POV-Ray : Newsgroups : povray.off-topic : A simple question of GPL Server Time
18 Oct 2026 15:19:59 EDT (-0400)
  A simple question of GPL (Message 1 to 23 of 23)
Subject: A simple question of GPL
Date: 8 Aug 2009 05:40:23
Message: <4a7d4807$1@news.povray.org>
OK, so I have some software released under the GPL, and I don't feel
like reading through 250 pages of dense legalese. So can anybody tell
me... is it legal to use such software for commercial work?
http://blog.orphi.me.uk/
Subject: Re: A simple question of GPL
Date: 8 Aug 2009 06:04:20
Message: <4a7d4da4@news.povray.org>
Yes.
-Aero
Date: 8 Aug 2009 06:05:13
Message: <4a7d4dd9$1@news.povray.org>
> Yes.
Heh. That was easy... :-)
Date: 8 Aug 2009 07:01:35
Message: <4a7d5b0f@news.povray.org>
> Yes.
  Although you should be careful on *how* you use it for commercial work.
  If you simply use the software itself, as an executable program, to do
your job, that's ok. (As an example: If you use Emacs, which is GPL, to
write your emails or programs as part of your payjob, that's naturally ok.)
However, there are other uses which are more restricted. For example, if
you embed the *sources* of the program into your own commercial program,
you'll have to publish your commercial program under the GPL.
  There are also other possible uses for which it's not completely clear to
me what the license demands. For example, if you make your commercial program
to call the GPL program externally, and you distribute this whole thing as one
software package, I'm not exactly sure what the licensing limitations are in
this case.
Date: 8 Aug 2009 07:27:30
Message: <4a7d6122$1@news.povray.org>
This is all I'm intending to do. I want to run GPG so I don't have to
pay money for PGP.
> this case.
Yeah, software licencing can get "interesting" real quickly...
Date: 8 Aug 2009 08:16:57
Message: <4a7d6cb9@news.povray.org>
> pay money for PGP.
  I find your original question a bit strange, really. For instance, Linux
is GPL, yet demonstrably Linux is quite widely used in commercial settings
and for commercial purposes. There are even some companies which actually
sell Linux distros, even though it's GPL (Red Hat being a prominent example).
  From this alone one should deduce that the GPL license certainly doesn't
forbid using GPL software for commercial purposes.
Date: 8 Aug 2009 08:40:20
Message: <4a7d7234$1@news.povray.org>
It's still legal, you just need to meet the requirements ;-).
> this case.
I'm actually not sure either how much you'll need to publish, but it's
still legal when you'll meet the requirements ;-).
-Aero
Date: 8 Aug 2009 10:41:23
Message: <4a7d8e93$1@news.povray.org>
I wasn't aware which exact licence Linux uses. (Although arguably the
fact that they want people to call it "GNU/Linux" should have been a
giveaway...)
Date: 8 Aug 2009 11:36:41
Message: <4a7d9b89@news.povray.org>
In article <4a7d4dd9$1@news.povray.org>,
>> Yes.
Hehe. Well, since people are not giving you an educational argument,
let's give it a try. I think the relevant parts here are (1)
motivation for the GPL, where
  [t]o protect your rights, we need to prevent others from denying you
  these rights or asking you to surrender the rights. Therefore, you
  have certain responsibilities if you distribute copies of the
  software, or if you modify it: responsibilities to respect the
  freedom of others.
which suggests that merely using the program, you don't have anything
to worry about; in fact, in ``basic permissions,'' we are told that
  [t]his License explicitly affirms your unlimited permission to run
  the unmodified Program.
Good. But what is the output of the program and what are you going to
do with it? Careful there. Because
  [t]he output from running a covered work is covered by this License
  only if the output, given its content, constitutes a covered
  work. This License acknowledges your rights of fair use or other
  equivalent, as provided by copyright law.
So a calculator that outputs numbers gives you nothing to worry about
because numbers are uncoverable by federal law. But consider a covered
program that logs in to an ftp site and prints all the GPL covered
code that it finds there. Such output is covered, and it might take
over your proprietary plans if you mix them in a special way.
Date: 8 Aug 2009 12:56:30
Message: <4a7dae3e$1@news.povray.org>
Use *for* commercial work, i.e. as a tool (e.g. compiler) - definitely so.
Use *in* commercial work, i.e. as part of it (e.g. a library) - depends
on your business model: If you can GPL your work and still make money
with it, then yes. Otherwise - definitely no.
Then again, in case of the "Lesser GPL" (LGPL) - definitely yes.
Date: 8 Aug 2009 13:52:29
Message: <4a7dbb5d$1@news.povray.org>
>> Yes.
GPL is about distribution, not about usage of the software.  Its purpose
is to ensure that code released under the GPL that's modified isn't only
redistributed in binary form, but that the modifications to the GPL'ed
code are also made available under the GPL.
There's no prohibition on usage of the code nor is there a prohibition on
selling the software as a product or part of a product.  But the source
code *must* be made available.
Jim
Date: 8 Aug 2009 13:54:56
Message: <4a7dbbf0$1@news.povray.org>
Technically, it doesn't, though many distributions provide an EULA of
sorts.  Each component can have its own copyright and license terms.
> giveaway...)
Not really, GNU doesn't necessarily imply GPL (though it's certainly most
likely).  Could be LGPL as well.  But also most include Firefox or
Mozilla, which are MPL.
Jim
Date: 10 Aug 2009 15:14:15
Message: <4a807187@news.povray.org>
Linux, as a *kernel*, of course has a license. It's the GPLv2.
A GNU/Linux operating system distribution, to use Stallman-compliant
terminology nitpicking, is a package of a lot of software that may each
have its own licensing.
Date: 10 Aug 2009 15:16:20
Message: <4a807203@news.povray.org>
> giveaway...)
They want to call the common operating system GNU/Linux because it's a GNU
operating system running the Linux kernel. It has nothing to do with the
Linux kernel license.
Debian GNU/kFreeBSD is a GNU variant with the FreeBSD kernel, which is not
GPL-licensed.
Date: 10 Aug 2009 15:41:43
Message: <4a8077f7$1@news.povray.org>
True, though it is commonly referred to as "the Linux kernel" - the usage
Andy wrote about (GNU/Linux) is a system, components of which are under a
variety of licenses. :-)
Yup.  :-)
Jim
Date: 10 Aug 2009 16:07:42
Message: <4a807e0e@news.povray.org>
> GPL-licensed.
  Before Sun Microsystems made their Solaris operating system open source,
was there any free Unix-based operating system out there which was *not*
based on GNU? Was there even any which was not based on gcc and its system
libraries?
Date: 10 Aug 2009 16:48:39
Message: <4a8087a7$1@news.povray.org>
Am Mon, 10 Aug 2009 16:07:42 -0400 schrieb Warp:
>> not GPL-licensed.
>   source,
> system libraries?
Didn't some BSD variants came with at least their own binutils at some
point? As far as I understand the BSD variants are historically not GNU
systems in the sense that they were developed by the FSF as a free OS -
even if they use GNU software as compilers today.
Date: 10 Aug 2009 16:52:52
Message: <4a8088a4@news.povray.org>
In article <4a807e0e@news.povray.org>,
>> GPL-licensed.
> libraries?
How much non-gnu must a system be to be non-gnu? I think the answer
here is all BSD systems which were free. At least today, you can run a
BSD system without most GNU software, but it will be a pity to miss
out on a whole lot of good software. For instance, forget the GCC.
But, strictly, I think the BSD systems could run on their own, even if
compiled by GNU.
(*) Changing subject
Although I see no problem in discussing terminology, I must say that
when discussing merits, we defeat the purpose of the Free movements.
They want things to be Free. Most people will agree on the very
fundamental principles; Freedom, Openness, et cetera. Then they fight
on petty issues, and segregate. Then everyone loses.
My most favorite example is the set of DJB tools. In 1996, I think, I
believe qmail was already released. The best mailer around. Until
today, no important system brings it default. The best UNIX mailer,
not included.
``Of course! It is not Free.'' (Now it is, but it wasn't.) Let's see
what it has always been, though. It has always been best, open, and
allowed anyone to make changes to it through patches, which allows you
to change it entirely. But somehow this was never enough.
On the bright side, such pressure made him change his mind. Many
packages are now public domain, which was the very Right Thing to do.
His other options were BSD or GPL or similar ones.
(*) The ridiculousness of the BSD license
The BSD license is the most ridiculous one around. It can be called
the superfluous-egotistical-public-domain-license.
Superfluous. If your software is popular, your name will never really
be disassociated with it. Who is behind tetex, or texlive? No idea.
But Donald Knuth is certainly the tex guy.
Egotistical. Kill people with my software, but keep my name on it.
Please please please, keep my name on it. I can't bare the liberty of
other people removing my name from my work.
Public domain. Do whatever you want with it. Such as kill people or
close your derived work.
I'm glad to say I cloned a BSD system and built it with qmail default
delivering outgoing mails only, dnscache caching resolutions for local
requests only, with daemontools included running svscan upon boot, and
ucspi-tcp ready to work. Manuals included. I also implemented my
favorite installation procedure:
   install <cd> <disk>
Zero questions asked. :-)
As far as I'm aware, it's the only UNIX system running the best
mailer. Who would've thought this'd be true still in 2009.
Date: 10 Aug 2009 18:01:36
Message: <4a8098c0@news.povray.org>
  Which compiler they used to compile themselves, if not gcc?
(I'm just being curious here, because I don't know.)
  I don't think using the term "public domain" with the BSD license is
correct. The license doesn't remove copyright, which is what "public
domain" means.
  (In fact, most western legal systems don't support the concept of
"removing copyright" from a work at all. In other words, the idea of
publishing something "into the public domain" is not supported by law.
There is no legal mechanism to do that in most countries, AFAIK. Copyright
is not only automatic, it's in fact inevitable. You can't get rid of it.
  The only case where a work loses copyright is by natural expiration
(which is a ridiculously long time). Also certain works by the government
itself are automatically non-copyrighted in most countries, and thus
directly in public domain. However, that's it. No other means.)
Date: 10 Aug 2009 18:18:56
Message: <4a809cd0$1@news.povray.org>
Am Mon, 10 Aug 2009 18:01:36 -0400 schrieb Warp:
A search turned up the Portable C Compiler
http://en.wikipedia.org/wiki/Portable_C_Compiler
but it looks that it was quite early replaced by gcc.
Date: 10 Aug 2009 19:56:22
Message: <4a80b3a6$1@news.povray.org>
In article <4a8098c0@news.povray.org>,
Dunno. But I think that is not as relevant as it might seem. You can
run a system without a compiler. You can run a BSD system, without
GCC, even though you might have used it GCC to compile the system.
Obviously, if your system lacks a compiler, that is a serious
handicap.
Just a thought.
> domain" means.
True. Let us see the implications, however. Public domain means it's
yours, as your neighbor's. Do whatever you want with it. BSD means
it's the author's, but you can do whatever you want with it, just like
as if it was yours, except of course that you cannot claim it's yours.
So, take all my money and do whatever you want it, including buy a
house for your to live your entire life and the life of the next
generations. Just always keep a paper in the house saying that the
initial money used was mine.
Everybody knows the Americas belonged to the people living there
before Europeans came on over. (And they didn't slap a BSD type of
license on it.)
This appears to be false. See Hampton versus Paramount Pictures, 1960.
  19 Rights gained under the Copyright Law, 17 U.S.C. 1 et seq., may be
  abandoned. Abandonment of such rights, however, must be manifested by
  some overt act indicative of a purpose to surrender the rights and
  allow the public to copy. National Comics Publications v. Fawcett
  Publications, 2 Cir., 191 F.2d 594, 598.  A.
http://www.altlaw.org/v1/cases/812127
Date: 11 Aug 2009 12:29:41
Message: <4a819c75@news.povray.org>
  But without a compiler you can't create the system in the first place.
And when we are talking about Unix, the language must basically be C, else
you will have a completely crippled system with no support for any third-party
tools.
Date: 16 Aug 2009 18:46:17
Message: <4a888c39$1@news.povray.org>
Technically not. :-)
   "We'd like you to back-port all the changes in 2.0
    back to version 1.0."
   "We've done that already. We call it 2.0."
