POV-Ray : Newsgroups : povray.off-topic : A puzzle Server Time
2 Nov 2026 08:53:32 EST (-0500)
  A puzzle (Message 1 to 49 of 49)
Subject: A puzzle
Date: 1 Aug 2009 09:29:00
Message: <4a74431c$1@news.povray.org>
Listening to some music, I observe that most of the drumbeat sounds
appear to be in the region below 200 Hz.
Wolfram Alpha tells me [EVENTUALLY!] that a 200 Hz sound has a
wavelength of about 170 cm.
Question: Since the doorway to be bedroom is less than 170 cm wide, does
that mean those waves can't leave the room? Or does the fact that it's
more than 170 cm tall negate that?
http://blog.orphi.me.uk/
Subject: Re: A puzzle
Date: 1 Aug 2009 09:37:28
Message: <4a744518@news.povray.org>
  I think you have a misconception of what wavelength means. The misconception
probably comes from those 2D drawings of wave functions.
  A sound wave (nor an electromagnetic wave for that matter) is not some
kind of sine wave which goes through the air. The sine wave function you
see drawn on a picture is just the representation of the function which
tells which direction the wave is "pushing" at certain point (and how
"strongly" it's "pusing"). The sine wave drawing is just a graph which maps
time to amplitude ("strength" of the sound wave), it's in no way meant to
represent the *physical* appearance of a sound wave.
  A sound wave is simply a phenomenon of air molecules pushing (and pulling)
adjacent air molecules. The phenomenon traverses through air. The maximum
strength at which this "pushing" happens is the amplitude of the wave, and
the rate of change between "pushing" and "pulling" is the frequency. The
distance between two "pushing" peaks is the wavelength.
Date: 1 Aug 2009 10:45:00
Message: <web.4a7453c2ced82d477cb678b90@news.povray.org>
Neither. It just means that the sound will spread very uniformly in the bedroom:
http://en.wikipedia.org/wiki/Diffraction#Single-slit_diffraction
Date: 1 Aug 2009 13:12:19
Message: <4a747773$1@news.povray.org>
"Orchid XP v8" <voi### [at] devnull> wrote in message
news:4a74431c$1@news.povray.org...
Sound (pressure) waves are longitudunal. You are thinking electromagnetic
waves, which are transverse.
Date: 1 Aug 2009 13:25:27
Message: <4a747a87@news.povray.org>
somebody <x### [at] ycom> wrote:
> You are thinking electromagnetic waves, which are transverse.
  A photon will travel rectilinearly, not in a sine wave pattern.
Date: 1 Aug 2009 13:57:24
Message: <4a748204@news.povray.org>
news:4a747a87@news.povray.org...
Transverse waves doesn't mean that the particle (or force carrier) travels
sinusoidally. In EM waves, field disturbances (E and B) are perpendicular
(mutually and) to the direction of motion. This is all the way back from
classical EM. Photons come in play with QFT with wave/particle duality, but
that still doesn't make EM waves longitudunal. Further, you cannot pinpoint
a photon's trajectory if you precisely know its wavelength (HUP), which of
course doesn't mean photons follow a sinusoidal path, but it makes the
transition from classical to quantum somewhat more intuitive, I think. A
wave packet (short duration in relation to wavelength) with high enough
energy will look just like a classical particle zipping by, but such
characterizations are scale dependent. With everyday EM signals, we are
mostly dealing in the wave realm.
Date: 1 Aug 2009 14:23:32
Message: <4a748824$1@news.povray.org>
Sound waves are longitudinal.
http://www.glenbrook.k12.il.us/GBSSCI/PHYS/Class/sound/u11l1b.html
Hence, they'll fit thru any hole big enough to not diffract the wave as it
goes through the hole.
Light is (essentially) a traverse wave[1], which is why your microwave oven
has little holes in the screen so you can see in without getting fried. It's
working like you think - the light has a frequency high enough that it fits
thru the holes, while the microwaves are bigger and bounce off.
On the other hand, radio waves are *so* big they go thru lots of inter-atom
holes at once (like a wave going past a row of pylons holding up a pier) and
hence will go thru walls where visible light won't.
[1] Of course, it's not a wave, but the math makes it have many of the same
properties as a wave, and this is one of them. That's why polarizers work
such as in sun-glasses. You can't polarize a longitudinal wave.
   "We'd like you to back-port all the changes in 2.0
    back to version 1.0."
   "We've done that already. We call it 2.0."
Date: 1 Aug 2009 14:30:58
Message: <4a7489e2@news.povray.org>
  I don't think it's as simple as the wavelength determining how well
electromagnetic radiation can traverse through matter. For example, x-rays
have a shorter wavelength than visible light, yet x-rays have more penetration
through matter.
Date: 1 Aug 2009 14:33:16
Message: <4a748a6c$1@news.povray.org>
But the math that describes the photon's interaction with nearby photons and
electrons is based on multiplication (and addition) of complex vectors,
which means it behaves as if there are conic-section waves involved,
sometimes. Bascially, any given photon goes straight (until it interacts
with something, at least), but a collection of photons will statistically
have some properties in common with waves because of complex
probabilities[1] involved in the interactions, which is why you get
diffraction and such.
[1] As in, probabilities in which the probability of an event happening is a
complex number (more specifically, a complex vector whose length is <= 1),
and the probability of two events happening is the product of the complex
numbers, etc.  I found it interesting that someone proved that only
1-dimensional and 2-dimensional probabilities are consistent, and you can't
build the same sort of system with (say) 3D vectors.
Date: 1 Aug 2009 14:54:49
Message: <4a748f79$1@news.povray.org>
> through matter.
I think the way it works is this:
X-rays actually are small enough to go between the atoms (altho they'll
still interact with the electrons, which is why metal still stops them,
having a "sea" of electrons on the surface).
Visible light hits (most) atoms and gets absorbed, reflected, etc.
Radio waves are physically bigger than the atoms (and the whole house, for
that matter) so they basically are ghosting along like a car through air.
If you have a stiff screen with water waves going thru, waves much smaller
than the holes will go thru, and waves much bigger than the holes will go
thru all the holes at once and reform on the other side. Waves bigger than
the holes but smaller than two holes will mostly bounce.
The higher the frequency, the "smaller" the photon is physically (as in, the
more precisely you can know its position).
At least, that's the naive layman understanding I use to sound like I know
what I'm talking about in newsgroups. ;-)
Date: 1 Aug 2009 16:44:16
Message: <4a74a920@news.povray.org>
  Of course it gets more complicated when you consider that some materials
let visible light through (such as glass) while other materials don't, even
though their density might be the same.
Date: 2 Aug 2009 05:22:29
Message: <ulma75ptvhc3thp1m82l91eip8ch2th4j4@4ax.com>
On Sat, 01 Aug 2009 14:29:00 +0100, Orchid XP v8 <voi### [at] devnull> wrote:
Sound waves are compressional (is that a word?) and rely on a medium to travel
in.
So tell your mother that she can't possibly be hearing them. ;)
Regards
Date: 2 Aug 2009 09:40:26
Message: <4A75974D.2040501@hotmail.com>
> in.
Because Andy's mum is not a medium?
Date: 2 Aug 2009 10:02:45
Message: <v07b75pgsgngqn8je4ol90nf0mf1ckghap@4ax.com>
>> in.
If she were then Andrew could give her a drink then punch her. Which would be
striking a happy medium. :P
Regards
Date: 2 Aug 2009 10:35:53
Message: <4a75a449$1@news.povray.org>
	Here I'd rather view them as photons, to whom I do not want to attach a
size. Perhaps the wavelength can be used to "fake" a size of the photon,
though.
	Keep in mind that everything I say is a bit of guessing and not
actually studied (well, not all of it at least).
	Essentially, an electron in an atom will usually absorb a photon only
if the photon has an energy such that there is an available energy level
for the electron to go to. For insulators, that means it will (usually)
have to cross the band gap. For metals, there is no (initial) band gap
and so electrons of low frequency are readily absorbed. Perhaps that's
why metals can easily get in the way of radio waves?
	However, I think there are higher bandgaps in metals, and so photons of
a certain energy range will pass through.
	(Insulators also have higher bandgaps).
	There's no "true" reflection. Quoting Wikipedia:
"Light waves incident on a material induce small oscillations of
polarisation in the individual atoms, causing each atom to radiate a
weak secondary wave (in all directions like a dipole antenna). All of
these waves add up to specular reflection..."
	For stuff like refraction, essentially, the material will get polarized
by the fields of the photons trying to pass through it. This will result
in internal electric fields that interact with that of the photon, and
result in a reduced speed, change in direction, etc. Essentially, the
relative permittivity that we used in physics courses is simply a model
of the effect of polarization on the external waves.
	I find it disturbing that Wikipedia's article on refraction has no
actual physical explanation, but I suspect I'm close.
> for that matter) so they basically are ghosting along like a car through
> air.
	For me, I'd prefer to view it more in terms of photons interacting
electrically with the solid (and/or taking into account the band
structure) rather than size. Although as I said, perhaps one could
produce an "effective" size which matches both what you say and the
actual theory - although there may be materials that fail the "size"
theory.
	When I studied solid state physics, we didn't cover interactions with
light. And I never thought to see if there was a pattern between lattice
constants (the spacing between atoms in the crystal), and their band
energies. I actually expect that the relationship between the band
energies/gaps and lattice constant is poor/nonexistent - which may
weaken your approach of using size for intermediate frequencies.
Kotter: "Have you ever considered becoming a vet?"
Epstein: "Uh...Uh no. My brother Sanchez was in the army. Didn't like it
a bit."
Date: 2 Aug 2009 11:01:18
Message: <4a75aa3e@news.povray.org>
  Does science even fully agree on the physics of refraction?
Date: 2 Aug 2009 11:23:44
Message: <4a75af80$1@news.povray.org>
	Don't really know. However, I think it does agree on the physics behind
refractive index. It's just a function of the permittivity, which
electromagnetics precisely describes (in terms of waves). I don't know
if there's a "particle" explanation.
a bit."
Date: 2 Aug 2009 12:51:35
Message: <4a75c417$1@news.povray.org>
> behind refractive index. It's just a function of the permittivity, which
IIRC, it's accurate enough that predictions of refraction based on
permittivity yield correct results, even for fringe cases like negative
or really high indices of refraction.
Chambers
Date: 2 Aug 2009 12:58:19
Message: <4a75c5ab@news.povray.org>
news:4a75aa3e@news.povray.org...
no
Yes, AFAIK, but the "problem" is that there are many levels of
understanding. Our everyday experiences can be a hindrance when trying to
understand things at a more "fundamental" level. Refraction (reflection,
dispersion, ...etc) are all emergent and not fundamental processes in QFT,
for instance. There, all you have are 1) emission of a photon  2) absorption
of a photon and the boring case of 3) unhindered transmission of a photon.
There's practically no common ground as far as the fundamental processes go
with classical wave mechanics. But it turns out, that within applicable
domains, their conclusions/predictions agree, and where they don't, we
realize we are out of the respective applicable domains.
Date: 3 Aug 2009 10:30:01
Message: <web.4a76f3c5ced82d47a107abcd0@news.povray.org>
Even this is only the case because the screen is conductive.
Date: 3 Aug 2009 11:05:01
Message: <web.4a76fc61ced82d47a107abcd0@news.povray.org>
There's another thing that takes effect in these scenario, and that's quantum
effects: Electromagnetic waves transmit energy in "standardized" packets, with
the energy of a single packet being dependent on the wavelength. Similarly, the
energy levels in whatever it interacts with are quantized, and in order to
interact, the EM packet's energy dose must be fitting to bring the "target's"
energy to a higher "valid" level.
Radio waves are too weak to interact with atomic particles presently bound to an
individual atom, and therefore can only interact with free electrons - which is
why they zip straight through insulating materials without effect, but readily
interact with conductors.
Visible light waves are strong enough to "kick" around electrons within an
individual atom, but they're too weak to kick it "loose" and impart any excess
energy to it as kinetic energy, so they are particularly picky what materials
they will interact with.
X-Rays are strong enough to kick eletrons loose from atoms, and any excess
energy will simply be converted to kinetic energy of the electron, so they will
interact with everything, just depending on the material density.
Try, and you'll see it's not true. In water, the ratio of pass-through vs.
bounce is primarily a matter of size of holes vs. size of non-holes.
Date: 3 Aug 2009 12:20:37
Message: <4a770e55$1@news.povray.org>
> effects:
Thank you for that excellent clarification. :-)  Or, rather, correction.
Date: 4 Aug 2009 03:14:24
Message: <4a77dfd0@news.povray.org>
> Wolfram Alpha tells me [EVENTUALLY!] that a 200 Hz sound has a wavelength
> of about 170 cm.
No.  Anyway sound goes through solid things as well as air so even if it
couldn't go through the gap it would go through the wall itself.
Try producing a tone that has the exact wavelength of the distance between
your speakers and the doorway :-)
Date: 10 Aug 2009 05:21:44
Message: <4a7fe6a8$1@news.povray.org>
>> does that mean those waves can't leave the room?
OK... but presumably the velocity of sound inside a brick wall is
different to free air, so there would be some kind of diffraction effect?
Date: 10 Aug 2009 05:23:56
Message: <4a7fe72c$1@news.povray.org>
...all of which is true. However, a simple experiment with a wavetank
quickly demonstrates that, for some reason that I don't comprehend,
large waves won't go through small gaps, and yet small waves will. This
is the precise opposite of what you would expect, but the results are clear.
(This also explains why animals that use echo-location use such
high-frequency sounds; they give better spatial resolution. I might even
go as far as to say that's why electron microscopes give better
resolution than light microscopes...)
Date: 10 Aug 2009 05:46:55
Message: <4a7fec8f@news.povray.org>
Probably, along with all the echo paths and different attenuation amounts of
different materials at different frequencies it probably explains why music
sounds horrible from the next room :-)
Date: 10 Aug 2009 05:58:00
Message: <4a7fef28@news.povray.org>
>>> it couldn't go through the gap it would go through the wall itself.
> amounts of different materials at different frequencies it probably
> explains why music sounds horrible from the next room :-)
It doesn't sound *that* bad. But there is a quite pronounced decrease in
bass as I walk through the doorway. You listen to the music and you
think the neighbors will be banking on the wall any minute now, and then
you step just outside the door and it suddenly seems radpically less
loud. I don't know if it's because you're out of line-of-sight with the
speakers or the width of the doorway or what...
Date: 10 Aug 2009 06:19:45
Message: <b1tv755bq6gejqkqc7qh0rfqc2iu1avffl@4ax.com>
Probably due to reasonable sound insulation of the walls and floor. I've lived
in flats where you would think that your neighbours were sitting in the same
room.
Regards
Date: 10 Aug 2009 07:56:25
Message: <4a800ae9$1@news.povray.org>
In article <4a744518@news.povray.org>,
Did you read one or more books that explain this and possibly more
with this level of clarity and language (more or less)? Could you cite
their names?
How come molecules "push" and "pull"? How come the strength varies?
I'd first think that it always gets weaker.
Date: 10 Aug 2009 08:33:31
Message: <4a80139b@news.povray.org>
The "push" and "pull" Warp is referring to (I guess) are the forces caused
by a pressure difference.  This causes the next "bit" of air to be moved,
thus creating another pressure difference, and the next bit moved, etc, this
is how the wave propagates - it's the same as a longitudinal wave in a
slinky spring.
Of course at a molecular level "pressure" is caused by colliding molecules
etc, but I don't think you need to work at this level of detail to model how
sound waves propagate, you can just assume that each bit of air has a
pressure, and pressure differences will generate forces.
Date: 10 Aug 2009 09:37:16
Message: <4a80228c$1@news.povray.org>
In article <4a80139b@news.povray.org>,
> slinky spring.
Alright. But I guess my question is how do I distinguish, for example,
a push from a pull. Should it all be just forces pushing one another?
But I guess when we talk about pressure, then a context in lower
pressure can be seen as pulling a context in higher pressure. Is that
the sort of pull that we're talking about?
Date: 10 Aug 2009 11:50:36
Message: <4A8041CB.10803@hotmail.com>
> room.
The sitting would not be the real problem I guess.
Date: 10 Aug 2009 12:01:50
Message: <4a80446e$1@news.povray.org>
Strictly speaking, with pressure there's only "push", with "pull" being
actually a push in the opposite direction:
(1) Pressure differential exerts a "pushing" force from high-pressure to
low-pressure region
(2) Pushing force accelerates medium in the gradient zone, speeding it
up until the pressure differential is compensated
(3) Inertia of the accelerated medium causes "overcompensation" of the
(4) Pressure differential is now reversed -> back to (1), now with
opposite direction
This is all that happens locally; at a larger scale, this will cause the
pressure differential to propagate through the medium as a wave.
Date: 10 Aug 2009 12:10:43
Message: <ajh085tqg9q9stc8cevv8qsj7i5shrs6be@4ax.com>
>> room.
Indeed not! Thanks to the walls and the lack of a blunt instrument, I'm still at
liberty :)
Regards
Date: 10 Aug 2009 14:11:20
Message: <4a8062c7@news.povray.org>
  The "push" and the "pull" are differentiated by the direction in which
the effect propagates. Also a "push" is a higher pressure wave which moves
towards some directin, while a "pull" is a lower pressure wave which moves
in that same direction.
  This can be visualized by imagining a long string of small spheres, each
sphere being connected to the next with a spring. If you push the first
sphere, it will push the next sphere (through their connecting spring),
which will push the next one, and so on. Overall this causes an advancing
phenomenon which traverses through the entire string.
  If you *pull* the first sphere, it will pull the next one, which will
pull the next one, and so on. Again, the overall effect advances in the
same direction and the pushing did.
  If you think what a loudspeaker does, it's exact that: By using air
pressure it "pushes" and "pulls" air alternatively. When it does so in
fast succession, our ears perceive these differential waves as sound.
Date: 10 Aug 2009 19:25:26
Message: <4a80ac66$1@news.povray.org>
It's because you're out of line-of-sight of the speakers.  They can't be
bothered to sing to you if they can't *see* you.  They're even less
intelligent than the Bugblatter Beast of Traal, so closing your eyes
where they can see you doesn't work as a noise-silencer.
Tim Cook
http://empyrean.freesitespace.net
Date: 11 Aug 2009 03:02:17
Message: <4a811779$1@news.povray.org>
> clear.
Hum... I hate to admit this, but it seems you're right: I just hacked
together a POV-Ray script to simulate a wavetank-kind-of-apparatus (very
idealized, but still...), initially to disprove your statement - only to
find that indeed small gaps will not let low-frequency waves pass.
Changes in gradient will pass through - but not oscillations.
Date: 11 Aug 2009 04:20:17
Message: <4a8129c1@news.povray.org>
Speaking of pressure, this visualization attempt is flawed. I repeat:
Strictly speaking, there's no such thing as a "pulling" force in air.
A proper way of visualizing it would be an arrangement of *loaded*
springs: If you displace the first sphere towards you, it will still
"push" the next one - but less so than the opposing push from the third
sphere, so the second sphere will give way towards you. Similarly, the
third sphere will then be pushed towards you by the fourth one, and so on.
Date: 11 Aug 2009 04:51:06
Message: <4a8130fa@news.povray.org>
Sure there is.  Ever heard the phrase "nature abhors a vacuum"?  That's
a pulling force.  Any decrease in pressure in an atmosphere will cause
molecules to be drawn to the source of the pressure difference.
Tim Cook
Date: 11 Aug 2009 06:01:34
Message: <4a81417e@news.povray.org>
>> This is the precise opposite of what you would expect, but the results
>> are clear.
Weird, isn't it?
Date: 11 Aug 2009 07:44:59
Message: <4a8159bb$1@news.povray.org>
"Natura abhoret vacui" is a very old misconception. At 0 degrees Kelvin,
nature has no problems with vacuum.
What is commonly percieved as a pulling force of the vaccum is in
reality a stronger pushing force (due to collisions of molecules) from
the high-pressure region than from the low-pressure region. As a matter
of fact, *both* exert a pushing force.
Date: 11 Aug 2009 14:25:12
Message: <4a81b788$1@news.povray.org>
On 08/11/09 03:51, Tim Cook wrote:
> Sure there is. Ever heard the phrase "nature abhors a vacuum"? That's a
	That's a push, not a pull.
	If you dip a straw into a glass of water, and "suck", all you're doing
is forcing your diaphragm to go down a bit, causing your lungs to
expand. This creates a region of low pressure in your lungs, and the
atmospheric pressure *outside* is what will actually push the water into
your mouth - it's a push by the atmosphere, not a pull by you.
Whose cruel idea was it for the word "Lisp" to have a "S" in it?
Date: 11 Aug 2009 21:39:39
Message: <4a821d5b$1@news.povray.org>
> doing is forcing your diaphragm to go down a bit, causing your lungs to
*thinks about it*  Seems to me like six of one, half-dozen of another,
but then again, centrifugal force is a nonexistent force conjured up to
describe motion in a particular frame of reference, too...from an
outside point of view, the math is easier/makes more sense when you
reduce everything to a single set of common elements with no overlap.
But having a word for 'suck' is handy for us lay-people--lets us
describe life in a shorter phrase than "region of low density of
pleasantness at self causes misfortune to be pushed onto me", as "life
sucks".
Tim Cook
Date: 12 Aug 2009 07:59:21
Message: <qjb5851h47av57afcqk5l42gvihri9enr9@4ax.com>
On Tue, 11 Aug 2009 21:39:33 -0400, Tim Cook <z99### [at] gmailcom> wrote:
>"life sucks".
No! Death pushes ;)
Regards
Date: 12 Aug 2009 10:33:34
Message: <4a82d2be$1@news.povray.org>
	Oh sure. If your goal was just to have simple models, then your
interpretation is fine (and even more accurate than centrifugal force).
	Note that I didn't say there _isn't_ a force on your part. Pulling down
that diaphragm requires force - about the same amount of force that the
atmospheric pressure applies to push the air in.
	Same as a vacuum cleaner. The mechanism requires a force/energy to
*push* air out from the back. This causes a vacuum and atmospheric
pressure then pushes the air into the tube from the other end - taking
the mess along with it.
	Well, I didn't imply you don't suck (no pun intended).
	Just think of the process of moving that diaphragm down as sucking
(which it is).
If Wile E. Coyote had enough money to buy all those Acme goods, why
didn't he just buy dinner?
Date: 12 Aug 2009 10:38:52
Message: <4a82d3fc$1@news.povray.org>
On 08/12/09 06:59, Stephen wrote:
> On Tue, 11 Aug 2009 21:39:33 -0400, Tim Cook<z99### [at] gmailcom>  wrote:
>> "life sucks".
> No! Death pushes ;)
Obligatory:
http://www.theatrecrafts.com/humour_darksuckers.html
Date: 13 Aug 2009 04:29:32
Message: <pmj785hdldrkv9lgu54vsmnl15ribfk197@4ax.com>
>>> "life sucks".
>> No! Death pushes ;)
>Obligatory:
LOL
Regards
Date: 14 Aug 2009 16:41:48
Message: <4a85cc0c$1@news.povray.org>
A sound wave can be diffracted, this helps it to travel.
Date: 16 Aug 2009 18:24:42
Message: <4a88872a$1@news.povray.org>
Actually, it does. It like big vacuums better than small vacuums, tho.
http://en.wikipedia.org/wiki/Casimir_effect
