POV-Ray : Newsgroups : povray.off-topic : pagefile.sys Server Time
18 Oct 2026 11:47:23 EDT (-0400)
  pagefile.sys (Message 1 to 27 of 27)
Subject: pagefile.sys
Date: 24 Sep 2009 22:55:58
Message: <4abc313e$1@news.povray.org>
I moved my page file to a second drive letter, but the original one on
my C drive is still there. It hasn't been modified or accessed since I
made the change, so I know it's not in use. How do I get rid of it? When
I try to run attrib on it I get an access error.
-Mike
Subject: Re: pagefile.sys
Date: 24 Sep 2009 23:06:22
Message: <op.u0slkws97bxctx@bigfrog.bredbandsbolaget.se>
Did you really move it, or did you just create another one? Windows'
pagefile options are per-drive; setting up a page file on a second drive
does not remove any that already exist. If you want to get rid of
C:\pagefile.sys, you must explicitly disable the page file on drive C.
Keep in mind though that some features -- like BSOD crash dumps -- require
at least a small page file on the system drive in order to work.
FE
Date: 25 Sep 2009 01:50:13
Message: <4abc5a15$1@news.povray.org>
> require at least a small page file on the system drive in order to work.
I set it to "No paging file" for that drive.
-Mike
Date: 25 Sep 2009 08:16:39
Message: <op.u0ta11xu7bxctx@bigfrog.bredbandsbolaget.se>
>> drive does not remove any that already exist. If you want to get rid of
What OS? If it indeed shows as "None" for drive C in the settings dialog,
you should be able to do "attrib -s -h c:\pagefile.sys", followed by "del
c:\pagefile.sys" (or just hit 'Del' in Explorer), at least in XP. In
Vista/Win7 you might have to take ownership of the file first.
You must of course also reboot after changing page file settings.
Is the new page file located on a drive that requires a special driver? If
so, Windows might decide to use a page file on C anyway because the paging
system is initialised very early in the boot process.
FE
Date: 25 Sep 2009 13:51:15
Message: <4abd0313$1@news.povray.org>
>>> of C:\pagefile.sys, you must explicitly disable the page file on
>>> drive C. Keep in mind though that some features -- like BSOD crash
>>> dumps -- require at least a small page file on the system drive in
>>> order to work.
> dialog, you should be able to do "attrib -s -h c:\pagefile.sys",
> followed by "del c:\pagefile.sys" (or just hit 'Del' in Explorer), at
> least in XP. In Vista/Win7 you might have to take ownership of the file
> first.
> If so, Windows might decide to use a page file on C anyway because the
> paging system is initialised very early in the boot process.
On a semi-side note. Had to defrag mine, which Windows doesn't normally
allow. Page Defrag utility from sysinternals works nice (though I need
to run it again, now that I succeeded in defragging all the files I
couldn't, because the page file was in 33,000 pieces... O.o It runs
before anything but the basics starts up, just after the initial loading
screen, so pagefile.sys isn't yet in use.
You would think, even with the slight overhead, trying to keep this
thing in one chunk, as much as possible, would have been useful... Sigh!
void main () {
   If Schrödingers_cat is alive or version > 98 {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 25 Sep 2009 14:24:24
Message: <4abd0ad8@news.povray.org>
What makes you think they don't?   If you fill up your disk, you're going to
get fragmentation.  Recreate your pagefile, and tell it to use a fixed size,
and you're done.
Date: 26 Sep 2009 18:41:26
Message: <4abe9896$1@news.povray.org>
> going to get fragmentation.  Recreate your pagefile, and tell it to use
> a fixed size, and you're done.
Uh. Doing that requires shutting up off, then rebooting, then defraging
the drive, then turning it on again.. Well, lets just say that, at least
one person trying this had it render the OS unbootable. I would rather
let the damn thing just handle it itself, which should include imho,
occationally using some idle time to restructure the file, so its
contiguous (like duh!). Near as I can tell, it isn't doing that at all
as part of normal operations.
Main reason I started into my own cleanup was that I was running Halo 2,
with the XP patching, Firefox open (I leave it that way) and 1-2 other
things, folding @home in the background, and the virus scan came up. It
ran out of virtual memory and started going *boom* on me. lol
Got to be about the one and only reason I am looking at getting 7, so it
doesn't have the memory limits XP did. Oh, that and the fact that XP's
boot.sys got mangled at some point (who knows by what), and I am not
sure I know how to reconstruct it, so I could add the dumb flag needed
to make it use more memory... It amazes me some times how much can break
on the OS and still be usable, kind of like owning a car, but where the
tail pipe hasn't fallen off yet, or an engine mount snapped. lol I hear,
kind of like with Windows, some people never had the cars, which got
recalled for their tendency to burst into flames, ever actually burst
into flames too... ;)
void main () {
   else
Date: 26 Sep 2009 20:03:27
Message: <4abeabcf@news.povray.org>
If you don't have enough space to put a pagefile on your machine that's
contiguous, then you're going to get fragmented files and all. Yep, yep, yep!
It defrags everything else that way. Just not the pagefile. Because, you
know the page file is usually open, and it's pretty easy to defrag it at
boot time if you want.
Of course, if you don't have enough free space to make a block of disk big
enough to hold a page file, then no, it's not going to defrag.
The only XP memory limits I know of was running into the 4G boundary. And
apparently that's a licensing thing - seems XP x86 is happy to use however
much memory you put in there, except that Microsoft tells it not to.
Date: 27 Sep 2009 18:31:33
Message: <4abfe7c5$1@news.povray.org>
>> defraging the drive, then turning it on again..
> yep!
Get enough now. Already defragged it once. Went from 33,000+ fragments
to 1,000, but.. Still be be nice for more.
Still, point is, if you have memory free, open or not, I see no reason
why, if you have free real memory, you couldn't page in some of the file
that isn't "in use", page it back out someplace saner, etc. and defrag
it that way. Ironically, its one thing I almost miss from the old
Win3.11 days, where you could use Norton's defragger to defrag
everything "including" the page file, and shift files you use a lot
closer to the start, and unscatter directories, *and* consolidate free
space. I get that Windows defrag now does most of those, but it does
them damned inefficiently, and no matter how many times you "force" it
to consolidate files, it will flat out *refuse* to consolidate the free
space, even when there is no sane reason to leave a handful of files
scattered willy nilly over the remaining disk space.
And, that is the problem. If you need to defrag something like the page
file, during boot, how do you do that, if it won't move the stupid files
that are in the way? :(
Actually reminds me of the ice truck issues at work. Big days for
shoppers we bring in a truck. The normal method of handling this seems
to have been to spend 3-4 hours trying to get early customers to move
their damn cars, so we could park the thing. This year we spent 2 hours,
at night, waiting for people to get a hint and stop parking where we
where trying to rope off, so that we just had to move the ropes the next
day. This, obviously, worked a whole lot better. lol
> And apparently that's a licensing thing - seems XP x86 is happy to use
> however much memory you put in there, except that Microsoft tells it not
> to.
Yeah. I know. But, the hack requires changing the boot.sys file. They
managed to make the OS smart enough to boot anyway, if its
damaged/missing (mine is missing for some reason), but didn't include
any way to rebuild it, if you lost/mangled it. So.. No file, no clue how
to write it, and therefor, no means to override the setting.
void main () {
   else
Date: 27 Sep 2009 19:51:43
Message: <4abffa8f@news.povray.org>
You just need to have enough space to put it there. :-)
> it that way.
Of course you could. As I said, the "sane" reason is that not enough people
want this to justify the difficulty of implementing it. And yes, it's
difficult. Probably much so more than you think.
> space.
Yeah, when you can shut down all other processes and do it with the machine
offline, it's a lot easier.
There is a sane reason, actually. You just don't know what that reason is.
:-)  One possibility is that they're protected because they're branches of
files carrying around the encryption key information. Another possibility is
that they're locked open for writing.
Copy those files to a different disk, delete them, defrag, copy them back.
>> not to.
Different hack, I suspect.
> They
LMGTFY.  http://mirror.href.com/thestarman/asm/mbr/bootini.htm
Date: 27 Sep 2009 21:10:01
Message: <4ac00ce9$1@news.povray.org>
I can show you how to get rid of most or all of those, btw.
It's probably either:
1) Encrypted file system data forks,
2) volume shadow copies (i.e., system restore files),
3) the USN journal
none of which can be moved by the normal defrag mechanism.
Date: 27 Sep 2009 21:55:19
Message: <4ac01787$1@news.povray.org>
You can use the defrag utility if you restart using Safe Mode + Command
Prompt. This might allow you to defrag the page file since lots of stuff
is being bypassed.
-Mike
Date: 28 Sep 2009 09:01:27
Message: <4ac0b3a7$1@news.povray.org>
> space.
Remember how, /theoretically/, you were supposed to actually /pay/ for
Norton Utilities back in those days?
Well, here may be news for you: There's still defraggers around for
sale, and which are said to perform better than the defragger MS is
giving away for free with their OS. ;-)
Question is, what is the most efficient distribution of empty space
after a defrag? One huge consecutive chunk?
Actually, that's rarely the case. This is only good for drives
containing a huge collection of immutable files, like some archive. As
soon as you expect the contents of the files to change, it will actuall
be more efficient to have some free space after each file, to allow for
it to grow without fragmenting /again/.
So the strategy employed by Windows' free defragger is probably not too
bad - and don't forget it's a tool you get with the OS for free. (Not
developed by MS themselves, btw.)
Date: 28 Sep 2009 10:07:19
Message: <4ac0c317$1@news.povray.org>
... furthermore, Windows' defrag apparently /does/ move files, but it
tries to arrange them in different sections, probably related to how
they are actually used/modified, or how large they are. Something along
those lines.
Date: 28 Sep 2009 11:02:54
Message: <4ac0d01e@news.povray.org>
Interestingly enough, Windows actually does keep track of which files change
and which don't. Plus, it's probably pretty easy to guess in most cases. EXE
and DLL files? Pack em tight. Mailbox files? You probably want to leave some
space.
> (Not developed by MS themselves, btw.)
That may have been true a long time ago, but I don't expect it's true any more.
Date: 28 Sep 2009 12:09:54
Message: <4ac0dfd2$1@news.povray.org>
> any more.
Vice versa actually: They used to develop their own defrag, but then (I
think starting with XP) switched over to some lightweight edition of a
third-party tool. Raised a lot of fuss over here in Germany due to that
company's involvement with Scientology.
Well, maybe they acquired the developer of that tool by now, don't know...
Date: 28 Sep 2009 13:24:05
Message: <4ac0f135@news.povray.org>
>> any more.
No, they used Executive Software's DiskKeeper stuff. MS developed all the
APIs and such. Executive Software just wrote the user interface part (and of
course provided info on how the API should be designed). I'm pretty sure
nobody outside MS wrote software that frobs the NTFS file system to
rearrange blocks.  (Granted, MS might have hired an outside company to
develop that, but it wasn't sold independently, so I don't count that.)
As for the defraggers on pre-NTFS file systems, I wouldn't really guess, but
Executive Software made the UI for the NT defragger.
Date: 28 Sep 2009 22:43:12
Message: <4ac17440@news.povray.org>
Darren New schrieb:
>>> any more.
> the APIs and such. Executive Software just wrote the user interface part
> (and of course provided info on how the API should be designed). I'm
> pretty sure nobody outside MS wrote software that frobs the NTFS file
> system to rearrange blocks.
"Diskeeper is a file system defragmenter originally for the VAX series
of minicomputers and later released for Microsoft Windows. It is the
flagship product of Diskeeper Corporation (formerly Executive Software).
The defragmenter program included with the Windows 2000, 2003, and XP
operating systems is based on a basic version of a previous Diskeeper
version."
(Wikipedia)
While the low-level code to perform the actual /swapping/ of individual
blocks of NTFS may well be MS stuff, /everything/ on top - including
such essential decisions as where to put which block of a file - is up
to individual software tools, and if MS did write anything of that which
is included in Windows XP, then apparently it's only the UI.
According to Wikipedia, the defragmenter that shipped with Windows 9x
was no MS stuff either, but licensed from Symantec.
Date: 28 Sep 2009 22:48:12
Message: <4ac1756c$1@news.povray.org>
Yes.  But that's really pretty trivial stuff compared to actually writing
the code in the file system that makes it work.
Executive Software wrote the code to do the swapping on the VAX, too. I.e.,
they wrote *all* the code, not just the code to invoke the API to defragment
a file.
If MS wrote the UI for XP, then everything is written by MS, since the UI
for XP just makes the decisions about where to put the blocks of the files
and swaps them. I.e., if MS wrote the UI for XP, and the algorithm for
picking which files to move where, and the API for swapping the blocks, then
they wrote everything, right?
I'm not sure I'm following. I'm just talking about it having two parts - the
UI, and the file system operations.
Yes.
Date: 29 Sep 2009 05:24:56
Message: <4ac1d268$1@news.povray.org>
> the UI, and the file system operations.
No, it's actually three parts:
(1) The UI to pick which drive to defragment, to visualize
defragmentation status, and to show a report afterwards
(2) The decision-making where to actually put exactly which file (the
"business logic" so to speak)
(3) The low-level code to swap one particular block with another in a
safe way
I'm not too familiar with NTFS, but I expect (3) to be not too
complicated, even if it may not be as simple as with FAT partitions,
while (2) is the one that actually determines the quality of the
defragmentation result: For instance, whether files in the same
directory are kept close together, or whether they are grouped according
to other criteria; how much free space is inserted after each file; and
plenty more stuff like that.
Date: 29 Sep 2009 12:33:57
Message: <4ac236f5$1@news.povray.org>
OK. I found this too trivial to talk about, given how simple the UI was.
Yeah. Really, it isn't that hard. If you're to the point where you have
movable files that you don't just move, your disk is too full anyway. The
only hard part is guessing the future of the files and how they'll be used
after you defrag them, and tracking all *that* is the responsibility of
other components of the OS.
> safe way
> complicated,
Until you take into account that other processes are reading and writing the
blocks at the same time, and you have to recover from a crash at any time
without actually running a chkdsk, and that some blocks are buffered in
memory, and some blocks are buffered on the readyboost memory, and that you
have volume shadow copies, and that you have compressed files, and that
defragging a file can actually change its size... But sure, if you ignore
all the hard parts, it's pretty easy.
Go read the papers Executive Software wrote about it. It is *far* from
trivial, and its even more complicated in Vista.
Sure. Plus, of course, MS added all the stuff that keeps track of how often
you use the file, what order the blocks are used in, and so on. None of that
is part of the defrag system at all.
For example, Vista tracks what blocks of which files are demand-paged in as
you boot and log in. (That's the "readyboot" subsystem.)  Their defragger
then doesn't defrag the file in block order, but rather into the order you
tend to demand-page it in, if I understand correctly.
You can make it arbitrarily complicated. Most UIs don't. DiskKeeper only
defragged stuff that it guessed would be faster to defrag than to just read
fragmented.
Date: 30 Sep 2009 16:50:57
Message: <4ac3c4b1$1@news.povray.org>
>> it will flat out *refuse* to consolidate the free space, even when
>> there is no sane reason to leave a handful of files scattered willy
> is. :-)  One possibility is that they're protected because they're
> branches of files carrying around the encryption key information.
> Another possibility is that they're locked open for writing.
No there isn't. Often, re-running the defrag will result in them moving
them anyway. The problem is simply that, unlike several third party
defraggers, the one in Windows **doesn't** consolidate free space, only
files. Once the files themselves are no longer fragmented, or there is
no available space, with the current configuration on the drive, to move
one of them, it stops. This happens **even if** it could have
consolidated some of the free space and thus "gained" the space needed
to move the file it refused to defragment. I know, I have played with
the thing enough, and re-run in multiple times, so I am well aware what
it will and won't do. And it simply won't move some files (even if it
clearly labels them, in its display, as "movable", if it doesn't need to
do so, since it doesn't treat "free space" as fragmented, and in need of
correction.
The stupid thing about this is.. assuming the files are mostly stable,
and won't change, like the OS partition, it actually makes it "more"
likely that any new files installed will "become" fragmented, the moment
you write them, since all the free space gaps are still there.
>> page file, during boot, how do you do that, if it won't move the
>> stupid files that are in the way? :(
Ah yes.. Because it "tells you" which files they are, so you can do
that, and they will never be something critical, which you can't move
someplace else first. And, as I pointed out above, **this doesn't fix
anything*, since it won't consolidate free space.
>>> use however much memory you put in there, except that Microsoft tells
>>> it not to.
Don't think so... Though, maybe there is some system file you can
replace, or something, that does it automatically. All I know is that
one version involves adding a flag to the startup for the OS, and that
is, I think, in the boot.sys file.
>> They managed to make the OS smart enough to boot anyway, if its
>> how to write it, and therefor, no means to override the setting.
Uh, yeah. And I am assuming my system is vanilla enough I could do that
manually, but I would still prefer something that could look at my
existing install and just recreate the file, so I know it is correct. I
have no clue what any of the partition, etc. stuff is in there, and I
don't want to spend an hour figuring it out. ;)
void main () {
   else
Date: 30 Sep 2009 16:52:20
Message: <4ac3c504$1@news.povray.org>
> 3) the USN journal
As I said, The files its not moving are marked as "movable" Its just not
defragging the free space, beyond a very minimalistic amount needed for
consolidating the files it is defragging, so you get gaps anyway.
void main () {
   else
Date: 30 Sep 2009 16:56:43
Message: <4ac3c60b$1@news.povray.org>
Darren New wrote:
>> actuall be more efficient to have some free space after each file, to
>> allow for it to grow without fragmenting /again/.
> change and which don't. Plus, it's probably pretty easy to guess in most
> cases. EXE and DLL files? Pack em tight. Mailbox files? You probably
> want to leave some space.
Ok, point taken, but.. 25% of the disk, so that the one it refused to
move is smack in the middle of the part I need to use? lol Rather have
it move all the ones that are likely to change to the end of the
contiguous area, so that the likely amount of fragmentations is less,
while still leaving the *end* of the disk free of random files. But,
maybe I am just overly picky... :p
void main () {
   else
Date: 30 Sep 2009 16:58:38
Message: <4ac3c67e$1@news.povray.org>
>> normally allow. Page Defrag utility from sysinternals works nice
>> (though I need to run it again, now that I succeeded in defragging all
>> the files I couldn't, because the page file was in 33,000 pieces...
>> O.o It runs before anything but the basics starts up, just after the
>> initial loading screen, so pagefile.sys isn't yet in use.
> is being bypassed.
> -Mike
Hmm. If it was that simple, I doubt they would have developed the tool,
but maybe. Though, in the case of this tool, its designed to *only*
defrag the one file, so its faster, and as a boot process, you might
probably want that. ;)
void main () {
   else
Date: 30 Sep 2009 18:50:08
Message: <4ac3e0a0$1@news.povray.org>
> them anyway.
I don't know if you're talking XP or Vista, but there are things in Vista
that are locked open until you modify enough stuff on disk that it rolls out
of the cache and gets closed. System snapshots spring to mind.
> files.
Bull. You can watch it happen yourself. It shows up in the status line of
the GUI on XP, for example.
This I'll believe. But that just means it doesn't move things reactively.
That doesn't mean it doesn't move things proactively.
> correction.
No, it doesn't defrag all free space. But it does defrag some free space.
There are calculations done as to whether it's worthwhile to move the file
that's already defragmented.
> and won't change,
Yep. Bad assumption, of course. But as I said earlier, the problem is with
guessing the future.
So write something that tells you what they are, and that moves it for you.
You have the APIs. :-)
Seriously, there should be a piece of code that says "find the files with a
gap more than 3x the size of the file in front and move it. :)
>>>> boundary. And apparently that's a licensing thing - seems XP x86 is
>>>> happy to use however much memory you put in there, except that
> Don't think so...
Well, considering the OP had to hack the registry and turn off a couple of
start-up tasks, I'm pretty sure.  You're talking about the 2G vs 3G limit.
I'm talking about making 32-bit XP use 8G of RAM.
What partition of which drive is NTLDR on?  Plug in those numbers, and you
win, if you're just using plain old SATA or IDE drives with no RAID or any
weird stuff like that.   Heck, get the numbers out of your GRUB
configuration for that matter.
Date: 30 Sep 2009 18:52:02
Message: <4ac3e112$1@news.povray.org>
That's probably a really good idea. Shove all the stuff you know won't
change to the base of the drive, and the other stuff to the middle. Feel
free to implement that algorithm. :-)
Might be fun to come up with a CLI defragger that could tell you where a
file is, where the free space is, or move the file to specific free space.
Then people could play with it with whatever language they want.
