POV-Ray : Newsgroups : povray.off-topic : Some math problems Server Time
21 Mar 2026 21:34:39 EDT (-0400)
  Some math problems (Message 1 to 10 of 32)
Subject: Some math problems
Date: 22 Sep 2009 13:10:56
Message: <4ab90520@news.povray.org>
Some relatively easy math problems for your consideration and enjoyment:
  1) The classical proof that there are infinitely many primes is a proof by
contradiction: Let's assume that there's a largest prime. If we multiply
all the primes up to that largest prime and add 1, we get a number which
is not divisible by any of the primes, and thus the assumption we made is
false: There was a prime which is larger than the one we assumed was the
largest.
  However, consider this: 2*3*5*7*11*13 + 1 = 30031, which is a composite
number.
  Isn't this a contradiction to the proof? It clearly doesn't hold that the
product of the first n primes plus 1 is a prime.
  How to explain this apparent contradiction?
  2) Assume you have an array of 24 integers. Each element of that array
can get a value between 0 and 7. Thus the total amount of different contents
for such as an array is 8^24, which is approximately 4*10^21.
  Now assume that you fill the array with some values and then calculate
all the possible permutations of that array. The amount of permutations
for 24 elements is 24!, which is approximately 6*10^23.
  Now here's the apparent paradox: The total amount of different contents is
about 4*10^21, and naturally all those permutations should be among them as
well. How come the total amount of permutations, 6*10^23, is way larger
than the total amount of possible different array contents?
  3) Assume two people, person A and person B, who want to decide who gets
a price by tossing a coin.
  Person A is a bad loser and a bully, so if he loses he says "I said it's
two out of three". So they play it like that. If A loses again, he says
"I said it's three out of five", and so on, until he wins.
  How many tosses is this game expected to last, in average?
  4) By their nature, factorials tend to accumulate trailing zeroes. For
example, 5! (120) has one trailing zero, 10! (3628800) has two trailing
zeroes, 25! (15511210043330985984000000) has six trailing zeroes, etc.
  Give a (non-recursive) mathematical function which, for an integer n,
gives the number of trailing zeroes in n!.
Subject: Re: Some math problems
Date: 22 Sep 2009 13:46:33
Message: <4ab90d79@news.povray.org>
Oh, I like that. That took a while to figure out.
That one's easy. :-)
Boring. :-)
Cute, and not too difficult, I'm thinking.
Date: 22 Sep 2009 14:07:18
Message: <4ab91256$1@news.povray.org>
> largest.
> number.
The answer lies (as I look at that bit of the wikipedia article on
primes) in that there exists a prime smaller than 30031 by which it's
divisible that's also larger than 13, so 13 isn't the largest prime.
The total amount of permutations doesn't consider duplicate cell values.
  It treats 77 and 77 (with the 7s being swapped) as two different numbers.
Tim Cook
http://empyrean.freesitespace.net
Date: 22 Sep 2009 14:15:00
Message: <4ab91424$1@news.povray.org>
I got 1, but I had to factor 30,031 before I got it.
Permutations and combinations make my eyes go wonky, so I have pass on 2.
I quite know what's meant in 3 by an "average", unless it's the convergence
of a series; not sure if I have that one or not.
As for 4, I'm stumped. :)
Thanks for the fun though... must get back to work now.
news:4ab90520@news.povray.org...
Date: 22 Sep 2009 15:20:20
Message: <4AB92374.4090307@hotmail.com>
> largest.
> number.
The claim is not that the products of primes plus one is a prime, just
that it has a prime divisor that is not one in the product.
8 is less than 24
same answer as: what will the average number if boys be if every pair of
parents continues getting children untill they get a boy. (assuming 50%
chance of a boy, which is not exactly correct, and that every pair that
gets one child can in principle get an infinite number)
just count the number of 5s, 25s, 125s etc
Date: 22 Sep 2009 15:33:41
Message: <4AB92693.7000807@hotmail.com>
BTW I did write a quick and dirty arbitrary precision integer thing to
compute some factorials. I saw the answer before actually having to use
it, but here is 100!:
93326215443944152681699238856266700490715968264381621468592963895217599993229915608941463976156518286253697920827223758251185210916864000000000000000000000000
in case you wanted to know.
Date: 22 Sep 2009 15:58:06
Message: <4ab92c4e@news.povray.org>
> 8 is less than 24
  So? How does that answer the question?
  It isn't. It would be if the game would have been "we throw the coin
until it gives heads". However, that's not how the game goes.
  Firstly, the question didn't ask for an algorithm to calculate the number
of zeros (which is what the "non-recursive" part more or less rules out).
It asked for a closed-form function which tells the number of zeros.
  Secondly, your algorithm is flawed. 10! has two zeros and only one 5 as
a factor.
Date: 22 Sep 2009 16:11:38
Message: <4ab92f7a$1@news.povray.org>
	For a tougher problem, estimate the number of digits in n!
	(Well, easy if you know one certain piece of information...).
I think animal testing is a terrible idea. They get all nervous and give
the wrong answers.
Date: 22 Sep 2009 16:17:26
Message: <4AB930D4.1060607@hotmail.com>
>> 8 is less than 24
that is obvious, I would think.
>> parents continues getting children until they get a boy.
Ok I read that wrong. Can you give an algorithm for 'and so on'?
1 2 3 4 5..
2 3 5 8 13...
or
1 2 3 4 5 ..
2 3 5 7 11...
or
> a factor.
No it has 2 both 10 and 5 have a factor of 5. So if you want your
algorithm:
sum_k floor(x/(5^k)) over all k from 1 till 5^k<=x
Date: 22 Sep 2009 16:44:44
Message: <4ab9373c$1@news.povray.org>
> largest.
> number.
I didn't verify whether 30031 is indeed composite - but one thing's for
sure: It is not a multiple of 2, 3, 5, 7, 11 or 13 (I checked :-)). So
whatever the smallest factor, that's (a) a prime by definition
(otherwise there would obviously be a smaller factor) and (b) it's
larger than 13, our "current largest prime". Q.e.d.
You used the wrong formula for your permutations, as the one you used
presumes that all elements are unique.
I think that very much depends on whether the sequence is
   1 - 3 - 5 - 7 -  9 - ...
or
   1 - 3 - 5 - 9 - 17 - ...
Obviously, trailing zeros are due to the presence of prime factors 2 and
5 in the factorial term. As that term is defined recursively as n! =
(n-1)!*n, n! "inherits" all the prime factors from (n-1)!, additionally
"injecting" its own prime factors.
We can ignore the factor 2 here, as the prime factor 2 is much more
frequent than the factor 5, so for every factor of 5 we have ample
factors of 2 to complement for a factor of 10, and thus a digit.
Any multiple of 5 will therefore "inject" at least one trailing zero.
Any multiple of 5^2 will "inject" an additional trailing zero.
Any multiple of 5^3 will "inject" an additional third trailing zeros.
And so forth.
Thus, the number of trailing zeros can be expressed as:
   floor(n/5) + floor (n/(5^2)) + floor(n/(5^3)) + ...
which is a perfectly valid, non-recursive (albeit infinite) mathematical
formula for the desired thing. (Unfortunately the floor() function
complicates matters, otherwise this would be a nice straightforward
geometric series, and we'd end up with the number of trailing zeros
being equal to n/4, which is apparently not /quite/ right :-P
