POV-Ray : Newsgroups : povray.off-topic : Somehow I always think of Andrew Server Time
13 Apr 2026 14:59:16 EDT (-0400)
  Somehow I always think of Andrew (Message 1 to 10 of 14)
Subject: Somehow I always think of Andrew
Date: 21 Jun 2009 13:33:36
Message: <4a3e6ef0$1@news.povray.org>
when I read something like this...
http://www.irregularwebcomic.net/
   Insanity is a small city on the western
   border of the State of Mind.
Subject: Re: Somehow I always think of Andrew
Date: 21 Jun 2009 14:00:37
Message: <4a3e7545$1@news.povray.org>
Why thank you. :-/
In a stunning turn of events, I was just in the middle of having a
conversation about whether assigning unique indicies to every variable
in a Lambda expression enables its reduction sequence to be computed
without name clashes. :-P
http://blog.orphi.me.uk/
Date: 21 Jun 2009 14:09:45
Message: <4a3e7769$1@news.povray.org>
> Why thank you. :-/
That was a complement. :-)
Along the lines of "Gee, I bet Andrew, with some practice, could also turn
out a blog full of interesting discussions of abstruse mathematical proofs
that would garner a world-wide audience, too."
Date: 21 Jun 2009 14:25:23
Message: <4a3e7b13$1@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:4a3e7769$1@news.povray.org...
> > Why thank you. :-/
And two's, no less.
Date: 21 Jun 2009 14:25:48
Message: <4a3e7b2c$1@news.povray.org>
>> Why thank you. :-/
> turn out a blog full of interesting discussions of abstruse mathematical
> proofs that would garner a world-wide audience, too."
1. What makes you think anybody reads that blog?
2. Every time I write... well, virtually anything, actually... almost
nobody reads it. Which is mainly why I seldom write anything.
Date: 21 Jun 2009 15:28:42
Message: <4A3E89EB.8050400@hotmail.com>
> Why thank you. :-/
There is alpha conversion to prevent that, but I guess you are talking
about an implementation not the theory. ;)
I seem to remember that labelling just with the level of the nesting is
enough. If you have unique identifiers throughout your program, that
certainly works.
On a similar note, assigning unique indices to the lambdas gives an
almost trivial way to prove that lambda calculus is Church-Rosser. At
least I think so, I have never seen that in a paper, so there might be a
complication that I missed.
Date: 21 Jun 2009 15:40:22
Message: <4a3e8ca6$1@news.povray.org>
Indeed. It's significantly less trivial than you'd imagine... o_O
> enough.
That would be de Bruijn indices. And I'm hoping to avoid needing to go
that far... (But we'll see!)
> certainly works.
Ah, but wait. Simply renaming all the variables before you start is
insufficient. Unfortunately.
   (\x -> x x) (\y -> y)
Make 'em all unique:
   (\x1 -> x1 x1) (\y2 -> y2)
Now beta-reduce:
   (\y2 -> y2) (\y2 -> y2)
Oh noes! No longer unique...
(In this instance it doesn't matter, but somebody showed me a slightly
more complicated example where it actually goes wrong.)
Date: 21 Jun 2009 15:55:25
Message: <4A3E902D.9090807@hotmail.com>
>>> variable in a Lambda expression enables its reduction sequence to be
>>> computed without name clashes. :-P
>> is enough.
It requires a different implementation and different data structures,
but as you already have proven that the other path is infeasible...
Having named bound variables is very natural if you were brought up in
imperative languages, but I don't see the point in functional languages,
other than in the human interface.
>> If you have unique identifiers throughout your program, that certainly
>> works.
> Now beta-reduce:
I didn't realize you would want to use them at run-time (bad idea IMHO,
see above). Not your fault, I just did not read carefully.
Date: 21 Jun 2009 16:03:37
Message: <4a3e9219$1@news.povray.org>
>>> is enough.
My whole program is "human interface". It doesn't do anything "useful",
it's just to allow a human being to easily observe the reduction
sequence. To that end, I'd like the program to avoid screwing around
with the human-provided variables names as much as is feasible. OTOH,
I'd also like the thing to *work*... ;-)
Well, I think if I can relabel the variables after each expression
transformation to recover uniqueness, it should work.
(Unfortunately the labeller currently looks only at the variable *names*
and ignores the index values. That means that expressions which already
have indicies can get renamed incorrectly.)
Date: 21 Jun 2009 16:35:19
Message: <da6t355eckbhjq6982016a9r06ptrv1oa6@4ax.com>
On Sun, 21 Jun 2009 19:25:52 +0100, Orchid XP v8 <voi### [at] devnull> wrote:
I read your blog a million times more than I read anyone elses.
Regards
