POV-Ray : Newsgroups : povray.off-topic : Bokeh, blurring, and POV-Ray Server Time
2 Nov 2026 08:51:18 EST (-0500)
  Bokeh, blurring, and POV-Ray (Message 1 to 6 of 6)
Subject: Bokeh, blurring, and POV-Ray
Date: 12 Aug 2009 08:06:05
Message: <4a82b02d@news.povray.org>
Apologies for the on-topic post...
Has anyone given any thought to altering the blur kernel in POVRay?
Currently it's rectangular, but really should be a Gaussian, I believe,
or at least allow for circular, with or without falloff.
What would be extra nice would be to add the ability to define number of
  aperture blades, whether the blades are curved, and the "structure" of
the bokeh (e.g. With some lenses, the circle of confusion is rather
constant, others have a fall off toward the edges, while others get
brighter at the edges (though, this is considered bad bokeh)) It would
lend some nice realism to scenes that use focal blur, I think...
IIRC, someone had set up a scene to do just that a while back, actually
doing it in SDL.
~Mike
Subject: Re: Bokeh, blurring, and POV-Ray
Date: 12 Aug 2009 09:20:00
Message: <web.4a82bccc5cceafad958421d50@news.povray.org>
I'll be brief:
• Solution 1: SDL trickery (physical aperture) that gives artifacts since it
uses obstructed rays.
http://news.povray.org/povray.binaries.images/thread/%3Cweb.47bf5650425b71eaae42298f0
• Solution 2: Circular aperture patched into POV:
    while( ! in_circle )
         try_again
• Solution 3: Hideously ugly patch that reads hard-coded ppm bokeh image.
Shameless example of use:
http://news.povray.org/povray.binaries.images/thread/%3Cweb.47c26b5e8e18150dae42298f0
• Solution 4:  bokeh_pigment a la MLPov
http://pov.monde.free.fr/mael/mlpov081eng.html
> doing it in SDL.
Hey, I poke my head in for five minutes and my work comes up!  I therefore
conclude that I'm the topic of many lively discussions!  Please, I need this.
Really though, I apologize that the right convergence of desire and opportunity
never came up so that I could learn how to patch POV properly and make something
people can use.  Now isn't the time either--of course--but maybe it needs to be
done.
 - Ricky
Date: 12 Aug 2009 09:35:01
Message: <web.4a82c43f5cceafad958421d50@news.povray.org>
"triple_r" <nomail@nomail> wrote:
Sorry.
http://news.povray.org/povray.binaries.images/thread/%3Cweb.47bf5650425b71eaae42298f0%40news.povray.org%3E/?ttop=318663
&toff=750
http://news.povray.org/povray.binaries.images/thread/%3Cweb.47c26b5e8e18150dae42298f0%40news.povray.org%3E/?ttop=318663
&toff=750
 - Ricky
Date: 12 Aug 2009 15:04:35
Message: <4a831243$1@news.povray.org>
You could have posted povray.programming (or, alternatively,
povray.pov4.discussion.org), for instance...
I presume you're talking about focal blur; well, it actually depends on
the number of samples you have it take. Values of 7, 19, 37, or anything
closely above these, will actually give you a hexagonal shape.
Yes, focal blur can definitely be improved. I don't think it ranks too
high on the agenda though.
Date: 18 Aug 2009 08:34:37
Message: <4a8a9fdd$1@news.povray.org>
I just tried this, neat!
Curious, but why is this? Are there any higher sample numbers that give
a hexagonal shape?
~Mike
Date: 18 Aug 2009 13:20:04
Message: <4a8ae2c4$1@news.povray.org>
> a hexagonal shape?
No, these are the only ones (at least at present).
What POV-Ray actually does is use the largest of several hard-coded
patterns (plus jitter) that fits the target count, then add some
arbitrary points to get the target count.
The hard-coded patterns are a 4-sample pattern as well as a 7-sample,
19-sample and 37-sample pattern. Except for the 4-sample pattern, all of
these fit nicely on a triangular grid to form a hexagon, which is what
gives you a hexagonal bokeh if you exactly match these numbers.
The additional random points are then taken from a square grid, which is
what leads to the square bokeh typical for other sample counts.
