POV-Ray : Newsgroups : povray.off-topic : Now *that* would run POV-Ray Server Time
18 Oct 2026 10:39:55 EDT (-0400)
  Now *that* would run POV-Ray (Message 1 to 19 of 19)
Subject: Now *that* would run POV-Ray
Date: 2 Oct 2009 18:47:35
Message: <4ac68307@news.povray.org>
Download 'image1.jpg' (96 KB)
Preview of image 'image1.jpg'
Subject: Re: Now *that* would run POV-Ray
Date: 2 Oct 2009 18:58:24
Message: <4ac68590@news.povray.org>
And it runs SUSE Linux. :)  I'm sure povray would compile for it. :-)
Jim
Date: 2 Oct 2009 22:59:59
Message: <4ac6be2f$1@news.povray.org>
bwahaha... It'd run MCPov in real time! :D
Date: 2 Oct 2009 23:59:02
Message: <4ac6cc06$1@news.povray.org>
What's the liquid we see sloshing around in it?  Tap water with food
coloring, or distilled water with green lighting, or nitrogen, or
something else?
...Chambers
Date: 3 Oct 2009 01:47:09
Message: <4ac6e55d@news.povray.org>
> something else?
I think they use propylene glycol (anti-freeze), though they sell
systems with R134a coolant too, so it might be that.
Date: 3 Oct 2009 04:47:07
Message: <4ac70f8b$1@news.povray.org>
Uh... assuming those cores are of some architecture that POV-Ray
supports, that is. :-P
http://blog.orphi.me.uk/
Date: 3 Oct 2009 08:40:45
Message: <4ac7464d@news.povray.org>
  POV-Ray doesn't support architectures. Compilers support architectures.
Date: 3 Oct 2009 09:55:01
Message: <4ac757b5$1@news.povray.org>
Are you seriously suggesting that POV-Ray can simply be recompiled for
any possible architecture that possesses a C compiler? I would think
it's more work than that.
Date: 3 Oct 2009 10:02:03
Message: <4ac7595b@news.povray.org>
  The backend (ie. core renderer) should be pretty much standard portable
C++, so if a standard conforming C++ compiler exists for the architecture,
the POV-Ray backend should be compilable to any such architecture. It's
then only a question of creating a frontend (in its most basic form it's
simply I/O: Some way of feeding the SDL file to the backend, and some way
of outputting the resulting pixels somewhere). Of course if the system
already has support for an existing POV-Ray fronted (eg. a unix-style
command-line interpreter) then it's much easier.
Date: 3 Oct 2009 15:13:45
Message: <4ac7a269$1@news.povray.org>
Dual-/quad-core AMD Opterons and a runtime environment including SUSE
Linux... I guess POV-Ray should even install "out of the box", with no
need whatsoever to adapt the system-specific config files :-)
Date: 3 Oct 2009 15:25:56
Message: <4ac7a544@news.povray.org>
  I wonder if POV-Ray 3.7 has ever been tested with that many rendering
threads, and whether it would cope.
Date: 3 Oct 2009 18:38:45
Message: <4ac7d275$1@news.povray.org>
I presume the machine is essentially a cluster, so not much luck there:
You'll have a huge number of dual- or quad-core machines to crunch away
at a single frame of an animation each, but that'll be about it.
Unfortunately, although 3.7 is SMP-ready, it isn't "network-ready" yet.
Date: 4 Oct 2009 11:18:12
Message: <4ac8bcb3@news.povray.org>
  I think there's some support in linux to make a cluster look like a
bunch of local processors.
Date: 4 Oct 2009 11:19:21
Message: <4ac8bcf9$1@news.povray.org>
If there isn't, Debian have a hacked PVM version of POV-Ray...
Date: 5 Oct 2009 10:44:47
Message: <4aca065f$1@news.povray.org>
Uh.. yeah, POV-Ray was designed to be portable.
~Mike
Date: 5 Oct 2009 10:48:09
Message: <4aca0729@news.povray.org>
Well, since apparently this puppy is running Linux (which POV-Ray
already supports) and an AMD64 CPU (which POV-Ray also supports), sure,
it's pretty trivial. But if you wanted to do this on some OS where
libPNG isn't available (for example)...
Date: 5 Oct 2009 12:09:02
Message: <4aca1a1e@news.povray.org>
  POV-Ray doesn't support any processors. Compilers do.
> sure,
  POV-Ray can be compiled without pnglib.
Date: 5 Oct 2009 14:28:54
Message: <4aca3ae6$1@news.povray.org>
Oh, right. I didn't know that.
[Or rather, I didn't know it's easy to enable or disable - which I
presume is what you meant.]
Date: 5 Oct 2009 19:54:38
Message: <4aca873e@news.povray.org>
If there really is, then be prepared for some serious performance
degradation, at least with some features (most notably radiosity,
probably also photons, and a few "smaller" ones like crackle patterns)
which rely on shared memory.
