POV-Ray : Newsgroups : povray.off-topic : Multiple cores Server Time
27 Jun 2026 02:02:06 EDT (-0400)
  Multiple cores (Message 1 to 6 of 6)
Subject: Multiple cores
Date: 2 Sep 2009 10:50:10
Message: <4a9e8622$1@news.povray.org>
I'm not very familiar with Vista, but can you move non-multi-core
supporting applications to different cores so that they run in parallel?
In particular, I've noticed that POV 3.6 only uses 50% of the CPU, so i
though I might run two instances, one per core.
-Mike
Subject: Re: Multiple cores
Date: 2 Sep 2009 10:53:50
Message: <4a9e86fe$1@news.povray.org>
In general, just running two copies of the application will do the job
[assuming it will let you]. You don't actually need to make each copy
run on a specific core. (You CAN, it's just usually not necessary.)
IIRC, POV-Ray might have a "keep single instance" option somewhere which
you'd need to turn off. (Other applications have something similar.)
Date: 2 Sep 2009 11:03:50
Message: <4a9e8956$1@news.povray.org>
Well, it happens automatically, yes. If you want to lock a process to a
particular core/CPU, you can do that too, either programaticly or thru the
GUI. Open the task manager, right-click on the task, and pick "processor
affinity..." and turn off the cores you don't want it to use.
   Understanding the structure of the universe
    via religion is like understanding the
     structure of computers via Tron.
Date: 2 Sep 2009 12:12:47
Message: <4a9e997f$1@news.povray.org>
> the GUI. Open the task manager, right-click on the task, and pick
> "processor affinity..." and turn off the cores you don't want it to use.
Thanks! That will make a big difference.
-Mike
Date: 2 Sep 2009 14:12:47
Message: <4a9eb59f@news.povray.org>
  You think that if you run two different programs at the same time, the
operating system will run both programs with only one core, and leave the
other idle? Why would it do that?
  Why not use POV-Ray 3.7?
Date: 27 Sep 2009 03:22:53
Message: <4abf12cd@news.povray.org>
Le 02/09/2009 20:12, Warp nous fit lire :
because it's still on beta and expiring soon ?
