Because you have to compile all the parts of the class at the same time in
C#. If you're *really* worried about it, you sign the result. :-)
Where did I say everything is public? I just said that the private methods
wind up being visible in the public "interface" file in C++. Again, I was
just commenting in terms of people complaining there was too much "visible"
in the C# way of doing things.
> namespace).
Hmm. But you don't get a "this" pointer, right? You need to start being
explicit about everything that OO is supposed to make implicit, like
accessing member variables from inside the function and all?
A header file is not really a "public interface". It's just a source code
file like any other. The "public interface" of a class is what you put
inside the "public" section of the class. Whatever there might be in the
"private" section is there purely for technical reasons, and you shouldn't
concern yourself about it and consider it effectively hidden (at least if
you want to maintain good OOD).
Yes, a class declaration cannot be split into two or more parts in C++
(for technical reasons), but that doesn't make the private part any more
"public".
There are other programming languages (such as Objective-C) where you
can split the class declaration into two, putting one part in a header
file and the other in the source file, but that's because the way objects
are implemented allows that (at the cost of speed and memory efficiency).
> > namespace).
The 'this' pointer is passed implicitly to member functions by the
compiler. If you decide to make it a local function instead, you'll have
to pass the object pointer explicitly as a function parameter. Otherwise
there isn't too much of a difference, just a small difference in syntax.
(The real difference between private member functions and local
functions is access scope.)
Date: 12 Oct 2009 19:08:10
Message: <4ad3b6d9@news.povray.org>
Actually, you can. COM does it. But you end up making all public methods
virtual, and a feature of C++ over C# is that you have the choice not to
make everything virtual :)
Right. If you're talking about C# being too "cluttered" in its declarations
(because they're technically in the class body, all one file sort of thing),
then the fact that you have to visually skip the private sections of the
class header I think would have to be accounted for in the "ease of use of
using a .h file for documentation" arguments.
> but that doesn't make the private part any more "public".
Only if you're looking at the ergonomics of using a .h file as documentation.
Good! I understood that right. :-)
Yeah, I guess that's true too. :-)
Not everything in C# is virtual either, if you don't declare it virtual.
You're thinking of Eiffel or something.
Date: 13 Oct 2009 13:51:28
Message: <4ad4be1f@news.povray.org>
Maybe Java.
I forgot to add one thing: executable code size.
I wrote a little app that uses C# and DirectX, just a simple physics-based
"game" with a few connected bodies controlled by the keyboard and an RK4
integrator. The result is drawn on the screen in a window. The generated
.exe is 23KB - I couldn't believe it and had to copy it to my other PC to
check it actually worked. Nowadays I guess it doesn't matter if your file
is 23KB or 2.3MB, but still I thought it was cool how small it was.
Date: 14 Oct 2009 12:02:26
Message: <4ad5f612@news.povray.org>
scott wrote:
> The generated .exe is 23KB - I couldn't believe it and had to copy it to
> my other PC to check it actually worked.
Why wouldn't it work? Because it is a 23KB app but actually depending on a
huge library on your PC where most of the code would be?
Guess what, it is, and the other PC had it as well ;)
Date: 15 Oct 2009 02:55:20
Message: <4ad6c758@news.povray.org>
IME (from Borland and older MS C++ compilers) when a compiler generates a
GUI-based .exe as small as that something is usually missing that nobody
without the compiler would have installed.
I'm sure in the "old days" I was generating several MB .exe files to be
redistributed, now it seems finally they are putting *just* the code you
wrote in the .exe, and everything else is assumed to be installed already
(ie the .net runtime). It makes it much more efficient to distribute,
especially when there are frequent updates.
Date: 16 Oct 2009 17:45:57
Message: <4ad8e994@news.povray.org>
I don't see the difference. Before, you needed the Borland Runtime. Now you
need .NET.
Date: 19 Oct 2009 06:48:38
Message: <4adc4406@news.povray.org>
> you
> need .NET.
Most people have the .net runtime, whereas most people do not have the
Borland runtime.
It's like the difference between sending someone an obscure document format
(and telling them where to get the reader from) or just sending them a PDF.
Technically you need a reader too for PDF, but almost everyone has it
already, so it's much more convenient.
>> Now you need .NET.
> Borland runtime.
> format (and telling them where to get the reader from) or just sending
> them a PDF. Technically you need a reader too for PDF, but almost
> everyone has it already, so it's much more convenient.
Where does this "everybody has the .NET runtime" myth come from?
My PC didn't have the .NET runtime. (If I hadn't installed VisualStudio,
it still wouldn't have it.) My brand new Vista laptop still doesn't have
the .NET runtime. My mum's PC doesn't have the .NET runtime. My
grandparents' PC doesn't have the .NET runtime. My dad's two Windows PCs
don't have the .NET runtime. And the 35 PCs at work didn't have the .NET
runtime either until we rolled out some app which actually needed it.
(We deployed it via Windows Update Server.)
So who is this "everybody" who already has the .NET runtime then?
Date: 19 Oct 2009 08:55:38
Message: <4adc61ca@news.povray.org>
The only people who don't have it are those that still have XP, have not
installed all the Windows Upates, and have never installed a program that
needed the .net runtime. It can't be that many compared to the number of
people without the Borland runtime :-)
> My brand new Vista laptop still doesn't have the .NET runtime.
Did you uninstall it somehow? Vista comes with .net 3.0.
> that needed the .net runtime. It can't be that many compared to the
> number of people without the Borland runtime :-)
I would think the number of people with the .NET runtime *is* far, far
larger than the Borland runtime. But still, I've yet to come across any
PCs which have the .NET runtime "already". All the machines at work had
to have it added, and my PC at home only has it because VS requires it
for some reason.
I'm also pretty certain that the .NET runtime is *not* automatically
installed by Windows Update. You can _request_ it from Windows Update,
but it's listed as "optional software" rather than a required update.
(Of course, updates to any version of the runtime you've already
installed get added automatically. But not the runtime itself.)
And what do you mean "still have XP"? Last time I checked, virtually
*everybody* is "still" using XP. (Except for the tiny few who bought a
new PC recently.)
I rephrase: The .NET runtime is not listed in add/remove programs. I
presumed this to mean it isn't installed.
Date: 19 Oct 2009 09:41:50
Message: <4adc6c9e@news.povray.org>
> installed by Windows Update. You can _request_ it from Windows Update, but
> it's listed as "optional software" rather than a required update. (Of
> course, updates to any version of the runtime you've already installed get
Oh ok I hadn't checked what category it came under, I just remember seeing
it on my XP box a long time ago.
> *everybody* is "still" using XP. (Except for the tiny few who bought a new
> PC recently.)
Recently I've seen a lot of people show up with Vista laptops, I guess most
people get them replaced every few years so it's not surprising. Anyway I
kind of meant the original un-updated XP, the service pack updates include
.net anyway.
BTW, according to Wikipedia 22% use Vista and 68% use XP, and you can guess
which way both those numbers are heading...
Ah ok, yes it *is* installed, but I assume you cannot uninstall it (because
presumably some parts of Vista were written to make use of it).
> Anyway I kind of meant the original un-updated XP, the service pack
> updates include .net anyway.
I'm pretty sure this is incorrect too. The Windows Update server had to
install SP3, reboot the PC and then install the .NET framework - which
doesn't like a lot of sense if SP3 *includes* it.
> guess which way both those numbers are heading...
Yes, I expect Vista usage to increase over time. (Or will it? Maybe
everybody will just move to Windows 7?) My point is *today* few people
use it.
> (because presumably some parts of Vista were written to make use of it).
Interesting. So it's installed but just not listed? Is there a
scientific way to confirm this?
I should have realised eventually I would have no choice in the matter...
"Invisible" <voi### [at] dev null> wrote in message
news:4adc6da2$1@news.povray.org...
> Interesting. So it's installed but just not listed? Is there a scientific
Look in Control Panel under Administrative Tools. If you have any of the
.NET frameworks installed, there should be an icon (or more) for it there.
IIRC, the only thing you'll see in Add/Remove programs is the service packs,
if any, that you have installed for the frameworks.
Check your "Windows\Microsoft.NET\Framework" folder (and "Framework64" if
applicable). Each installed .NET version has its own subfolder there.
Alternatively, just run Windows Update and see which ones you have not yet
installed.
FE
Oh ok, I don't remember so I might be wrong, I thought I read that from XP
SP2 onwards .net was included. Might the SP install just have deferred the
installation of .net until after the reboot?
I assume Windows 7 will include .net, so the % of machines with .net
installed should continue to rise.
>> to install SP3, reboot the PC and then install the .NET framework -
>> which doesn't like a lot of sense if SP3 *includes* it.
> XP SP2 onwards .net was included. Might the SP install just have
> deferred the installation of .net until after the reboot?
Nope. I sometimes have to do this manually if WUS doesn't work for some
reason, and just installing SP3 is insufficient. No amount of rebooting
helps. You have to also manually install the .NET framework, which is a
seperate [240 MB] download.
Oh, sure. I meant will Windows Vista continue to increase once Windows 7
is out. ;-)
Date: 21 Oct 2009 05:26:37
Message: <4aded3cd@news.povray.org>
> is out. ;-)
Probably, for a while. Especially in large companies there is always a big
delay between a new OS being released and that OS starting to be used. From
my experience a lot of places are starting to roll out Vista on new
machines, I suspect that trend will continue for at least another year or so
until they have tested Windows 7 sufficiently.
>> 7 is out. ;-)
> big delay between a new OS being released and that OS starting to be
> used. From my experience a lot of places are starting to roll out Vista
> on new machines, I suspect that trend will continue for at least another
> year or so until they have tested Windows 7 sufficiently.
Certainly the company I work for has vowed to not even touch Vista. They
were going to wait 3 years, but not I think they're looking at going
straight to Windows 7.
Weird really. As soon as a new server OS comes out, they can't install
it fast enough. But desktop OS, they tend to wait until it's a few years
old before even testing it.
