POV-Ray : Newsgroups : povray.off-topic : How to lift 600-tonnes ships at virtually no energy costs Server Time
2 Nov 2026 06:11:31 EST (-0500)
  How to lift 600-tonnes ships at virtually no energy costs (Message 1 to 21 of 21)
Subject: How to lift 600-tonnes ships at virtually no energy costs
Date: 19 Sep 2009 10:15:46
Message: <4ab4e792@news.povray.org>
I think this is one of the most ingenious canal lock designs to date:
http://en.wikipedia.org/wiki/Falkirk_Wheel
Virtually all you need to do is overcome some friction (note that the
thing does not dip into water at the lower basin, otherwise energy would
be needed to displace water in that position). And there's no risk of
breaking of any cables or hydraulic pipes.
Subject: Re: How to lift 600-tonnes ships at virtually no energy costs
Date: 19 Sep 2009 10:39:26
Message: <f8r9b59m0jhmle3b8elotmtq8hk7fdhkl4@4ax.com>
Aye, it's braw. :)
Regards
Date: 19 Sep 2009 10:40:39
Message: <4ab4ed67@news.povray.org>
  Somewhat similar ingenious engineering tricks were, in fact, quite common
in antiquity. Nowadays we are too used to everything being done with
electricity, fuel-based motors and the likes, so much that it often feels
that most of humanity has forgotten all the clever tricks that people in
the past had in their sleeves.
  For example, a farmer wants to build an irrigation system which takes some
water from a nearby (large) river to his crops. Problem: The crops are 10
meters higher than the surface of the river. How to lift the water to the
crops?
  In today's dumbed-down lazy society most people just use some electrical
or fuel-based water pump to lift the water, which consumes energy,
pollutes the air, is expensive, and whatnot. Few people realize that
this problem was very ingenuously solved *thousands* of years ago. The
solution is completely automatic and self-supporting (ie. doesn't require
any external power source, besides the flowing river itself), and can be
constructed from cheap basic materials. It's very environment-friendly
because it causes zero pollution and doesn't consume any energy.
  Can you figure out this clever solution?
Date: 19 Sep 2009 10:58:32
Message: <s4s9b5phucq9eb19g3ggc3rcmsu4d3r7f3@4ax.com>
Yes, if the answer is what I think it is it was reinvented in the 18th Century.
No spoilers :)
Regards
Date: 19 Sep 2009 11:30:32
Message: <4ab4f918$1@news.povray.org>
A water wheel with either a spiral tube to transfer the water up the
bank or buckets on the side that are dumped at the top.
Date: 19 Sep 2009 13:35:53
Message: <4ab51679$1@news.povray.org>
> crops?
Yup.
If the river flows fast enough, a whater-wheel can be (and often is)
used, with some buckets attached in a smart way, using simple lever
principles to use the running-water's power to lift the water up.
(A modern-times alternative, which can reach quite astonishing lifting
heights even when just a small height difference is available in the
water source, would be a hydraulic ram.)
Date: 19 Sep 2009 13:50:17
Message: <4ab519d9@news.povray.org>
  Good to see that not all ingenuity has died with modern times... :)
  A more complicated invention of antiquity is the so-called south-pointing
chariot. A Chinese invention which is, basically, a chariot with a figure
on top which always points in the same geographical direction regardless of
how the chariot is moved and turned. In other words, the figure acts as a
non-magnetic compass, obviously very useful for travelling long distances.
The invention might be as old as from 2600 BC (although with certainty it's
at least from 200 AD).
  Now that one requires a bit more engineer ingenuity to build.
http://en.wikipedia.org/wiki/South_Pointing_Chariot
Date: 19 Sep 2009 14:10:12
Message: <4ab51e84@news.povray.org>
Not only that: It also requires high precision in the manufacturing at
least for parts of the device. Quite a remarkable feat even for 3rd
century I'd say.
Date: 19 Sep 2009 14:55:46
Message: <4ab52932@news.povray.org>
> Quite a remarkable feat even for 3rd century I'd say.
An even more remarkable feat for being built just days after Noah's flood
subsided! ;-)
Date: 19 Sep 2009 19:09:39
Message: <4ab564b3$1@news.povray.org>
It would have to be very heavy, otherwise it might bounce instead of
roll around corners, and rotation information would then be lost.
Also, I am having trouble visualizing how the device behaves differently
on curved surfaces (i.e. the Earth) as opposed to a flat plane. I wish
the article had some diagrams or animations.
-Mike
Date: 20 Sep 2009 03:44:34
Message: <4ab5dd62@news.povray.org>
  I don't think that the curvature of Earth played a significant role in
the distances involved (probably like a thousand kilometers at most,
relatively close to the equator).
Date: 20 Sep 2009 06:44:36
Message: <4ab60794$1@news.povray.org>
SharkD wrote:
>> south-pointing
>> regardless of
>> distances.
>> it's
> -Mike
I don't think the the curved surface causes the distance that each wheel
travels to vary. It is more the geometry of the problem. Start at a
point on the equator, with the compass pointing south, and go directly
north till you hit the pole. Turn 90 degrees left, and the compass
should point to your left. Walk to the equator. By now, the compass
would be pointing to the east.
Also it is a good example of how a triangle is not limited to 180
degrees outside of Euclidean geometry.
Date: 20 Sep 2009 08:50:43
Message: <4ab62523@news.povray.org>
> flood subsided! ;-)
Yes, that's why I'm rather inclined to believe the 200+some AD assumption.
Date: 20 Sep 2009 09:14:05
Message: <4ab62a9d$1@news.povray.org>
Indeed. I guess they'd have "re-calibrated" the cart daily whenever
possible. Sunrise or sunset would have been a good opportunity. So the
device would have had to work for typical distances of, say, some 100
km: Two days' travel for a human (I don't think a traveling band would
have had the luxury of a cart ride for all at that time), allowing for
an occasional day good enough for traveling but too bad to get a vector
to the morning or evening sun and no chance of asking any locals where
exactly south might be.
And the precision required would have been quite a deal lower than for,
say, finding Baker Street 22a after having made so many U-turns - all
they needed was a rough vector to the next village.
Date: 20 Sep 2009 10:14:00
Message: <4ab638a8$1@news.povray.org>
Quite spectacular looking thingy - but the principle is the same as used
here:
http://de.wikipedia.org/wiki/Schiffshebewerk_Niederfinow
Have a trough (granted: a rather big one) filled with water and a
counterweight equal to the weight of trough and water. Ship moves in,
displaces water in trough equal to ship's own weight, balance achieved.
All needed to lift any weight you want is a big enough trough and some
electrical power to overcome friction.
About the cables: of minor importance - a cable can break but the Falkirk
Wheel's supports may break, too. Cables do not tend to break easily, if well
maintained.
The Wheel is looking much more impressive - but on the other hand it needs a
lot more space.
"clipka" <ano### [at] anonymousorg> schrieb im Newsbeitrag
news:4ab4e792@news.povray.org...
Date: 20 Sep 2009 12:37:24
Message: <4ab65a44$1@news.povray.org>
> here:
It appears a good deal more complicated in the actual implementation:
192 counterweights, double cables for safety, and not to forget the
additiona worm drives normally running "idle", just in case the second
set of cables doesn't hold either. All this is done away by the
exceptionally simple construction of the Wheel.
As an aside, by using another caisson as the counterweight you also get
effectively twice the capacity for the same total weight.
Date: 20 Sep 2009 13:15:15
Message: <4ab66323@news.povray.org>
The article does say something about it working for geodesics, too.
Date: 20 Sep 2009 18:13:42
Message: <4ab6a916@news.povray.org>
Well, you are right - the technical execution is more complex.
But then the wheel only seems to be more impressive than the elevator
because it is better looking, a real beauty ;-)
And the principle is beautiful, too.
Let's compare the technical details:
(Provided the English wikipedia is correct for the Wheel, the German
wikidepia for the elevator)
                       Wheel / Elevator
Trough capacity:   2 x 250 t / 1 x 2500 t
Lift:                   24 m / 36 m
Build date:             2002 / 1914
Basically the Wheel, impressive as it looks, is quite small compared to the
rather unspectacular looking elevator. The elevator can lift 10x more
tonnage. If you take in account that for smaller ships the wheel can bring a
little ship up and another one down, if there actually >are< two ships there
at the same time wanting to go into opposite directions, the elevator can
still shift 5x more tonnage in a single go.
Now, I am no architect, but I guess if you wanted the Falkirk Wheel to shift
10 times more load, across 1.3 times the distance, the wheel would become
very heavy indeed. If the troughs were made to hold 2500 t of water the
supports would have to carry 10x more load. You would have to increase the
Wheel's diameter to 49 m minimum, and this would add to the forces that
would have to be absorbed by the Wheel's wings.
A non-rhetoric question:
Has anybody here any idea how much the Wheel's wings or struts would have to
weigh to replicate the ship elevator's capacity?
news:4ab65a44$1@news.povray.org...
>> here:
> It appears a good deal more complicated in the actual implementation: 192
> counterweights, double cables for safety, and not to forget the additiona
> worm drives normally running "idle", just in case the second set of cables
> doesn't hold either. All this is done away by the exceptionally simple
Date: 21 Sep 2009 00:34:07
Message: <4ab7023f$1@news.povray.org>
Easy enough to gum up, though: just knock it over, and it loses its basis.
Impressive, nonetheless :)
...Chambers
Date: 21 Sep 2009 02:49:28
Message: <4ab721f8$1@news.povray.org>
> device would have had to work for typical distances of, say, some 100 km:
FWIW modern cars today use the same principal.  That's why if you have a car
with GPS (a built-in one, not an aftermarket one) it still knows which way
you are facing when driving around underground (eg parking garage or
tunnel).
Date: 21 Sep 2009 09:44:27
Message: <4ab7833b$1@news.povray.org>
"Houston, we're navigating close to gimbal lock!" :-)
