POV-Ray : Newsgroups : povray.off-topic : A simple question of GPL Server Time
13 Apr 2026 11:16:33 EDT (-0400)
  A simple question of GPL (Message 1 to 10 of 23)
Subject: A simple question of GPL
Date: 8 Aug 2009 05:40:23
Message: <4a7d4807$1@news.povray.org>
OK, so I have some software released under the GPL, and I don't feel
like reading through 250 pages of dense legalese. So can anybody tell
me... is it legal to use such software for commercial work?
http://blog.orphi.me.uk/
Subject: Re: A simple question of GPL
Date: 8 Aug 2009 06:04:20
Message: <4a7d4da4@news.povray.org>
Yes.
-Aero
Date: 8 Aug 2009 06:05:13
Message: <4a7d4dd9$1@news.povray.org>
> Yes.
Heh. That was easy... :-)
Date: 8 Aug 2009 07:01:35
Message: <4a7d5b0f@news.povray.org>
> Yes.
  Although you should be careful on *how* you use it for commercial work.
  If you simply use the software itself, as an executable program, to do
your job, that's ok. (As an example: If you use Emacs, which is GPL, to
write your emails or programs as part of your payjob, that's naturally ok.)
However, there are other uses which are more restricted. For example, if
you embed the *sources* of the program into your own commercial program,
you'll have to publish your commercial program under the GPL.
  There are also other possible uses for which it's not completely clear to
me what the license demands. For example, if you make your commercial program
to call the GPL program externally, and you distribute this whole thing as one
software package, I'm not exactly sure what the licensing limitations are in
this case.
Date: 8 Aug 2009 07:27:30
Message: <4a7d6122$1@news.povray.org>
This is all I'm intending to do. I want to run GPG so I don't have to
pay money for PGP.
> this case.
Yeah, software licencing can get "interesting" real quickly...
Date: 8 Aug 2009 08:16:57
Message: <4a7d6cb9@news.povray.org>
> pay money for PGP.
  I find your original question a bit strange, really. For instance, Linux
is GPL, yet demonstrably Linux is quite widely used in commercial settings
and for commercial purposes. There are even some companies which actually
sell Linux distros, even though it's GPL (Red Hat being a prominent example).
  From this alone one should deduce that the GPL license certainly doesn't
forbid using GPL software for commercial purposes.
Date: 8 Aug 2009 08:40:20
Message: <4a7d7234$1@news.povray.org>
It's still legal, you just need to meet the requirements ;-).
> this case.
I'm actually not sure either how much you'll need to publish, but it's
still legal when you'll meet the requirements ;-).
-Aero
Date: 8 Aug 2009 10:41:23
Message: <4a7d8e93$1@news.povray.org>
I wasn't aware which exact licence Linux uses. (Although arguably the
fact that they want people to call it "GNU/Linux" should have been a
giveaway...)
Date: 8 Aug 2009 11:36:41
Message: <4a7d9b89@news.povray.org>
In article <4a7d4dd9$1@news.povray.org>,
>> Yes.
Hehe. Well, since people are not giving you an educational argument,
let's give it a try. I think the relevant parts here are (1)
motivation for the GPL, where
  [t]o protect your rights, we need to prevent others from denying you
  these rights or asking you to surrender the rights. Therefore, you
  have certain responsibilities if you distribute copies of the
  software, or if you modify it: responsibilities to respect the
  freedom of others.
which suggests that merely using the program, you don't have anything
to worry about; in fact, in ``basic permissions,'' we are told that
  [t]his License explicitly affirms your unlimited permission to run
  the unmodified Program.
Good. But what is the output of the program and what are you going to
do with it? Careful there. Because
  [t]he output from running a covered work is covered by this License
  only if the output, given its content, constitutes a covered
  work. This License acknowledges your rights of fair use or other
  equivalent, as provided by copyright law.
So a calculator that outputs numbers gives you nothing to worry about
because numbers are uncoverable by federal law. But consider a covered
program that logs in to an ftp site and prints all the GPL covered
code that it finds there. Such output is covered, and it might take
over your proprietary plans if you mix them in a special way.
Date: 8 Aug 2009 12:56:30
Message: <4a7dae3e$1@news.povray.org>
Use *for* commercial work, i.e. as a tool (e.g. compiler) - definitely so.
Use *in* commercial work, i.e. as part of it (e.g. a library) - depends
on your business model: If you can GPL your work and still make money
with it, then yes. Otherwise - definitely no.
Then again, in case of the "Lesser GPL" (LGPL) - definitely yes.
