POV-Ray : Newsgroups : povray.off-topic : Windows Graphic Programming Server Time
2 Nov 2026 08:49:39 EST (-0500)
  Windows Graphic Programming (Message 1 to 47 of 47)
Subject: Windows Graphic Programming
Date: 30 Jul 2009 15:40:52
Message: <4a71f744@news.povray.org>
This is a spin of pf the "Please tell me it isn't so!" thread and so off
topic to off topic.
Clipka:
>>> > > it's a bit complicated... (Because it *is* a bit complicated.)
David:
>> > If it is (and I can't believe that it's all that complicated), why is it??
Well, exasperated, I'm willing to admit it: Graphics programming in
Windows is
complicated, too complicated to bother with it appears to me. So I guess
I'll have
to admit that Windows programming in a multitasking environment is
*hard* and not
much fun and I can't do it , at least with tools and help I have been
able to find.
Thanks for all the help. If anyone knows anything that might help me dig
into it, let me know.
"I'm not smarter than a fifth grader." ;)
(My thought about Microsoft and all its current software are *very*
uncharitable.)
David :)
Subject: Re: Windows Graphic Programming
Date: 30 Jul 2009 16:11:21
Message: <4a71fe69$1@news.povray.org>
Use a higher-level library. Use Tcl/Tk, or Qt, or .NET, or any of the
hundreds of free systems that let you say "create a window X by Y, put an
image there, and give me commands to set colors into pixels."  It's about 10
lines of Tcl code, for example, and probably not a *whole* lot more .NET code.
   "We'd like you to back-port all the changes in 2.0
    back to version 1.0."
   "We've done that already. We call it 2.0."
Date: 30 Jul 2009 16:17:15
Message: <4a71ffcb$1@news.povray.org>
Le 30/07/2009 21:41, David H. Burns nous fit lire :
> topic to off topic.
> Clipka:
> David:
>>> is it??
> Windows is
> I'll have
> *hard* and not
> able to find.
> uncharitable.)
> David :)
Just 0.002€ (yes, only 10% of usual): have a look at fox-toolkit library.
(C++)
Compatible with X11 & Windows, high level enough and yet allowing finer control if
needed.
Date: 30 Jul 2009 16:46:15
Message: <4a720697@news.povray.org>
> uncharitable.)
For example, attached is an old Tcl program that draws fractals on the
screen then saves them as image files. It should still run. (Drawing pixel
by pixel in Tcl is very slow, by the way. You're supposed to use
higher-level objects.)
Also attached is an old OLD Java program[1] which calculates a rather
complex image (sample attached) based on Conway's game of life, but in so
doing draws it on the screen. The things to note is that the main class
inherits from Frame, the update() function (near like 550) and the paint
function (near line 500). The rest is just figuring out what needs to be
painted.  I don't know if this one will still run as-is, but it's basically
the same idea used in most lower-level toolkits.  You create a window, and
when you get the request to paint the window, you get a "graphics" to paint
on which has a bunch of methods you can use to change what's displayed.
You can look at
http://www.java2s.com/Code/CSharp/2D-Graphics/Setimageresolutionandpaintit.htm
for drawing with .NET.  The thing to note is again the class inherits from
"Form", Main() calls Application.Run with a new instance of that form, and
the form overrides the Paint event to also invoke Form1_Paint. Inside the
Form1_Paint routine, you get out the Graphics object and invoke methods on
it for filing rectangles, darwing images, lines, etc whatever else you want.
It's in the docs. Follow the breadcrumbs backwards for examples of how to do
all kinds of stuff.
What more do you need?
[1] Hence the ".JAVa" extension. ;-)
Download 'fractal.tcl.txt' (4 KB) Download 'cavern.java.txt' (18 KB) Download 'cave7.gif' (82 KB)
Preview of image 'cave7.gif'
Date: 30 Jul 2009 18:24:54
Message: <4a721db6$1@news.povray.org>
To be perfectly frank, a lot --or maybe nothing. :)
I must retreat and study these.
David
Date: 30 Jul 2009 18:32:05
Message: <4a721f65$1@news.povray.org>
> (C++)
needed.
David
Date: 31 Jul 2009 13:39:20
Message: <4a732c48@news.povray.org>
http://www.gamearchitect.net/Articles/SoftwareIsHard.html?dupe
Date: 31 Jul 2009 14:27:38
Message: <4a73379a@news.povray.org>
  It actually *is* possible to have software development which produces
(almost) bug-free programs on schedule and within budget. However, getting
to that point is extremely hard and probably prohibitively expensive.
  I loved that one article (which has also been referenced here in the past)
on how software is produced by NASA. The development system is absolutely
draconian and bureaucratic, where not a single feature or even line of code
is added, removed or modified without the change being carefully documented
and passed through an admission process. The rules are mind-numbingly strict
and bureaucratic.
  However, it works. Where projects of similar size in other, more regular
software companies, have something like 5000 bugs found in beta-testing
stage, NASA software projects have something like 5. And not just critical
bugs. *Any* bugs.
  And they *learn* from the bugs. Every time a bug is found in beta-testing,
they carefully study and document the *reason* why the bug got through to
beta-testing in the first place, through all the safeguards and development
methods, and once the reason is understood, these safeguards and methods are
improved so that similar bugs will never pass again undetected.
  (This idea of actually learning from bugs and documenting them in order
to avoid them in the future is actually a superb idea. However, how many
companies do that? I'd say the amount is really, really small. Most developers
just fix the bug and *forget* about it. Then they are doomed to repeat the
same process again in the future in similar situations.)
  And as said, they not only produce virtually bug-free programs, they do
so in schedule and within budget. How many other companies can say that?
  I liked how the article talked about the one guy who was a developer at
NASA, who wanted to go to the software industry where he could develop
software with more freedom, without all the bureaucracy. He got shocked
at how bad software development was elsewhere, and returned to NASA after
a few years.
  Of course getting to this kind of development must be rather hard and
expensive (at least at first). It also requires a kind of mentality and
expertise that most project leaders just don't have.
Date: 31 Jul 2009 14:50:14
Message: <4a733ce6$1@news.povray.org>
I think it's probably similar for a lot of safety-critical code.
The thing about NASA is they have safety-critical code, extremely bad press
when it fails, and a software budget dwarfed by everything else they do.
When the concern doesn't include how much it costs or how long it takes,
it's a whole bunch easier to make perfect code.
Having the same development platform for 35 years can also help, as does
having every bit of specs about how absolutely everything works. And in all
honesty, the programs aren't all that big. How many bugs have you written
because you're using some infrastructure code that isn't documented
correctly and completely?
Which is not to say they're not awesome. I'm just saying they're solving a
different problem than 3DRealms was trying to solve. :-)
http://www.atarimagazines.com/compute/issue132/92_Space_shuttle_techno.php
http://www.popsci.com/node/31716
Date: 31 Jul 2009 15:06:54
Message: <4a7340ce@news.povray.org>
  Btw, it really amuses me when the Moon landing conspiracy theorists make
the point that the lunar lander computers had less computing capacity than
a modern cellphone, like that was some kind of proof that the landings were
impossible.
  These people have clearly not seen any 4k intros (it's really amazing how
much functionality you can squeeze into 4 kilobytes of code), or tried to
find out how much hardware a cellphone really has.
  (Personally I see it the other way around: I'm amazed at how much
computing power there is in a device which you can hold in your hand.
Technology has really taken huge leaps.)
Date: 31 Jul 2009 15:07:30
Message: <4a7340f2$1@news.povray.org>
OK. I admit it programming is hard -- a lot harder than I imagined. It's
much
harder than it used to be, but why? Well there's multitasking, increase
in hardware complexity,
the internet (one has to deal with the possibility that umpteen
advertisers are
going to send unwanted pop-ups to you machine), Microsoft updates every 15
or 20 minutes, viruses (exploiting deliberate loopholes in the Windows
operating system),
to name a few reasons. Does this make difficult programming inevitable.
I suppose it does;
at least it is so and little can be done about it. But I'm not
altogether convinced that this should
make it so difficult for me programming on my own computer largely for
my own use and not
really caring whether I'm connected to the internet all the time.
It doesn't explain why I have had so much difficulty finding
understandable paradigms and
prototypes for WINAPI applications -- though that might be due to the
fact that I don't have
ready access to a large library (or store) where I can thumb through the
programming books.
All this is very educational. :)
David
Date: 31 Jul 2009 16:03:27
Message: <4a734e0f@news.povray.org>
> impossible.
That reminds me:
Someone built a working replica of the guidance computer. Pretty neat!
http://agcreplica.outel.org/
Yeah, I remember the days of intros and such. Always cool to see how
much they could cram into such a small executable.
~Mike
Date: 31 Jul 2009 16:27:29
Message: <4a7353b1$1@news.povray.org>
> much
1) Your programs are bigger. (For example, my Linux boot partition won't
even fit in the address space that CP/M used to allow for a disk drive.)
2) Your programs are way more complex. You're not writing to the screen and
reading from the keyboard any more. Note that stdio programs are just as
easy as they used to be.
3) Your programs depend on a lot more than they used to. You have all kinds
of libraries to do all kinds of things you wouldn't have dreamed of when you
were using an 8-bit computer. You can't port OpenGL to a Z80.
4) Most importantly: Each line of code interacts with other lines of code.
Building 20 houses is 20 times as hard (or less) than building one house.
Building a program 20,000 lines long is much harder than 20x the effort for
a 1,000 line program.
Only if you want to take advantage of it. Find an old copy of MS-DOS, boot
it, and suddenly programming will be easy again.
> I suppose it does;
> my own use and not
Whether you're connected to the internet is irrelevant for your own
programs, unless you're using the internet.
Date: 31 Jul 2009 16:35:00
Message: <web.4a7354487b75ea1f34ae7f580@news.povray.org>
Pfft! That's not a faithful replica: For instance, he didn't use core rope for
ROM, like the original did...
(not that I could blame that guy in any way - that type of ROM required manual
programming - *literally* >_<)
Date: 31 Jul 2009 16:46:31
Message: <4a735827$1@news.povray.org>
Yeah, he also admits to using RAM chips over core.. As well. I'm
guessing it was quicker to use a chip that build a memory core from
scratch ;)
Heh. Bit, by bit... fun stuff.
~Mike
Date: 31 Jul 2009 17:55:02
Message: <4a736836@news.povray.org>
  Well, that depends. If your CLI program wants to eg. take advantage of
multiple processors, it will usually be a bit more complicated. (Although
some programming languages make this a bit easier.)
  A couple of decades ago multiprocessor computers were huge servers which
price started from $100k up, so for regular people it was just a dream.
  (Ok, you *could* write multithreaded CLI programs two decades ago, but
it wasn't as beneficial back then as it is nowadays.)
Date: 31 Jul 2009 18:08:23
Message: <4a736b57$1@news.povray.org>
True. Let's rephrase as "if you want your programs to do the same things
they did under MS-DOS, they're just as hard to write now and no harder."
My point is that programming has gotten easier over time (such as with the
invention of OOD, sophisticated IDEs and debuggers, etc) but the ambitions
have grown greater.
Date: 31 Jul 2009 20:10:17
Message: <4a7387e9@news.povray.org>
> boot it, and suddenly programming will be easy again.
	Are you kidding?
	I'd love to see what happens if I boot MS-DOS on my P4 2.53 GHz. How
will it handle my video card? RAM? I suppose that 640K thing is there,
but what if I want to use stuff like smartdrv and access higher memory?
	Heck, the "complicated" programming of today may be easier than booting
to DOS.
	(And yes, DOSBox is cheating).
Give a man a fish and you feed him for one day. Teach him to use the Net
and he won't bother you for weeks.
Date: 31 Jul 2009 21:26:25
Message: <4a7399c1$1@news.povray.org>
>     Are you kidding?
> booting to DOS.
I suspect that he's kidding, but I've often though about it. Hmm... I
may have an old copy
of DOS, if I can find it, and a computer that I wouldn't be afraid to
try it on. I suspect it won't
boot but it may be worth a try. Finding the disk will be a long term
project, I'll report results, if any,
eventually. But one couldn't use the high resolution graphics -- or
could one??
Of course one can do a certain amount of "system" programming even on XP
and
and it is much easier--and faster. Maybe I should take another look at
that assembly programming
site I ran across a while back.;)
David :)
Date: 31 Jul 2009 21:45:01
Message: <web.4a739d727b75ea1f5ea616ae0@news.povray.org>
> scratch ;)
Quite a deal quicker, I bet... cheaper as well I reckon (let alone that I'd have
no idea where to get some thousand tiny ferrite cores...)
(Interestingly, from all I know, core memory has never been produced with
automated machinery...)
But at least he's using wire-wrap technology. Does anyone happen to know whether
that's still in normal use these days? I heard much to my surprise that it's
more reliable than PCBs, at least when using thru-hole technology...?
Yeah. Probably makes you wish you had listened when your grandma tried to teach
you needlework...
Date: 31 Jul 2009 22:55:00
Message: <web.4a73ad9d7b75ea1f5ea616ae0@news.povray.org>
You'll not run into trouble with *those*:
- Video cards are all still VGA compatible (if only to interface to the BIOS).
- RAM will be 1 MB, minus whatever is occupied by hardware; contiguous memory
will be 640K of course.
- XMS drivers like HIMEM.SYS used Intel's Protected Mode architecture to access
memory above 1 MB; of course the Protected Mode is still there in modern
processors.
However, you forgot one thing that could ruin your day:
.... do you have an old PS/2 keyboard, or is it USB already?
You may also want to think about whether you can access any of the installed
hard drives. NTFS won't do of course, but also FAT32 won't do. Forget LBA mode,
to be DOS-accessible your hard disk partition must be somewhere near the
beginning of the disk and small enough.
To be able to still play around with DOS, on my last computer (Pentium 4, 2GB) I
had installed one of those parallel-IDE-to-CompactFlash adapters, and used an
old 256MB CF card. That, combined with the old PS/2 keyboard and PS/2 mouse,
did the job.
Date: 31 Jul 2009 23:10:24
Message: <4a73b220$1@news.povray.org>
I just booted a Windows 98 rescue floppy burned onto a DVD on a USB keyboard
on an x64 machine with 6G of RAM. Worked well enough to bring up a DOS
prompt and "more readme.txt" worked, so it can't be *too* hard.
No, it couldn't see the NTFS drives. :-)
Date: 31 Jul 2009 23:40:00
Message: <web.4a73b8c57b75ea1f5ea616ae0@news.povray.org>
Yeah, Windows 98 did come with integrated USB support already.
I wouldn't expect MS-DOS 6.0 (for instance) to do the same stunt.
Date: 31 Jul 2009 23:48:50
Message: <4a73bb22@news.povray.org>
> could one??
	Sure you could. 1024x768 on Fractint. And some DOS games. Likely not
easy, though.
When the lion was given his courage, he promptly ate up the Wizard,
Dorothy, the scarecrow and the tinman.
Date: 31 Jul 2009 23:50:54
Message: <4a73bb9e$1@news.povray.org>
	PS/2 (or whatever it's called).
	In any case, aren't there adapters to convert USB to PS/2?
	Never knew what the benefit of a USB keyboard was...
	Along with whether it can handle huge HD's...
Date: 1 Aug 2009 06:41:38
Message: <4a741be2@news.povray.org>
> > could one??
> easy, though.
  One of the major problems nowadays in running an old DOS game from DOS
is that you will most probably not get any sound. While display cards still
preserve old VGA compatibility, most soundcards and soundchips have long
ago dropped any SoundBlaster backwards compatibility. And even if that SB
compatibility could be somehow emulated, I bet you would have to fine-tune
those environment variables settings for hours before you get anything.
(I bet you will never get it working.)
  Also many old DOS games simply crash or hang when run in a modern PC
because modern PCs are so fast that it messes up the timing routines in
those games. The older the game, the more probable that they didn't expect
PCs to become thousands of times faster.
  There may also be other minor problems with XP's and Vista's DOS simulation
which may make the game unable to run or unstable.
  DOSBox has the advantage that it fully emulates a SoundBlaster card with
all the environment variables already set up correctly, so most if not all
DOS games supporting SB will work out-of-the-box.
Date: 1 Aug 2009 06:43:17
Message: <4a741c45@news.povray.org>
  Try hot-swapping a PS/2 keyboard and you'll see the benefit.
Date: 1 Aug 2009 09:48:53
Message: <4a7447c5$1@news.povray.org>
>> could one??
> easy, though.
Yes, I have used that resolution with Fractint,  but the computer was
booted up
in Windows (95? 98?).
Date: 1 Aug 2009 11:00:01
Message: <web.4a7457a97b75ea1f7cb678b90@news.povray.org>
How often a day do you do that on your desktop computer? :P
Date: 1 Aug 2009 11:08:07
Message: <4a745a57@news.povray.org>
  Not often with the keyboard, but I often swap my USB mouse between
my desktop computer and my work laptop. An old PS/2 mouse couldn't be
used like that (and not only because the laptop as no PS/2 port).
Date: 1 Aug 2009 11:30:00
Message: <web.4a745d627b75ea1f7cb678b90@news.povray.org>
The actual benefits are more in that...:
(1) You don't have gazillions of different connectors.
Imagine that in addition to FireWire and eSATA for external bulk memory devices,
network connector for network (of course), DVI and HDMI for display, and
what-have-you-not, you still needed the good old PS/2 for the keyboard, another
(don't mix them up!) for the mouse, parallel port for the printer and EEPROM
flasher and dongles and what-have-you-not, the Gameport for joysticks and MIDI,
and last not least RS232 for the modem and diverse like chip-card readers and
stuff alike.
PS/2 is just two connectors to get rid of, but what sense would it make to
introduce a "universal" peripherals interface to replace a host of other
connectors, but stick with the old ones for keyboard and mouse?
(2) You can have multiple keyboards at once, and/or keyboars with non-standard
keys.
Like, for instance, those nifty multimedia keys. Or one of these beasts, for
that matter:
http://catalog.belkin.com/IWCatProductPage.process?Product_Id=393741
(Yes, they did similar with PS/2, most notably for joysticks with gazillions of
buttons and switches; but would two of such products from different vendors be
compatible with one another?)
(3) The keyboard can double-feature as a hub to connect other periphery to, like
USB sticks for instance.
Date: 1 Aug 2009 11:40:01
Message: <web.4a74619f7b75ea1f7cb678b90@news.povray.org>
Hum... I guess other people would buy another mouse, right? :P
Date: 1 Aug 2009 14:05:15
Message: <4a7483db@news.povray.org>
This was the rescue disk, which was basically an MS-DOS disk. You got a
command prompt so you could run chkdsk and fdisk. No extra drivers.
Now, it's possible the BIOS is taking the USB and putting it out to the
appropriate BIOS calls.  I suspect that's what "legacy USB emulation" means
in the BIOS settings.
There were no graphics or mouse or anything involved. Since the topic was
the complexity of graphics programming, I just checked to see if the command
line came up and ran.
Date: 1 Aug 2009 14:07:52
Message: <4a748478$1@news.povray.org>
Yes. PS/2 is the little DIN plug.  Anyone still have one of the full-size
DIN plugs they used before that?
Sort of. It's more like some keyboards are built to recognise that plug
being on there and switch to sending PS/2 signals. You can't take every USB
keyboard and use it with the adaptor.
You can have more than one, you can put it on a hub, you can hot plug it
between machines, and you need less driver software to use it from scratch
assuming someone already gave you a USB driver.
For the average desktop user? Not a whole lot.
Date: 1 Aug 2009 14:21:54
Message: <4a7487c2@news.povray.org>
  Mostly useless, though. If you connect eg. a USB mouse to a Win98 system,
chances are that it won't work. (You have to install some driver.)
Date: 1 Aug 2009 14:23:15
Message: <4a748812@news.povray.org>
  My keyboard is so old that it has one of the big plugs. I have to use an
adaptor to connect it to a modern PS/2 connector.
Date: 1 Aug 2009 14:46:19
Message: <4a748d7b$1@news.povray.org>
Yeah, I have one of those left too, but I don't use it any more.
I recently spilled on my usual keyboard, so I switched to another I had
sitting around.  I hadn't realized how much I touchtype even things like
"home" and "end" and "page down".  For several days I was hitting "insert"
instead of "home" because the block of keys is across instead of down on
this one.
Date: 2 Aug 2009 02:31:58
Message: <4a7532de$1@news.povray.org>
> Windows is complicated, too complicated to bother with it appears to me.
This is why I use OpenGL for graphics.
John
Date: 2 Aug 2009 10:01:54
Message: <4a759c52$1@news.povray.org>
	I'm not understanding why.
	I've tried this on Linux on my office machine, and it worked just fine.
	The problem usually is that if you load X without the mouse plugged in,
then you'll need to reload X to get the mouse working. However, if you
loaded X with the mouse, and then switch the mouse in the same session,
it works fine.
Kotter: "Have you ever considered becoming a vet?"
Epstein: "Uh...Uh no. My brother Sanchez was in the army. Didn't like it
a bit."
Date: 2 Aug 2009 10:04:56
Message: <4a759d08@news.povray.org>
	So in other words, it's merely for manufacturer convenience?
> keys.
> that matter:
	USB is not needed to get those multimedia keys. My keyboard is PS/2 and
it has them.
	I suppose if I think really hard, I'll come up with a need for more
than one keyboard...
	True, but that usage seems rare. I can't recall seeing a keyboard that
had this - although I don't doubt their existence.
a bit."
Date: 2 Aug 2009 10:30:29
Message: <4a75a305@news.povray.org>
  If I unplug and re-plug my PS/2 keyboard, it won't work, neither in Linux
nor in Windows. I have to reboot.
Date: 2 Aug 2009 11:31:09
Message: <4a75b13d$1@news.povray.org>
	Just tried it right now (30s unplugged). Plugged it back in. Works
fine. Could this be a kernel thing? Perhaps my kernel is more recent?
dmesg doesn't show anything...
	OK. Weird. I just unplugged again and replugged it in within 2-3
seconds, and the keyboard didn't work. I unplugged it and waited over 45
seconds, and plugged it back in. It works now. No reboot, no reloading of X.
a bit."
Date: 2 Aug 2009 14:01:02
Message: <4a75d45e$1@news.povray.org>
Which leads to cheaper machines, yes. Especially laptops, where space around
the edge is limited. Plus, I'm not sure how docking/undocking would interact
with such.
> and it has them.
Correct.
Different keyboards with different sets of keys, like a music keyboard
perhaps. (Not what was meant, but you see what I'm saying - specialized key
layouts, etc).
And, of course, docked laptops.
> that had this - although I don't doubt their existence.
I had this built into a monitor once. Was weird. Never used it.
I'd surely use a USB thumbdrive port built into my keyboard.
Date: 2 Aug 2009 15:25:42
Message: <4a75e836$1@news.povray.org>
> around the edge is limited. Plus, I'm not sure how docking/undocking
> would interact with such.
<snip>
	As I never owned a laptop, I can see why I never saw much of a need for
USB keyboards...
a bit."
Date: 3 Aug 2009 10:20:00
Message: <web.4a76f1647b75ea1fa107abcd0@news.povray.org>
Me!
Only via an adapter though; don't want to swap my good old Cherry keyboard with
anything else. At least not until I come across something that's really worth
it.
(BTW, strictly speaking, PS/2 was an 80286-based PC series by IBM, which
happened to introduce those "mini-DIN" plugs, hence the colloquial name.)
Date: 3 Aug 2009 10:24:43
Message: <4a76f32a@news.povray.org>
  According to wikipedia PS/2 is not designed to be hot-swappable, and
whether it will work after a hot-swap depends on the hardware and software.
It even warns that on older PCs hot-swapping a PS/2 device might even damage
the circuits.
Date: 3 Aug 2009 14:15:00
Message: <web.4a7728a37b75ea1fa107abcd0@news.povray.org>
Maybe because the hardware wasn't designed to inform the software of a plug-in
event, so the OS (well, keyboard driver, to be precise) needs to poll at
regular intervals to detect the keyboard was absent, in order to re-initialize
the hardware?
