There are many people who believe that Haskell is a weird and baffling
language. Personally, I think this is untrue. Obviously, I am in the
minority here. But today, I found this:
http://www.e-pig.org/downloads/epigram-notes.pdf
WTF-O-Meter: 11.0
(Calibrated with 2001: A Space Oddessy as the 10.0 reference point.)
If you thought Haskell was far-out, this stuff is just mental. Even I
have only the vaguest comprehension of what the hell they're talking
about. This must surely be the only paper ever to refer to Haskell and
ML as "traditional languages". (Not, say, Java and C...) Truly there are
more things in Heaven and Hell than Man can know! o_O
http://blog.orphi.me.uk/
Heh, but you think C is a weird and baffling language, so it balances
out. ;)
Jim
> out. ;)
Baffling? Yes. Weird? Not so much. Just ill thought out.
Somebody somewhere obviously thought that treating characters and arrays
as the same type was a good idea...
I think that many people who try to understand haskell feel like trying
to understand a paper like that one (even if more practical Haskell
programs are not that complicated).
Will Haskell ever become mainstream? Yes, as soon as highly theoretical
math papers become mainstream. ;)
Sounds like they've reinvented typestate, but I'd have to go dig up my other
technical books from two decades ago to see if their formulae match.
"We'd like you to back-port all the changes in 2.0
back to version 1.0."
"We've done that already. We call it 2.0."
>> out. ;)
Consider when it was created. I'm sure Brian and Dennis (ie, K&R,
creators of the C programming language) would probably disagree with
you. ;-)
Personally, I think it is - data is data is data is data. A "string" is
an array of characters.
Jim
It's tremendously well thought out, actually. It just doesn't do what you
want it to do. But C was much better thought out than a lot of the stuff
that came after it. After all, what did they add to it? ANSI type
declarations. Structure assignment. That's pretty much it on the significant
changes.
There were a number of languages in the 90's less well thought out, wherein
(for example) a leading 0 on a number meant it was octal *even if* you read
it from the terminal, or a \0 meant the end of the string but there weren't
any mem___() functions. Etc.
Characters and arrays aren't the same type. If you look at C and recognise
that every manipulable value fits in a machine word, the type system makes
much more sense. (Broken, of course, with structure assignment, which wasn't
in the original C version.)
Other than "I don't understand the type system" and "they could have done
better if they were writing a different language", what do you think is
poorly thought out? (I'll grant the whole idea of the need for header files
is kind of silly, but there *are* limitations you put on a language whose
compiler has to fit in 32K.)
More to the point, a bit of text is quite literally a "string" of
characters :) Or where did you think the term came from?
And, since characters were represented by bytes at the time, a string
would then be an array of bytes.
Chambers
I know you think you're being funny, but let us examine that claim for a
moment...
SQL is based on some highly theoretical mathematics: the relational
algebra. Everybody thinks they're called "relational databases" because
tables can have "relationships". However, this is false; it's because
"tables" are actually *relations*. You know what the definition of a
relation is?
"A relation is a subset of the extended Cartesian product of the
domains of its respective attributes."
Seriously. That's the definition of a relation. It's a set of tuples. A
Cartesian product. As soon as you start to dig into this stuff, you
rapidly find yourself reading about set theory, predicate logic,
functions and determinents, the relational operators of projection,
restriction and Cartesian product, the algebra of those operations
(i.e., how you can reorder them and still get the same result),
existential vs universal quantification, normalisation rules... and so
on and so forth.
Dr Constable: "Boyce Codd Normal Form states... Andrew!"
Andrew: "...every determinent is a candidate key."
Dr Constable: "...thank you Andrew. What this means[...]"
I have Database Systems by C J Date on my bookshelf. It's freakin' HUGE,
and some of the chapters contain utterly impenetrable mathematics that
even I can't begin to comprehend. (Anybody have any clue how the
relational calculus is different from the relational algebra??)
And yet... relational databases are the most popular kind of databases.
SQL is almost the *only* language for controlling databases. SQL is
basically the relational algebra with COBOL-style syntax. And yet, when
you write some statement in relational algebra, everybody's eyes glaze
over. But write some SQL, and people are much happier.
SQL is actually quite easy to understand. You just need to know about
tables and joins and normalisation and you're basically done. (Obviously
if you're going to make a professional career out of this stuff, there's
a lot more to it than you might think. But the basics are quite easy.)
Tell somebody that it's more efficient to take the disjunction of two
predicates rather than the union of two relations and they look at you
all confused. But tell them to use an OR-clause in their WHERE-condition
rather than doing a UNION query and they usually understand.
It seems to be simply a question of how you dress up the terminology.
You talk about abstract relations and domains and set-theoretic
operations and predicates and people look confused. Talk about SQL
statements and most people seem to not have a problem with it; I guess
because SQL seems far more concrete and "real-world".
All of this makes me wonder... What would happen if somebody designed a
language which was exactly like Haskell, but had syntax like Pascal or
something? What if it didn't use terms like "monad" and "functor" and
"existential quantification", but used something more concrete-sounding?
Of course, the really bizare (and wonderful!) thing about Haskell isn't
its syntax, it's the ways in which you can use it. But I wonder... If
you dressed Haskell up in sheep's clothing, how long would it take
normal programmers to realise that what you're getting them to do is
actually crazy? >:-)
Just for giggles, I'm designing this language. So far I've implemented
half the standard libraries with it. The results are... interesting. The
code becomes 85% more verbose, but I wonder if it makes any difference
to the level of comprehendability.
> other technical books from two decades ago to see if their formulae match.
It sounds interesting and even possibly useful, but... it's
incomprehensible. I can't make much sense out of it. Clearly whoever
wrote this document knows what they mean. Unfortunately they didn't do a
very good job of explaining it! :-P
Yes.
> SQL is
Actually, it's relational calculus with COBOL-style syntax. ;-)
Go for it. Then write a parser to translate it into Haskell.
It absolutely depends on the keywords you use.
If you choose them to match the strict technical terms, then you're lost.
If you manage to choose them in a way that common people can relate to them,
then you may have a fair chance - even if that means picking words that would
be technically imprecise or even outright wrong.
>> (Anybody have any clue how the relational calculus is different from
> Yes.
Care to explain?
>> SQL is basically the relational algebra with COBOL-style syntax.
You know, until I read COBOL, I had no idea SQL looked like COBOL. (OMG,
I think we have reached a tautology here!) But having seen COBOL, SQL
really does seem overly wordy and silly... heh. :-D
>> a language which was exactly like Haskell, but had syntax like Pascal
>> or something? What if it didn't use terms like "monad" and "functor"
>> and "existential quantification", but used something more
>> concrete-sounding?
Heh. Assuming I don't give it a type system which exceeds Haskell's
expressive power. >:-D
But an interpretter should definitely be possible. Especially since it's
easier to parse... ;-) I might even build a debuggar.
Yeah, indeed.
I've come up with a language I'm calling Hax. I haven't finished
figuring out what it looks like or how it works yet. It's basically
Pascal with a few tweaks. And by "tweaks" I mean that the similarity
between Hax and Pascal is like Java vs C++. Superficially, it looks the
same. But if you investigate for more than 5 seconds, you'll discover
that they're actually TOTALLY UNRELATED! >_<
In particular, many of the things that are implicit in Haskell are
explicit in Hax. (E.g., allocating memory is always explicit, no
implicit constructor functions, no currying...) And I'm trying to make
the syntax as non-weird as possible. (No whitespace layout, no obscure
symbols, no little ASCII-art arrows and zigzags.)
Additionally, some of the weirder features of Haskell are missing. (No
more curried functions, no lambda functions, no pattern matching...) It
makes the language less expressive, but no less powerful. And it makes
it far more similar to familiar languages. CASE expressions now look
more like Pascal or C, but with some extra super-powers. Literally, if
you go "hey, this is basically Pascal, but it lets you do these EXTRA
THINGS..." it comes across is kinda neat.
...or I'm delusional, of course. I have noticed that I code certain
examples, look at them and go "hmm, there's no way a regular programmer
would do it THAT way..." We'll see.
Oh, and "monads" are now called "procedures". ;-) This does not
accurately reflect what they are and what they do, but it's far more
intuitive to explain.
>> Yes.
> Care to explain?
It's kind of like the difference between functional and procedural.
In the calculus, you say "give me a table with the name, salary, and hire
date from table X and table Y where X.name=Y.name and salary < 500"
In the algebra, you say "join table X and Y, and from that select the ones
where the names are the same, and from that select the ones where the salary
is < 500, and from that project over name, salary, and hire."
Think of SQL compared to something like
(((X join Y) select {salary < 500})
select {X.name = Y.name}) project [name,salary,hire]
Only select, project, and join are defined in the algebra. There's no
"exists" and such.
What - a functional language without lambda functions? C'mon, I always thought
that was the icing on the cake...
I'd love to see such a functional language. Maybe it would help me grok the
concept, too - it somehow feels that functional programming concepts may really
be useful, and that I just didn't manage to really grasp the concepts.
And I mean grasp, not just comprehend from a theoretical point of view.
It's nice to have, but you can live without it. Debatably, not having it
makes things more explicit. In the language I'm designing, you basically
always have to give a function a name before you can call it.
FWIW, I've always thought of curried functions as a syntactic short-cut
as well. It turns out I was wrong; without curried functions, there are
certain programs you actually can't write.
I'm ambivilent about these design choices. I'm still playing with my
options...
(As already stated, no curried functions prevents the definition of
certain operations. Additionally, not having lambda functions and
curried functions means that creating functions is more hard work, and
this somewhat tips the balance of power. It makes you more likely to
define functions directly rather than as special cases of high-order
functions, because it's almost more work to call a high-order function
than to type in the definition directly. This is possibly not a good
idea...)
Well, we'll see. It may be that having everything explicitly spelled out
makes it clearer what's actually going on.
Alternatively, maybe all the syntactic chatter will be so OTT that it
just obscures the meaning.
Or maybe the fundamental problem is that functional programming is just
weird, and no amount of dressing it up will solve that. We'll see... ;-)
>>> Yes.
>> Care to explain?
> hire date from table X and table Y where X.name=Y.name and salary < 500"
> ones where the names are the same, and from that select the ones where
> the salary is < 500, and from that project over name, salary, and hire."
> "exists" and such.
So are the two formalisms of equivilent expressive power?
...so does this qualify me as a haxor? :-D
More like a Haxet :P
Invisible's hacket ;)
Regards
As far as I understand it, yes. They're just different ways of saying the
same thing. It has been a number of years since I've had to deal with the
formalisms of it. Also, there may be differences when it comes to updating
the relations (insert, delete, update, etc), as I don't know just how that's
handled in the formal math of it.
> language.
There are many people who believe that English is a weird and baffling
language.
I kinda like that.
John
As I've rapidly discovered, designing a language like this means that
the syntax tree ends up being *really* complicated!
I mean, your basic Haskell syntax tree consists of a type for
expressions, a type for patterns, and a type for type signatures. And
for that, you get a usable language. (Of course, once you start wanting
classes and infix operators and modules and so on, it starts to get more
complicated. But the basic language is really very simple.)
Hax, on the other hand, requires about four pages of type declarations
to describe its syntax tree. (And, therefore, a similar amount of code
every time you want to process it somehow.) I'm not even sure I've got
it right yet! o_O
Hmm, maybe this wasn't such a sensible idea after all. ;-)
I'm swingin' by my tale in a syntax tree. ;)
Did the original forbidden fruit come from a fault tree?
Is there an icon for Totally unrelated (= out on a limb)? :-P ?
David :)
Maybe you should rename the language "Hoax" :P
(*ducks and runs*)
Considering it's purpose... that might not actually be such a bad idea.
Didn't someone create a computer language based on LOLcat speak?
~Mike
That would be LOLCODE, yes:
http://en.wikipedia.org/wiki/LOLCODE
