POV-Ray : Newsgroups : povray.off-topic : Turing determination Server Time
31 Jul 2026 11:28:50 EDT (-0400)
  Turing determination (Message 1 to 10 of 60)
Subject: Turing determination
Date: 22 Jul 2009 09:59:28
Message: <4a671b40$1@news.povray.org>
OK, so Darren will know the answer to this one...
It's common knowledge that if you write an arbitrary program in a
Turing-complete programming language, it is impossible to determine
whether the program will ever halt.
This poses several interesting questions. For example:
- What is the "most powerful" language for which you *can* tell is an
arbitrary program will halt?
- If you have an arbitrary program written in a Turing-complete
language, which properties *can* you determine, and which ones *can't*
you determine?
You can't determine whether the program halts after a finite or infinite
number of steps. But you can trivially determine whether it halts after
less than 1,000 steps. You can't determine if it's type-safe [only
whether it is well-typed according to some more restrictive set of
rules]. Can you determine whether a particular execution path is ever
taken? Or whether a given variable will ever be read/written? You can't
determine whether two programs do the same thing, but can you determine
whether one algorithm is the inverse of another? And so on...
Subject: Re: Turing determination
Date: 22 Jul 2009 10:14:15
Message: <4a671eb6@news.povray.org>
  That's not stated correctly. It's impossible to create an algorithm which
would tell for all possible programs whether they terminate or not.
  It is, rather obviously, possible to create an algorithm which tells for
*some* programs whether they terminate or not.
  In other words, in the generic case the problem is unsolvable, but in
specific cases it can be solved.
  That's completely (and rather trivially) equivalent to the halting problem.
Date: 22 Jul 2009 10:17:50
Message: <4a671f8e$1@news.povray.org>
Right. You can't solve the problem for all possible programs, only for
some of them.
So what's the smallest limitation you could impose on the programs to
make it possible to solve them all?
I had a sinking feeling it might be...
Date: 22 Jul 2009 10:27:23
Message: <4a6721cb@news.povray.org>
  I don't know, but I would bet that if you can't loop nor recurse, that's
a pretty safe bet.
Date: 22 Jul 2009 10:39:04
Message: <4a672488$1@news.povray.org>
I forget what it's called, but basically anything with for loops instead of
while loops does the trick. You have to rule out recursion also.
Essentially, anything with indefinite loops is out, as far as I understand.
> taken?
No. That's called the "printing problem". Put a halt statement on that
execution path.
Put a halt statement everywhere you read or write that variable.
> You can't
No, because then you could determine whether a third program does the same
thing as the first, if they're both inverses of the same program.
See how it goes?
   "We'd like you to back-port all the changes in 2.0
    back to version 1.0."
   "We've done that already. We call it 2.0."
Date: 22 Jul 2009 11:26:41
Message: <4a672fb1$1@news.povray.org>
> of while loops does the trick. You have to rule out recursion also.
So no GOTO then?
Basically, anything where flow control is data-dependent?
>> Can you determine whether a particular execution path is ever taken?
> execution path.
I had a feeling it might be undecidable...
This too.
>> You can't determine whether two programs do the same thing, but can
>> you determine whether one algorithm is the inverse of another?
> same thing as the first, if they're both inverses of the same program.
> See how it goes?
Seems to me that almost anything remotely useful to know is undecidable.
How helpful...
Date: 22 Jul 2009 11:28:29
Message: <4a67301d$1@news.povray.org>
> you determine?
This seems relevant:
http://en.wikipedia.org/wiki/Rice%27s_theorem
Now, if only it wasn't completely incomprehensible...
Date: 22 Jul 2009 12:21:38
Message: <4a673c92$1@news.povray.org>
> a pretty safe bet.
You can loop if you can prove a bound on the looping; i.e., a Pascal style
for-loop, or any loop with a loop variant (in the technical sense of that term).
You can recurse as long as you always have an upper bound on the recursion.
You can also prove it if your language disallows dynamic allocation,
including not having unboundedly-large integers.  Think of some of the
original microcomputer BASIC interpreters, with 26 16-bit variables to work
with. You could still loop forever, but if you run more than 26^2^16 steps,
you're looping.
Date: 22 Jul 2009 12:24:34
Message: <4a673d42$1@news.povray.org>
>> instead of while loops does the trick. You have to rule out recursion
>> also. Essentially, anything with indefinite loops is out, as far as I
>> understand.
> So no GOTO then?
Forward goto, sure. :-)
No. Well, yes, in a sense. You're trying to simplify something that's
already trivially simple, and in so doing just raising questions about what
you mean by your version of the words.  "Indefinite loops are out." A loop
you can't look at and tell at compile time the maximum number of times it'll
loop is an indefinite loop. While loops are not indefinite loops if you can
tell at compile time how often they'll loop: See Eiffel's loops, for example.
Recursion is OK as long as you have an upper bound on how often you recurse,
somehow.
Only on unbounded computers.
Date: 22 Jul 2009 12:29:14
Message: <4a673e5a$1@news.povray.org>
What part do you not understand?
 > for any non-trivial property of partial functions,
A partial function is one that isn't defined for every input value. The way
you model that in a computation is to have the function not return, i.e.,
get stuck in an infinite loop.
 > there is no general and effective method
"general and effective" means it works for all inputs and always returns.
(An "effective" function always returns an answer when computed.)
 > Here, a property of partial functions is called trivial if it holds for
all partial computable functions or for none,
So if some partial functions have that property but not all, it's a
non-trivial property.  A "trivial" property might be that it executes at
least one computation, for example.
 > and an effective decision method is called general if it decides
correctly for every algorithm.
That pretty much sums it up.
Or were you saying the proof is too confusing?
