POV-Ray : Newsgroups : povray.off-topic : how to scheme a cat up? Server Time
13 Apr 2026 09:44:01 EDT (-0400)
  how to scheme a cat up? (Message 1 to 10 of 22)
Subject: how to scheme a cat up?
Date: 17 Aug 2009 21:27:17
Message: <4a8a0375$1@news.povray.org>
How strong are my imperative ways?
#!/usr/bin/env mzscheme
(module cat scheme/base
(define (cat)
 (let ([ln (read-line)])
     (if (not (eq? ln eof))
         (and (display ln) (newline) (cat))
         (exit) )))
; main
(cat)
%fortune | ./cat
Let me put it this way: today is going to be a learning experience.
How would you scheme up your cat?
Subject: Re: how to scheme a cat up?
Date: 18 Aug 2009 09:48:04
Message: <4a8ab114@news.povray.org>
> (define (cat)
>          (exit) )))
> ; main
> (cat)
> %fortune | ./cat
...wuh??
Date: 18 Aug 2009 10:30:38
Message: <4a8abb0e$1@news.povray.org>
In article <4a8ab114@news.povray.org>,
Invisible wrote:
> ...wuh??
What? You don't program in Scheme? Why in the world would you not? :P
This program above is a prototype of the UNIX cat program. I was
wondering how people would sort of write those lines in usual
Scheme. But I guess I might be in the wrong off topic group. :-)
Date: 18 Aug 2009 10:33:06
Message: <4a8abba2@news.povray.org>
Because it looks like THAT? :-P
Oh, right.
In Haskell, we just say
   main = interact id
Date: 18 Aug 2009 11:57:51
Message: <4a8acf7f$1@news.povray.org>
In article <4a8abba2@news.povray.org>,
Looks interesting! :P
>    main = interact id
That's right! I should copy that! ;)
Date: 18 Aug 2009 13:26:05
Message: <4a8ae42c@news.povray.org>
> (define (cat)
>          (exit) )))
> ; main
> (cat)
> %fortune | ./cat
  'cat' is a program for concatenating files. It's used like:
cat file1 file2 file3 > concatenated_files
  Your program does not fulfill this role.
  (Some people abuse 'cat' to concatenate one single file with nothing,
but that doesn't mean that the role of 'cat' is anything else than
concatenating files.)
Date: 18 Aug 2009 14:42:44
Message: <4a8af624$1@news.povray.org>
In article <4a8acf7f$1@news.povray.org>,
>>    main = interact id
(define (interact f)
         (and (display (f ln)) (newline) (interact f))
         (exit))))
(define (id x) x)
(define (cat)
  (interact id))
;main
(cat)
%printf 'my\nbeloved\ncat\n' | ./cat
my
beloved
cat
Date: 19 Aug 2009 00:06:16
Message: <4a8b7a38@news.povray.org>
In article <4a8ae42c@news.povray.org>,
>> (define (cat)
>>          (exit) )))
>> ; main
>> (cat)
I wasn't aware of the definition of cat. But I think it's true that
without reading files, it is unable to concatenate. After a day of
work, I can now tell one how to scheme a cat.
     (cond
      [(not (eq? ln eof))
         (and
	   (printf "~a\n" (f ln))
	   (interact f))])))
(define (id x) x)
(define (cat files)
  (for-each
   (lambda (x)
     (with-input-from-file x
       (lambda ()
	 (interact id))))
   files))
;main
(cat (vector->list (current-command-line-arguments)))
With with-input-from-file, we get the stdin connected to the file
opened, so no changes in interact were required.
This cat does not handle exceptions. I might see how that works next.
Although Haskell has always looked wonderful to me, I had the
intuition that a Lisp like language would suit me better because I'm
kind of syntax minimalist. I gave up on the idea that this is good,
and went to check Haskell out. I liked it a lot, but I'm coming back
to believe that my initial intuition deserves attention.
Like someone once put it; a good language has to be hackable. I think
Lisp likes might be hackestables.
Date: 19 Aug 2009 02:35:00
Message: <web.4a8b9c8c606eeda4cb3dd3d0@news.povray.org>
>      (cond
>       [(not (eq? ln eof))
>          (and
>     (interact f))])))
> (define (id x) x)
> (define (cat files)
>   (for-each
>    (lambda (x)
>        (lambda ()
>   (interact id))))
>    files))
> ;main
That's the PLT way.  here's another:
#!r6rs
(import (rnrs base)(rnrs io simple)(rnrs programs))
; simple and straightforward standard R6RS scheme solution
(define (cat files)
  (for-each
    (lambda (file)
      (call-with-input-file file
        (lambda (port)
          ; no simple line-oriented IO in standard R6RS
          ; so you either write one or loop char-by-char
          (let go ((c (read-char port)))
            (if (not (eof-object? c))
              (begin
                (write-char c)
                (go (read-char port))))))))
    files))
(cat (cdr (command-line)))
you can run it like:
plt-r6rs cat.scm foo.txt bar.txt
Neither does mine.  There is a file-exists? function though:
http://www.r6rs.org/final/html/r6rs-lib/r6rs-lib-Z-H-10.html#node_chap_9
I just love Lisp, Scheme in particular.  Minimalist like C, only much higher
level.  Incidentally, the only two languages I truly enjoy, for different
purposes sure.
yes, I'm aware the C solution for this particular example would be way
shorter... :P
Date: 19 Aug 2009 04:40:32
Message: <4a8bba80$1@news.povray.org>
Interesting. I thought it was for concatenating a file to stdout...
Alrighty then:
   import System.Environment
   main = do
     args <- getArgs
     mapM_ (\arg -> readFile arg >>= putStr) args
That seems to work.
I'm guessing the real cat program also has assorted command-line
switches as well though?
