POV-Ray : Newsgroups : povray.off-topic : Linux directory usage question Server Time
2 Nov 2026 07:03:16 EST (-0500)
  Linux directory usage question (Message 1 to 26 of 26)
Subject: Linux directory usage question
Date: 15 Sep 2009 18:44:46
Message: <4ab018de$1@news.povray.org>
To all Linux gurus here: can anybody tell me how many files can be stored in
a Linux directory without performance degradation? Or is there no limit for
directory entries on Linux file systems?
On a web server I have about a thousand product shots in a single directory
(web shop demands it) - how many more before Linux stops to like me? ;-)
Subject: Re: Linux directory usage question
Date: 15 Sep 2009 19:40:47
Message: <4ab025ff$1@news.povray.org>
That depends more on the file system than the kernel. If you're using ext2
or ext3 (I think both have it) there's a flag you can turn on that says to
build extra indexes for directories. Otherwise, I think they're linear.
Date: 15 Sep 2009 20:32:12
Message: <4ab0320c@news.povray.org>
Well, I use ext2. If I understand ext2 correctly, you may have 32k
subdirectories before linux throws the towel. Would it crash? Or be graceful
about it? I surely will not try it out...
However, I cannot find anything about the number of files I can store in a
single directory. I assume that this number is limited by diskspace only.
But it is no good to assume. And since I know no linux guru but am pretty
sure here are quite a lot of them to be found, I asked the question. I would
hate to delve through tons of technical documentation.
I did not know about the indexing flag, though, thank you. Maybe I'll find
more on it.
It's always a surprise what can or cannot be done with or to a filesystem if
you take a closer look. I really hate the ADS on Windows NTFS, for
instance - I find this an abomination. ;-)
"Darren New" <dne### [at] sanrrcom> schrieb im Newsbeitrag
news:4ab025ff$1@news.povray.org...
>> directory (web shop demands it) - how many more before Linux stops to
>> like me? ;-)
Date: 15 Sep 2009 21:24:34
Message: <4ab03e52$1@news.povray.org>
I never heard of that. It's perhaps an artifact of how many links you can
have to one file, since ".." in a subdirectory links back to the parent
directory.
Now you have me curious enough to try it. ;-)
Most likely, since I think ext is in many ways similar to the original v7
directory layout that BSD replaces the API for.
Every time I've been foolish enough to build a system like that, I've put a
layer of subdirectories between, so that file abcdefghijk.txt would be
stored in /stuff/abc/def/ghi/jk.txt or some such.
> more on it.
I found it thru yast, but I'm sure you can turn it on and off with ext2tune
or whatever it's called. Apparently, "-O dir_index" passed to mkfs.ext3 will
do the trick, but I think you can turn it on with an fsck as well.
Whyfor? Every file system nowadays has something like this, including Linux.
And it's pretty useful and a logical extension of how NTFS organizes files
anyway. What don't you like about it?
Date: 16 Sep 2009 03:44:47
Message: <4ab0976f$2@news.povray.org>
Now I have a vague recollection of somebody at uni telling us that ext2
works by storing 4096 file entries in an inode. Once you have more files
than that, the inode stores a pointer to another inode. This inode
contains not file pointers, but inode pointers. So at this level of
indirection, you can have up to 4096 * 4096 files. I vaguely recall that
if you exhaust this, it goes to a third level of indirection. But I
can't remember whether it stops there.
Of course, given the source this information came from, it could be
completely bogus. ;-)
http://blog.orphi.me.uk/
Date: 16 Sep 2009 06:27:22
Message: <4ab0bd8a$1@news.povray.org>
WIYF (http://en.wikipedia.org/wiki/Ext2#File_system_limits):
"If the number of files in a directory exceeds 10000 to 15000 files, the
user will normally be warned that operations can last for a long time
unless directory indexing is enabled. The theoretical limit on the
number of files in a directory is 1.3 × 10^20, although this is not
relevant for practical situations."
You may also want to check out info on the tune2fs utility, which I'd
expect the thing to use if you wanted to enable directory indexing. But
of course you'd need full control over the file system for that, so if
your shop is hosted on a shared server, you may be out of luck.
I think the main problem with those is that other file systems don't
have them. They're a pretty neat idea to tag files with additional
information.
Date: 16 Sep 2009 08:38:48
Message: <4ab0dc58@news.povray.org>
Not precisely.
Even in a virtually empty directory (or file, for that matter), the
actual data is not stored in the inode itself; instead, in the simplest
case an inode will refer to up to a dozen of data blocks, which in turn
store the actual data. Thus, data is limited to e.g. 48 kB on a file
system with 4 kB data blocks.
For the many cases where this should be insufficient, three more data
block pointers are available, which are treated specially:
If required, the first of the three special pointers is used to
reference a data block holding an additional list of pointers to actual
data blocks - i.e. it would reference quite a bunch of additional data
blocks via one level of indirection. Sticking to the 4 kB data block
example, that would give another 1024 data blocks (1036 in total), for a
bit above 16 MB of data in total. (Note that the 12 direct data block
pointers are still used in this case.)
If even more data blocks are required, the second special pointer is
used in a similar way, except that it references even more data blocks
via two levels of indirections, adding another 1024x1024 data blocks for
a bit above 64 GB of data in total. Ultimately, the third special block
pointer would also be used in pretty much the same way, except that it
would use three levels of indirection, for some 2 TB of data in total.
(Note that the data blocks holding the indirection tables are not
inodes; that would be a waste of resources, as inodes (a) store a host
of other information aside from the data block pointers, and (b) are a
rather precious resource in themselves, as only a fixed number of them
exists.)
Obviously, the math you heard at university doesn't really work out, as
it ignores that inodes and indirection blocks have different capacity of
block pointers. Even more, block size may vary from 1kB to 8kB, and
directory entry sizes even vary at run-time depending on filename length.
On a sample directory on my Linux system, I figured that one data block
(4 kB) contains roughly 75 directory entries.
With direct blocks only, this would give me a bit short of 1000 entries.
One level of indirection would give me 1 million entries.
Second level gives me 1 billion.
Third level gives me 1 trillion.
File operations will be bogged down long before however, as the
directory entries are stored within the data blocks as an unordered
linked list, which needs to be traversed for each single file lookup.
Not to mention that with so many files, the directory information alone
would occopy 1/4 of the maximum file system capacity of ext2 (at a block
size of 4 kB), which does not leave much room for actual data per file :-P
Definitely so. Though it's probably not much of an issue in practice :-)
For a block size of 8kB, that would actually be sufficient to reference
more blocks than the file system as a whole can handle :-)
Well, it's not too far off the mark. Unless that person is expected to
train you to become Linux Gurus :-)
Date: 16 Sep 2009 12:05:50
Message: <4ab10cde$1@news.povray.org>
I hate to mention this, but if you put 100,000 files in a directory and then
delete them all, operations on the directory will still be slow. An 'ls' on
the empty directory, or even an rmdir, can take several minutes as the
machine scans thru the directory making sure it is indeed empty before
deleting it.
> have them.
Nonsense. Every modern operating system has them. Macs have had them since
400K floppies were the norm. NTFS has always (as far as I remember) had
them. Newer Linux file systems have them (altho IIRC they're sometimes
organized more as tag/value pairs) - JFS, XFS, Reiser, ZFS, etc. They call
them "Extended attributes" under Linux. Not surprisingly, they're used
similarly to how NTFS uses the streams. (Huh. According to wiki, even FAT
supports them if you use the right kind on NT.)
The biggest problem is that POSIX doesn't support them, so implementors
aren't sure how to build a non-proprietary interface to them that will be
accepted.
http://en.wikipedia.org/wiki/Extended_file_attributes
Date: 16 Sep 2009 12:06:53
Message: <4ab10d1d$1@news.povray.org>
Orchid XP v8 wrote:
>> stored in a Linux directory without performance degradation? Or is
>> there no limit for directory entries on Linux file systems?
Heh. You're confusing free space, used space, and i-nodes (which are
descriptors for files).
It is.
Date: 16 Sep 2009 12:07:16
Message: <4ab10d34@news.povray.org>
No. It was a first course in filesystems. I imagine the guy picked est2
because it was easy to look up the reference material. (We never, ever
used anything that actually had est2 on it...)
While we're on the subject... NTFS has an optimisation where "small"
files are stored in the same block as the directory entry. (Saves
seeking and wasting half a disk block.) Does est2 have any optimisations
for small files?
Date: 16 Sep 2009 12:19:12
Message: <4ab11000@news.povray.org>
Well, he still failed. Or you misunderstood what he was saying. :-)
If you want to know how ext2 works, look up how Unix v7's file system worked
about 30 years ago. It's essentially the same, except in *where* it stores
things physically on the disk. The concepts are all the same.
> for small files?
NTFS's "i-nodes" (called MFT records) are some 1K to 4K in size. Ext2's
inodes are closer to 64 bytes or something. There's no slack space to speak
of in an ext2 i-node.
Anyway, the idea of the data being stored in the same place as the
attributes on NTFS is based on the fact that the data, the permissions, and
the locations where other data is stored, is all the same sort of "stuff".
If your list of permissions gets too big, or your file has lots of
fragments, those too might wind up being stored in the "data" area of the disk.
Date: 16 Sep 2009 12:25:58
Message: <4ab11196@news.povray.org>
http://en.wikipedia.org/wiki/Comparison_of_file_systems#Limits
  I think most file systems (such as ReiserFS) have O(log n) indexing for
files in a directory. So they don't get degraded at all.
Date: 16 Sep 2009 12:31:13
Message: <4ab112d1$1@news.povray.org>
It's an option called "dir_index" on ext2/3 that you can set with tune2fs or
with the appropriate fsck (and of course during mkfs).  Just in case you
ever need to know. :-)
Date: 16 Sep 2009 15:25:55
Message: <4ab13bc3@news.povray.org>
>> est2 because it was easy to look up the reference material.
It was... my God... about ten years ago now. o_O
>> optimisations for small files?
> speak of in an ext2 i-node.
Sure. I was just wondering if ext2 does anything special with small
files, that's all.
Since files can only be allocated an integral number of data blocks,
really tiny files potentially waste an entire block. A directory full of
millions of tiny files could actually eat quite a lot of space. But by
putting that data inside the directory itself, you avoid all that wasted
space, and save on some disk seek time to boot. It seems like a neat trick.
Then again, I've sometimes wondered what would happen if you had some
filesystem that split the disk into several seperate regions with
different block sizes, and allocated files accordingly. (I.e., put the
really huge files in the area with big blocks, and the tiny files in
some area with tiny block sizes.) I rather suspect you'd permanently be
running out of whichever size you happen to need the most tho...
Date: 16 Sep 2009 15:43:28
Message: <4ab13fe0@news.povray.org>
> files, that's all.
Right. It could, for example, pack data from multiple small files into one
sector/block/whatever. But i-nodes are too small for that.
Now you're talking about directories, which are different from i-nodes. And
no, if you put the data in the directory, then you couldn't have multiple
links to a small file.
And interesting thought. I've never seen that done.  Given that disks are
broken into sectors all the same size, and given that the only reasons for
allocating space in units larger than one sector are defragmentation and
efficiency of storing pointers to clusters, there's no real good reason for it.
On the other hand, the Amiga formatted the floppy track every time it wrote
the track, so you could probably actually fit more large files on a disk
than small files, even if every small file was exactly one sector, by making
the sectors physically larger on tracks where they store a big file.
Date: 16 Sep 2009 17:44:57
Message: <4ab15c59@news.povray.org>
>> be running out of whichever size you happen to need the most tho...
> are broken into sectors all the same size, and given that the only
> reasons for allocating space in units larger than one sector are
> defragmentation and efficiency of storing pointers to clusters, there's
You are aware that modern file systems use block sizes /significantly/
larger than the disk sector size?
A disk sector is 512 byte in size virtually everywhere, while file
systems typically use block sizes one order of magnitude larger.
Why? Because it is actually more memory-efficient to /not/ use even the
smallest gaps - because that inflates the required management overhead,
severely reducing the total payload capacity when the files are
sufficiently /large/ on average.
In the end, some compromise is used, based on the statistical
distribution of file sizes. A really /good/ system administrator might
tune the various volumes on his systems to have block sizes that match
the actual use.
> wrote the track, so you could probably actually fit more large files on
> a disk than small files, even if every small file was exactly one
> sector, by making the sectors physically larger on tracks where they
> store a big file.
That won't work for hard disk drives: Even if you /could/ still
low-level-format them (and maybe that's actually still possible with
special tools), it would be a particularly bad idea, given that they
don't even disclose their actual drive geometry anymore these days
(aside from the /official/ total capacity - but even that may be only
half the truth, as I heard say that modern hard drives reserve some
sectors as spare, to deal with sectors that over time begin to "almost
lose data", i.e. become seriously difficult to read - so those can be
avoided and operation can safely continue without any true problems
while the system administrator orders a new drive - provided he has kept
an eye on the SMART status of his drives).
Date: 16 Sep 2009 18:49:03
Message: <4ab16b5f$1@news.povray.org>
>>> the really huge files in the area with big blocks, and the tiny files
>>> in some area with tiny block sizes.) I rather suspect you'd
>>> permanently be running out of whichever size you happen to need the
>>> most tho...
Thats what I said.
I take it you didn't actually read what I wrote?
"The only reasons for allocating space larger than one sector are
defragmentation and efficiency of storing pointers to clusters."
Incidentally, the management overhead isn't that high when the structure you
use to store the location of files isn't O(n) in the number of clusters.
NTFS, for example, stores file extents: an unfragmented file will occupy the
same amount of space to describe its location regardless of file size.
> the actual use.
Yep. Or you just buy a bigger drive. :-)
>> on a disk than small files, even if every small file was exactly one
>> store a big file.
Hence my specification that it was only Amiga floppy drives, yes. Indeed,
even other controllers wouldn't do it efficiently, requiring two rotations
of the disk to first format then write it. The Amiga used the DSP hardware
(if you want to call it that) to do the MFM encoding, so it could
efficiently encode the track every time it wrote it without hardware
dedicated just to that.
Google says this doesn't work nearly as well as you might like it to. :-)
Date: 16 Sep 2009 19:51:04
Message: <4ab179e8$1@news.povray.org>
Well, I did, but I may have perfectly misunderstood what you had written.
Date: 16 Sep 2009 19:52:22
Message: <4ab17a36$1@news.povray.org>
Fair enough. :-)
Subject: ADS on NTFS and reported HDD usage
Date: 18 Sep 2009 07:27:27
Message: <4ab36e9f$1@news.povray.org>
Thank you all for your input, friends, though this comes a bit late. Work
got in the way yesterday, so I could not access the newsgroup. I gained some
valuable insights into ext2.
Since some of you asked what I did not like about ADS on NTFS, here it is:
There is no easy way to access ADS in Windows Explorer. The only way to do
it is use API-calls to access the ADS (to my best knowledge).
Again to my best knowledge (which is somewhat lacking in the field of file
systems, admittedly), you have to scan every single directory using
API-calls to determine which ADS-files are stored on your HDD.
And most importantly, if you store data in ADS, it is nowhere reported in
Windows Explorer. I have heard it said that you could run into serious
problems if you HDD seems to be almost full - but in truth >is< completely
full, because of ADS-files which file-sizes are reported nowhere.
So, if you are in the mood, you could fill a seemingly empty HDD by creating
a few really huge ADS-files on  it.
Anybody wanting to write to this HDD should be ready for an interesting
experience...
I hope linux ext2 does not do the same.
Subject: Re: ADS on NTFS and reported HDD usage
Date: 18 Sep 2009 07:47:03
Message: <4ab37337$1@news.povray.org>
In fact, you don't need any special API calls. There is a filename
syntax for accessing alternate streams. For example:
C:\> echo This is a test > Test.txt
C:\> echo This is another test > Test.txt:alt
Congratulations, you just greated a file with an ADS named "alt".
I will admit, however, that most programs don't know about this
"feature" and will complain if you try to use it. (E.g. both the TYPE
command and Notepad complain that no such file exists.)
> Windows Explorer.
This appears to be true. Even the "size on disk" field doesn't appear to
change when adding and removing ADS, with is rather anomolous.
Still, most ADS are so tiny it probably doesn't matter too much.
Date: 18 Sep 2009 08:34:38
Message: <4ab37e5e$1@news.povray.org>
So what you're basically saying is you don't hate ADS - you hate Windows
Explorer's poor (or actually nonexistent) support for it.
Date: 18 Sep 2009 12:08:16
Message: <4ab3b070$1@news.povray.org>
You can open any stream by name. It's
C:\Users\Darren\Desktop>echo hello >hello.txt
C:\Users\Darren\Desktop>echo goodbye >hello.txt:goodbye.txt
C:\Users\Darren\Desktop>type hello.txt
hello
C:\Users\Darren\Desktop>more < hello.txt:goodbye.txt
goodbye
Some programs try to parse the file name, but < and > don't, so it works fine.
Of course, yes, to get a list of what streams are out there, you need API calls.
Yes. As is true of Linux's extended attributes and Mac's file forks, too.
Yep.
> experience...
If you're malicious and don't care if you get caught after the fact, and the
person you're pulling this trick on doesn't know about ADS, then yes, this
can happen.
Now that you know, go download the free program that scans your disk and
finds your ADS's for you, and you don't have to worry any more. :-)
I believe ext2 puts an upper limit on how much you can store in ADS.
Something like 64K IIRC.
Date: 18 Sep 2009 14:54:00
Message: <4ab3d748$1@news.povray.org>
Yes, I realize you are completely right ;-)
It is not the fault of ADS that Windows makes it hard for us to know what is
actually stored on the hdd.
I always wonder when the first virus/worms make use of this "feature"... do
you know if anti-vir scanners look for ADS-files with malicious payload?
"clipka" <ano### [at] anonymousorg> schrieb im Newsbeitrag
news:4ab37e5e$1@news.povray.org...
>> is:
Date: 18 Sep 2009 14:59:01
Message: <4ab3d875$1@news.povray.org>
Hi, Darren,
thank you, but I know of this and already have programs which can identify
ADS. Nonetheless, it is no fun scanning a couple of 1.5 TB for possibly
malicious files.
As clipka did make me realize: i really don't care for ADS one way or the
other - it might even be useful - but I hate Windows Explorers complete lack
of support for it.
news:4ab3b070$1@news.povray.org...
>> do it is use API-calls to access the ADS (to my best knowledge).
> hello
> goodbye
> fine.
> calls.
>> file systems, admittedly), you have to scan every single directory using
>> creating a few really huge ADS-files on  it.
> Yep.
>> experience...
> the person you're pulling this trick on doesn't know about ADS, then yes,
> this can happen.
Date: 18 Sep 2009 15:17:37
Message: <op.u0gvvnfy7bxctx@e6600>
On Fri, 18 Sep 2009 20:54:16 +0200, TC get-enough-spam-already-2498.com>
They already exist.
> do you know if anti-vir scanners look for ADS-files with malicious
> payload?
At least some of them do.
FE
