POV-Ray : Newsgroups : povray.off-topic : Questionable optimizations Server Time
22 Mar 2026 04:27:12 EDT (-0400)
  Questionable optimizations (Message 1 to 10 of 44)
Subject: Questionable optimizations
Date: 17 Jul 2009 19:50:34
Message: <4a610e4a$1@news.povray.org>
Someone recently found a bug whereby a piece of C code read
xyz->pdq = some value;
if (!xyz) return (error code);
do_something_dangerous();
Someone mapped a page into 0, invoked the bit of the kernel that had the
code, and did something dangerous in spite of xyz being null.  It turns out
GCC looks at the test for NULL in the second line, decides that since it has
already been dereferenced in the first line it can't be NULL (or a segfault
would have thrown), and eliminates that test.
Now the question I have is, why in the world would you optimize that test
away? Is using a value and then testing it for null later so frequent that
you need to throw away that test? And if so, wouldn't it be better to simply
warn that it probably isn't what you intend, just like happens with
comparing an unsigned value to a negative number?  I just can't imagine a
situation where the compiler can prove that xyz has been dereferenced
without it being checked yet the null test later isn't indicative of a
programming error.
   "We'd like you to back-port all the changes in 2.0
    back to version 1.0."
   "We've done that already. We call it 2.0."
Subject: Re: Questionable optimizations
Date: 17 Jul 2009 21:33:38
Message: <4a612672@news.povray.org>
... Which should be interpreted as "I recently found a discussion of a bug
that someone else found..." :-)  Just to clear that up.
Date: 18 Jul 2009 07:43:35
Message: <4a61b567$1@news.povray.org>
Darren New wrote:
> .... Which should be interpreted as "I recently found a discussion of a
> bug that someone else found..." :-)  Just to clear that up.
At a guess that would be:
http://www.theregister.co.uk/2009/07/17/linux_kernel_exploit/
John
"Eppur si muove" - Galileo Galilei
Date: 18 Jul 2009 08:00:02
Message: <4a61b942@news.povray.org>
  Why couldn't the compiler assume that if nothing modifies xyz between
the assignment and the test, that it doesn't get modified? It seems to me
like a rather valid assumption.
  The only exception is if xyz is not local to the function, in which case
it might get modified by another thread. But in that case you have to tell
the compiler that it may be modified at any time (by at the very least
specifying that xyz is volatile, although it's better that access to it
is guarded by a mutex lock).
  (Btw, AFAIK the C standard specifially says that a null pointer cannot
contain a valid value. Thus the compiler can assume that it can't contain
a valid value.)
Date: 18 Jul 2009 15:48:20
Message: <4a622704$1@news.povray.org>
Yes, but since that wasn't the point of my question and people might
reasonably assume I'm bashing on Linux if I posted a link to it, I thought
I'd omit it.  The question was why the compiler felt the need for *that*
optimization in the first place. When would it ever be a good idea?
Date: 18 Jul 2009 15:52:01
Message: <4a6227e1$1@news.povray.org>
There's no assumption xyz didn't get modified. The assumption is that since
you referenced it in the first line, the second line will never fail because
the first line would have dumped core.  I.e., if the first line had been
   int pdq = *xyz;
   if (!xyz) do_something();
then the compiler would omit the code to invoke do_something(), as well as
the test. No assignment to xyz, but just a reference.
I'm trying to figure out what possible benefit such an optimization could
have. I.e., this code is obviously *wrong* - why would you bother to include
optimizations to improve the performance of erroneous code?
> a valid value.)
Yep.
Date: 18 Jul 2009 15:54:32
Message: <4a622878$1@news.povray.org>
> a valid value.)
The problem is that in C a null pointer is represented
by 0, but 0 is a valid memory address. So when you
have a valid pointer to address 0, then the optimizer
thinks you are checking for null, not for address 0.
It does seem bad to me to have a so much bloat
in the control switches for the GCC optimizer.
Take a look...
http://gcc.gnu.org/onlinedocs/gcc-4.4.0/gcc/Optimize-Options.html#Optimize-Options
Date: 18 Jul 2009 16:07:40
Message: <4a622b8c$1@news.povray.org>
> by 0,
Depends on the architecture, really, but in most cases, yes.
The exploit was a bug in the kernel that dereferenced a pointer before
checking for null, and the compiler silently optimized out the later check
for null. If you can get the first dereference to work (by mapping some
valid memory to the address associated with the null pointer value) then you
skip over code people thought they wrote into their program and which the
compiler removed.
Tell me about it. Just wait till you have the fun of cross-compiling the
compiler. :-)
Date: 18 Jul 2009 16:13:43
Message: <4a622cf7$1@news.povray.org>
Let's say I wrote a macro that does something that happens to be useful to
me, along these lines:
#define DO_USEFUL_STUFF( OBJECT ) if ( OBJECT ) OBJECT->usefulMethod();
Now, I go and use this macro in different places. In some places, the object
passed is likely to be NULL. In others, it's not. I would be glad that the
compiler is optimizing out the unnecessary checks for me, while still
letting me benefit from the general usefulness of my macro.
Of course this is a contrived example, but it's probably not too far from a
real use case.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 18 Jul 2009 16:58:56
Message: <4a623790@news.povray.org>
> > a valid value.)
  Well, dereferencing a null pointer is undefined behavior, so from the point
of view of the standard the compiler can do whatever it wants. Thus gcc is
not doing anything wrong here (because after a null pointer dereference there
is no "wrong" to be done).
  If someone is to be blamed is the designers of the kernel if they decided
that a null pointer points to a valid address, against the C standard, and
then implemented the kernel in C (using a standard-conforming C compiler).
