POV-Ray : Newsgroups : povray.off-topic : For a price Server Time
27 Jun 2026 05:11:19 EDT (-0400)
  For a price (Message 1 to 10 of 26)
Subject: For a price
Date: 17 Aug 2009 16:21:23
Message: <4a89bbc3$1@news.povray.org>
http://www.bonnersmusic.co.uk/buy/Hammond/PK25PXK_25_Note_Midi_Pedalboard
...uh, yeah, maybe I won't bother. O_O
http://blog.orphi.me.uk/
Subject: Re: For a price
Date: 17 Aug 2009 17:16:48
Message: <4a89c8c0$1@news.povray.org>
They say necessity is the mother of all invention. Well I've just
invented something truly absurd. I've found a way to play bass notes
even though I don't have a peddle board. The concept is quite simple:
play the note with my finger, and then hold it down with my foot, while
I play the rest of the music. The result has to be seen to be believed.
I should probably get out more...
Date: 17 Aug 2009 18:07:44
Message: <4a89d4b0$1@news.povray.org>
4a89c8c0$1@news.povray.org...
> They say necessity is the mother of all invention. Well I've just invented
> something truly absurd. I've found a way to play bass notes even though I
> don't have a peddle board. The concept is quite simple: play the note with
> my finger, and then hold it down with my foot, while I play the rest of
LOL  !
My father who plays organ at the church and has only an old piano to
practice home built a pedalbord which just pulls the lower octaves keys from
under with nylon strings.
Another way :  http://www.orchetect.com/resources/midi-organ-pedals.php
Marc
Date: 17 Aug 2009 22:17:44
Message: <4a8a0f48$1@news.povray.org>
Ooh, I want one!
...but I need a keyboard first :(
...Chambers
Date: 17 Aug 2009 22:19:21
Message: <4a8a0fa9$1@news.povray.org>
How hard would it be to get a couple of pressure sensors, and wire them
up to a MIDI plug so you could have your own?
Then you could go to the pub and tell some random girl, "Hey, baby, you
ever dated a guy who wired his own base?" :)
...Chambers
Date: 18 Aug 2009 03:07:33
Message: <4a8a5335$1@news.povray.org>
> How hard would it be to get a couple of pressure sensors, and wire them up
That's what I thought the moment I saw it.  Or maybe simpler to buy a
standard cheap MIDI keyboard to get all the electronics and rig up some nice
wooden pedals to it.
Date: 18 Aug 2009 04:32:35
Message: <4a8a6723$1@news.povray.org>
Harder than you'd think.
A peddleboard needs to not break when an 80 Kg person stamps on it. This
is non-trivial.
Where the hell do you buy pressure sensors?
You realise that MIDI is a serial communications protocol, right? It's
not like you just connect each sensor to a different pin on the plug;
you need some fairly elaborate electronics in there.
*facepalm*
Date: 18 Aug 2009 04:35:26
Message: <4a8a67ce$1@news.povray.org>
>> them up to a MIDI plug so you could have your own?
> nice wooden pedals to it.
I guess that's a possibility, assuming I can find one that isn't
touch-sensitive. (For some reason, as soon as you buy a stand-alone MIDI
controller everybody automatically thinks you want the finest
weighted-key action with touch sensitivity and polyphonic aftertouch...
Hence, keyboards that have MIDI are quite cheap, but MIDI keyboards are
surprisingly expensive.)
Assuming you find one that isn't touch-sensitive, so pressing a key just
closes a circuit, it should be possible to rig something up.
The next problem is going to be how to make it sturdy enough to not fall
apart. ;-)
Date: 18 Aug 2009 05:08:32
Message: <4a8a6f90@news.povray.org>
> touch-sensitive.
Oh ok I didn't realise the pedals didn't need to be touch sensitive, even
simpler then!
Alternatively use another input method to a PC (you can get multiple digital
input to USB boards) and then generate the MIDI signals in software.
> apart. ;-)
The pedals are not going to be taking massive forces so you don't need to
worry about using bearings or anything fancy like that.  I would just put a
hole through the pedal at the back and let it rotate on a bolt that is
secured to some base-plate.  That way you can place each pedal at a
different angle.  To provide the resistance just glue on a lump of stiff
rubber underneath each pedal and mount a micro-switch to trigger at the
correct position.  Shouldn't take too much work.
Date: 18 Aug 2009 05:37:49
Message: <4a8a766d$1@news.povray.org>
>> touch-sensitive.
> even simpler then!
I'm trying to simulate a pipe organ here. They're generally not
particularly touch sensitive. ;-)
[Although... the mechanical-action ones *are* very slightly touch
sensitive, which not a lot of people know.]
>> just closes a circuit, it should be possible to rig something up.
> digital input to USB boards) and then generate the MIDI signals in
> software.
I'm guessing generating MIDI signals in software is going to be intractable.
>> fall apart. ;-)
> to worry about using bearings or anything fancy like that.  I would just
> put a hole through the pedal at the back and let it rotate on a bolt
> that is secured to some base-plate.  That way you can place each pedal
> at a different angle.  To provide the resistance just glue on a lump of
> stiff rubber underneath each pedal and mount a micro-switch to trigger
> at the correct position.  Shouldn't take too much work.
For one thing, it's going to take some big chunks of solid wood, and a
big iron bolt. Given how ludicrously expensive actual wood is, I guess
it might not even come out any cheaper than just buying the one in the
shop...
