POV-Ray : Newsgroups : povray.off-topic : Turing determination Server Time
2 Nov 2026 09:47:34 EST (-0500)
  Turing determination (Message 1 to 50 of 60)
Goto Latest 50 Messages Next 10 Messages >>>
Subject: Turing determination
Date: 22 Jul 2009 09:59:28
Message: <4a671b40$1@news.povray.org>
OK, so Darren will know the answer to this one...
It's common knowledge that if you write an arbitrary program in a
Turing-complete programming language, it is impossible to determine
whether the program will ever halt.
This poses several interesting questions. For example:
- What is the "most powerful" language for which you *can* tell is an
arbitrary program will halt?
- If you have an arbitrary program written in a Turing-complete
language, which properties *can* you determine, and which ones *can't*
you determine?
You can't determine whether the program halts after a finite or infinite
number of steps. But you can trivially determine whether it halts after
less than 1,000 steps. You can't determine if it's type-safe [only
whether it is well-typed according to some more restrictive set of
rules]. Can you determine whether a particular execution path is ever
taken? Or whether a given variable will ever be read/written? You can't
determine whether two programs do the same thing, but can you determine
whether one algorithm is the inverse of another? And so on...
Subject: Re: Turing determination
Date: 22 Jul 2009 10:14:15
Message: <4a671eb6@news.povray.org>
  That's not stated correctly. It's impossible to create an algorithm which
would tell for all possible programs whether they terminate or not.
  It is, rather obviously, possible to create an algorithm which tells for
*some* programs whether they terminate or not.
  In other words, in the generic case the problem is unsolvable, but in
specific cases it can be solved.
  That's completely (and rather trivially) equivalent to the halting problem.
Date: 22 Jul 2009 10:17:50
Message: <4a671f8e$1@news.povray.org>
Right. You can't solve the problem for all possible programs, only for
some of them.
So what's the smallest limitation you could impose on the programs to
make it possible to solve them all?
I had a sinking feeling it might be...
Date: 22 Jul 2009 10:27:23
Message: <4a6721cb@news.povray.org>
  I don't know, but I would bet that if you can't loop nor recurse, that's
a pretty safe bet.
Date: 22 Jul 2009 10:39:04
Message: <4a672488$1@news.povray.org>
I forget what it's called, but basically anything with for loops instead of
while loops does the trick. You have to rule out recursion also.
Essentially, anything with indefinite loops is out, as far as I understand.
> taken?
No. That's called the "printing problem". Put a halt statement on that
execution path.
Put a halt statement everywhere you read or write that variable.
> You can't
No, because then you could determine whether a third program does the same
thing as the first, if they're both inverses of the same program.
See how it goes?
   "We'd like you to back-port all the changes in 2.0
    back to version 1.0."
   "We've done that already. We call it 2.0."
Date: 22 Jul 2009 11:26:41
Message: <4a672fb1$1@news.povray.org>
> of while loops does the trick. You have to rule out recursion also.
So no GOTO then?
Basically, anything where flow control is data-dependent?
>> Can you determine whether a particular execution path is ever taken?
> execution path.
I had a feeling it might be undecidable...
This too.
>> You can't determine whether two programs do the same thing, but can
>> you determine whether one algorithm is the inverse of another?
> same thing as the first, if they're both inverses of the same program.
> See how it goes?
Seems to me that almost anything remotely useful to know is undecidable.
How helpful...
Date: 22 Jul 2009 11:28:29
Message: <4a67301d$1@news.povray.org>
> you determine?
This seems relevant:
http://en.wikipedia.org/wiki/Rice%27s_theorem
Now, if only it wasn't completely incomprehensible...
Date: 22 Jul 2009 12:21:38
Message: <4a673c92$1@news.povray.org>
> a pretty safe bet.
You can loop if you can prove a bound on the looping; i.e., a Pascal style
for-loop, or any loop with a loop variant (in the technical sense of that term).
You can recurse as long as you always have an upper bound on the recursion.
You can also prove it if your language disallows dynamic allocation,
including not having unboundedly-large integers.  Think of some of the
original microcomputer BASIC interpreters, with 26 16-bit variables to work
with. You could still loop forever, but if you run more than 26^2^16 steps,
you're looping.
Date: 22 Jul 2009 12:24:34
Message: <4a673d42$1@news.povray.org>
>> instead of while loops does the trick. You have to rule out recursion
>> also. Essentially, anything with indefinite loops is out, as far as I
>> understand.
> So no GOTO then?
Forward goto, sure. :-)
No. Well, yes, in a sense. You're trying to simplify something that's
already trivially simple, and in so doing just raising questions about what
you mean by your version of the words.  "Indefinite loops are out." A loop
you can't look at and tell at compile time the maximum number of times it'll
loop is an indefinite loop. While loops are not indefinite loops if you can
tell at compile time how often they'll loop: See Eiffel's loops, for example.
Recursion is OK as long as you have an upper bound on how often you recurse,
somehow.
Only on unbounded computers.
Date: 22 Jul 2009 12:29:14
Message: <4a673e5a$1@news.povray.org>
What part do you not understand?
 > for any non-trivial property of partial functions,
A partial function is one that isn't defined for every input value. The way
you model that in a computation is to have the function not return, i.e.,
get stuck in an infinite loop.
 > there is no general and effective method
"general and effective" means it works for all inputs and always returns.
(An "effective" function always returns an answer when computed.)
 > Here, a property of partial functions is called trivial if it holds for
all partial computable functions or for none,
So if some partial functions have that property but not all, it's a
non-trivial property.  A "trivial" property might be that it executes at
least one computation, for example.
 > and an effective decision method is called general if it decides
correctly for every algorithm.
That pretty much sums it up.
Or were you saying the proof is too confusing?
Date: 22 Jul 2009 14:17:59
Message: <4a6757d7@news.povray.org>
I believe it's called a "primitive recursive" language.
This is also relevant:
http://en.wikipedia.org/wiki/Total_functional_programming
Date: 22 Jul 2009 14:18:36
Message: <4a6757fc$1@news.povray.org>
Yes, that rings a bell. :-)
Date: 22 Jul 2009 14:27:42
Message: <4a675a1e$1@news.povray.org>
news:4a671eb6@news.povray.org...
which
Even so, one has to be careful, for it's possible to determine if any such
finite program will halt or not - just run the program until all possible
states would be exhausted.
Date: 22 Jul 2009 14:55:19
Message: <4A676097.3020908@hotmail.com>
On 22-7-2009 18:24, Darren New wrote:
>>>> an arbitrary program will halt?
>>> understand.
>> So no GOTO then?
define forward
> what you mean by your version of the words.  "Indefinite loops are out."
> A loop you can't look at and tell at compile time the maximum number of
> times it'll loop is an indefinite loop. While loops are not indefinite
> loops if you can tell at compile time how often they'll loop: See
> recurse, somehow.
Perhaps also things that are decidable are not really useful to know.
Example: you are going to die. See, not a bit of information added to
the common knowledge, but is was decidable.
Date: 22 Jul 2009 14:58:28
Message: <4A676153.2010902@hotmail.com>
> which
Why would the number of states be finite and why do you assume determinism?
Date: 22 Jul 2009 15:05:45
Message: <4a676309$1@news.povray.org>
Am Wed, 22 Jul 2009 20:55:19 +0200 schrieb andrel:
>>> So no GOTO then?
> define forward
Higher adress than current one in sequential memory?
Date: 22 Jul 2009 15:15:13
Message: <4A676541.4010800@hotmail.com>
>>>> So no GOTO then?
>> define forward
Physical memory or logical?
Date: 22 Jul 2009 15:24:34
Message: <4a676772@news.povray.org>
  A finite program might never exhaust all possible states with unbounded
memory.
Date: 22 Jul 2009 15:27:49
Message: <4a676835$1@news.povray.org>
Am Wed, 22 Jul 2009 21:15:13 +0200 schrieb andrel:
>>>>> So no GOTO then?
>>> define forward
Logical and assuming the program and the MMU doesn't do "nasty" stuff :).
Date: 22 Jul 2009 15:56:12
Message: <4A676EDB.2090603@hotmail.com>
>>>>>> So no GOTO then?
>>>> define forward
I think we can safely assume that the program is in one block, or are
there systems where parts of programs van be in more than one segment?
Also assume that you can not execute something in a data or stack segment.
We have nearly pinned it.
Now we only have to make sure a compiler leaves the order of the
statements in place or it knows compile time where everything will end
up. Shouldn't be too difficult.
Codebuster's verdict: possible.
Date: 22 Jul 2009 17:18:27
Message: <4a678223$1@news.povray.org>
news:4a676772@news.povray.org...
such
possible
> memory.
True in that Turing machines do have unbounded memory. Of course no real
machine does or will.
Date: 22 Jul 2009 17:21:33
Message: <4a6782dd$1@news.povray.org>
"andrel" <a_l### [at] hotmailcom> wrote in message
news:4A6### [at] hotmailcom...
> > which
such
possible
determinism?
The Turing process does not prescribe for true randomness. And with
determinism plus finite resources, states will be finite.
Date: 22 Jul 2009 17:33:20
Message: <4a67859f@news.povray.org>
  That doesn't make solving the halting problem any easier.
  It's like the computational complexity of algorithms: Since an algorithm
will always be run on a computer with limited resources, techincally speaking
that means that all (terminating) algorithms are O(1).
  Of course that's not useful information. It doesn't tell us anything.
The unbounded case is much more informative and useful.
Date: 22 Jul 2009 17:35:48
Message: <4A678634.3050908@hotmail.com>
> such
> possible
>> memory.
A Turing machine with unspecified memory size will do. Aside: Your cell
phone's state space far exceeds the number of particles in the universe
multiplied by the age of the universe measured in Plack times. What was
your point?
Date: 22 Jul 2009 17:48:29
Message: <4a67892d$1@news.povray.org>
Sure it does, if you have a machine to test it on that has exponentially
more memory than the machine it runs on.
If you have a pseudo-Turing machine with 5 states and a binary tape only 10
symbols long, if it runs more then 5K steps, it's never going to halt.
The halting problem is specifically about Turing machines with unbounded
memory, if that's what you mean.  (I know you know this, so I must be
misunderstanding what you mean.)
Maybe you mean it doesn't make practical program analysis significantly
easier to know it's only going to run on a machine with a few gigabytes of
memory?
Good thing that's not how O() is defined. :-)
Date: 22 Jul 2009 17:50:15
Message: <4a678997$1@news.povray.org>
andrel wrote:
>>> So no GOTO then?
> define forward
Such that you never branch to an address you've already executed.
Nah. It's useful to know you haven't violated the type system, and that's
decidable.
Date: 22 Jul 2009 18:05:56
Message: <4A678D44.7050606@hotmail.com>
On 22-7-2009 23:50, Darren New wrote:
> andrel wrote:
>>>> So no GOTO then?
>> define forward
That is a rather useful definition, but it may have to imply that the
code that you jump to is not reachable in any other way. Or perhaps that
is what you want.
> that's decidable.
I seem to remember that type systems had the same complexity as or might
even be Turing machines in themselves, but I assume you know better.
Date: 22 Jul 2009 18:28:57
Message: <4a6792a9@news.povray.org>
  I think it is. The problem "sort 10 elements" can be solved in O(1).
Likewise the problems "sort 1 million elements" and "sort 10^100000 elements"
are both O(1). Any problem on a computer with limited resources is O(1).
Larger O functions come into play only when the resources are unlimited.
  However, it's not at all useful to think of algorithms as running within
limited resources. That doesn't give us any useful information. Computational
complexity analysis only gives useful information when assuming that resources
are unbounded.
Date: 22 Jul 2009 19:21:03
Message: <4a679edf$1@news.povray.org>
>   I think it is. [...]
I'm pretty sure O() is defined as some function whose value exceeds the
measurement of your algorithm as n approaches infinity, with n being the
size of the input (measured in some particular way). So O(n^2) means some
measurement of your algorithm will eventually be and stay below k*n^2 as n
grows without bound.
So if your input isn't unbounded, then O() doesn't make much sense. If your
input is unbounded, then you have an unlimited amount of resources going
into the problem, as input is one of your resources. Certainly you can't
sort an unbounded number of elements without an unbounded amount of resources.
I.e., the way O(n) is usually defined counts "n" in memory, and "n" has to
grow without bound.  (I.e., O(n) usually assumes "offline" work.)
> are unbounded.
Certainly computational complexity analysis gives useful information for
bounded workloads in the sense that an O(lg n) sort is better than an O(n^2)
sort[1], even on smaller workloads. It's not really useful to say sorting 10
million text lines is O(1) because you know you only have 10 million of them.
I think we're still talking silly definitions, tho. We both know what's
going on here. :-)
[1] Modulo ridiculous constants, of course.
Date: 22 Jul 2009 19:22:45
Message: <4a679f45$1@news.povray.org>
> is what you want.
As long as you haven't executed it before you goto it, you're OK. If you
skip forward over something, then branch back to it, then fall into what
you've already executed, you'll execute the same bit of code twice. But you
can't execute it *three* times without branching to something you've already
executed.
It depends on the type system. Some are. Most aren't. I'm talking about the
ones that aren't. :-)
Date: 23 Jul 2009 04:30:47
Message: <4a681fb7$1@news.povray.org>
andrel wrote:
> Aside: Your cell
> your point?
Damn, that's a nice calculation. I wish I had the data to do crap like
that! :-D
Date: 23 Jul 2009 05:01:10
Message: <4a6826d6$1@news.povray.org>
>> that's decidable.
The way I heard it, it is undecidable whether an arbitrary program is
"type-safe". (I.e., it never tries to perform an operation on an
unsuitable type.) So various type systems have been invented where it is
decidable whether a given program is "well-typed" (i.e., it fits the
rules of the type system). Under this definition, certain programs which
are type-safe are rejected as ill-typed because they violate some
restriction of the type system.
In other words, the type system is an artiface invented to turn an
undecidable problem into a decidable one.
For example:
   5 + (if 1 == 1 then 0 else "yellow")
This is type-safe (it produces the answer 5), but most type systems
would reject this as ill-typed.
Of course, by the time you get to Haskell with a few language extensions
turned on, the automatic type inferrence engine is basically a Prolog
program that gets run at compile-time, and can take an unbounded amount
of time (and space) to terminate...
Date: 23 Jul 2009 05:06:27
Message: <4a682813$1@news.povray.org>
OK, so let me get this straight:
If there exists a property that some programs have and some other
programs do not have, it is impossible to tell which programs have this
property.
This seems downright false. For example, some programs contain a
variable named "X", while others do not. Yet it is trivial to determine,
for any possible program, whether or not it contains such a variable. So
this cannot possibly be what Rice's theorum is saying.
Date: 23 Jul 2009 09:44:53
Message: <4a686955@news.povray.org>
  Of course it makes sense. "How many steps are needed to sort an array
of 10 elements?"
  You are basically arguing that "O(1)" doesn't make sense.
Date: 23 Jul 2009 12:27:37
Message: <4a688f79$1@news.povray.org>
> property.
As noted in the first sentence of the Wikipedia article:
"Rice's theorem states that, for any non-trivial property of partial
functions, there is no general and effective method to decide whether an
algorithm computes a partial function with that property."
Wheather or not a program contains a variable named "X" is not a
property of the function which it's computing -- it's only a property of
the program itself so Rice's theorem doesn't apply.  Also note that
generally within this context the functions are assumed to be on the
natural numbers.
Date: 23 Jul 2009 13:14:29
Message: <4a689a75$1@news.povray.org>
> of 10 elements?"
But O() notation is defined as a function related to an "n" input size that
In mathematics, computer science, and related fields, big O notation
describes the limiting behavior of a function when the argument tends
towards a particular value or infinity, usually in terms of simpler functions.
http://en.wikipedia.org/wiki/Order_notation
What's the argument that's tending towards infinity?
No, it makes perfect sense as long as some input value is getting
progressively larger. (Or heading towards a value that takes progressively
more time or space.)  O(1) is the *output* when the *input* grows without
bound. If your input grows without bound, the function isn't meaningful.
Date: 23 Jul 2009 13:16:07
Message: <4a689ad7$1@news.povray.org>
Invisible wrote:
> The way I heard it,
That's my understanding too.
... which is why it so often tickles me to see people complaining about a
language that (for example) won't let you use conditionally-uninitialized
variables, without complaining about it preventing things like ...
Date: 23 Jul 2009 13:27:47
Message: <4a689d93$1@news.povray.org>
> property.
Almost. The "property" is a property of the language the program accepts,
not the program. Note that a "language" in this case isn't the programming
language, but the mapping from inputs to outputs. In other words, a
"property" is a relationship between input and output, not a property of the
text of the program.
A "property" of a program is the subset of all possible functions that has
that property.  The property "halts when given an empty string" is defined
as "the set of all programs that halt when given an empty string." The
property "outputs the word 'green' somewhere" means "the set of all programs
that output the word 'green' somewhere".
The theorem states that you can't tell what properties a function has. In
other words, if you look at a property as a collection of functions that
does *that*, then you can only tell if a function has it or not only if that
set is universal or empty.
Spend a couple minutes looking at the "formal statement".
That's not a property of the program. That's a property of the source code
used to describe the program. The exact same program may or may not have an
X. If you replace X with Y everywhere, the exact same program (defined in
terms of its inputs and outputs) doesn't have an X.
Date: 23 Jul 2009 13:28:49
Message: <4a689dd1@news.povray.org>
> natural numbers.
Or, more precisely, someone has already proven that any possible input and
output can be mapped isomorphically into the natural numbers.
Date: 23 Jul 2009 13:31:24
Message: <4a689e6b@news.povray.org>
  I didn't understand that.
Date: 23 Jul 2009 13:59:34
Message: <4a68a506$1@news.povray.org>
I'm saying O() is defined as "a function that's always bigger than *your*
function, even as the input to your function grows without bound." If your
input doesn't grow without bound, O() isn't well defined.
O() is defined as an asymptotic value. You can't have an asymptote of one value.
It's like asking whether you can solve the halting problem for one program I
give you. That isn't "the halting problem", so the answer is in a completely
different class.
Date: 23 Jul 2009 14:11:02
Message: <4a68a7b6@news.povray.org>
> different class.
  I don't know why, but I'm still understanding that as "O(1) doesn't make
sense".
  The only way for an algorithm to be O(1) is that it does *not* depend on
any amount of input. You seem to be arguing that the O notation does not
describe such algorithms. Thus O(1) is nonsensical.
  But O(1) is not nonsensical. It's commonly used.
Date: 23 Jul 2009 14:34:02
Message: <4a68ad1a$1@news.povray.org>
>> this property.
> accepts, not the program. Note that a "language" in this case isn't the
> programming language, but the mapping from inputs to outputs. In other
> words, a "property" is a relationship between input and output, not a
> property of the text of the program.
> has that property.  The property "halts when given an empty string" is
> defined as "the set of all programs that halt when given an empty
> string." The property "outputs the word 'green' somewhere" means "the
> set of all programs that output the word 'green' somewhere".
> In other words, if you look at a property as a collection of functions
> that does *that*, then you can only tell if a function has it or not
> only if that set is universal or empty.
> code used to describe the program. The exact same program may or may not
> have an X. If you replace X with Y everywhere, the exact same program
> (defined in terms of its inputs and outputs) doesn't have an X.
OK, so Rice's theorum applies only to the input/output behaviour of the
program then?
Does that mean it *doesn't* apply to things like time or space usage?
http://blog.orphi.me.uk/
Date: 23 Jul 2009 14:52:11
Message: <4a68b15b$1@news.povray.org>
> program then?
Correct.  If you have any (computable) bound on the time or space usage,
then it's easy to determine if a given program will exceed those bounds
in computing a function by simply running it and checking (note in the
space usage case you might have to run it exponentially longer than the
space bound).  If the program runs too long or uses too much space, you
can just terminate it and halt, so this property is decidable.
Date: 23 Jul 2009 14:57:30
Message: <4a68b29a@news.povray.org>
>> the program then?
Right. So if I write a pure function (i.e., some code that takes some
input and returns some output but does nothing else - aside from maybe
allocating memory), it is impossible to tell anything about this
function other than how long it's going to take and how much memory it's
going to eat?
Hmm, well that's a fairly dissapointing result. Apparently static
analysis is an entirely hopeless endevour...
Date: 23 Jul 2009 15:04:22
Message: <4a68b436$1@news.povray.org>
> going to eat?
It's slightly worse than that.  You can only *verify* a guess for the
time/space consumption for each input you test.  It's always possible
that the program could be entirely correct but exceed these bounds.  And
really this is only possible through sort of a "cheat" -- there's not
any interesting static analysis going on anywhere in this.
Doesn't mean static analysis can't be useful in practice though.
Date: 23 Jul 2009 15:05:07
Message: <4a68b463$1@news.povray.org>
> sense".
You realize that in O(1), the 1 is the *output* of the analysis, right?
Correct. The algorithm runs the same number of steps regardless of how much
input you give it. That's O(1). "Return the first element in your input" is
an O(1) operation.
No. I'm saying O() is nonsensical if you have an algorithm that only takes a
fixed-size input. O() isn't defined on algorithms that can't handle
unbounded size inputs, since it's defined as how many resources an algorithm
consumes while running on increasingly larger inputs. If it doesn't run at
all on increasingly larger inputs, O() isn't defined.
It's commonly used, but not on algorithms with fixed-size inputs. If you
have a sort that only accepts 10 integers to sort, O() isn't defined,
because O() asks how fast does the algorithm run as you give it more than 10
inputs. If the answer is "it crashes with more than 10 inputs", it makes no
sense to ask how fast the answer comes back.
 > "How many steps are needed to sort an array of 10 elements?"
That's not a question that is answered with O() notation, exactly because
every single operation with a fixed size input runs in the same length of
time, as far as O() is concerned. It's like asking what answer is returned
by a function that gets stuck in an infinite loop. "Answer" isn't defined in
that case.
You may want to say "Any algorithm that only runs on a fixed-size input I
define as running in O(1)", but that's an addition to the defintion that
everyone else uses.
Date: 23 Jul 2009 15:06:40
Message: <4a68b4c0$1@news.povray.org>
> program then?
Basically. It applies to the execution of an abstract program running on a
given input. (I.e., a particular turing machine with a particular input tape.)
I don't know.
Date: 23 Jul 2009 15:11:50
Message: <4a68b5f5@news.povray.org>
> > sense".
  I don't understand that.
> an O(1) operation.
  How is that different from "sort the first 10 elements of the input"
(which is basically equivalent to "sort an array of 10 elements")?
> inputs.
  Hence with your "return the first element in your input" O() isn't defined
either.
Date: 23 Jul 2009 15:12:56
Message: <4a68b638$1@news.povray.org>
> going to eat?
No, you can't tell how long it's going to take or how much memory it'll use.
You can only tell if it's going to take more than X time or more than Y
memory.  You do that by running it until it either halts or exceeds that
limit. (And you can tell if you got in a loop using only a fixed amount of
memory, so that's not hit by the halting problem.)
That's different from figuring out the minimum X time to doesn't take longer
than, for example.
