If you built a laptop where the entire lid was a solar panel, would it
generate anywhere near enough power to run the laptop?
Would it even generate enough power to recharge the battery in a
reasonable amount of time?
(For reasons unknown, Dell sent me a free gift today: A solar charger.
Who knows, it may even be useful...)
So long as you're happy to use it lying down :-)
I was thinking more that while the lid is shut, it could be soaking up
some rays and recharging the battery.
The fatal flaw in this plan, of couse, is that most normal /homo
sapiens/ would put the laptop back in its bag...
I'm just curios as to whether a solar panel that size can generate
enough current to be useful, that's all.
> I'm just curios as to whether a solar panel that size can generate enough
About 100W / m^2 *roughly* from what I remember. My (big) laptop is 0.1m^2,
so 10W. Enough to charge it slowly (my AC adapter is 90W IIRC).
But you would have to leave it in direct sunlight, don't most laptop specs
say not to leave it in direct sunlight?
> 0.1m^2, so 10W. Enough to charge it slowly (my AC adapter is 90W IIRC).
> specs say not to leave it in direct sunlight?
...so in other words, *no*.
In fact, my old laptop idles at 20W, which is *still* too much. At best,
the solar panel would double the battery life. (If it weren't for the
minor detail that the battery is cluser-****ed anyway...)
Then again, with that old laptop, I start wondering if you could use it
to run a small steam engine connected to a generater. The thing gets hot
enough! :-P
Check it out:
http://blog.orphi.me.uk/about/power
You'll notice that I mainly measured high-power devices anyway, but still...
(I love the way turning my PC on requires 50% more power than playing a
3D-intensive computer game...)
Now then, what do you suppose the total area of my roof is? (Are solar
panels even waterproof?!) With all that area, you could generate...
almost 1 kW. On a sunny day.
So, let's see... *almost* enough power to run half a vacuum cleaner.
I wonder if it would make a difference living in the Sahara?
Better to put solar panels on your roof and then just use the standard
charger.
> Then again, with that old laptop, I start wondering if you could use it to
> enough! :-P
In terms of generating power, bigger is always more efficient, something
per-laptop is likely never to work. Just face it, CPUs currently are just
electrical heaters that happen to do some calculations at the same time.
Of course they are waterproof, they are also lots-of-snow and
big-lumps-of-ice proof. Otherwise people wouldn't put them on their roof.
FWIW there are different ratings depending on how much snow-load you want to
support.
> With all that area, you could generate... almost 1 kW. On a sunny day.
A house down the road from us just got them installed, seems like they had a
grid of 6x5 panels put on their roof, they look about a m^2 each, so 3 kW.
It seems quite popular around here (southern Germany), especially in the
more rural areas.
Sure, but you don't run that very often. Usually the power company will buy
back any excess power you don't use (which I suspect is most of the time
when it's sunny), and of course if you need more you can buy it from them
too. I wouldn't be surprised if you got a negative power bill overall
without too many panels.
The main difference would be due to how many hours of sunlight you got on
average each day, somewhere where it rains the whole time is not likely a
good idea.
> just electrical heaters that happen to do some calculations at the same
> time.
LOL. I'm sure this says something deep about quantum thermodynamics.
Hmm, I wonder... does the human brain heat up significantly when you
think harder?
[Before anybody else points this out, I know it heats up *measurably*.
I'm wondering if it heats up *significantly*...]
OTOH, the brain is inherantly decentralised. It relies on ludicrous
numbers of independent elements operating in a massively parallel
mannar. A laptop works on one specific element peddaling along in serial
as fast as possible.
Say, whatever happened to ANN chips?
> roof. FWIW there are different ratings depending on how much snow-load
> you want to support.
Wait - I thought that was still science fiction? You mean people
somewhere *actually do this* now??
Not in *this* house. ;-) The kettle gets far more use... oh, wait...
> buy back any excess power you don't use (which I suspect is most of the
> time when it's sunny), and of course if you need more you can buy it
> from them too. I wouldn't be surprised if you got a negative power bill
> overall without too many panels.
I rather suspect not. Turn on the kettle, the toaster and the microwave
oven at the same time (not implausible) and you're now sucking down
double-digit kW values. Plus all those things like the freezer which you
never, ever turn off. I doubt you can power an entire building full of
stuff and show a positive net balance for more than an hour or so a day.
Unless you live in the mediterranian, perhaps. (Remember, I live in
Britain, a nation famous for its rain.)
> on average each day, somewhere where it rains the whole time is not
> likely a good idea.
Actually, I guess the *main* difference would be that if you live in the
Sahara, you don't give a **** about electricity, but you urgently need
to find a crapload of water real soon now...
They make a flexible solar panel that
puts out about 50 Watts, open it's 54" x 32",
folded up it's about the size of a text book.
It'll run a laptop pretty easy.
There's no real problem with putting solar
panels on houses in temperate areas, (they're
waterproof), it just means you need more panels,
so it increases the cost. Cost is the big downside
of solar electric panels, it costs more than just
buying the juice in the first place. There's quite
a few places working on making it cheaper with
limited success.
Solar concentrators rely on technology that can
be much cheaper, it's just mirrors. Evacuated
solar tubes can produce scalding hot water, or
you can build simpler solar hot water heaters
DIY at very low cost. The heat can then be
directly used for heat, thus cutting out the
90+ percent loss of turning sunlight to electricity
and then turning electricity to heat. The downside
is maintenance of the anti-freeze.
> Wait - I thought that was still science fiction? You mean people somewhere
The company I work for made 600 MW of solar panels in 2006 (that's the
latest figures I could find), I'm sure it's gone up lots since then. Drive
around any village around here and you're bound to see at least a few houses
or barns covered in them.
Sure, but what's the average power over a longer period of time? You can
easily calculate this from your power bill. IIRC for me it was around 300W,
and yes I have a fridge, freezer, TV, computer etc. Even fridges and
freezers are not actually on continuously.
If you assume I'll get 2 hours a day sunlight on average (this is a big
underestimate, especially as the panels generate a reduced level of power
even when it's cloudy), that means I would need 3600W of solar panels, or an
area roughly 6x6 metres. Doesn't seem that outrageous.
> Sahara, you don't give a **** about electricity, but you urgently need to
Funny, when I was in the Sahara desert, the villages there had a perfectly
fine water supply, also ATM machines, mobile phone coverage, etc.
> Drive around any village around here and you're bound to see at least a
> few houses or barns covered in them.
Mmm, interesting. I've never seen that. (Again, presumably because I
live in England.)
>> the Sahara, you don't give a **** about electricity, but you urgently
>> need to find a crapload of water real soon now...
> perfectly fine water supply, also ATM machines, mobile phone coverage, etc.
Heh. And here I was thinking the only thing in a desert is sand...
At first glance I'd say, "might be".
If you ever took to the outside with a magnifiying glass and a piece of
paper on a summer day, you probably know how much power there is in
sunlight, when concentrated. So as a first rought guesstimate, imagine a
magnifying glass the size of a laptop lid, concentrating solar energy on
something as big as a CPU die.
If that would produce as much heat as a running CPU, then we're at least
talking about the same orders of magnitude.
Upon closer inspection of the problem, this article:
http://home.howstuffworks.com/home-improvement/energy-efficiency/question418.htm
states that with cheapo solar cells, you can harvest no more than about
.045 W per square inch; the article then goes on presuming a figure of
.070 W, probably assuming the use of higher-quality cells.
With a laptop about as large as an A4 sheet of paper - about 100 square
inch - that would give you... 7 Watts. Not /quite/ the order of
magnitude you'd probably need...
Hmm. What's the TDP of a typical CPU? About 150W? Oh dear...
> enough! :-P
Heh, someone called my name?!
Oh boy, I've definitely been doing too much research for that locomotive
model lately, reading stuff like this for instance:
http://www.the-nerds.org/Steam-Car-Day.html
Well, at least by now I know what /some/ of the greebly stuff on a
locomotive is actually good for...
That's nearly enough to power a low-power laptop.
The OLPC (one laptop per child) scheme says their laptops are limited to
use 15 Watts
http://laptop.org/en/laptop/hardware/specs.shtml
So 7 watts is nearly there - you could fit a fold-out panel on the back
of the laptop or do something cunning with mirrors / fresnel lenses to
focus more sun on the panel.
I believe my mini ITX server uses 10 - 20 W depending on load and it's a
1 Ghz machine with a fullsize hard drive but no display and it's not the
most efficient design out there.
On the other hand "my" blade centre with 12 quad core servers in it uses
1700 W which is more than 3x my house's average consumption.
> think harder?
No, because the efficient adaptive cooling system makes sure it doesn't :-P
But yes, the human brain makes for a good deal of energy consumption in
the organism. And consumption does vary, so heat output will, too.
I'm particularly slim by build, despite virtually living on sweet stuff.
An acquaintance suggested that in order to start gaining weight, I
should actually do /more/ bodily exercising (especially endurance
training; I'm admittedly quite lazy in that respect). Why? Because
endurance training is a perfect "no-brainer".
In other words: I'm probably this slim because I think too much...
>> think harder?
One thing a lot of people don't seem to realise is that the brain does
*other stuff* besides thinking...
Yeah, the turn-on is always the hardest part :-P
Definitely so. Seen this a /lot/ in south-eastern Germany, too. And the
house I grew up in (and which my parents sold some months ago) has just
been equipped with solar panels, too (not sure whether the photovoltaic
or water-heating type) - even despite it being on a hillside facing
north, in a particularly rainy valley of a particularly rainy area of
western Germany.
It's really gearing up these days in Germany. I guess the development of
oil prices in the last 1-2 years are taking effect: People started
getting aware in a very practical way that we'll not be able to live on
fossil fuels forever.
It's still not competitive with grid power /yet/, but the government
does a lot here to support such investments, so for the end user it does
pay off. All the more if you figure in future oil price rises, which
people in Germany have started to do. It's now actually considered a
financial investment over here, not just an ecological one.
And I just read that for instance in Hawaii, solar power is now already
cheaper than ordinary grid power.
Sure - but given that evolution added(!) some 200% more brain mass to
Homo Sapiens over his ancestors and relatives, apparently /for/ thinking
(and speaking, which appears to be a closely related task), I guess it
is reasonable to assume that the /majority/ of our brain's capacity is
devoted on it.
For a laptop CPU, you're going for a good deal less.
Also note that's the /maximum/ rating.
The big kicker is installation/material cost. Last I checked, at normal
usage, with both electric and water heating done or supplemented by
solar, it'd take like 20 years to recoup the price...but it *would* be
regained.
Tim Cook
http://empyrean.freesitespace.net
On 21-9-2009 15:16, clipka wrote:
>> a 3D-intensive computer game...)
All those electron that have to get up to speed. When they are moving it
costs less to keep them at speed. Or maybe not.
On 21-9-2009 15:10, Verm wrote:
> clipka wrote:
>> square inch - that would give you... 7 Watts. Not /quite/ the order of
> use 15 Watts
That is what they are limited to. IIRC the goal was about 2W as you can
generate that as a human being of child like proportions. Might be in
this video
http://www.ted.com/talks/nicholas_negroponte_on_one_laptop_per_child_two_years_on.html
There is that story about, I think, Shell that they build a new building
with a giant heater for the winter, just when everything was nearly
finished they brought in a supercomputer that needed a giant cooling
system. A bit more communication would have saved a lot of money.
Nope. I looked into it, even the EeePC line takes enough power to
operate that you would need one of those folding panel things they now
make, which unfolds to about 6'x4', if I remember right. Or, more
specifically, you could probably manage it with like 5'x3', or
something, but they don't make ones that size. One the size of the back
of a laptop would only net you probably 30-40% (guessing) of the power
needed, and that is without peripherals of any kind.
Recharging is a little less of an issue, but its going to take time to
do it, and probably longer than a wall plug.
void main () {
If Schrödingers_cat is alive or version > 98 {
if version = "Vista" {
call slow_by_half();
call DRM_everything();
call functional_code();
else
call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
On the other hand at my site they did think about that, so they
integrated the cooling of the machine rooms with the heating of the rest
of the site....
10 years (or so) later our machines are a lot more efficient and create
less heat so they no longer provide enough to warm the site, so a new
gass powered heating system was needed.
I believe the "new" UK ATC centre on the south coast has the same
problem - but they've not yet installed any more heating. (they switched
from huge CRT displays to beautiful flatscreens that don't get as toasty)
Same happened at University - building had been planned to be full or CRT
heaters, only everything got replaced by LCDs so we all froze. At least
that's what they claimed...
My old laptop runs ~35W on full power, according to ACPI. You just
happen to have a cheap-series powerhog ;).
-Aero
