POV-Ray : Newsgroups : povray.off-topic : Something from Nothing? Server Time
31 Jul 2026 11:20:50 EDT (-0400)
  Something from Nothing? (Message 1 to 10 of 25)
Subject: Something from Nothing?
Date: 25 Jul 2009 18:58:54
Message: <4a6b8e2e$1@news.povray.org>
What is it with the creationists who as "do you believe nothing came from
something?"
Why do they think there's evidence the universe ever didn't exist?
Often creationists will say "matter can neither be created nor destroyed,
hence God must have created it."
If you don't accept that, but if you instead think there are natural
situations under which matter can be created, then there's no need for God
to answer the question "can everything come from nothing".
If you *do* accept that, then there's no reason to believe there was ever
"nothing" to start with.
Think about the Big Bang, and how we know about it. Stars are spreading
apart, and the farther away they are, the faster they're moving away.
Logically following back in time, that means all the stars were squished
together some billions of years in the past.
Now, if you believe the universe is closed (i.e., has enough matter that
there's a bounded amount of space), then this means that all matter was
squished into the minimum amount of space possible. If there were areas
where it couldn't be squished further, gravity would quickly iron them out.
  (Indeed, this is the cause for the interest in the details of the
variations of the background radiation - why is it irregular, if everything
started out uniformly?) It does *not* mean there was nothing. Instead, it
means there was *everything*.  The entire universe was uniformly packed as
absolutely chock full of matter as possible.
If you believe the universe is open (i.e., that space is flat and infinite),
then following back in time just means that everything comes together into
an infinitely large infinitely dense universe of matter and energy. Actually
quite 100% opposite of "nothing". This may seem nonsensical unless you're
used to dealing with infinitites, but if you imagine stars coming closer
together and there's always more stars to replace the ones coming in from
far away, it makes perfect sense, just like there's the same number of even
integers as there are integers.
In neither case does the Big Bang imply "nothing," any more than a
demolition of a building implies the rubble came out of "nothing." There's
no "common sense" reason to believe there was ever a time when there was
"nothing," and the very idea that there was "time" without "something" is
nonsensical. After all, if you're going to argue religion based on the Big
Bang, you ought to be accepting the rest of General Relativity too. As far
as I know, there's no scientific reason to believe there was ever a time
when there was "nothing" either.
   "We'd like you to back-port all the changes in 2.0
    back to version 1.0."
   "We've done that already. We call it 2.0."
Subject: Re: Something from Nothing?
Date: 26 Jul 2009 01:08:04
Message: <4a6be4b4@news.povray.org>
You start with questions. Are you looking for answers or do you only want
to preach. If the latter, have at it to your heart's content. If the
former, though
this may be "off-topic", I and probably others may be able to suggest
answers--
or maybe more questions. :)
David
> from something?"
> destroyed, hence God must have created it."
> God to answer the question "can everything come from nothing".
> ever "nothing" to start with.
> out.  (Indeed, this is the cause for the interest in the details of the
> everything started out uniformly?) It does *not* mean there was nothing.
> Instead, it means there was *everything*.  The entire universe was
> uniformly packed as absolutely chock full of matter as possible.
> infinite), then following back in time just means that everything comes
> together into an infinitely large infinitely dense universe of matter
> and energy. Actually quite 100% opposite of "nothing". This may seem
> nonsensical unless you're used to dealing with infinitites, but if you
> imagine stars coming closer together and there's always more stars to
> replace the ones coming in from far away, it makes perfect sense, just
> like there's the same number of even integers as there are integers.
> There's no "common sense" reason to believe there was ever a time when
> there was "nothing," and the very idea that there was "time" without
> "something" is nonsensical. After all, if you're going to argue religion
> based on the Big Bang, you ought to be accepting the rest of General
> Relativity too. As far as I know, there's no scientific reason to
> believe there was ever a time when there was "nothing" either.
Date: 26 Jul 2009 03:14:43
Message: <4a6c0263@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:4a6b8e2e$1@news.povray.org...
> something?"
I think even creationists (most anyway) accept that matter and energy are
transmutable, or sides of the same coin, so I'm not sure if that's the
precise form of the statement, or if you are thinking more along the lines
of the first cause argument (
http://en.wikipedia.org/wiki/First_cause_argument , also maybe
http://www.infidels.org/library/modern/theodore_schick/bigbang.html ).
It used to be that time was considered strictly a product of Big Bang, so it
would be meaningless to even ask about such a time or cause. However, it
became more complex sometime recently.
Cause is also a nebulous concept: When you shoot two billiard balls towards
each other, what "causes" the collision? You? Inertia? Motion? At a
fundamental level, collapse of wavefunction is what comes closest to talking
about discrete causes, but even then, such can be seen as incomplete
understanding/modeling on our part. If we consider the combined wavefunction
of you and the billiard balls, there remains no deeper cause of any events
except the existence of the wavefunction itself - attributing discrete
causes to discrete events becomes an artifact of the model/interpretation,
and the non-unitariness of the operation one that of the observer/observed
dichotomy.
In any case, defining as god whatever remains when our understanding stops
back in time, although useless, is not in itself false or inconsistent. It's
when someone claims that that "god" is the same as Allah, God... etc which
assumes personality, wishes, demand, pettiness, vengefulness, caring... etc
that absurdness arises.
Date: 26 Jul 2009 12:40:17
Message: <4a6c86f1$1@news.povray.org>
What I usually hear is "how can something come from nothing?"
However, regardless of the precision of phrasing, it's still not true. And
it's actually pretty easy to measure: small volumes of vacuum have less
stuff in them than large volumes of vacuum.
No, more like
http://en.wikipedia.org/wiki/Something_from_nothing
First cause is something different, that comes after you admit something
can't come from nothing.  I'm also not talking about the question of "*Why*
is there something instead of nothing?"
That's one way of arguing about it.  Another way (which I put up here
recently that nobody even commented on) was that perhaps time slowed due to
the changes in physics (as in, infinite mass making infinite gravity making
infinite redshift making ...) and the universe has always been around, even
tho it only started four billion of *our* years ago.
> However, it became more complex sometime recently.
Sounds interesting! Have you a cite?
I would say it's "false" because that's not what God means. I could define
"apple" as what remains when our understanding stops back in time, but that
wouldn't make me right. :-) Nobody calls it God if it stopped existing when
the universe came into being, except maybe the Mayans.
> It's
Right. That comes after, tho.
Date: 26 Jul 2009 14:42:47
Message: <4a6ca3a7@news.povray.org>
news:4a6c86f1$1@news.povray.org...
http://en.wikipedia.org/wiki/Loop_quantum_gravity
And esp. Section 7 in:
http://relativity.livingreviews.org/Articles/lrr-2005-11/
Date: 26 Jul 2009 14:54:55
Message: <4a6ca67f$1@news.povray.org>
Now my brain hurts. Thanks loads. ;-)
Seriously, cool stuff. I wish I understood it all.
Date: 27 Jul 2009 08:00:01
Message: <web.4a6d96b0a9205ca034d207310@news.povray.org>
> something?"
Whoa.  I've listened to a whole year of Astronomy Cast, and I thought that the
Big Bang *was* about the creation of matter. It is precisely not, as once
described by Cal Thomas, a scenario you seem to agree with, "the explosion of
an eternally existent cosmic egg."
Big Bang = Gen 1:1 = in the beginning, the cosmos [sic] was created.
Date: 27 Jul 2009 12:06:40
Message: <4a6dd090$1@news.povray.org>
The big bang is postulated because everything is moving apart. If you
reverse time, everything is moving back together again. Much like people
knew what temperature was "absolute zero" long before they could get
anywhere close to making it in the lab.
You can have an explosion of an eternally existent cosmic egg without
creating matter. Indeed, if it's eternally existent, that's precisely the
point I'm making.
> Big Bang = Gen 1:1
Well, no. That's exactly my point. In the beginning was *everything*.
Date: 27 Jul 2009 12:36:39
Message: <4a6dd797@news.povray.org>
  Of course it's not just that simple, as many of the features of the
observed universe don't conform to a simplistic Big Bang. This has prompted
refinements of the theory, including the cosmic inflation, which theorizes
that there was a time shortly after the Big Bang when the universe inflated
at an exponential rate. (And no, this doesn't go against general relativity.)
Date: 27 Jul 2009 13:00:46
Message: <4a6ddd3e@news.povray.org>
Certainly. And it turns out that there's a fair amount of heat-like energy
left in a substance at absolute zero, simply due to quantum exclusion and
such. My point was that "everything was all together" was the original
motivation of the "big bang", and not "something from nothing."
If we knew what happened in the first 10^-43 seconds, maybe we'd know where
everything came from, but there's no reason I know of, outside genesis, to
think there was nothing before there was something.
