POV-Ray : Newsgroups : povray.off-topic : Firefox is strange Server Time
2 Nov 2026 07:01:32 EST (-0500)
  Firefox is strange (Message 1 to 18 of 18)
Subject: Firefox is strange
Date: 15 Sep 2009 07:50:54
Message: <4aaf7f9e$1@news.povray.org>
I don't know when this started happening, but when I run Firefox it
seems to be using an awful lot of CPU power and thrashing the HD quite a
bit. Even when I haven't asked it to do anything. And when I close it,
the window disappears, but it still shows up in Task Manage (and using
quite a bit of CPU power) for about 30 seconds afterwards, and then it
shuts.
Anybody have any idea why?
http://blog.orphi.me.uk/
Subject: Re: Firefox is strange
Date: 15 Sep 2009 11:10:00
Message: <web.4aafad64f3c6882ab92de52d0@news.povray.org>
> shuts.
That sounds suspicious to me.  What version?  Have you tried running it in safe
mode with your add-ons disabled, and seeing if it does the same thing?
-Reactor
Date: 15 Sep 2009 12:15:12
Message: <4aafbd90$1@news.povray.org>
I don't know if this is it, but I've had friends who had firefoxen that work
really poorly because their history and/or cache has hundreds of thousands
of entries in it, and firefox is just trying to update all the changes back out.
Date: 15 Sep 2009 13:56:28
Message: <4aafd54c@news.povray.org>
Happens on two seperate PCs - one of which has AV on it. I *think* it's
Firefox 3.0, but I could be wrong.
Date: 15 Sep 2009 18:33:24
Message: <4ab01634@news.povray.org>
Try to update to the newest version of Firefox 3.5 - had similar problems
with an early 3.5 (forgot which subversion) - and it took ages to start.
This error has been fixed by now - if error it can be called. They develop
primarily for Linux, the problem did lie with some windows libraries, if I
remember correctly.
IF problems persist - to boot from a clean disk an run your favourite
AV-program and/or Spybot Search&Destroy. A virus might be another possible
explanation.
Date: 15 Sep 2009 18:46:54
Message: <4ab0195e$1@news.povray.org>
> work really poorly because their history and/or cache has hundreds of
> thousands of entries in it, and firefox is just trying to update all the
> changes back out.
	It's a factor, but it shouldn't result in too high CPU usage. Most
likely it's an addon that's causing the trouble.
	If he's on Linux, then the Flash plugin is crap. It can continue to eat
up CPU even if you close the tab that had the Flash application.
If you think nobody cares, try missing a couple of payments.
Date: 16 Sep 2009 10:21:36
Message: <4ab0f470$1@news.povray.org>
to eat
Yeah, Flash or Acrobat, I've had both hang up and peg the CPU.
Jim
Date: 16 Sep 2009 11:48:12
Message: <4ab108bc$1@news.povray.org>
http://3laws.wordpress.com/2009/08/03/you-will-fail-at-everything-forever/
Flash is responsible for global warming!
Date: 16 Sep 2009 12:38:35
Message: <4ab1148b$1@news.povray.org>
forever/
LOL
Date: 16 Sep 2009 16:41:13
Message: <4ab14d69@news.povray.org>
> shuts.
One thing I have a huge issue with is Flash. Seems to be a leak in there
some place, when playing movies, where it will *refuse* to close at all,
since it can't unload the fragmented mess created by playing too many of
them. It gets worse if I have a lot of tabs open. In fact, when ever I
get high CPU usage, or slow shut down, or even slow performance in other
applications, its almost *always* the result of playing several Youtube
videos, and the fact that I leave firefox open all the time.
void main () {
   If Schrödingers_cat is alive or version > 98 {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 16 Sep 2009 17:49:38
Message: <4ab15d72@news.povray.org>
Hum... so from all I hear - I guess I'd better ditch my idea of
switching from IE8 to Firefox, huh?
After all, really the only thing that bothers me about IE8 is that for
the 64-bit version (which I've made standard on my Windows XP x64
system) Adobe hasn't released a Flash player yet (can it really be
*that* much of a problem?), so I always need to explicitly launch the
32-bit version.
Date: 17 Sep 2009 11:59:51
Message: <4ab25cf7$1@news.povray.org>
>> there some place, when playing movies, where it will *refuse* to close
>> at all, since it can't unload the fragmented mess created by playing
>> too many of them. It gets worse if I have a lot of tabs open. In fact,
>> when ever I get high CPU usage, or slow shut down, or even slow
>> performance in other applications, its almost *always* the result of
>> playing several Youtube videos, and the fact that I leave firefox open
>> all the time.
My laptop (C2D T5600, Linux x86_64) isn't fast enough to play most
flashvideos in the browser. If I download the video with eg. youtube-dl,
MPlayer plays the video with 1% CPU usage max.
That's just incredible piece of shit.
> 32-bit version.
IIRC the Linux community waited 5 years (2004-2009 (I'm not perfectly
sure if they released it 2009 or 2008)) to get 64-bit Alpha-version of
Flash released. The quality is still incredibly low.
I wouldn't hold my breath...
-Aero
Date: 17 Sep 2009 16:48:25
Message: <4ab2a099$1@news.povray.org>
>> all the time.
> 32-bit version.
That's a bit like saying, "Guess I should forget about switching from
the car which has a tendency to break gas lines and explode, to ones
that needs its air filter changed too much.", isn't it?
IE, and I have to assume 8 is the same, had similar, and often far
worse, issues with some plugins. Its just, when that breaks, it tends to
be cataclysmic, not simply annoying.
void main () {
   else
Date: 17 Sep 2009 18:18:34
Message: <4ab2b5ba$1@news.povray.org>
	I believe that shouldn't be a problem in Windows. It's the Linux flash
plugin that notoriously fails at using your video card.
ASCII and ye shall receive.
Date: 19 Sep 2009 14:47:32
Message: <4ab52744$1@news.povray.org>
They didn't exactly wait.  They were developing their own OSS flash
player, until Adobe noticed.  Around 2007, Adobe promised a native 64
bit flash player, and that kind of killed development.  In 2008, they
again said "real soon now."  Earlier this year, they got the alpha
version released.
Personally, this is one thing I'd like to see an OSS version that I
could use, since I'm trying to get as much software as possible in the
64bit form.
...Chambers
Date: 19 Sep 2009 19:25:29
Message: <4ab56869@news.povray.org>
Well yes, that's true. I do still count is as waiting ie. the original
manufacturer isn't active.
Actually it wasn't even Adobe back then, it was still Macromedia :-).
Linux in general never got Flash 8 - Macromedia decided that it's not
needed. After Flash 6 the Flash 10 has been the first Linux -version
that I haven't found a memory leak from. Version 7 leaked big time at
first (something like half an hour -> 500MB oslt, doing nothing), which
was fixed pretty quickly, but smaller leaks was left behind. Also note
that the fact that I haven't found a memory leak from Flash 10 doesn't
100% surely mean there isn't one - it's possible that it just hasn't
occured to me.
> version released.
Yep. And that alpha version sucked big time, but that's normal for an
alpha version. The newest version now* is much better, but it's still buggy.
*) Newest from Portage - I haven't checked if Portage is lagging behind.
> 64bit form.
I'd like to see an OSS version of some open flash-like technology for
multiple reasons. Especially I'd like to seen open technology (somehow I
don't fully trust on Silverlight, even though MS has given big promises
about it).
> ...Chambers
-Aero
Date: 19 Sep 2009 20:15:57
Message: <4ab5743d$1@news.povray.org>
I think they're calling it HTML5. :-)
Date: 20 Sep 2009 03:37:33
Message: <4ab5dbbd$1@news.povray.org>
Might be true and would sound great. I haven't even checked HTML5 yet.
-Aero
