There's a well-known illusion where you have a bunch of identical blue
squares, each surrounded by a different background, and it makes the
blue squares look like they're all different shades of blue (even though
they are in fact identical).
However, for some reason, I can't get this particular illusion to work.
Take a look at the attachment. All the blue squares are clearly and
obviously the same shade of blue. WTF?
Download 'colours.png' (3 KB)
Preview of image 'colours.png'
Get rid of the white padding between the squares?
It's possibly too close to the pale blue centres and is giving the brain
a reference colour.
Have fewer larger squares?
Now experiment to find the maximum resolution of this type of illusion
that still tricks the brain?
Best explanation I know of is here:
http://blogs.discovermagazine.com/badastronomy/2009/06/24/the-blue-and-the-green/
Best Regards,
Mike C.
Different shades of grey to me. (I must get a new laptop)
Regards
Heh, that really does work...
Download 'illusion1.png' (3 KB)
Preview of image 'illusion1.png'
Instead of "optical failure", shouldn't this be "optical success"?
"Eureka!" said Archimedes to the skunk.
Or, as one newpaper once posed, "if you set out to fail, and succeed,
what have you done?"
BEHOLD THE LIER PARADOX! GODEL, ESCHER, BACH, AN ETERNAL GOLDEN BRAID!!!
Your squares are simply way too small (on an average computer display at
average viewing distances) for this to work.
It's a brain failure failure. ;-)
Jim
You know, I'm not so sure this is a mental illusion. Viewing the image
horrifically out of focus still shows the same effect, so I'm not sure
the illusion is mental; I think it might literally be optical.
Viewing it out of focus means the colours reaching your retina are actually
differnt (because one is mixed with orange and the other with magenta). See
attached blurred version...
When you're viewing it *in* focus there really are the same colours coming
to your retina that the brain interprets differently depending on what
colours are around it.
Download 'image1.png' (13 KB)
Preview of image 'image1.png'
