POV-Ray : Newsgroups : povray.off-topic : Heavy metal Server Time
18 Oct 2026 19:46:10 EDT (-0400)
  Heavy metal (Message 1 to 46 of 46)
Subject: Heavy metal
Date: 1 Jun 2009 10:32:38
Message: <4a23e686@news.povray.org>
OK, so I've been experimenting with Wolfram's Alpha thingy. Useful if
you happen to want to know how long 10^15 seconds is, if you want a
graph quickly, or if you want to look up the electrical resistence of
silicon. Not much use for anything else.
I did find some interesting information though...
Alpha claims that the current trading price for gold is approximately
£600 "per Troy ounch" (whatever the hell that is). Silver, on the other
hand, is more like £10 / oz t. (...??!) And Platinum is about £744 / oz
t. (I had no idea Platinum was so expensive!)
I tried to get similar data for other substances, but Wolfram's "data
curators" evidently haven't got that far yet. I did find a website
though that claims that the London Metal Exchange has the following prices:
   Sn $14.325 / Kg
   Ni $13.770 / Kg
   Cu $ 4.776 / Kg
   Pd $ 1.530 / Kg
   Zn $ 1.509 / Kg
   Al $ 1.384 / Kg
(Not sure why the LME lists prices in USD, but still...)
This table is completely baffling to me. As everybody knows, Alunimium
is about the most expensive metal you can buy (except for weird stuff
like Titanium, or the "precious metals" like Gold or Silver), and Lead
is about the cheapest metal there is. Except that this table says no
such thing!! o_O
Hmm, I wonder why Iron isn't listed? A rather common metal, after all...
Subject: Re: Heavy metal
Date: 1 Jun 2009 12:12:15
Message: <4a23fddf$1@news.povray.org>
I've found it to be useful for figuring out caloric information for
recipes.
Jim
Date: 1 Jun 2009 12:27:10
Message: <4a24015e$1@news.povray.org>
http://www.wolframalpha.com/input/?i=troy+ounce
Yep.
Because it's a metal commodity exchange, and those metals are sold in
dollars. Just like oil, for example.
> such thing!! o_O
These are futures markets, not stores. You're not buying the metals. You'
re
buying futures on the metals. That's one reason you'll see funky pricing.
Plus, I don't think Aluminum is that expensive. It used to be expensive
before they figured out how to extract it from common compounds (which is
why the Washington Monument has a cap of aluminum), and it's probably
expensive for its weight and structural properties (you don't build
airplanes out of nickel or tin and it's more expensive than heavier thing
s
like iron and brass), but I don't think it's expensive on an absolute bas
is
or they wouldn't make aluminum foil and aluminum cans from it.
Welcome to the London Metal Exchange
The London Metal Exchange is the world's premier non-ferrous metals marke
t.
   There's no CD like OCD, there's no CD I knoooow!
Date: 1 Jun 2009 13:26:52
Message: <4a240f5c$1@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:4a23e686@news.povray.org...
Dated, but still a good read:
http://minerals.usgs.gov/minerals/pubs/metal_prices/
Date: 1 Jun 2009 14:05:41
Message: <4a241875@news.povray.org>
  As everybody knows? Aluminium is used for almost everything, from
cookware to car and airplane chassis.
Date: 1 Jun 2009 14:24:42
Message: <4a241cea$1@news.povray.org>
Last I heard, airplanes aren't exactly "cheap", nor are cars, and
cookware made of alunimium rather than steel is vastly more expensive.
(Ditto for computer cases.)
http://blog.orphi.me.uk/
Date: 1 Jun 2009 15:33:21
Message: <4a242d01@news.povray.org>
  That only tells that steel is cheaper than aluminum, not that aluminum
is super-expensive.
Date: 1 Jun 2009 15:51:53
Message: <op.uuu2spfo7bxctx@e6600>
On Mon, 01 Jun 2009 20:24:51 +0200, Orchid XP v8 <voi### [at] devnull> wrote:
Airplanes and cars are expensive, but not primarily because of raw material
costs I think.
> and cookware made of alunimium rather than steel is vastly more
> expensive.
The only reasonably useful aluminium cookware I have seen are frying pans,
and those are always Teflon-coated. Even so, I have not found them to be
more expensive than their cast-iron counterparts. In fact, the cheapest
ones are typically aluminium.
The same goes for computer cases; the cheapest ones are aluminium.
FE
Date: 1 Jun 2009 17:06:32
Message: <4a2442d8$1@news.povray.org>
> pans, and those are always Teflon-coated.
http://www.vita-mix.com/household/products/neova/
Highly recommended, btw. :-)
Aluminum conducts heat almost as well as copper and is less prone to
corrosion and is lighter, so it's a good choice for cookware.
Date: 1 Jun 2009 18:34:40
Message: <op.uuvab1rh7bxctx@e6600>
Yeah, I have seen multi-layer cooking pots, but I would tend to classify
those as steel pots. I will admit, though, that there may be sufficient
aluminium in there to noticeably affect the material cost.
As an aside, I do own several "pure" aluminium pots. They work fine, but
they get ugly with old age.
I prefer iron; cookware that lets you cook *and* work out at the same time.
FE
Date: 1 Jun 2009 18:44:39
Message: <4a2459d7$1@news.povray.org>
> time.
You just have to be careful not to put things that are overly acidic into
the container - and remember not to scrub it with a wire brush (had a
friend who was being helpful and didn't know better with our cast iron
skillet....took us about 4 months to re-season the surface.  On the plus
side, bacon for the WIN!)
Jim
Date: 1 Jun 2009 20:10:09
Message: <4a246de1@news.povray.org>
I read this in a Facebook comment:
"This search engine is useless!
http://www.wolframalpha.com/input/?i=britney%20spears%20naked"
Date: 1 Jun 2009 21:34:45
Message: <4a2481b5$1@news.povray.org>
> the container
Why? The old Alzheimer's thing?  I think they figured out that was a
procedural error.
Date: 1 Jun 2009 22:11:08
Message: <4a248a3c@news.povray.org>
>> into the container
> procedural error.
Nope, acidic foods can destroy the "seasoning" of cast iron, and if you
then wash it in water, you can cause the pan to oxidize.
But even if you don't use water, stripping the seasoning off the pan can
create a metallic taste in foods cooked in the pan.  As Alton Brown would
say, that's definitely NOT good eats.
Jim
Date: 1 Jun 2009 22:17:14
Message: <4a248baa$1@news.povray.org>
Oh, right, sure. I thought you were talking about the aluminum. My bad.
Date: 1 Jun 2009 23:10:05
Message: <4a24980d$1@news.povray.org>
Ah, I see.  I hadn't heard the Alzheimer's thing before.  :-)
Jim
Date: 2 Jun 2009 05:04:29
Message: <4a24eb1d$1@news.povray.org>
> This table is completely baffling to me. As everybody knows, Alunimium is
> about the most expensive metal you can buy (except for weird stuff like
Ermm no, a more accurate statement would be that aluminium is about the
cheapest metal you can buy, except for plain old steel.
Also note that if you need a part of a certain strength, you can usually
make it using less mass (although more volume) of aluminium compared to
steel.  That's why aluminium is used in things that need to be light
(planes, cars), but steel is used in things that need to be very small (eg
mobile phones, cameras).
Date: 2 Jun 2009 13:08:39
Message: <4a255c97$1@news.povray.org>
Wasn't aluminum cookware linked to Alzheimer's?
~Mike
Date: 2 Jun 2009 13:30:00
Message: <web.4a25612cdedb4e855fd99d9e0@news.povray.org>
Can you guess the cost of saffron per ton?
Date: 2 Jun 2009 13:48:32
Message: <4a2565f0$1@news.povray.org>
I looked it up and was glad to see that it's still significantly less
expensive per weight than gold.  Of course you don't often use gold as
an ingredient in food (not that I ever cook with saffron either come to
think of it.)
Date: 2 Jun 2009 14:24:11
Message: <4a256e4b$1@news.povray.org>
> think of it.)
Goldschlager.
Oh, and I do have saffron in my spice rack. :D
~Mike
Date: 2 Jun 2009 15:06:51
Message: <4a25784b@news.povray.org>
Yes, mistakenly. They found aluminum in the brain tissue of alzheimer's
patients. Then they realized the dyes they used to detect alzheimers had
aluminum in them.
Date: 2 Jun 2009 16:16:46
Message: <4a2588ae$1@news.povray.org>
>> to think of it.)
> Goldschlager.
That exact drink was actually the reason that I put the word "often" in
there.  I suspect there's probably a few other dishes where it serves as
essentially a very expensive form of food coloring.
I've never quite been able to convince myself to buy any.  Someday I'm
sure I'll spring for it, but given that I mostly live on ramen,
crackers, and pb&j it just seems like a bit much right now.
Date: 2 Jun 2009 20:30:59
Message: <4a25c443$1@news.povray.org>
A Troy ounce is 480 grains.  There are 7000 grains in a pound.  This
makes a Troy ounce about 31.1 grams or so.
>   Sn $14.325 / Kg
>   Ni $13.770 / Kg
>   Cu $ 4.776 / Kg
>   Pd $ 1.530 / Kg
>   Zn $ 1.509 / Kg
>   Al $ 1.384 / Kg
I'm rather surprised to see palladium going for $1.53 for a kilogram,
rather than $240 or so per ounce like it does on other sites, so I'd
have to say that Pd is really supposed to be Pb (AKA lead) above.
John
Date: 3 Jun 2009 04:03:28
Message: <4a262e50@news.povray.org>
Right. So 31.1 grams of gold is... a pretty tiny volume, I would think.
>> prices:
>>   Sn $14.325 / Kg
>>   Ni $13.770 / Kg
>>   Cu $ 4.776 / Kg
>>   Pd $ 1.530 / Kg
>>   Zn $ 1.509 / Kg
>>   Al $ 1.384 / Kg
Owned.
Again.
Date: 3 Jun 2009 07:36:50
Message: <4a266052$1@news.povray.org>
For anything that needs high, non-localised heat then nothing beats
high-quality iron cookware (take note of Jim Henderson's notes about
seasoning tho'). I've got a cast-iron skillet for steaks and a cast-iron
omelette pan. Neither has ever been washed, just clean with salt, oil
and kitchen paper; they get better as the years roll on.
John (dreaming of the perfect omelette)
"Eppur si muove" - Galileo Galilei
Date: 3 Jun 2009 09:07:06
Message: <4a26757a$1@news.povray.org>
> aluminum in them.
D'oh!
~Mike
Date: 3 Jun 2009 09:10:32
Message: <4a267648@news.povray.org>
On occasion I like to do fun things like make saffron rice...
But, yeah... if your diet consists of mostly ramen and pbj, ;)
~Mike
Date: 3 Jun 2009 13:14:20
Message: <4a26af6c$1@news.povray.org>
>> alzheimer's patients. Then they realized the dyes they used to detect
>> alzheimers had aluminum in them.
> D'oh!
Is this like the thing where they discovered that the police
breathaliser machines were being kept in alcohol to keep them sterile?
Date: 3 Jun 2009 21:13:55
Message: <4a271fd3$1@news.povray.org>
Gold's density is around 19.2 g/cm^3, and so a troy ounce of gold is
about 1.6 cm^3, which is about the volume of four and a half American
pennies.  Not a bad way to carry around a few hundred dollars in value.
  Just don't lose it.
John
Date: 4 Jun 2009 00:40:57
Message: <4a275059@news.povray.org>
> pennies.
That doesn't sound quite right. Here's an ounce of gold and an American
quarter. It's just over 3 cm in diameter and about 3mm thick.
Download 'sn150175.jpg' (176 KB) Download 'sn150176.jpg' (156 KB)
Preview of image 'sn150175.jpg'
Preview of image 'sn150176.jpg'
Date: 5 Jun 2009 07:26:15
Message: <4a2900d7$1@news.povray.org>
>>  so a troy ounce of gold is about 1.6 cm^3, which is about the volume
>> of four and a half American pennies.
A quarter is not as voluminous as 4.5 American pennies.
In any event, a Troy ounce is about 31.104 grams, and gold is 19.3 grams
per cm^3 (I misremembered it as 19.2 when making my earlier
calculation), giving a volume of 1.611 cm^3 for a Troy ounce of gold.
A coin, 3cm in diameter by 3mm thick, will be about 2.1cm^3.  What's the
alloy content of the coin?
John
Date: 5 Jun 2009 07:29:21
Message: <4a290191@news.povray.org>
>> American quarter. It's just over 3 cm in diameter and about 3mm thick.
http://www96.wolframalpha.com/input/?i=1+oz+t+Au
Date: 5 Jun 2009 07:32:31
Message: <4a29024f@news.povray.org>
...so a 1.1 x 1.1 x 1.1 mm block of this stuff costs £664, eh? That's
pretty freakin' expensive, right there!
I'd hate to imagine how much a solid gold ring costs.
Date: 5 Jun 2009 11:37:49
Message: <4a293bcd$1@news.povray.org>
Would weigh a bit too, I think.
Jim
Date: 5 Jun 2009 11:43:44
Message: <4a293d30$1@news.povray.org>
The one I posted a picture of? It's a bullion coin, so 24k or better.
Date: 5 Jun 2009 11:45:50
Message: <4a293dae$1@news.povray.org>
Gold rings aren't pure gold, or they'd bend very easily.
http://www.bullionjewelry.com/
Date: 5 Jun 2009 11:48:36
Message: <4a293e54$1@news.povray.org>
Sure. But they'd never ever corrode. ;-)
Date: 5 Jun 2009 12:32:10
Message: <4a29488a$1@news.povray.org>
Um, yes? So?
Date: 5 Jun 2009 22:42:18
Message: <4a29d78a@news.povray.org>
Not sure on your maths there.
A cube 1.1mm in a side has a volume of about 0.001331 cubic cm. A bit
over one thousandth of a cubic cm.
A cube 1.17cm (11.7mm) on a side would have a volume of approximately
1.6 cubic cm.  And that is about right for an ounce of gold.
Date: 6 Jun 2009 07:27:34
Message: <4a2a52a6$1@news.povray.org>
Oh, OK. I misread the unit on the printout. Well that's a rather larger
lump of gold then. ;-)
Date: 6 Jun 2009 13:14:29
Message: <4a2aa3f5$1@news.povray.org>
> What's the alloy content of the coin?
Wolfram was clueless, but wikipedia says it's 91.x% gold, so weighs 1.09 oz.
Date: 8 Jun 2009 04:07:49
Message: <4a2cc6d5@news.povray.org>
> Um, yes? So?
If you're making decorative items, this is a benefit.
Date: 8 Jun 2009 09:13:23
Message: <4a2d0e73$1@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:4a293d30$1@news.povray.org...
     You can't get better than 24 carat. Well, in fact, you can't get 24ct,
it will always be 999.999 fine gold.
      ~Steve~
Date: 8 Jun 2009 12:01:10
Message: <4a2d35c6$1@news.povray.org>
As I said later, I looked it up and it's about 91% gold. I realized after
I'd written this that bullion *coin* probably isn't close to 24k. :-)
Date: 8 Jun 2009 13:10:37
Message: <4a2d460d$1@news.povray.org>
news:4a2d35c6$1@news.povray.org...
>> 24ct, it will always be 999.999 fine gold.
 Ah right, well, I didn't read every post in this thread, but it reminds me
of a guy that came to one of my old places of work to sell 150 full gold
sovereigns. He had them in plastic tubes that held ten each, so I picked
them up and was surprised by the weight.
    ~Steve~
