POV-Ray : Newsgroups : povray.off-topic : Suggestion: OpenCL Server Time
18 Oct 2026 15:19:52 EDT (-0400)
  Suggestion: OpenCL (Message 1 to 50 of 72)
Goto Latest 50 Messages Next 22 Messages >>>
Subject: Suggestion: OpenCL
Date: 13 Aug 2009 15:56:43
Message: <4a846ffb$1@news.povray.org>
I have just learned about it and I think this could be a great
improvement for POV-ray since uses: CPUs, GPUs and "any other
processors" to process programs. I'll clarify even more just in case:
OpenCL lets you use CPU(s) Core(s) + GPU(s) Core(s) + "Any other
processor(s)/core(s)"; but for most of us is just: CPU(s) Core(s) +
GPU(s) Core(s).
PS: I think it should be a 'Suggestions' newsgroup for this sort of things.
Subject: Re: Suggestion: OpenCL
Date: 13 Aug 2009 17:24:09
Message: <4a848479$1@news.povray.org>
> GPU(s) Core(s).
(*groans*)
Sorry, but you violated the "suggetions to use GPU to speed up POV-Ray
may (and invariably will) be posted in intervals of 3 months" rule... we
just had this discussion about CUDA.
OpenCL can't change the basic hardware architecture of a GPU; all it
does is provide a layer on top (= added overhead!) to faciliate porting
existing programs to GPUs - still those programs must be suited to the
GPU architecture in order for the added processing power to outweigh the
surplus inter-xPU communication overhead, let alone give any speed benefit.
As soon as POV-Ray is fully capable of running a distributed render on a
network, it *might* be worth investigating whether the render back-end
could also be fully ported to GPUs, to just add some more "machines" to
the team. Until then, I don't think it makes much sense to think about
it (unless we'd want to develop a completely new render engine using a
totally different approach). And even then, question is whether the GPU
would be fast enough at the tasks at hand to pay off the effort of
getting the code to compile for the GPU.
OpenCL, however, will definitely *not* be an option, as it is a subset
of C (the 3.7 code is written in C++), and has severe limitations that
POV-Ray's architecture cannot comply with - most notably that recursions
are not allowed. POV-Ray absolutely positively needs recursions to
handle secondary rays, and also uses recursive calls for nested
definitions of textures pigments or CSG objects.
povray.pov4.discussion.general might be an appropriate spot.
Date: 13 Aug 2009 17:40:01
Message: <web.4a848773f26f07ca859688b90@news.povray.org>
> (*groans*)
I think the standard answer should just be "Go right ahead!  Come back when
you're done."
 - Ricky
Date: 13 Aug 2009 19:05:04
Message: <4a849c20$1@news.povray.org>
triple_r schrieb:
>> (*groans*)
> you're done."
No, that would constitute being mean to people just becuase they're not
that deep into that matter... (although it is definitely tempting ;-))
Date: 13 Aug 2009 22:23:07
Message: <4a84ca8b@news.povray.org>
> you're done."
>  - Ricky
standard? standard retarded answer maybe... as I'm proposing this to the
POV-Team not saying it must be implemented, nor I'm implying I'd
implement it.
People that doesn't have any pro-active opinions to contribute to the
discussion should abstain from give it.
Date: 13 Aug 2009 23:08:02
Message: <4a84d512@news.povray.org>
> (*groans*)
Way to go to start a discussion...
I think you are wrong: "OpenCL (Open Computing Language) greatly
improves speed and responsiveness for a wide spectrum of applications in
numerous market categories from gaming and entertainment to scientific
and medical software."
 From here:
http://www.khronos.org/news/press/releases/the_khronos_group_releases_opencl_1.0_specification/
Have you appreciated first hand that overhead making it inviable for
POV-Ray?
"Tony Tamasi, senior vice president of technical marketing at NVIDIA
stated: “OpenCL adds fuel to the most exciting parallel computational
revolution of our generation – GPU Computing. It also provides another
powerful way to harness the enormous processing capabilities of our
CUDA-based GPUs on multiple platforms." From the same link.
Some GPGPU provide 64-bit Floating Point computing wich is, I think, the
major concern baout raytracing.At the seems some CUDA capable GPUs does
and for sure some ATI's too:  ATI Stream Technology
(http://www.amd.com/US/PRODUCTS/TECHNOLOGIES/STREAM-TECHNOLOGY/Pages/stream-technology.aspx).
Granted, this new C standard (C99) is not fully supported in any C++
implementations; Intel C++ supports it for the most part but not fully.
But I think a port to C++ probably is in the making since C++ is by
far more popular than C99 IMHO, so I think, since it has been released
about 8 months ago, maybe there is a C++ ported OpenCL spec or maybe
more by now. Many  computing intensive apps. would want this for themselves.
As you may know I participate in WCG (www.worldcommunitygrid.org) a
scientific research worldwide computing grid for protein-based disease
research like AIDS, Cancer, Human Proteome Folding, etc. There is a
GPU-based implementation of the Human Proteome Folding project and it
makes great progress, so I know it works well.
OK, maybe is not as suitable for raytracing as it is for protein folding
research, maybe the explanation why not is in the discussion about CUDA
is where the answer is, but maybe is worth it because it has 64-bit
Floating Point computing, which IIRC is the one and only big obstacle to
avoid GPU-aided raytracing.
Or what I'm missing? don't want any details, only the highlights if you
care to answer.
>> things.
thanks, I think I'll try povray.programming.
Date: 13 Aug 2009 23:41:53
Message: <4a84dd01$1@news.povray.org>
> care to answer.
Double precision floating point was only the first objection which held
things up.  For several years we've been saying that it's "the reason",
but that's just to simplify things as the other reasons don't matter if
this first one remains unresolved.
Of course, modern GPUs now allow double precision, so we can get to the
other objections now.  Specifically:
1) Recursion.  As clipka (Christian?) wrote, it is absolutely essential
for POV.
2) Data parallelization versus code parallelization (this is related to
the first, but is not strictly the same).
The ray tracing algorithm follows drastically different code branches on
a single set of data, based on recursion (reflections & refractions), as
well as the other various computations needed (texture calculation,
light source occlusion, etc) which almost all need access to the entire
scene.
Modern CPUs are great for this, as each core is essentially independent,
yet all may access a common memory pool (the RAM).
Modern GPUs are not only poor for this, but physically incapable of
running this way.  They are built to run simple procedures on massive
sets of parallel data (such as rasterization).
Have you ever written a shader for a GPU?  They're extremely limited,
and you must run *the same shader* on each parallel core.  Whereas each
core of your CPU can be running an entirely different procedure.
In other words, GPUs are precisely the wrong solution for POV, while
CPUs are perfect for it.
...Chambers
Date: 14 Aug 2009 01:57:29
Message: <4a84fcc9$1@news.povray.org>
> clipka wrote:
>> (*groans*)
Sure, but you're really not the first one, and haven't been so recently.
>  From here:
That's a nice statement. Where does it originate from?
Ah, a paper from the group that designed OpenCL to the press. What could
be their major goal with such a paper? They're not possibly trying
primarily to get attention to that thing? Right, sure they wouldn't want
to hype that thing.
Also note that...
- "a wide spectrum of applications" is a very vague statement, and may
exclude some.
- The categories mentioned all have one thing in common: Massive number
crunching with few decision making.
POV-Ray does number crunching too, in a sense, but there's a lot of
desision making involved.
> POV-Ray?
How could I? Do you have an OpenCL implementation available for me so
that I could test it?
But I have read about some limitations of GPU processing in general and
with regard to raytracing in particular, and imagine to have enough
understanding of computer architecture to be able to say that data
exchange between CPU and GPU requires a tad more overhead than
inter-process communication between separate threads running on the same
CPU.
Another marketing blurp. Of /course/ the vice president of a big player
in the GPU market is advertising it as the greatest invention since
sliced bread: It will sell more of their chips.
It used to be one of the major ones, and particularly easy to explain,
though it's a limitation that is gradually disappearing. I named some
others in my previous post.
> themselves.
I doubt that C++ support is to come anytime soon, given that OpenCL is
even more limited than C99: No function pointers for instance. How could
you possibly implement polymorphic objects if you don't even have
function pointers at your disposal?
If a standard imposes limitations which are more rigorous than what
you'll find on most brain-dead embedded microcontrollers, then there's a
hardware reason for it.
It used to be the Big One that used to be mentioned first whenever the
discussion popped up again, and possibly the only thing the POV-Ray
developers really cared about, historically: Without support for
double-precision floating point, there was no point in having any closer
look at GPUs. Fortunately for scientific simulations (like that protein
folding thing), the precision issue is improving now (probably /because/
the GPU developers want to go for that scientific sim market share).
Howver, other limitations still apply, which are no issue for such use
cases, but a problem for POV-Ray.
> care to answer.
No support for recursion is one I named already.
Another one is that GPUs are highly optimized for massively parallel
computations where exactly the same program with exactly the same
control flow is run on a vast number of data sets (which is why they
/can/ be so fast on this type of problems in the first place), but they
can /only/ run programs of this type; so if program flow must be
expected to change from one data set to the next, each data set must be
run on its own, along with (for instance) 31 "empty" data sets: You lose
97% of your processing power. That does not leave much.
Massive parallelization /could/ be used for the primary rays in a scene.
However, those are not the problem anyway: You only have a few million
of those, and sophisticated bounding and caching typically keep the
workload per ray low. It's usually the secondary rays (testing for
shadows, following reflected and refracted rays, and some such) that eat
most of the time.
I had actually and honestly hoped to discourage you with my initial
groaning. I guess the POV-Ray dev team is better informed about GPU
computing than you expect.
Date: 14 Aug 2009 01:59:07
Message: <4a84fd2b$1@news.povray.org>
Close to it: Christoph.
Date: 14 Aug 2009 03:09:27
Message: <4a850da7@news.povray.org>
Chambers wrote:
>> you care to answer.
> for POV.
I suppose this is unsolvable without an C++ ported OpenCL.
they say "an API for coordinating data and task-based parallel
computation...", this doesn't help? If it could do both maybe would be
of use for POV-Ray.
> scene.
> ....Chambers
I see... maybe if GPGPUs are not use as co-processors but as an
auxiliary co-processor that is called on demand, if GPU compliant
procedure needs to be processed. Are absolutely sure there isn't a case
where a GPU can help? maybe in the middle of a rendering/parsing?
Date: 14 Aug 2009 03:32:58
Message: <4a85132a@news.povray.org>
>> clipka wrote:
>>> (*groans*)
>> in numerous market categories from gaming and entertainment to
>> scientific and medical software."
>>  From here:
> to hype that thing.
> Also note that...
> exclude some.
>> POV-Ray?
> CPU.
>> the major concern baout raytracing.
>> fully. But I think a port to C++ probably is in the making since C++
>> is by
>> themselves.
>> folding research, maybe the explanation why not is in the discussion
>> about CUDA is where the answer is, but maybe is worth it because it
>> has 64-bit Floating Point computing, which IIRC is the one and only
>> big obstacle to avoid GPU-aided raytracing.
>> you care to answer.
> most of the time.
So, you assume that is just a huge amount of hype, and even if it works
for other apps., won't for POV-Ray. I think there are more to analyze
than just simple generalizations. Anyway, is a POV/TAG-Team decision, we
can merely speculate.
And you know what I expect the POV/TAG-Team to know... you assume too
much...
groaning is an emotional response and as such, irrational: I haven't
been  reading this NG for a long time and the first line of text I read
was your groaning, besides of the rudeness, it explains nothing, and
clarifies the same way. I don't like emotional responses to intellectual
matters, I find them quite out of place, getting in the way of
logical/rational thinking, making a mess of things, reason enough for me
to disregard them on sight. Discouraging/intimidating me is not that easy.
Date: 14 Aug 2009 05:27:07
Message: <seba85lvjseiqv1l1vuam2kuuh68if0phe@4ax.com>
On Fri, 14 Aug 2009 03:32:15 -0400, Saul Luizaga <sau### [at] netscapenet> wrote:
Is there still a TAG team? I know Warp is still around and Gilles and Ken pop in
occasionally but when was the last time any of the others replied to a post?
Regards
Date: 14 Aug 2009 05:37:11
Message: <4a853047@news.povray.org>
No idea man, I assume there is a TAG-Team since I don't think a highly
technical freeware like this can't exist without one.
Date: 14 Aug 2009 05:50:18
Message: <4a853359@news.povray.org>
  There are certain subjects which repeat themselves time after time when
some people think that they have an ingenious new idea which surely nobody
has even thought of before and thus they come here and write about it. For
the umpteenth time for regulars. Something which has already been discussed
like a million times to death. No wonder regulars are tired of explaining
the same thing over and over.
  At some point in the past, whem XML was all the hype, it was a rather
regular occurrence for someone to come here and suggest that povray's
scene description language would be changed to XML-conforming. No wonder
that after some time people just start responding to it with "no, that's
just a braindead idea" rather than going once again to minute details why
the idea doesn't work.
  To be fair, though, not all such ideas are unimplementable. The most
prominent example is multithreading: In the past it was again and again
suggested, and again and again shot down as unfeasible due to all the
povray features which are not thread-friendly. In a way, both views were
right: Yes, multithreading *is* implementable in povray (as demonstrated),
and yes, it *is* a huge, huge task (as also demonstrated). Not only did it
require an almost complete refactoring of the source code, but even after
all these years there are still minor problems to be solved because of the
problems introduced by multithreading.
  Using the GPU for rendering in povray is equally unfeasible, even though
for slightly different reasons. Mostly it has to do with GPU features (or
lack thereof) and the amount of data which would have to be constantly
transferred between the graphics card and the system RAM, which would most
probably nullify any theoretical speed advantage.
Date: 14 Aug 2009 06:36:34
Message: <4a853e32$1@news.povray.org>
> for POV.
> scene.
There are two problems: recursion and divergence.
When a ray hits something, zero or more secondary rays are spawned. On
the CPU, this is usually just a recursive function call, but the GPU
does not permit such a thing.
Also, a GPU consists of *hundreds* of cores, but they must all execute
the same code path (but with different data). You can set the GPU up to
process multiple rays, but as soon as some of the rays hit object A but
others hit object B, the code paths that need to be taken diverge from
each other, which the GPU does not permit.
The solution in both cases is to put rays into "queues", such that all
the rays in a given queue take the same code path [for a while]. When
you need to spawn a secondary ray, you add it to a queue rather than
recursively tracing it. When some rays hit an object and others don't,
you add them to different queues. The rays in each queue can then be
processed in batches later.
The key problem is that if a queue ends up with very few rays in it,
you're going to have a hell of a lot of idle cores while you process
that queue. The GPU is usually clocked far slower than the CPU; it only
"appears" fast because it has hundreds of cores working in parallel. If
most of those cores are actually idling, you're going to have a problem.
It may turn out not to be any faster than the CPU under unfavourable
conditions.
Another possibility is to run the main renderer on the CPU, adding rays
to queues, and sending any "sufficiently large" queues to the GPU for
processing. I don't know if bandwidth limitations between the two would
make this viable...
Date: 14 Aug 2009 12:52:25
Message: <4a859649$1@news.povray.org>
In article <4a84d512@news.povray.org>,
Saul Luizaga wrote:
>> (*groans*)
LOL!
Date: 14 Aug 2009 16:00:09
Message: <4a85c249@news.povray.org>
Invisible wrote:
I understand perfectly this problems.
> make this viable...
Exactly, that is why I asked: "Are absolutely sure there isn't a case
where a GPU can help? maybe in the middle of a rendering/parsing?".
As for the bandwidth and memory concerns, from here:
http://forums.amd.com/devforum/messageview.cfm?catid=328&threadid=95060&enterthread=y
Q: What are AMD's stream computing product features?
A: AMD's FireStreamtm 9170, our latest generation stream computing GPU,
features:
* 320 stream cores (compute units or ALUs)
* 2GB on-board GDDR3 memory
* Double precision floating point support
* PCIe 2.0 x16 interface
View AMD FireStream 9170 specifications here:
http://ati.amd.com/products/streamprocessor/specs.html
Memory Concern:
  Maybe would be a good idea to leave the processed data on the video
card  local memory until is needed in Main Memory.
Bandwidth Concern:
- M4A78 PLUS MoBo
(http://usa.asus.com/products.aspx?l1=3&l2=149&l3=758&l4=0&model=2889&modelmenu=1):
# It features dual-channel DDR2 1066 memory support and accelerates data
transfer rate up to 5200MT/s via HyperTransport™ 3.0 based system bus.
- CPU :AMD Phenom™ II Key Architectural Features
(http://www.amd.com/us/products/desktop/processors/phenom-ii/Pages/phenom-ii-key-architectural-features.aspx)
# One 16-bit link at up to 4000MT/s
# Up to 8.0GB/s HyperTransport™ I/O bandwidth; Up to 16GB/s in
HyperTransport Generation 3.0 mode
# Up to 37GB/s total delivered processor-to-system bandwidth
(HyperTransport bus + memory bus)
- PCIe Local Bus: PCIe® Base 2.1 Specification
PCIe Card Electromechanical 2.0 Specification
(http://www.pcisig.com/specifications/pciexpress/base2)
# Signaling
PCI Express Base 2.0 specification doubles the interconnect bit rate
from 2.5 GT/s to 5 GT/s in a seamless and compatible manner. The
performance boost to 5 GT/s is by far the most important feature of the
PCI Express 2.0 specifications. It effectively increases the aggregate
bandwidth of a 16-lane link to approximately 16 GB/s.
- Video Card: MD FireStream 9170 (specs above)
As you can see, maybe bandwidth it isn't much of an issue since The
transfer between the PCIe video card and the Main memory can me made at
5 GT/s. Is this still insufficient for POV-Ray peak performance?
Date: 14 Aug 2009 16:16:27
Message: <4a85c61b@news.povray.org>
Well instead of groaning you can make a small .txt file in your PC:
"Alrady discussed, conclusions were:
1)....
2)...
3)..."
or something like that, to avoid frustration and redundancy.
I don't think my ideas are revolutionary, nor new, nor ingenious, I'm
just suggesting something that MAY or MAY NOT have not been discussed
before.
Also I assume everyone here knows more than me, including the
POV/TAG-Team, so this is more of a hint than a suggestion. Sometimes
smart people forget about simple things.
I see, I know POV-Ray source code is HUGE and any minor changes
represent big efforts. But, at the seems, in this case was a necessary one.
Maybe there is a use for it, not as another main processor but as
secondary one. I posted about it in another post.
Date: 14 Aug 2009 16:17:36
Message: <4a85c660@news.povray.org>
:-D
Date: 14 Aug 2009 19:44:28
Message: <4a85f6dc$1@news.povray.org>
I mean, the video card has 2GB GDDR3 of RAM and if a suitable threads
are found for the GPU and all that work can be leaved in the video card
memory until is needed.
Maybe, even the data in the video card memory could be used to give a
partial rough preview as the scene is rendered, wouldn't be any clear
sometimes but it could give you a hint what the GPU is doing on the fly,
at least I think it would be cool to see it. Probably even won't be too
much of a delay to display this since is already in he video card. Of
course this is very optional.
Also I was wondering: what is the bandwidth between the CPU and the Main
Memory at render time? maybe this can help us calculate a rough estimate
of the bandwidth needed for the video card.
Cheers.
Date: 14 Aug 2009 20:16:59
Message: <4a85fe7b$1@news.povray.org>
>> essential for POV.
Recursion is not a feature of C++, it is also a part of standard C99.
>> to the first, but is not strictly the same).
> of use for POV-Ray.
Did you actually /read/ the spec - or just the enthusiastic introduction?
Sure, it does support task-based parallel computation - why? Probably
because it also targets classic multi-core CPUs, which are ideally
suited to task-based parallel computing.
GPUs perform very poorly with task-based parallel computations, due to
their hardware architecture. A software abstraction layer won't change
that fundamental limitation.
No.
POV-Ray's internal workflow does not support asynchronous computations
(other than having multiple threads independently render parts of the
image), so only blocking "calls" to the GPU would be of any use, putting
the CPU task in waiting state in the meantime. Therefore, only portions
of the code that can be computed /significantly/ faster by the GPU, or
have any /significant/ size, would warrant "outsourcing" of
computations, otherwise parameter passing and task switching overhead
would bog down performance instead of increasing it.
But the only sections of POV-Ray code that do ask for parallelization
are RGB color and 3D vector computations, or similarly-sized problems;
these can be parallelized quite well on modern CPUs as well using SSE2
(i.e. the GPU will not be much faster), and are heavily intermixed with
conditional branching (i.e. the size of outsourceable work packages is
very small)
Date: 14 Aug 2009 20:31:37
Message: <4a8601e9$1@news.povray.org>
>> rays to queues, and sending any "sufficiently large" queues to the GPU
>> for processing. I don't know if bandwidth limitations between the two
>> would make this viable...
Note that although the approach /may/ (!) work, it is a /fundamentally/
different approach from what POV-Ray is doing.
Changing POV-Ray to use that approach would imply virtually a complete
rewrite of the render engine.
So you're looking at peak data transfer rate limits and from them can
infer that transfer between CPU and GPU memory space is not an issue?
Did you consider latency issues, or the overhead created by the OpenCL
framework itself? How about the latency for a "function call"?
If your work packages are large enough, then these are no issues. But in
a raytracer, be prepared for rather small work packages.
Date: 14 Aug 2009 20:59:48
Message: <4a860884@news.povray.org>
I didn't see much analyzing on your side - only enthusiasm about what
they write in the introduction. It appears to me that you don't know
much about POV-Ray's architecture or GPU architecture, and are actually
not too familiar with the OpenCL framework either.
I'm not generalizing. I did have a look at the paper, and analyzed it
(and POV-Ray's program structure) in enough detail to present hard facts
why POV-Ray and OpenCL won't mix, at least not at the time being.
 > Anyway, is a POV/TAG-Team decision, we can merely speculate.
No, we can say for sure that they will /not/ go for OpenCL anytime near.
> much...
 From your postings, it is quite obvious that you assumed OpenCL to be
something brand new, with you being the first in all the POV-Ray
community to discover it.
FYI: OpenCL has been mentioned in the POV-Ray NGs half a year ago already.
And that's exactly why I issued this loud groan: You /obviously/ didn't
even bother to check whether anyone ever brought up the topic of GPU
usage any time recently, or you would have noticed that it had just been
on the agenda again, in the incarnation of CUDA.
Even after you were informed that the topic had been discussed just
recently, you also obviously haven't bothered to check the thread on
that topic, to get yourself updated on the problems of using GPUs with
POV-Ray, and compare how that applies to OpenCL.
You just came stumbling in, hollering "hey, I got this great perfect
idea for POV-Ray...", as if the people developing POV-Ray would never
have heard of it otherwise. Even upon receiving a not-so-positive
reaction indicating that you /might/ be wrong, you stuck to that
attitude, hollering right away again in p.programming in the same style.
There's rudeness in that, too.
Date: 14 Aug 2009 21:13:35
Message: <4a860bbf$1@news.povray.org>
> 1)....
> 2)...
> 3)..."
What, and have it clutter my hard disk, and three months later when it's
really needed I don't remember where I put it?
Furthermore, as is just being demonstrated, people don't take the
explanations and leave it be, but start discussions about it. Or they
don't understand the explanations and ask. Or...
> before.
Next time you're in that situation, you might as well /check/ if it has
been discussed before.
Reread your original post. It doesn't sound like what you describe now.
Not really. Major changes represent major efforts. As of now, GPU
support would be a more-than-major effort.
/Some/ changes that look like minor ones do require big efforts due to
how the internal structure happens to be. Others appear like a major one
  but are actually a piece of cake to implement.
Maybe it's worth reconsidering in a year or so.
Date: 14 Aug 2009 23:57:45
Message: <4a863239$1@news.povray.org>
And that's another problem.  While a GPU has *hundreds* of cores that
all work in parallel, in raytracing you're unlikely to encounter more
than a few dozen rays which require the same test.  It's just not
efficient to solve this problem with GPUs.
Note that, while GPGPU has come a long way in recent years, the only way
to make it more useful for POV is to make it more like a CPU and less
like a GPU.  While GPUs in general may go this route in the future (Tim
Sweeney thinks so), really GPUs will focus first and foremost on what
games need... and games don't need raytracing yet.
...Chambers
Date: 15 Aug 2009 00:01:59
Message: <4a863337$1@news.povray.org>
NB: There are some apps, which theoretically *should* benefit massively
from GPGPU, which are actually hurt by it.
Case in point: TMPGEnc, using CUDA.  Video encoding has long been touted
as one of the best areas for improvement via GPGPU.
On a GeForce 260, it's actually *slower* than a Core 2 Quad 6600 (2.4gHz).
Imagine a dual-processor six-core Xeon system (12 cores, 24 threads) and
you'd need a few dozen GPUs (running literally *thousands* of threads)
to match the performance.
...Chambers
Date: 15 Aug 2009 02:07:42
Message: <4a8650ae@news.povray.org>
Agreed. It's no small task, by any stretch of the imagination...
http://blog.orphi.me.uk/
Date: 15 Aug 2009 02:10:58
Message: <4a865172@news.povray.org>
>> in a raytracer, be prepared for rather small work packages.
I'm not sure I agree with these statements.
Tracing a scene involves shooting thousands, or even tens of thousands
of rays at the top-level geometry. While there may be some objects which
are quite small, most objects will be hit by hundreds and hundreds of rays.
Now, whether it's efficient to run the entire rendering engine on the
GPU is debatable, but it would seem to be that it should be possible to
achieve *some* speedup by running at least part of the tracing process
on the GPU. (The only question is bandwidth.)
More to the point, if a GPU was more like a CPU, it wouldn't be faster
than a CPU.
Date: 15 Aug 2009 04:03:15
Message: <4a866bc3$1@news.povray.org>
Let's say a scene rendered for display on a 1080p TV has approximately
300 objects in it, each one covering a similar portion of the display
(for simplicity's sake).
That's a total of 1,920x1,080=2,073,600 pixels, or 6,912 for each
object.  Admittedly, this is more than my statement of "a few dozen" :)
  However, each level of recursion will split the groups rays - let's
say into 4 groups (I honestly think they would be grouped in more,
smaller, groups, but this will make the math easier).  After only 4
levels of recursion (a value entirely common in scenes) the rays are
bundled in groups of 25 (assuming an even distribution, of course).
With a smaller image, more objects, and less tight grouping, you'd get
such small groups after only one or two levels of recursion.
> than a CPU.
True ;)
...Chambers
Date: 15 Aug 2009 04:16:09
Message: <4a866ec9$1@news.povray.org>
> After only 4 levels of
> recursion (a value entirely common in scenes) the rays are bundled in
That seems small enough that it might be worth transferring back to the CPU.
But if you think about common scenes where you have walls and floors and
so forth, it might be worth using the GPU to test ray intersections
against these, and against bounding volumes (if you're using them). Huge
numers of rays need to be run through these tests, so the GPU can fire
those off quite quickly. It might also be worth running the "so what the
hell is the colour of this surface?" calculation on the GPU - what with
texturing, normal maps, multiple light rays of different angles and
colours, etc.
Also, let's clear this up: My understanding is that the GPU does not
require *all* cores to run an identical kernel. IIRC, the cores are
grouped into (fairly large) bundles, each bundle runs a single kernel,
but different bundles can run completely different kernels. So you don't
need a ray queue with enough rays for the entire GPU, just for a whole
bundle of cores.
Date: 15 Aug 2009 12:49:01
Message: <4a86e6fd$1@news.povray.org>
But those tests are also quite simple, so would benefit the least from
the GPU.  If isosurfaces could be translated efficiently into shaders,
then those would show the most benefit (and Julia fractals, of course).
> colours, etc.
Possibly.  In fact, using the GPU for GI might be an option.  For
instance, we could run a single extremely high resolution pass with no
lighting or texturing, just intersections, and cache all the
intersection locations.  Then, feed these intersections to the GPU, and
have it calculate lighting for those points.  Feed the lighting data
back to the CPU for radiosity, and voila!  Fast GI :)  (Of course,
implementing it would be a b*tch, but that's beside the point).
> bundle of cores.
True, I think the shaders are in blocks of 4, and you have to have
groups of 32 blocks running the same shader or something like that
(which would be 128 shaders per program).  I don't remember the exact
numbers, though, and in fact it's probably GPU dependent.
...Chambers
Subject: clipka I'll answer you here...
Date: 15 Aug 2009 13:07:11
Message: <4a86eb3f$1@news.povray.org>
>>> GPU for processing. I don't know if bandwidth limitations between the
>>> two would make this viable...
>> at 5 GT/s. Is this still insufficient for POV-Ray peak performance?
You just don't like to be corrected due to your intellectual vanity and
arrogance, leave those aside for good, they don't do anybody any good.
I made a search on p.o-t on the subject and found nothing. The question
was: "are you ABSOLUTELY SURE it won't work...?" First you say NO. then
MAY (!) work. Obvious contradiction. Then you made a number of
assumptions (againg) about me, all of them WRONG and this is for sure
rude. Posting on p.p was only the right thing to do, since it was a
suggestion I didn't started a discussion there, but here.
On my first post in this thread: get some perspective dude, it was for
everyone, from little tech knowledge to the most advanced, of course
most advanced readers can obvious the explanation/clarification I made
about OpenCL.
To the subject: I don't know much about GPUs, POV-Ray internals,
programming, nor OpenCL, but I do know a little about Computer
electronic architecture. Some of the questions I made are not meant for
this NG readers not even the TAG-Team but to the POV-Team, so they can
made calculations about OpenCL.
I think they may have a structured and classified diagram of ALL POV-Ray
programming structures, knowing approximately how much each structure
would take in the CPU, so from the data I provided they could see:
1) What GPU capable structures.
2) The amount of time that the selected GPU capable structures could
take to do a given process.
3) And this should be first, see if it is worth it, to consider the GPU
aid, if not possible through OpenCL, make a custom framework. If it is,
calculate how many GPU capable structures there are to have a second
evaluation, and see if that number is worth the effort.
4) ETC.
So I'm analyzing to the best of my abilities as everyone here, including
you, but you're taking this too emotional and going for personal attacks
on me trying to discredit me. I'm just trying to see all possibilities
of GPU acceleration and have a discussion and maybe lighten up the
analysis a little for the POV-Team, but maybe is not me place nor even
non POV-TAG-Team people, so maybe I should just had this addressed to
the POV-Team for their consideration only and avoid so much "bothering"
people here. But as you can see there are somethings to say about it
still...
Subject: Re: clipka I'll answer you here...
Date: 15 Aug 2009 13:51:51
Message: <4a86f5b7$1@news.povray.org>
This sounds more like you.
Believe it or not, this subject is an official Dead Horse.  Please stop
beating it, you'll only get a bloody mess.
First, p.o-t is the wrong forum.
Second, posts here expire.
No, you didn't even ask a question.  You made a statement: "I have just
learned about it and I think this could be a great improvement for POV-ray"
This is something which, by your own words, you have just heard about.
You then quoted a whole bunch of marketing blurbs about it.
Trust me.  We have not just heard about it, but have been looking at the
idea for more than *10 years* now.  I haven't specifically looked at
OpenCL, but I have CUDA, and the underlying hardware hasn't changed
enough yet to overcome the inherent limitations in the system.
Then why is it so hard for you to accept that this isn't a good idea at
this time?
If you really want to help make POV-Ray better, the source code is
available.  Please, dig in!  Start reading the p.p group, and look at
some of the outstanding bugs!  That would surely be appreciated more
than your parroting some random marketing blurbs.
...Chambers
Date: 15 Aug 2009 14:09:04
Message: <4a86f9c0@news.povray.org>
right...
news://news.povray.org:119/4a850da7@news.povray.org, check the last
paragraph, proves you wrong. Did you liked to be corrected?
> this time?
> ....Chambers
So open minded... thanks, I out of here for good.
Date: 15 Aug 2009 16:08:03
Message: <4a8715a3$1@news.povray.org>
Yes, I do as a matter of fact.  I don't like being wrong.
...Chambers
Date: 15 Aug 2009 17:36:54
Message: <4a872a76$1@news.povray.org>
This may be because p.o-t is actually not the best place for such a
posting, as it is intended for topics /not/ related to POV-Ray.
 > The question
You're quoting me out of context, and out of chronological order.
You proposed OpenCL for POV-Ray. If you go back to my first reply,
you'll find that my answer was manifold back then already - but not
contradictory (nor were my follow-ups):
(I) *NO*, OpenCL will *not* be an option for POV-Ray, because (a) it is
written in a different language (namely C++), and (b) the internal
architecture makes heavy use of constructs not available in OpenCL (most
particularly recursions).
Both of this still stands. If you have any substantial information that
make both of these arguments moot (other than wishful thinking about
where the OpenCL project /may/ be heading some time in the future
according to your imagination), then go ahead and correct me.
There is another point in which I might be mistaken: My argument is
based on assumptions that (a) POV-Ray will not go back to C again, and
(b) the fundamental architecture will not change anytime soon. However,
given that POV-Ray has /just been/ ported from C to C++, and the feat of
adding SMP support has /already/ taken something like 3 years, I don't
expect any strong urge to introduce even more fundamental changes in the
underlying architecture.
This urge /might/ be greater if there was a clear promise of benefit.
However, even /that/ is still doubtful.
(II) Yes, it *MIGHT* be possible to run a full-fledged independent
POV-Ray thread on a GPU; however, this would require some conditions to
be fulfilled first:
(1) POV-Ray would /first/ have to be brought to the point where it can
run distributed renders on multiple machines.
The reason here is that in order to run a separate thread on the GPU,
POV-Ray would need to be enabled to run render threads in fully separate
(or at least non-synchronized) address spaces. As this is also /the/
main prerequisite for distrubuted rendering on multiple machines (in
this multiprocessing model, communication bandwidth and latency are
likely to pose not so much of a problem even in the network, let alone
between CPU and GPU), and network rendering is already a goal POV-Ray is
committed to, I do /not/ expect GPU support to be tackled any time
earler: Network rendering comes with a clear promise of a fair gain in
render speed and usability, while the benefit of GPU rendering is still
carrying a big question mark.
(2) Someone would have to come up with a GPU programming framework much
better suited to POV-Ray, which eliminates all the issues in (I), i.e.
supports C++ and recursions.
(III) With the intention of elaborating on (I), I noted that yes, it
*MIGHT* be possible to include GPU support via OpenCL use in POV-Ray
even without changing the fundamental structure of the application,
*BUT* this would /very/ likely lead to worse performance than without
the GPU support, due to (a) the inability of POV-Ray to supply the GPU
with a large enough and parallelizable work package, and (b) the
inability of POV-Ray to continue while the GPU is processing that work
package.
As a resume, I still am perfectly sure that OpenCL is *not* currently an
option to speed up POV-Ray.
Plus, I am perfectly sure that OpenCL will be further revisited now and
then, and reconsidered as an option, should it be improved to the point
where it appears to make some sense.
There's not much that can be calculated from your figures, except the
peak memory transfer rate of some - presumably - representative graphics
hardware. Program execution speed, however, also depends on the
particular compiler (and optimizer!) - which are not even available yet.
That would help in no way, because these structures all rely on an
architecture that, as already pointed out, is fundamentally incompatible
with OpenCL-based GPU computing.
I don't think that the POV-Ray dev team should even be bothered with
this, because from all I see, current GPU architectures would appear to
either require a /monstrous/ amount of framework development to make it
work for /POV-Ray/ (again, most particularly due to the lack of support
for recursion, which apparently is a hardware limitation, not a
framework thing), or provide /very small/ gain or even a disadvantage
(due to the small size of work packages POV-Ray could supply to the GPU,
and the lack of POV-Ray to do anything else while waiting for the
results), or require a /monstrous/ amount of POV-Ray architecture changes.
I don't think the POV-Ray dev team /want/ to be bothered (once again)
with this anyway.
And even /if/ they wanted to be bothered, /I/ as a POV-Ray user wouldn't
want them to, because I think there are plenty of features which are
more important to invest time into, where a gain is clearly visible,
while the gain of GPU support is still /very/ questionable, for all the
reasons I (and others) have presented by now.
Date: 15 Aug 2009 17:53:08
Message: <4a872e44$1@news.povray.org>
Are you actually aware that Chambers and CLipka are two totally
different persons? That there are actually /two/ persons trying to
convince you that OpenCL will get POV-Ray nowhere (with others having
joined in occasionally)?
Maybe you should re-read all the replies you got, and have a look at who
actually wrote them, and what you replied to whom.
And Chambers is right: There wasn't a question to start with. You only
went for a more questioning style some postings into the discussion.
Date: 16 Aug 2009 04:12:41
Message: <4a87bf79$1@news.povray.org>
>> and so forth, it might be worth using the GPU to test ray
>> intersections against these, and against bounding volumes (if you're
>> using them). Huge numers of rays need to be run through these tests,
>> so the GPU can fire those off quite quickly.
> the GPU.
How do you figure that?
The benefit of the GPU isn't the complexity of the kernels it executes
(usually quite the converse), it's more the fact that it can do the same
operations many, many times over simultaneously.
No arguments here.
>> It might also be worth running the "so what the hell is the colour of
>> this surface?" calculation on the GPU - what with texturing, normal
>> maps, multiple light rays of different angles and colours, etc.
Yes, there's a couple of ways you might implement this, with varying
degrees of accuracy. For example, you could feed the GPU a polygon mesh
approximating the scene. (There are already known algorithms for doing
GI on a polygon mesh.) Or you could just use the GPU to accelerate the
insane number of ray intersection tests required during GI.
>> don't need a ray queue with enough rays for the entire GPU, just for a
>> whole bundle of cores.
Yeah, I'm pretty sure the batch sizes vary by GPU model. But the main
point is, you don't have to assign *all* cores to the same kernel; just
sufficiently large bunches of them.
Date: 16 Aug 2009 11:33:22
Message: <4a8826c2$1@news.povray.org>
>> the GPU.
Because you need to look at the ratio of computation time to
transmission time.  The simpler something is, the lower the ratio, and
the less worthwhile offloading is (after all, it messes with the cache,
the bus, the memory system, etc).  Ideally, whatever you offload will be
computationally intensive, so the transmission time is justifiable.
The key, of course, being "sufficiently large bunches."  There's a
strong likelihood that POV wouldn't be able to consistently create
batches that are sufficiently large.
...Chambers
Date: 17 Aug 2009 04:26:16
Message: <4a891428$1@news.povray.org>
This is the key question, yes.
Date: 17 Aug 2009 08:34:35
Message: <4a894e5b@news.povray.org>
> for POV.
> The ray tracing algorithm follows drastically different code branches on a
> well as the other various computations needed (texture calculation, light
> source occlusion, etc) which almost all need access to the entire scene.
Often you need to drastically change your algorithm to get it running well
on a GPU.  It's quite trivial to rewrite the raytracing algorithm to work on
masses of rays in parallel with no branching or ray spawning, and then do
the branching/spawning for the rays all in one go.  After this you can
efficiently use the GPU and CPU in parallel.
Date: 17 Aug 2009 08:42:06
Message: <4a89501e@news.povray.org>
> The solution in both cases is to put rays into "queues", such that all the
> rays in a given queue take the same code path [for a while]. When you need
> to spawn a secondary ray, you add it to a queue rather than recursively
> tracing it. When some rays hit an object and others don't, you add them to
> different queues.
Why add it to a different queue?  All rays that still need to be traced
(whether they are reflection, refraction, primary or shadow rays) simply
need to be intersected with the scene geometry.  If you like you could keep
a flag in the queue for each ray to say what type it is, but the GPU part
that does the ray-scene intersection probably doesn't care what sort of ray
it is.
In that way the GPU will just process as many rays as it can in batches
until the scene is complete.  The CPU would handle preparing the queue at
each step, ie removing rays that have terminated and inserting new rays for
shadows and reflections etc.
Of course to be able to do efficient scene intersection on the GPU it would
probably be best to only allow triangle-based scenes, and figure out some
way to store a Kd-tree of triangles efficiently in a texture.  Sounds like
the sort of thing someone has already done a PhD on :-)
Date: 17 Aug 2009 09:05:29
Message: <4a895599$1@news.povray.org>
I was thinking more along the lines of each surface possibly having a
different code path for computing illumination. Rays in the same bundle
can't take different code paths.
> at each step, ie removing rays that have terminated and inserting new
> rays for shadows and reflections etc.
Depends on whether you're thinking of running the whole computation on
the GPU, or just the ray intersection tests, or what.
> would probably be best to only allow triangle-based scenes
I see no especial reason why you can't do arbitrary intersection tests
on a GPU. The math isn't that complicated. The only real problem is
going to be trying to run something like isosurfaces, which use adaptive
space division; a GPU probably won't like that. But something like a
Newton iteration should be fine. [That obviously isn't applicable to
general isosurfaces though...]
> and figure
> out some way to store a Kd-tree of triangles efficiently in a texture.
Also depends on whether you're trying to write your code as a shaper, or
use a real GPGPU system. (Such as the OpenCL in the title.)
> Sounds like the sort of thing someone has already done a PhD on :-)
Indeed, that's where I read about the render queue approach. (No, I
don't remember where *exactly*.)
Date: 17 Aug 2009 10:07:07
Message: <4a89640b$1@news.povray.org>
Sure they can, you just have an "if" in the shader code based on some flag
in the ray data.
> Depends on whether you're thinking of running the whole computation on the
Some things I think the CPU still needs to do, like preparing the ray data
to put on the GPU at each step. It is quite hard to write a shader that does
anything other than return one "output value" per "pixel", ie you can't
write a shader that returns a veriable number of rays, the only thing you
can do is return a flag set that means "spawn another ray".
> I see no especial reason why you can't do arbitrary intersection tests on
I was thinking more about how to store the scene on the GPU efficiently, if
you just have a triangle list it is relatively simple.
> The only real problem is going to be trying to run something like
> isosurfaces, which use adaptive space division; a GPU probably won't like
> that.
Nah it's no problem :-)  Modern GPUs don't have any limit on loops or number
of instructions or anything like that.
I think something like a raytracer will be too complicated for a computer to
try and figure out how to put it on the GPU the best way, needs to be hand
coded by an intelligent person :-)
> Indeed, that's where I read about the render queue approach. (No, I don't
Damn.  If you think up *anything* you think is new, you can be guaranteed
that someone else somewhere has already thought of it :-)  The internet just
makes it easy to find that person!
Date: 17 Aug 2009 10:44:09
Message: <4a896cb9$1@news.povray.org>
>> bundle can't take different code paths.
> flag in the ray data.
I was under the impression that all cores in the bunch would have to
take the same branch of the if - you can't have half go one way and half
go the other. (That's what makes it a SIMD architecture.)
I was also under the impression you can have predicated instructions,
however. (I.e., a single instruction that executes or doesn't based on a
condition. But not a whole alternate execution path.)
> data to put on the GPU at each step. It is quite hard to write a shader
> that does anything other than return one "output value" per "pixel", ie
> you can't write a shader that returns a veriable number of rays, the
> only thing you can do is return a flag set that means "spawn another ray".
> if you just have a triangle list it is relatively simple.
Again, depends on whether you're writing a shader, or using a GPGPU system.
>> like that.
> number of instructions or anything like that.
But they don't allow recursion. That's the issue.
>> or use a real GPGPU system. (Such as the OpenCL in the title.)
> computer to try and figure out how to put it on the GPU the best way,
> needs to be hand coded by an intelligent person :-)
...and?
All GPGPU does is allow you to run programs on a GPU which don't
necessarily have to be shaped like shaders. You still have to write the
code yourself. It's just that you don't have to pretend it's
graphics-related even if it isn't.
> guaranteed that someone else somewhere has already thought of it :-)
> The internet just makes it easy to find that person!
I've had the same problem with mathematics my entire life.
Do you know how hard it is to draw a cube made of 8 cubes and measure
all their sides? Do you know how long it takes to expand (x+y)^9
manually, by hand? Do you have any idea how long it takes to figure out
what the pattern is and where it's coming from?
...and then I discover some entry-level textbook that tells me how some
dead guy already figured all this out several centuries ago. AND FOR
ARBITRARY EXPONENTS!! >_<
Why do I bother?
Date: 17 Aug 2009 12:10:45
Message: <4a898105$1@news.povray.org>
keep diluting/lying yourself, you're doing a great job, keep it up!
Date: 17 Aug 2009 12:13:41
Message: <4a8981b5$1@news.povray.org>
> ....Chambers
yeah, right.... hahaha
Date: 17 Aug 2009 12:27:34
Message: <4a8984f6$1@news.povray.org>
That would be "deluding", not "diluting".  :-)
   "We'd like you to back-port all the changes in 2.0
    back to version 1.0."
   "We've done that already. We call it 2.0."
Date: 17 Aug 2009 12:50:42
Message: <ei2j85prd9nij7psofehqd05jhpaqc3e3k@4ax.com>
Like it makes any difference? Just show him where the fluoride lake is.
Regards
Date: 17 Aug 2009 13:41:20
Message: <4a899640$1@news.povray.org>
Most speakers of english-as-a-second-language around here seem to appreciate
learning the right words, is all.
