POV-Ray : Newsgroups : povray.off-topic : Interesting take on C++ vs others... Server Time
2 Nov 2026 12:17:33 EST (-0500)
  Interesting take on C++ vs others... (Message 1 to 22 of 22)
Subject: Interesting take on C++ vs others...
Date: 2 Jun 2009 14:21:04
Message: <4a256d90$1@news.povray.org>
http://metamatix.org/~ocaml/price-of-abstraction.html
Very artificial benchmark to prove a point, methinks, but it's basically
supporting what Warp says. :-)
   There's no CD like OCD, there's no CD I knoooow!
Subject: Re: Interesting take on C++ vs others...
Date: 2 Jun 2009 15:19:55
Message: <4a257b5b@news.povray.org>
  C++ has indeed always been designed for number-crunching in mind, and
abstraction has always been added with the condition that it should not
have a significant hit to performance (or, at least, it should be possible
to create a compiler which can internally optimize away most of the overhead
caused by abstraction).
  That's precisely one of the reasons why I like C++'s design (even though
I'm also aware of its flaws in other respects). Given my line of work, it
makes me appreciate it even more. (I have to create quite often programs
which are quite number-crunching-heavy, and C++ allows me to easily do that
while still having a good level of abstraction. In other words, I don't have
to resort to such hardware-level coding as would be necessary with C.)
  Of course this doesn't mean that all possible C++ programs are always
automatically superfast. There are many situations where, if you don't know
what you are doing, you are going to end up with rather suboptimal solutions,
even if your algorithms are ok. (OTOH this is not really a problem exclusive
to C++, as C and many other "low-level" languages will have the exact same
problems.)
  (Btw, about the C++ program in that webpage: I think that if he had told
gcc to generate SSE code rather than FPU code, he would have got the desired
rounding without having to resort to inline asm...)
Date: 2 Jun 2009 15:29:43
Message: <4a257da7@news.povray.org>
Yah. Given that what I tend to do is complex interrelated data structures
with trivial amounts of math added, it doesn't seem as beneficial to me.
> problems.)
I think that's probably true of pretty much every language. I once spent an
hour removing the loops from the professor's APL code, and the run time went
from 15 minutes to about 30 seconds. And of course one major reason you have
a DBA is that SQL can give you crappy performance even if the algorithms are
decent.
Maybe he was trying to use the same FPU code that the other languages were
using. SSE uses a whole different execution model, yes?
Date: 2 Jun 2009 15:33:14
Message: <4a257e7a@news.povray.org>
  Why should that matter? The compiler should optimize as well as it can,
using any means it can.
  The SSE version would most probably have not been significantly faster,
but he would have got his 64-bit rounding without having to resort to
non-standard code.
Date: 2 Jun 2009 15:59:05
Message: <4a258489@news.povray.org>
> > problems.)
  I was more referring to some things which in theory one shouldn't have
to worry about, and which in many languages *are* things you don't have to
worry about, but in C++ they can bite you if you don't know about them.
  One concrete example which is a real shame with most C++ compilers is
memory allocation/deallocation speed. For some reason most compilers (and
very especially gcc) do a very poor job at this, even though they could
demonstrably do it much better.
  For example, consider this simple program:
#include <set>
int main()
    std::set<int> numbers;
    for(int i = 0; i < 10000000; ++i) numbers.insert(i);
  It does nothing else than add 10 million consecutive integers into a
balanced binary tree, and then destroys it and ends.
  Compiling this program with "g++ -O3 -march=native" in my system creates
a program which in my computer takes a bit over 15 seconds to run.
  Is this time spent into inserting elements and rebalancing the tree?
No. It's mostly spent in allocating memory!
  Let's change the 'number' definition a bit:
std::set<int, std::less<int>, FSBAllocator<int> > numbers;
  FSBAllocator is a memory allocator I have made. From a functional point
of view it doesn't change anything significant: The program still does the
exact same thing as before, and it even consumes about the same amount of
memory.
  However, when I run the modified program, it only takes 2.9 seconds.
Date: 2 Jun 2009 16:03:49
Message: <4a2585a5$1@news.povray.org>
OK. It was just a guess. :-)
Science depends on changing as few things as possible. If you're doing an
experiment comparing the speed cost of abstractions, running it on different
CPUs isn't a logical thing to do. :-)
Date: 2 Jun 2009 16:10:18
Message: <4a25872a$1@news.povray.org>
> to worry about,
Sure. And in theory, you shouldn't have to worry about what order you list
the tables to be joined in SQL. :-) More similar than you may think, I think.
Yep. That has always been a bane. Lots of people try to write
special-purpose allocators just for their programs which still don't do as
well as a good GC mechanism, too. (I posted a bunch of links to the actual
research a few months back.)
Allocation performance has always been a problem even long before C++ was
around. You'd certainly think people would have gotten it right by now. I
wonder why it's so hard, tho? Is it attempts to avoid fragmentation or
something?
I remember programs on machines with no MMU (like the Amiga) which had to
deallocate its memory on exit, when you'd exit the program and it would
spend long seconds cleaning up its memory. Even nowadays, you can sometimes
hear the disk thrash while exiting if you've started paging. :-)
It's cool to have a language where you can change that stuff without
screwing with the compiler, yes. :-)
Date: 2 Jun 2009 17:10:01
Message: <web.4a25948d6c437e29773c9a3e0@news.povray.org>
I'm not an OCaml expert, but I'd say that benchmark is flawed -- OCaml is
supposed to give performance very similar to C++ and its very unlikely Scala
running on top of JVM to beat it.  The author did use -O3 on GCC, what options
for ocamlopt?
Perhaps I should bring on Jon Harrop to the rescue. :)
Date: 2 Jun 2009 17:25:53
Message: <4a2598e0@news.povray.org>
  Show me one benchmark which isn't.
Date: 2 Jun 2009 17:45:00
Message: <web.4a259c526c437e29773c9a3e0@news.povray.org>
The algorithm here is a standard, not much to do about it.  Other than that, the
only thing one can do is use proper optimization flags for the compilers.  The
famous Language Benchmark Game gives proper optimization flags for the tools
that accept it and that makes it pretty fair.
Date: 2 Jun 2009 20:54:47
Message: <4a25c9d7$1@news.povray.org>
>>> problems.)
> #include <set>
> int main()
> memory.
Does it do something simple, like anticipate future needs based on the
current vector size?
John
Date: 3 Jun 2009 09:26:11
Message: <4a2679f3@news.povray.org>
  My allocator can only be used to allocate elements of the same size.
It allocates larger buffers of memory and then manages a simple list of
free blocks.
Date: 3 Jun 2009 21:15:51
Message: <4a272047$1@news.povray.org>
> free blocks.
Pretty much what I'd thought; allocate space for more than one when
called, and return a piece of the extra space for later calls.
John
Date: 4 Jun 2009 00:35:20
Message: <4a274f08$1@news.povray.org>
That's kind of how every allocator works. :-) The difference is Warp's has a
different pool for each specific size of item, so you don't get
fragmentation. The first empty you find is always the right size.
Date: 4 Jun 2009 02:56:19
Message: <4a277013@news.povray.org>
  There's also one advantage: If a block of memory becomes completely
freed, the allocator frees this block of memory from the underlying
(compiler-provided) system allocator. If then new objects are allocated
and the current list of free objects is empty, it will allocate a new
memory block and start returning the space in consecutive order. In other
words, it effectively resets the ordering of freed objects in certain
situations.
  I have noticed enormous speedups because of this, compared to the system
allocator. If I *don't* free the blocks of memory (thus effectively resetting
the ordering of the list of free objects in that block) the allocator becomes
much slower. My conclusion is that the allocator is cache-friendlier than
the system allocator: Returning space for allocated objects consecutively in
memory is much faster than returning them in random order (which is what
tends to happen when you just keep a list of freed objects without ever
resetting their ordering).
  According to my tests this can have such a big impact that even spending
time sorting freed objects can speed up memory allocation overall. Cache
misses simply are really expensive.
Date: 4 Jun 2009 12:37:22
Message: <4a27f842$1@news.povray.org>
Have you ever tried building one that uses a bitmap of free entries? Since
they're all the same size, it would seem easy to do all the math needed quickly.
That's probably another reason the performance of compacting GCs are often
better than "manual" malloc and free.
Date: 4 Jun 2009 12:47:46
Message: <4a27fab2@news.povray.org>
nemesis escreveu:
well, and truly I did:
to: namekuseijin <nam### [at] gmailcom>
date Tue, Jun 2, 2009 at 9:49 PM
subject Re: ocaml benchmark going bad
On Tuesday 02 June 2009 22:19:53 you wrote:
 > Hey, man.  Thought you'd like to know about this:
 > Don't know how old it is but seemingly OCaml is taking a beating by
 > both C++ and Scala on a mandelbrot implementation.  Perhaps the author
 > forgot some options to the ocamlopt compiler?
 > saw it in the povray newsgroups:
http://news.povray.org/povray.off-topic/thread/%3C4a256d90%241%40news.povra
 >y.org%3E/
The author claims that the programs are equivalent when they are not and
makes many completely false statements as a consequence. Objectively, he
should have asked for peer review but, actually, he could have written
decent OCaml code just by copying any of the many efficient Mandelbrot
benchmarks written in OCaml that are freely available on the web.
Firstly, he uses a simple and efficient imperative loop in the C++:
int iters1(int max_iter,double xc,double yc) {
   double x = xc;
   double y = yc;
   for(int count = 0;count<max_iter;count++) {
      if( x*x + y*y >= 4.0) { return count; }
      double tmp = x*x-y*y+xc;
      y = 2.0 * x * y + yc;
      x = tmp;
   return max_iter;
Great. I'd expect to see a simple imperative and efficient loop in OCaml
but the OCaml code he describes as "equivalent" is actually completely
different:
let iters1 max_iter xc yc =
  let rec aux count x y =
    if count = max_iter then max_iter else begin
      if x *. x  +. y *. y >= 4.0 then count else
      aux (count+1) (x *. x -. y *. y +. xc) (2.0 *. x *. y +. yc)
    end in
  aux 0 xc yc
Eh? He's used a nested recursive function for no reason and that has
introduced two radical differences compared to the C++:
1. OCaml does not unbox floats across function boundaries like this so
the floats are needlessly allocated and deallocated at every iteration
in the OCaml. In comparison, the C++ does no heap allocation.
2. His nested function is not self-contained: it captures xc and yc from
its environment. So this is compiled into a closure (a concept that does
not exist in C++, of course) incurring allocation and making every
single function invocation in the inner loop several times more
expensive. In comparison, the C++ does direct function calls to
statically-known locations.
No problem, I thought. This was obviously written by a C++ guy who
doesn't know OCaml. But then I saw his OOP example in C++:
class Complex {
public:
   Complex(double xc,double yc) : x(xc), y(yc) { }
   double norm_square() {
      return x*x+y*y;
   Complex operator*(const Complex &other) {
      return Complex(x*other.x-y*other.y,
                     x*other.y+y*other.x);
   Complex operator+(const Complex &other) {
      return Complex(x + other.x, y + other.y);
private:
   double x;
   double y;
int iters2(int max_iter,double xc,double yc) {
   Complex c(xc,yc);
   Complex z(xc,yc);
      if( z.norm_square() >= 4.0 ) { return count; }
      z = z * z + c;
   return max_iter;
His overloaded * does not implement multiplication correctly but, more
importantly, he forgot that objects in C++ are represented by pointers.
By removing all of the pointers he has removed all of the allocation but
also any chance of using subtypes and/or inheritance. In other words,
this is not OOP at all. He has just used a struct.
Let's try an honest C++ equivalent that does support OOP, i.e. you can
derive a new kind of complex number from the Complex class and use it
interchangeably because they will have the same uniform run-time
representation of a *pointer* to an object:
#include <cstdio>
const int RESOLUTION = 5000;
class Complex {
public:
      return x*x+y*y;
   Complex *sqr() {
     return new Complex(x*x - y*y, 2 * x*y);
   Complex *add(const Complex *other) {
     return new Complex(x + other->x, y + other->y);
private:
   double x;
   double y;
   Complex *c = new Complex(xc,yc);
   Complex *z = new Complex(xc,yc);
      if( z->norm_square() >= 4.0 ) {
        delete c;
        delete z;
        return count;
      Complex *z2 = z->sqr(), *oz = z;
      z = z2->add(c);
      delete z2;
      delete oz;
   delete c;
   delete z;
   return max_iter;
int main() {
   int    max_val = RESOLUTION/2;
   int    min_val = -max_val;
   double mul = 2.0 / max_val;
   int    count = 0;
   for(int i=min_val;i<=max_val;i++) {
      for(int j=min_val;j<=max_val;j++) {
         count += iters2(100,mul*i,mul*j);
   printf("result: %d\n",count);
That is 15x slower than his C++ code because allocation is so
inefficient in C++.
He also failed to mention that abstraction is usually achieved with
functors and not objects in OCaml. Let's try using the higher-order
module system:
let resolution = 5000
module type COMPLEX = sig
  type t
  val mk : float -> float -> t
  val norm2 : t -> float
  val add : t -> t -> unit
  val sqr : t -> unit
end
module Complex : COMPLEX = struct
  type t = {mutable r: float; mutable i: float}
  let mk r i = {r=r; i=i}
  let norm2 z = z.r *. z.r +. z.i *. z.i
  let add z1 z2 =
    z1.r <- z1.r +. z2.r;
    z1.i <- z1.i +. z2.i
  let sqr z =
    let r' = z.r *. z.r -. z.i *. z.i and i' = 2.0 *. z.r *. z.i in
    z.r <- r';
    z.i <- i'
end
module Iters(C: COMPLEX) = struct
  let iters max_iter xc yc =
    let c = C.mk xc yc in
    let i = ref 0 and z = C.mk xc yc in
    while !i < max_iter && C.norm2 z < 4.0 do
      C.sqr z;
      C.add z c;
      incr i
    done;
    !i
end
let () =
  let module I = Iters(Complex) in
  let max_val = resolution/2 in
  let min_val = - max_val in
  let mul = 2.0 /. float max_val in
  let count = ref 0 in
  for i = min_val to max_val do
    for j = min_val to max_val do
      let x = float i *. mul in
      let y = float j *. mul in
      count := !count + I.iters 100 x y;
    done
  done;
  Printf.printf "result: %d\n" !count
So here are my timings:
C++:    3s   (raw)
C++:   35s   (genuine objects)
OCaml:  4.6s (record)
OCaml: 10s   (functor)
Dr Jon Harrop, Flying Frog Consultancy Ltd.
http://www.ffconsultancy.com/?e
Date: 4 Jun 2009 14:26:00
Message: <4a2811b8@news.povray.org>
> more
  Everything was fine until this point. However, this is starting to
sound more like he is deliberately trying to come up with a contrived,
yet plausible-sounding way of artificially making the C++ version slower.
  I find it rather ironic (and hypocritical) to do that immediately after
he argued that the straightforward iterative version in C++ had an "unfair"
advantage over the proposed Ocaml version which used recursion. In other
words, he is arguing that the first Ocaml version was slower because the
wrong (and inefficient) methodology for the given task was used. Then he goes
right ahead and gives us the completely wrong (and inefficient) methodology
in the "abstracted version" of the C++ program, just to artificially make
it slower.
  The original article didn't say anything about "object-oriented programming".
It only talked about abstracting away the complex number type. Even if you
could argue that for an implementation to be "OOP" it *must* support dynamic
binding, he is (probably deliberately) missing the point: The point was not
to make the program object-oriented, but to abstract away the complex number
type. In other words, to make it more modular. And the suggested C++ class
does exactly that, and it does so in the way that the language was designed.
  Maybe he wanted to point out that in Ocaml you cannot do the same, ie.
create classes which are *not* dynamically bound, and thus the comparison
is "unfair". However, if Ocaml lacks such capabilities, that's hardly C++'s
problem. The goal was to abstract away the complex number type as efficiently
as possible, nothing else. His argument about "OOP" is completely flawed.
Date: 4 Jun 2009 15:54:14
Message: <4a282666$1@news.povray.org>
I have to say, after posting it and rethinking about, that I believe he
missed the point the poster wanted to say:  that higher abstractions
like recursion and getting away from lowlevel machinery do indeed incur
in a cost.
He correctly identifies unboxing and variable capture as extras not
present in the C++ code but that was precisely the point of the author
-- "The price of abstraction".  By making OCaml behave the same as C++,
you can indeed maxout performance, but that was not the point... yes,
Warp, I see what you mean about the dumbing down of the C++ code.
In any case, although he went after C++, I was more annoyed at seeing
another higher-level language with high level constructs, Scala on the
JVM, outpacing OCaml.  That's what really stroke me as odd.
a game sig: http://tinyurl.com/d3rxz9
Date: 4 Jun 2009 16:11:40
Message: <4a282a7b@news.povray.org>
> Scala on the
  If the JVM performs JIT-compiling, I don't see the problem...
Date: 4 Jun 2009 16:16:44
Message: <4a282bac$1@news.povray.org>
Warp wrote:
> However, if Ocaml lacks such capabilities, that's hardly C++'s problem.
Indeed, I think that was specifically the point of the article in the first
place. :-)
Date: 4 Jun 2009 16:34:48
Message: <4a282fe8$1@news.povray.org>
Warp escreveu:
>> Scala on the
JIT-compiling doesn't beat g++ compiling in that benchmark, nor do I
understand quite why it should beat OCaml either -- the author mentions
poor OCaml float performance.
I'm not an OCaml programmer, which is why I asked Mr. Harrop for some
insight.  I only knew, based on more than one source, that it's capable
of very C++-like performance.  caught off-guard...
