POV-Ray : Newsgroups : povray.off-topic : Low-level fun Server Time
4 Jul 2026 03:31:22 EDT (-0400)
  Low-level fun (Message 8 to 17 of 47)
<<< Previous 7 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Low-level fun
Date: 20 Sep 2009 10:18:51
Message: <4ab639cb$1@news.povray.org>
>> ...it all seems like a hell of a lot of work just to write a PNG file.
> Why not just go grab libpng? That's how POV-Ray does it.
Isn't that a DLL?
So... I'd *still* need to figure out how DLLs work. ;-)
http://blog.orphi.me.uk/
Date: 20 Sep 2009 10:24:55
Message: <4ab63b37$1@news.povray.org>
>> But of *course*, if you're writing new software, you will only be
>> interested in making it work for Windows 7 (which, I add, isn't even
>> available yet).
> Of course it's available. Not the release version, but the betas.
They have a beta already? Damn, that was fast...
>> Why would you want to target the OS that 99% of your market is still
>> using when you could target some brand new unreleased one and thus
>> force everybody to actually buy it?
> It's not *that* hard to figure out which 2% of the features in the OS
> are new to Windows 7 and which are the same stuff that's been around for
> 5+ years.
Actually, MSDN does a surprisingly good job of documenting this
information, yes.
>> - A DLL is a file containing a set of procedures. You can dynamically
>> load it into memory and call these procedures. (I'm not precisely sure
>> how...)
> Yes. It's a dynamically-linked library. Says it right there in the name.
In other words, it's a shared library. I more or less knew they before. ;-)
> In the beginning of the file is a table of names and pointers. You can
> look up the name to get the pointer, or you can just branch indirectly
> thru the pointer if you know at compile time its offset.
I just meant I haven't found the actual function call for getting access
to the exposed symbols yet.
(According to Wikipedia, seems to be GetProcAddress()...)
>> - RPC is both a network protocol and a system for calling procedures
>> in another running program. This program may or may not be running on
>> the same computer.
> Well, RPC is a generic term, meaning to invoke a procedure in someone
> else's address space. Sun took the term and used it to refer to their
> particular implementation. Ever since, "RPC" has been like "PC" - do you
> mean Personal Computer or an IBM compatible machine running MS-DOS?
Sure. But in this case, I'm talking about Microsoft RPC. As in, that
service that if it stops running, your entire PC shuts down for some
reason... (MS Blaster, anyone?)
>> As best as I can tell, you write a list of procedures that you want to
>> be able to call remotely, and run this through the MIDL compiler. This
>> spits out two blobs of code. You link one into your client, and it
>> enables you to call these procedures just like any other procedure.
> Right. Actually, not quite right. What it spits out is a description of
> the COM interface. Then your compiler takes that description and
> generates the actual code to call it. It's not some secret code. It's a
> well-defined interface that any compiler can implement. Heck, I can call
> it from Tcl.
I'm not quite following.
According to the documentation, you write an MIDL file, and the compiler
generates a header file and two C source code files. You link one into
the client, and one into the server. (I haven't tried it, so I don't
know what's actually *in* these C files, mind you...)
>> However, what the generated code actually does is scoop up the
>> parameters passed, serialise them somehow, and then presumably call
>> some secret undocumented Win32 function to actually send this data
>> somewhere.
> Yes. Because the best way to promote everyone to use your technology is
> to not document how to incorporate it into your code.
> Sheesh.
> Even *wikipedia* documents what the calls are. Why would you think it's
> secret?
Because the MIDL compiler generates this code, so technically you don't
need to know how it actually works. (Also, I couldn't find any functions
anywhere which looked likely.)
>> The data is then sent either via local IPC or network RPC packets to
>> the server side.
> Yes.
>> The code blob linked into the server then unserialises the data and
>> calls the actual procedure inside the server. Then the procedure's
>> return value (if any) goes through the same process in reverse, ending
>> up at the client end just like a normal procedure call.
> Basically, yes.
>> Oh, and there's optional authentication, encryption, asynchronous
>> messaging, message queues (but only in Windows 2000, no other OS), and
>> a bunch of other stuff that didn't make sense.
> Everything from Windows 2000 on, which I believe is where they
> introduced DCOM.  Regular COM, where you're calling a different process
> on the same machine, obviously doesn't need authentication, encryption,
> etc.
I'm reasonably sure NT 4 has DCOM, but possibly with NTLM authentication
only. Windows 2000 is where they added Kerberos, for sure.
>> - COM allows you to create objects, find out what interfaces they
>> support, and call the functions in those interfaces. These objects can
>> be provided by a DLL loaded into your program, an EXE running on the
>> same computer, or (hypothetically) a program running on some remote
>> computer. So it's like a system that can DLL procedure calls or RPC
>> calls - and you don't have to care which.
> Exactly. Plus, it's an active object, i.e., what people call an "Actor".
...you mean the object can be doing other stuff by itself before you
specifically ask it to do something?
> A process running Excel is basically one big COM object, with methods
> like "open a spreadsheet" and "return the value of column B row 27."
> That's how people do these automation tasks.
Heh. I had always assumed that such tasks are simply impossible, because
I've never come across a programming language that can do them. (Well,
except VB. And who the hell understands that?)
>> Again, I haven't actually figured out how to *call* a COM method.
> You can use IDispatch::Invoke for dynamically linked stuff.
> http://msdn.microsoft.com/en-us/library/ms690156(VS.85).aspx
> http://en.wikipedia.org/wiki/IDispatch
> http://msdn.microsoft.com/en-us/library/ms221479.aspx
> I'll grant you, that one was a bit ugly. :-)
But, uh, isn't IDispatch::Invoke *itself* a COM method??
Seriously, I see CoInitialise() and CoUninitialise() to start/stop the
COM library. I see CoGetClassObject() and CoCreateInstanceEx(), but I
can't see a CoCallMethod() or similar anywhere.
> Only because your language doesn't already have COM in it. Once you get
> the basics worked out, then you can say "How do I convert an Excel
> spreadsheet to a pie chart as a GIF file" and do it with the same code.
> Most programming languages have the COM stuff already built for them
> (which is kind of the poing of making it standard, see) so it's just a
> matter of invoking the component.
Well, maybe I need to sit down and spend some time creating "COM
support" for Haskell, and then everything will become trivial. :-P
Date: 20 Sep 2009 10:47:04
Message: <4ab64068$1@news.povray.org>
Well well, it appears there's already a library on Hackage that's
supposed to provide COM support.
Oh, would you look at that? It won't compile. What a *big* surprise...
They really, really need to make it so that packages that call C will
actually compile on Windoze. :-P
Date: 20 Sep 2009 11:23:18
Message: <op.u0kac3fz7bxctx@e6600>
On Sun, 20 Sep 2009 16:24:57 +0200, Orchid XP v8 <voi### [at] devnull> wrote:
>>> available yet).
Actually, the RTM (Release-To-Market) version was finished a couple of
months ago and was made available through MSDN and the like on August 6th.
It is scheduled to hit stores on October 22nd.
FE
Date: 20 Sep 2009 12:45:50
Message: <4ab65c3e$1@news.povray.org>
That's because from C, you call the methods directly via their procedure
addresses - which, as Wikipedia correctly claims, you get via
GetProcAddress().
So you'd need to declare a function pointer to whatever type it should
be according to the COM object's interface definition, assign it a value
via GetProcAddress(), and then invoke that function pointer just like
you would invoke any other function.
Date: 20 Sep 2009 12:48:00
Message: <4ab65cc0$1@news.povray.org>
... especially if that package is intended to provide COM support, which
doesn't make much sense on other platforms anyway :-P
Date: 20 Sep 2009 12:49:53
Message: <4ab65d31@news.povray.org>
> Isn't that a DLL?
Here's good news for you: You can compile libpng as a static lib, too -
POV-Ray actually does that (at least on Windows).
Date: 20 Sep 2009 13:00:45
Message: <4ab65fbd$1@news.povray.org>
No, the beta is already *expired*. :-)
>> name. :-)
Not necessarily shared. Just dynamically linked. It happens that on Windows
(and Linux, as far as I know) that such libraries are indeed shared. But you
can have dynmamic linking without sharing and you can have sharing without
dynamic linking.
Yes.
It shuts down because huge amounts of the OS are built premised on the
availability of COM. It doesn't completely shut down, of course, but
everything *interesting* does.
It generates a TBL file, which your tool then reads to generate whatever
language-specific bindings you want.
A) No it doesn't. It also generates a TBL file.
B) You'd have to know how it works to interface it to any language not
written in C.
Could be, could be.
Yes. As I said, "Excel" is a COM object. It's running in a separate process.
That's why it's not just a DLL.
*Every* language can do it. I've done it from Tcl (as well as writing COM
servers). It's trivial from C# and as trivial as anything is in C, and VB,
and WSH. Like I said, WSH is basically a shell designed to do nothing but
COM calls.
Hmmm.  Well, ship me the two C files from your MIDL, and I'll tell you what
the call it. :-)
That's the general idea, yes.
Date: 20 Sep 2009 13:21:46
Message: <4ab664aa$1@news.povray.org>
Cross-OS DCOM is actually pretty handy.  I did that once to parse Excel
spreadsheets from Linux servers.
Date: 20 Sep 2009 13:40:30
Message: <4ab6690e$1@news.povray.org>
Yeah, MS asserts that COM is usable on other platforms as well. Anybody
know how you actually do this?
