Ah yes, another day, another piece of stupidity to sort out.
We have some equipment in our lab. It needs a computer to control it.
Unfortunately, the control software requires somebody to be logged in.
As soon as you log out, it quits the control program, halting the machine.
But don't worry. There is a straight-forward way to solve this problem.
We have some other software, which we are already using, which has the
facility to control this equipment. And *this* software runs as a
service, as it should, and has appropriate security access controls and
auditing and so forth. This will make our job vastly easier - even
easier than it is currently.
So we're _not_ going to use this feature. Why? Because the people at HQ
don't use this feature. Currently all the sites work slightly
differently, and the people in charge want to "harmonise" business
practice across all sites. In English, they want everybody to do exactly
what HQ does.
I should point out that when somebody asked HQ for the wiring diagram to
connect up a certain piece of equipment, their senior lab expert sent
back a diagram that includes, among other things, a paper clip to
complete the circuit. (We won't be following this practice. We elected
to use a junction block, like any half-sane person would...)
Getting back on track... How *are* we going to control this equipment
then? Well, the solution dictated to us by HQ is to use a seperate
laptop to run the control software. Which seems reasonable, if not
particularly optimal.
Ah, but here's the fun part: The equipment is controlled by RS-232. Now,
how many laptops do you know of which actually possess a serial port?
Exactly.
But it's OK, it's not a problem. All we have to do is purchase a USB to
serial converter and we're golden.
Except that the control software stubbornly, repeatedly *refuses* to
believe me that the USB serial port actually exists. Every other piece
of software I've tried can access it without issue. But not the one
piece of software that we *need* to access it. No sir. Not interested.
It can "see" the port, but it refuses to *select* that port. And nothing
I've done so far seems to convince it to work.
I also got sent three laptops from HQ which have built-in serial ports.
The reason for this is that they're ancient. One of them is already set
up and running. One of them won't turn on. The charging indicator comes
on when I plug it in, but it won't actually switch on. And the third...
well, I was hoping to set that up today.
I became worried when I saw the big "Designed for Windows 98" sticker on
it. The harddrive is a mess. It has every application, screensaver, game
and utility imaginable installed. It has files everywhere. My plan was
to erase everything and load Windows XP, except - and you can see the
horrifying inevitability of where this is going - the laptop is powered
by an AMD K6-II processor and sports 64MB of RAM.
Now there is no way in HELL that Windows XP is going to run like
anything faster than a glacier with 64MB of RAM. Hell, Windows 98 crawls
along on this PC!
Clearly improving the CPU is impossible, but maybe adding more RAM would
speed it up? Except... what the hell kind of RAM does a K6 laptop take
anyway? Wikipedia claims that the K6 has a 66MHz FSB, so... PC66 maybe?
Of course, that's no longer on sale. But Wikipedia claims PC100 is
backwards-compatible. Ah, but *that* isn't available either. But I can
buy PC133. Wikipedia claims PC133 is backwards-compatible with PC100,
but is that transitive? Will PC133 work in a PC66 laptop?
On top of that, PC133 is *very* expensive. Like, £80 for 128MB. And
128MB is really not enough. But the biggest single-stick listing I can
find is for 512MB (which should probably just about work). Then again,
this is a *laptop*. How many tracks do you think Compaq bothered to
connect up? Can it actually address half a gigabyte of RAM??
Still, I have until tomorrow to sort all this out... no biggie.
In article <4a815b1f$1@news.povray.org>,
[...] LOL! I mean, sorry.
You know, the whole idea of working somewhere and having to accept
tyranical measures is wrong. Work is far too important to leave it up
to others. It is the very foundation of one's life.
I do know what to do in my case, but I don't know what to do in
everyone's case. I don't think I ever will. But I do think that one
must think about saving oneself from the tyranny of companies.
Particularly because we can. Or can't we?
The more I think about this, the more I'm losing the will to go on. All
this effort to jump through hoops to hook up an elaborate jerry-rig of
obsolete hardware to solve a problem which we ALREADY HAVE A PROPPER
SOLUTION FOR. The correct solution is right in front of our eyes, so
we're just going to ignore something and build something that's going to
cause us problems for years to come instead. WHY?! >_<
What happens if you use it anyways?
HQ gets upset because you don't follow protocol. You get upset because they
require an unreasonable solution. They get more upset because you are now
deliberately disobeying orders. You get more upset they don't listen to
reason. They get upset because they can't simply apply one rule to all groups
and create a nice, perfect world. Meanwhile, both groups think the other is a
collection of complete idiots, too stubborn to just do the reasonable thing,
solve the problem, and move on.
At least, that's how it works around here. Now, it's an external contract so
it's a little different, but really it's basically the same. They used
incorrect physics to redesign the prototype so it can use a little less power.
We know it won't work and don't want to go down that road. We try to explain it
to them, but they just get upset that we refuse to help them. And it goes back
and forth.
- Ricky
Indeed, my advise would be to find an (obscure) british rule about
quality control that could be interpreted to the effect that the HQ
solution being illegal. There may be a rule about using an OS that is
unsupported and therefore vulnerable to any new virus that comes out.
OSLT. Andy, use your knowledge, you know more about legal requirements
than HQ.
In article <4A8### [at] hotmail com>,
> than HQ.
That's good thinking. One could actually find in the law the support
needed to defend oneself from corporative despotism. I just hope you
can find something in the law... :-)
Also notice this can always get one fired. Disobedience is not at all
praised out there.
> praised out there.
Depends on the job and the company, and the reason why. If a company is
making you do something that could get you put in jail, disobedience is
the right course of action.
Jim
The MHRA gets upset with us for using a software feature which we
haven't performed extensive formal testing on.
Now, we *could* devise and execute a test plan... but nobody here really
has the necessary expertise. HQ does. And they can't be bothered to go
down this route.
What OS can the software run in? You might make use of virtualization
(VMWare, VirtualPC, etc.) to solve your problem.
You should be able to control the properties of the virtual machine and
tell it it has a serial port even if it doesn't. Running an old OS
within a virtual machine on a modern laptop should still be faster than
running the same OS on its native hardware.
-Mike
Yeah, I've been thinking about that.
I have a laptop with a USB to serial adaptor, but the software
stubbornly *refuses* to use it. If I were to set up a virtual machine,
then the software would be unable to tell it's accessing a USB device;
it would look like a native serial port.
OTOH, last time I tried to set up a virtual machine, it took two days
just to install Windows XP and update to service pack 3. That's quite
absurdly slow...
> absurdly slow...
You need better hardware. It should never take that much time to install
an OS - in my VMs, it never took that long....
What specs on the machine (including host OS)?
> absurdly slow...
Was it VirtualBox 3.0 with multi-core (SMP) enabled?
When I tried that, it took several hours for Windows XP to install, on an
AMD 4200+ CPU. VBox SMP support still sucks.
>> absurdly slow...
From memory, it was a 4 GHz Pentium IV with 512 MB RAM, running QEMU.
(The laptops I'm looking at using are this spec or worse.)
>>> absurdly slow...
>> install an OS - in my VMs, it never took that long....
Memory would be the issue here, no wonder it took forever to install, it
was probably swapping fiercely.
For good virtualization, you really need to have at least 1 or 2 GB of
memory. Insufficient host memory can lead to serious performance
problems.
Jim
>>>> absurdly slow...
> problems.
It didn't seem to be swapping *at all*. Hardly any HD activity. Just
100% CPU, constantly.
I've heard people claim that the problem is QEMU - which is a user-mode
hardware emulator rather than a virtualisation program that runs most
code natively... but having never seen any other VM product, I don't
know if it makes much difference.
http://blog.orphi.me.uk/
>>>>> days just to install Windows XP and update to service pack 3. That's
>>>>> quite absurdly slow...
>> it was probably swapping fiercely.
>> problems.
If for some reason the guest OS isn't relinquishing control to the host
(which can happen), that also would explain it. But if your host OS
requires 256 MB to run and the guest requires 256 MB to run, there's no
memory left for the actual virtualization software, so it has to get
memory from somewhere.
512 MB is a fairly low spec for any system doing virtualization,
regardless of the software. My bet is still on memory.
Grab VMware Server from http://www.vmware.com - it's free. Not quite as
easy to use as VMware Workstation, but WS is a pay-for product.
Jim
> Unfortunately, the control software requires somebody to be logged in. As
Can't you just lock the machine instead of logging off?
> believe me that the USB serial port actually exists. Every other piece of
> software I've tried can access it without issue. But not the one piece of
> software that we *need* to access it. No sir. Not interested. It can "see"
> the port, but it refuses to *select* that port. And nothing I've done so
OOC what COM port number is assigned to the USB COM port? If it's higher
than 4 then you might try changing it to 4 or below (you can usually do it
from device manager under the properties of the USB-COM adapter). Some
older programs don't like working with things like COM7 which those USB
converters typically come up as.
>> machine.
The issue being that it is then impossible for anyone except the person
logged on to discover if the machine is still running OK, how far it's
got, etc.
If we used the other software, this problem would be 100% solved. The
other software runs as a service, multiple people can access it, you can
set up access controls and auditing... the whole nine yards. But the
people at the top can't be bothered to put in the effort to test it, so
we can't use it.
>> nothing I've done so far seems to convince it to work.
> higher than 4 then you might try changing it to 4 or below (you can
> usually do it from device manager under the properties of the USB-COM
> adapter). Some older programs don't like working with things like COM7
> which those USB converters typically come up as.
Defaults to COM3. I've tried changing it to COM2 also. (COM1 is the
built-in modem.)
However, today I obtained the latest version of the control software,
and it now works perfectly with the USB adaptor. Go figure...
>>> machine.
> got, etc.
Set up a "lab" user or some such that everyone knows the login for, we have
that here to solve exactly that problem with our temperature logging
software. OOC, are normal applications required to carry on running if the
user who started them logs off? I have no idea.
>> person logged on to discover if the machine is still running OK, how
>> far it's got, etc.
Then the *other* piece of software running on the computer wouldn't be
able to log audit events under the correct username.
> running if the user who started them logs off? I have no idea.
Under Windows, any processes started by a user ordinarily get terminated
when that user logs off. Unless they do something special to prevent this...
Why not? If it can log them under the correct username when nobody is
logged on, why shouldn't it be able to do it when someone else is logged on?
> this...
Like what? Do most programs cope OK with running when nobody is logged on?
I would have thought some get a bit screwed up what with there being no
desktop or whatever.
> on?
The program continues to run with nobody logged on, and continues to
execute any instructions it has been given. However, to give it
instructions, you have to log on, and it records the username of the
person giving the instructions. If we had a single logon, there would be
no record of who issued those instructions.
>> terminated when that user logs off. Unless they do something special
>> to prevent this...
> on? I would have thought some get a bit screwed up what with there being
> no desktop or whatever.
No, I meant unless the *program* does something special to tell the OS
it wants to keep running.
It sounds like the guys at HQ are looking at trying to run our problem
software as a service somehow... We'll see if they can actually get it
to work. (I rather suspect not.)
Just set it up so the program that you give commands to cannot be started as
the lab user, and then do "Run As" the real user when you need to issue
commands...
BTW I thought you could switch users on XP and Vista without the first
user's programs being shut down.
>> be no record of who issued those instructions.
> started as the lab user, and then do "Run As" the real user when you
> need to issue commands...
That could work, I guess.
Uh... yeah, possibly.
You do know you can have two people logged on at the same time, yes?
Start program one, lock the screen, log in as second user, start program
two, lock the screen.
"We'd like you to back-port all the changes in 2.0
back to version 1.0."
"We've done that already. We call it 2.0."
Actually, that might be slightly harder with AD. You might have to log in
remotely to have multiple accounts logged in at once.
In Windows XP, you cannot "switch users" like that if the computer is part
of a Windows domain. But it is supported since Vista.
Is that true even if you log in remotely with RDP? I know we did that with
Win2000, so I find it hard to believe XP can't?
>> part
> with Win2000, so I find it hard to believe XP can't?
Windows XP Professional supports 1 user logging in via RDP (but only if
nobody is logged in remotely). Windows 2003 Server supports multiple RDP
sessions, but Windows XP supports only one at a time. As in, before
anybody else can connect, you must disconnect (i.e., log out).
>>> part
Yes. Distinguish "logged in" from "connected". Just like you can only
"switch users" on XP Pro by locking the screen, you can have multiple
programs running concurrently under multiple user accounts by logging in
remotely under different names and disconncting rather than logging out.
>> if nobody is logged in remotely). Windows 2003 Server supports
>> multiple RDP sessions, but Windows XP supports only one at a time. As
>> in, before anybody else can connect, you must disconnect (i.e., log out).
It's an interesting theory. I don't think it works like that, but I
don't have time to try right now.
(Of course, by default, only an administrator can log in via RDP in the
first place...)
I can guarantee it works that way without AD.
> first place...)
That's trivial to fix.
