POV-Ray : Newsgroups : povray.off-topic : Today's venom: Acrobat Server Time
18 Oct 2026 17:34:58 EDT (-0400)
  Today's venom: Acrobat (Message 1 to 50 of 83)
Goto Latest 50 Messages Next 33 Messages >>>
Subject: Today's venom: Acrobat
Date: 29 Jun 2009 06:44:19
Message: <4a489b03$1@news.povray.org>
Ah, Adobe Acrobat.
Of course, you can obtain Acrobat Reader for free. (What good is an
authoring tool without a ubiquitous platform to deploy for?) But the
full Acrobat package, last time I looked, is about £400.
But what the hell do you actually *get* for your money?
Of course you get the ability to generate PDF files. But you know what?
Any number of freeware tools can do this also. (E.g., Ghostscript can
transform PostScript to PDF. All you need is a PostScript printer driver
- and Adobe just happen to have one available for free download - print
your document to a PS file, and then have GS convert it to PDF. Done.)
My goal today was very simple:
1. Take a PDF file and remove the headers and footers.
2. Overlay one PDF file over another.
That is all. However, it seems that £400 of software is unsufficient to
achieve this trivial goal.
As far as I can tell, Acrobat can rearrange pages, delete pages, insert
pages from other files, and this split or merge seperate PDF files. It
can rotate pages, and it allows you to edit metadata and security
restrictions.
What it does *not* appear to allow is modifications to the actual
contents of the pages. You can add [extremely limited] additional
graphics and text, but you *cannot* remove what is already there. Which
is obviously absurd. You also can't copy content from one page and paste
it onto another page, completely preventing the overlay I want to do.
In short, I've got two digital files in front of me and the premium
editor program for that file format, yet I cannot achieve my trivial
aim. I am actually going to have to PRINT THIS STUFF OUT and play with
glue and scissors. How pathetic.
Subject: Re: Today's venom: Acrobat
Date: 29 Jun 2009 07:04:46
Message: <4a489fce$1@news.povray.org>
I always thought of PDFs as the digital version of print-outs.  Think what
you would do if someone gave you two printed out sheets and asked the
above...
BTW, you might be able to find some software that renders a PDF to an image
file, then use some paint program to do what you want.
Date: 29 Jun 2009 07:07:01
Message: <4a48a055$1@news.povray.org>
Before doing this, you can also simply use the copy tool (the one with
the camera icon). Copy and paste the parts of the documents you need
into a grapical program (or combine them as povray image_maps :-). nd
you're done without scissors.
Thibaut
Date: 29 Jun 2009 07:53:06
Message: <4a48ab22$1@news.povray.org>
They are. Except that unlike a PostScript page description (which is an
unstructured arbitrary Turing-complete program which may or may not
produce an image as a side-effect of its execution), a PDF file contains
sufficient metadata to be easily manipulatable. (E.g., it's not
Turing-complete, it's easy to locate a specific page, it has a bounding
box included, etc.)
> Think
> what you would do if someone gave you two printed out sheets and asked
> the above...
Yeah, well, if digital printouts have only the same functionality as
real printouts, then they're rather pointless. We may as well just use
paper and save ourselves £400. :-P
> image file, then use some paint program to do what you want.
Both Ghostscript and Acrobat will happily transform PDF into a bitmap
image. (Though Acrobat will only produce Windows Bitmap - the most
braindead image format in widespread use.)
The trouble is, then the pages would be bitmap images. That means that I
can manipulate then with IrfanView. On the other hand, it means they'll
either be vastly lower resolution than the original vector graphics, or
they'll be absolutely huge files...
Date: 29 Jun 2009 08:47:01
Message: <4a48b7c5$1@news.povray.org>
> Yeah, well, if digital printouts have only the same functionality as real
Except I can send a "digital printout" to 50 different people in 5 different
countries within a few seconds from my desk, try doing that with real
printouts :-)
What's your printer? 600dpi?  Just convert them into bitmaps using that
resolution and do your work on it, then save them to PDF again.  It's quite
common to work on A4 size at 600dpi on a normal PC these days...
Or, presumably, if you are meant to be modifying these documents, then you
can just ask the original author for the original files to modify?  That
might be easier in the end.
Date: 29 Jun 2009 08:55:51
Message: <4a48b9d7$1@news.povray.org>
> different countries within a few seconds from my desk, try doing that
> with real printouts :-)
Sure. But you don't need Acrobat for that, just Acrobat Reader. We paid
a shedload of money for the full Acrobat Professional package on the
expectation that it would allow us to, you know, *modify* PDF files. :-P
>> I can manipulate then with IrfanView. On the other hand, it means
>> they'll either be vastly lower resolution than the original vector
>> graphics, or they'll be absolutely huge files...
> quite common to work on A4 size at 600dpi on a normal PC these days...
Mmm, A4 at 600dpi. That's going to be a few megapixels...
In the end, I ended up just double-printing the damned thing. Which
meant I had to print it three times before I figured out the paper path,
scaled everything so the new headers don't overprint the document
content, and so on and so forth. All of which would have been *so* much
easier with some suitable software... but hey, Adobe has our money. Why
should they give a damn?
> you can just ask the original author for the original files to modify?
> That might be easier in the end.
Right. Because BackupExec *totally* has options for customising the
header and footer on the job logs it prints out. ;-)
Date: 29 Jun 2009 09:03:49
Message: <4a48bbb5$1@news.povray.org>
Just when you thought your day couldn't get any worse... it does.
I now have to phone a lady who doesn't speak propper English and make
her PC work. Oh, did I mention? She's in a different country...
Yay, me. :'{
Date: 29 Jun 2009 09:12:09
Message: <4a48bda9$1@news.povray.org>
> Yay, me. :'{
I'm almost glad the number doesn't work... :-P
Still, I don't suppose there's any way I can realistically get rid of
this person.
Date: 29 Jun 2009 09:12:13
Message: <4a48bdad@news.povray.org>
Of course.
> We paid a shedload of money for the full Acrobat Professional package on
> the expectation that it would allow us to, you know, *modify* PDF files.
> :-P
Did you read the "features" page of Acrobat Professional?
http://www.adobe.com/products/acrobatpro/features/
I make it 35MP, about 3x what consumer digital cameras are up to now,
shouldn't be a problem to edit a file this size.
> Right. Because BackupExec *totally* has options for customising the header
You mean it only gives you job logs in PDF format?  That's a bit pants.
Date: 29 Jun 2009 09:19:07
Message: <4a48bf4b$1@news.povray.org>
On my old wreck of a PC? It's not going to be much fun...
Actually they're XML files with a custom schema. My guess is that it's
using the Internet Explorer rendering engine to print them. Suffice it
to say, this is a backup program. It has a button marked "print", and
that's basically it. You have no control over formatting. I did,
however, manage get it into PDF format.
(Print to a PostScript printer, send to file instead of the printer, use
Ghostscript to convert PS to PDF. Yay, I have a working PDF file now.)
I stupidly assumed that since we have PDF editing software, it would be
easy to, you know, edit the PDF file.
Date: 29 Jun 2009 09:23:37
Message: <4a48c059$1@news.povray.org>
Yeh you'd think so, but for some reason they seem to want to make it really
hard/impossible to actually modify any detail on a PDF page.  I always
wondered myself if there was any software capable of doing this...
Date: 29 Jun 2009 09:25:00
Message: <web.4a48bfccc3f10ba5fd99d9e0@news.povray.org>
> > Yay, me. :'{
> this person.
I bet that's what the Call Centres in India say about us :)
Date: 29 Jun 2009 09:36:55
Message: <4a48c377$1@news.povray.org>
>> this person.
Hmm. Probably.
Well anyway, I just had a conversation with somebody who doesn't speak
English very well, and doesn't know how to operate a computer. As if
that wasn't bad enough, the phone line kept repeatedly cutting out.
Perfect. :-S
Date: 29 Jun 2009 09:38:37
Message: <4a48c3dd@news.povray.org>
>> be easy to, you know, edit the PDF file.
> really hard/impossible to actually modify any detail on a PDF page.
Pretty dumb really. Especially when PDF has so many enhancements over PS
that should make this kind of thing really easy.
> I
> always wondered myself if there was any software capable of doing this...
In principle it shouldn't be too hard.
In fact, in principle you can ask Ghostscript to convert the PDF into
PostScript and edit the thing by hand. In practice, this turns out to
be...rather hard.
(Not many people know this, but you *can* in fact write PDF files using
only Notepad. You'd have to be insane to try it though...)
Date: 29 Jun 2009 09:43:31
Message: <4a48c503@news.povray.org>
> English very well, and doesn't know how to operate a computer. As if that
> wasn't bad enough, the phone line kept repeatedly cutting out. Perfect.
> :-S
Even better is when their OS isn't in English, then the fun really starts
over the phone :-)
Date: 29 Jun 2009 09:50:02
Message: <4a48c68a$1@news.povray.org>
>> Perfect. :-S
> starts over the phone :-)
The fun is, she couldn't log in because the laptop had a UK keyboard. So
we sent her a French keyboard. Ah, but the laptop still thinks it has a
UK keyboard, so now the keys pressed don't even correspond to what the
keyboard types!
Of course, she changed the regional settings - but only for her account.
That means the Windows login prompt still has the wrong keymap.
Isn't technology wonderful?
Can my day get any worse??
I said CAN MY DAY GET ANY WORSE?!? DO YOU HEAR ME MURPHY!?
Date: 29 Jun 2009 10:00:00
Message: <web.4a48c7bfc3f10ba5fd99d9e0@news.povray.org>
I thought that was the purpose of PDF. Not being able to change documents,
unless you have the original, is perfect for version control.
Date: 29 Jun 2009 10:00:01
Message: <web.4a48c844c3f10ba5fd99d9e0@news.povray.org>
> >> this person.
> Hmm. Probably.
> Perfect. :-S
Welcome to my world ;)
Date: 29 Jun 2009 10:03:23
Message: <4a48c9ab@news.povray.org>
On the contrary, you can build PDF "forms" which can be filled in
electronically and returned. (But only if you have the server-side
technology. Isn't that nice?) The whole marketing for Adobe Acrobat
talks about "collaboration" and exchanging data and vivid, "alive"
documents.
Adobe Acrobat can indeed alter several aspects of a PDF file. Just not
any of the *useful* ones...
We use a 3rd-party product for version control. The files you get from
it might be editable, but the "definitive version" is whichever one
exists in the document control system, so it doesn't matter.
Date: 29 Jun 2009 10:52:45
Message: <4a48d53d$1@news.povray.org>
He heard me.
I was just asked to set up a web presentation. Do you think I could get
the God-damned thing to work?!
First I turned on the laptop, and it spent 20 minutes updating itself.
So rather than having half an hour to get it going, I had 10 minutes. By
this point all the attendees have turned up and their waiting to know
when it'll be working - so no pressure or anything. Not that I've ever
used Live Meeting before. But will it connect the desktop? No, no, and,
er, NO.
So we decide to give up (they don't want to keep the other sites
waiting), and everybody goes home. 3 minutes later, Live Meeting works
perfectly. WTF?
WHY DOES MY LIFE HATE ME?! >_<
Date: 29 Jun 2009 10:56:54
Message: <4a48d636$1@news.povray.org>
...and now the French women is back.
When will it all end?
Date: 29 Jun 2009 11:26:43
Message: <4a48dd33@news.povray.org>
Your life really doesn't sound so bad, it all seems like normal jobs an IT
guy working for an international company should be doing.  Try getting up at
4am, sitting on a plane for 8 hours, then going to a customer meeting for 2
hours, then having dinner (in a time zone 6 hours behind where you started),
then having a 3 hour conference call with non-English-speaking people, then
going to bed 24 hours after you got up, then working 16 hours a day for a
week.  Want to swap?
Date: 29 Jun 2009 11:36:15
Message: <4a48df6f$1@news.povray.org>
> IT guy working for an international company should be doing.
A normal IT guy working for an international company would presumably be
earning slightly more than £14k/year. I would also *hope* that such a
person wouldn't be considered utterly incompetent every single time any
kind of minor technical glitch occurs. But maybe I'm just kidding myself...
> Try
> getting up at 4am, sitting on a plane for 8 hours, then going to a
> customer meeting for 2 hours, then having dinner (in a time zone 6 hours
> behind where you started), then having a 3 hour conference call with
> non-English-speaking people, then going to bed 24 hours after you got
> up, then working 16 hours a day for a week.  Want to swap?
What's the pay packet like? :-P
(That's rhetorical of course. I wouldn't travel to a foreign country if
you paid me.)
Date: 29 Jun 2009 11:55:01
Message: <web.4a48e2a1c3f10ba1ccf29180@news.povray.org>
I have a solution to your PDF problems installed on my computer:
It's called Scansoft PDF Professional and lets you double print PDFs and other
nice things.
http://www.nuance.co.uk/pdfconverter/create/
Date: 29 Jun 2009 12:20:16
Message: <4a48e9c0$1@news.povray.org>
There's a plugin for OpenOffice 3.x to do just this.
Jim
Date: 29 Jun 2009 12:23:12
Message: <4a48ea70@news.povray.org>
You forgot PPM. ;-)
   Insanity is a small city on the western
   border of the State of Mind.
Date: 29 Jun 2009 12:26:23
Message: <4a48eb2f$1@news.povray.org>
I'd be surprised if "PDF manipulation software" included everything you
needed to write documents in PDF. That would be "word processor/image
manipulator/font editor/PDF manipulation software" to me.
Why not write a new XSLT to take the XML from backup exec and output
something a word processor can handle, like RTF or LaTeX or something?
That's why BE is giving it to you as XML.
Date: 29 Jun 2009 12:27:50
Message: <4a48eb86$1@news.povray.org>
On Mon, 29 Jun 2009 17:26:42 +0200, scott wrote:
> Want to swap?
I was thinking something similar, but unlike you, I can't go into details
about what last week held for me.
Jim
Date: 29 Jun 2009 12:28:40
Message: <4a48ebb8@news.povray.org>
That's one of the things they fixed on Vista. It's really obvious now how to
use a different input mechanism to log in.
Date: 29 Jun 2009 13:52:03
Message: <4a48ff43@news.povray.org>
>> account. That means the Windows login prompt still has the wrong keymap.
> how to use a different input mechanism to log in.
I can understand different users having different language settings. But
the friggin' keymap?? HOW can that be different for each user?!
http://blog.orphi.me.uk/
Date: 29 Jun 2009 13:52:44
Message: <4a48ff6c@news.povray.org>
>> (Though Acrobat will only produce Windows Bitmap - the most braindead
> You forgot PPM. ;-)
That's why I said "in widespread use". ;-)
Date: 29 Jun 2009 13:54:21
Message: <4a48ffcd$1@news.povray.org>
Well, you know, it's not like I'm trying to do anything complex. A few
trivial cut/paste operations is all. But noooooo, that would be too
useful...
BackupExec does not "give" it to you at all. It displays it in screen
for you, and lets you print it, but it won't let you "have" the
underlying file at all. (Although it does tell you that this log is file
38H4G28JHQ83BH94EH.XML if you're interested.)
Date: 29 Jun 2009 14:39:16
Message: <4A490A54.2030707@hotmail.com>
On a desktop it is possible, for a laptop a bit more difficult, although
you can always plug in a usb keyboard... No, come to think about it, it
should on all systems be possible. Only I would expect that it would
take at least 5 generations for MS to get right. If on Vista it already
works that could be an indication that MS has changed it's testing
procedures. That reminds me that on this Vista system the exceptions
during filecopy also finally are handled in a useful way. Something
fishy going on. Anybody knows more?
Date: 29 Jun 2009 14:40:27
Message: <4a490a9b$1@news.povray.org>
And in what sense is that not letting you have the underlying file?
Date: 29 Jun 2009 14:41:48
Message: <4a490aec@news.povray.org>
You've never heard of remote logins?  (Altho I don't know at which end of
the protocol the translation is done.)
I'm more familiar with chinese input mechanisms than french keyboards. You
can imagine how it would be difficult to log in with a password in chinese
if you didn't have the appropriate input drivers available from the login
screen.
Date: 29 Jun 2009 14:43:51
Message: <4a490b67@news.povray.org>
>> But the friggin' keymap?? HOW can that be different for each user?!
> of the protocol the translation is done.)
One would *hope* RDP transports character codes, not scancodes. (But,
knowing M$...)
> You can imagine how it would be difficult to log in with a password in
> chinese if you didn't have the appropriate input drivers available from
> the login screen.
Hmm. I don't want to know why you know that...
Date: 29 Jun 2009 14:45:31
Message: <4a490bcb$1@news.povray.org>
Ah yes, that's the Really Fun Thing(tm). What happens if you have an
English PS/2 keyboard and an American USB keyboard plugged in at the
same time? The answer: No matter what keymap you select, one or other of
the keyboards will malfunction. Isn't that wonderful?
I know little about Vista. ;-)
Date: 29 Jun 2009 14:59:47
Message: <4A490F23.2090705@hotmail.com>
>> from the login screen.
But we do, and we know why you don't. ;)
Date: 29 Jun 2009 15:02:50
Message: <4a490fda$1@news.povray.org>
Hmm. I wonder what else you people know?
Date: 29 Jun 2009 17:15:35
Message: <4a492ef7$1@news.povray.org>
More than you could imagine.
-Aero
Date: 29 Jun 2009 17:26:43
Message: <4a493193$1@news.povray.org>
> knowing M$...)
Which works great until the program at the other end asks for scancodes.
Because my wife is chinese?
Date: 29 Jun 2009 22:46:26
Message: <4a497c82@news.povray.org>
	Since no one mentioned it, Gimp can open up pdf's as images.
AAHH!!! I've deleted all my RAM!
                    /  \/  \ u e e n     /  \/  a w a z
                        >>>>>>mue### [at] nawazorg<<<<<<
                                    anl
Date: 29 Jun 2009 23:58:41
Message: <4a498d71$1@news.povray.org>
As can Paint Shop Pro, if you already own it.
Or, open it in Reader and take a screen shot. ;-)
Date: 30 Jun 2009 02:31:40
Message: <4A49B14C.3090106@hotmail.com>
I think it would have been more fun to keep Andy in suspense for a few
more days.
Date: 30 Jun 2009 02:55:21
Message: <4a49b6d9@news.povray.org>
And would presumably be meant to be working for almost 100% of the time, and
not moaning whenever he actually had to do some real IT work :-)
> I would also *hope* that such a person wouldn't be considered utterly
> incompetent every single time any kind of minor technical glitch occurs.
Surely you've demonstrated how you can solve all the minor technical
glitches though?  Surely not everyone in your company is that dumb that they
all think you're totally incompetent?
Did you ever try to work pro-actively? I mean by suggesting things to your
boss that you think you should be doing (in order to improve the company's
IT), rather than just waiting to be told things to do?  It might make them
think more of you as a valued employee contributing to the company rather
than "just" an IT worker who fixes stuff when asks.
> you paid me.)
Well clearly you have travelled to a foreign country, when you actually paid
yourself to go, albeit for a holiday.  Are you really telling me that if
paid enough you still wouldn't travel abroad to work for a few days?  How
about to go to a conference?  OOC why not?
Date: 30 Jun 2009 02:58:58
Message: <4a49b7b2$1@news.povray.org>
>> Want to swap?
Sometimes I think to myself about just giving up this stuff and going to
work selling drinks on the beach somewhere hot :-)  Is it really worth
having so much more responsibility and stress for your whole life just to
get a bigger house or faster car or whatever?  Are you really going to be
happier in the end?
Date: 30 Jun 2009 03:40:01
Message: <web.4a49c0adc3f10ba7ba8dc80@news.povray.org>
There are more things in heaven and earth, Andrew,
Than are dreamt of in your philosophy.
Date: 30 Jun 2009 03:45:00
Message: <web.4a49c1efc3f10ba7ba8dc80@news.povray.org>
> >> Want to swap?
> happier in the end?
The trick is, finding a job that you actually enjoy.
I’ve been lucky, most of my jobs I would have paid to do but then I was probably
born at the right time. I did not need a degree to operate the photocopier the
way my wife did.
Remember “you are a long time dead”.
Date: 30 Jun 2009 04:11:40
Message: <4a49c8bc$1@news.povray.org>
> more days.
Yes, because I...don't...*want*...to know...? Hmm...
Date: 30 Jun 2009 04:19:57
Message: <4a49caad$1@news.povray.org>
Hmm, maybe I don't enjoy my job as much as I think I do, if I am always
thinking it would be more fun to stay at home and do other stuff.
