POV-Ray : Newsgroups : povray.off-topic : It's a fact Server Time
13 Apr 2026 09:44:01 EDT (-0400)
  It's a fact (Message 1 to 10 of 18)
Subject: It's a fact
Date: 26 Aug 2009 06:46:39
Message: <4a95128f@news.povray.org>
Fact: Staring at hex dumps makes your eyes go weird after a while. O_O
Subject: Re: It's a fact
Date: 26 Aug 2009 09:10:30
Message: <4a953446$1@news.povray.org>
I've just been reading
http://www.pkware.com/documents/casestudies/APPNOTE.TXT
which contains the specification of the file format used by PKZIP.
(Otherwise known as a "zip file".)
Jesus, this file format is so old and crufty! >_< Talk about lame...
Anyway, on line 554 we find the following:
       compression method: (2 bytes)
           (see accompanying documentation for algorithm
           descriptions)
           0 - The file is stored (no compression)
           1 - The file is Shrunk
           2 - The file is Reduced with compression factor 1
           3 - The file is Reduced with compression factor 2
           4 - The file is Reduced with compression factor 3
           5 - The file is Reduced with compression factor 4
           6 - The file is Imploded
           7 - Reserved for Tokenizing compression algorithm
           8 - The file is Deflated
           9 - Enhanced Deflating using Deflate64(tm)
          10 - PKWARE Data Compression Library Imploding (old IBM TERSE)
          11 - Reserved by PKWARE
          12 - File is compressed using BZIP2 algorithm
          13 - Reserved by PKWARE
          14 - LZMA (EFS)
          15 - Reserved by PKWARE
          16 - Reserved by PKWARE
          17 - Reserved by PKWARE
          18 - File is compressed using IBM TERSE (new)
          19 - IBM LZ77 z Architecture (PFS)
          97 - WavPack compressed data
          98 - PPMd version I, Rev 1
It's not actually 100% clear whether these codes are decimal or
hexdecimal. But either way, I have a Zip file with nothing seems to be
able to read, and all the files are compressed with method 0x0063.
(That's 99 decimal.)
So I guess that's why nothing can read this Zip file then...
Man, spending a day staring at hex dumps is no fun at all! >_<
Date: 26 Aug 2009 09:25:26
Message: <4a9537c6@news.povray.org>
Did you try the latest version of WinZip?
Date: 26 Aug 2009 09:25:42
Message: <op.uy9t84fm7bxctx@e6600>
GIYF
http://www.winzip.com/aes_info.htm
FE
Date: 26 Aug 2009 09:30:57
Message: <4a953911@news.povray.org>
No - for the obvious reason that this would require money.
Date: 26 Aug 2009 09:31:59
Message: <4a95394f$1@news.povray.org>
> GIYF
Hmm, that also explains the 0x9901 extra record tag I keep seeing.
So it's just AES encrypted? I'm surprised 7zip can't handle that...
Date: 26 Aug 2009 09:36:18
Message: <4a953a52$1@news.povray.org>
Well would you look at that? It seems I'm using the very last version of
7zip to *not* support AES encryption. *facepalm*
I used to check the 7zip website all the time, but after years of
seeming inactivity, I gave up looking for new versions... Apparently
development has started going forward again.
Date: 26 Aug 2009 09:54:13
Message: <4a953e85@news.povray.org>
...but apparently using the latest version of 7zip fixes the problem.
It's because the files are AES-256 encrypted. Go figure.
Date: 26 Aug 2009 10:45:46
Message: <4a954a9a$1@news.povray.org>
No it doesn't:
http://www.winzip.com/downwz.htm
Date: 26 Aug 2009 13:26:32
Message: <4a957048@news.povray.org>
scott escreveu:
You lamer!  I was expecting this to make him post all day long about his
efforts to implement an unzipper in Haskell. :P
oh the fun...
a game sig: http://tinyurl.com/d3rxz9
