POV-Ray : Newsgroups : povray.off-topic : Someone with JDK installed Server Time
31 Jul 2026 05:42:49 EDT (-0400)
  Someone with JDK installed (Message 1 to 5 of 5)
Subject: Someone with JDK installed
Date: 27 Sep 2009 06:19:56
Message: <4abf3c4c$1@news.povray.org>
Would you mind compiling this for me?
http://github.com/Atmospherian/Haxer
In case you're curious it's a Adobe Flash to HaXe translator. Translates
source code from one application's format to the other.
ty
-Mike
Subject: Re: Someone with JDK installed
Date: 27 Sep 2009 21:58:26
Message: <4ac01842$1@news.povray.org>
> ty
> -Mike
Or, could someone provide an example command line to compile the program?
This is the one I'm using:
"C:\Program Files\Java\jdk1.6.0_16\bin\javac.exe"
"J:\ProgsWin\Haxer\src\net\interaxia\haxer\Haxer.java"
It results in the following errors:
J:\ProgsWin\Haxer>"C:\Program Files\Java\jdk1.6.0_16\bin\javac.exe"
"J:\ProgsWin
J:\ProgsWin\Haxer\src\net\interaxia\haxer\Haxer.java:3: package
net.interaxia.ha
xer.api does not exist
import net.interaxia.haxer.api.AllTypes;
J:\ProgsWin\Haxer\src\net\interaxia\haxer\Haxer.java:4: package
net.interaxia.ha
import net.interaxia.haxer.api.ObjectType;
J:\ProgsWin\Haxer\src\net\interaxia\haxer\Haxer.java:5: package
net.interaxia.ha
xer.scanner does not exist
import net.interaxia.haxer.scanner.Inspector;
J:\ProgsWin\Haxer\src\net\interaxia\haxer\Haxer.java:6: package
net.interaxia.ha
import net.interaxia.haxer.scanner.Scanner;
J:\ProgsWin\Haxer\src\net\interaxia\haxer\Haxer.java:7: package
net.interaxia.ha
xer.translator does not exist
import net.interaxia.haxer.translator.Translator;
J:\ProgsWin\Haxer\src\net\interaxia\haxer\Haxer.java:48: cannot find symbol
symbol  : class HaxeFile
     private static void saveOutputFile(String rootFolder, HaxeFile file) {
J:\ProgsWin\Haxer\src\net\interaxia\haxer\Haxer.java:27: cannot find symbol
symbol  : class Scanner
         Scanner scanner = new Scanner();
J:\ProgsWin\Haxer\src\net\interaxia\haxer\Haxer.java:30: cannot find symbol
symbol  : variable AllTypes
         AllTypes.getInstance();
J:\ProgsWin\Haxer\src\net\interaxia\haxer\Haxer.java:31: cannot find symbol
         List<HaxeFile> haxeFiles = new ArrayList<HaxeFile>();
J:\ProgsWin\Haxer\src\net\interaxia\haxer\Haxer.java:33: cannot find symbol
symbol  : class Inspector
             Inspector i = new Inspector(f);
J:\ProgsWin\Haxer\src\net\interaxia\haxer\Haxer.java:38: cannot find symbol
         for (HaxeFile hf : haxeFiles) {
J:\ProgsWin\Haxer\src\net\interaxia\haxer\Haxer.java:39: cannot find symbol
symbol  : class Translator
             Translator t = new Translator(hf);
J:\ProgsWin\Haxer\src\net\interaxia\haxer\Haxer.java:56: cannot find symbol
symbol  : class ObjectType
         ObjectType shortName =
AllTypes.getInstance().getTypeByShortName(fileNam
e);
e);
18 errors
Date: 28 Sep 2009 00:04:31
Message: <op.u0x79wmu7bxctx@bigfrog.bredbandsbolaget.se>
> "C:\Program Files\Java\jdk1.6.0_16\bin\javac.exe" ^
You need to compile all the source files, either all at once or in the
correct order (as determined by dependencies).
Something like this:
   cd /d "J:\ProgsWin\Haxer\src\net\interaxia\haxer"
   *.java ^
   api\*.java ^
   scanner\*.java ^
   translator\*.java
FE
Date: 28 Sep 2009 00:45:15
Message: <4ac03f5b$1@news.povray.org>
OK, I got it to compile. But, when I try to execute it I get this error:
J:\ProgsWin\Haxer>cd "src"
J:\ProgsWin\Haxer\src>"C:\Program Files\Java\jdk1.6.0_16\bin\java.exe"
java -cla
sspath . net.interaxia.haxer.Haxer
Exception in thread "main" java.lang.NoClassDefFoundError: java
Caused by: java.lang.ClassNotFoundException: java
         at java.net.URLClassLoader$1.run(URLClassLoader.java:200)
         at java.security.AccessController.doPrivileged(Native Method)
         at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
         at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
         at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
         at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
         at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:320)
Could not find the main class: java.  Program will exit.
J:\ProgsWin\Haxer\src>pause
Press any key to continue . . .
Any ideas?
-Mike
Date: 28 Sep 2009 01:04:35
Message: <op.u0ya1zhq7bxctx@bigfrog.bredbandsbolaget.se>
> J:\ProgsWin\Haxer\src>"C:\Program Files\Java\jdk1.6.0_16\bin\java.exe" ^
> java -classpath . net.interaxia.haxer.Haxer
Just skip the "java" part of the argument list.
   java.exe -classpath . net.interaxia.haxer.Haxer
FE
