POV-Ray : Newsgroups : povray.off-topic : Advanced Server Time
2 Nov 2026 12:16:29 EST (-0500)
  Advanced (Message 1 to 7 of 7)
Subject: Advanced
Date: 30 May 2009 16:44:20
Message: <4a219aa4$1@news.povray.org>
I have a candle on my windowsil. Do you know, I looked at it this
afternoon, and it had *melted* in the sun. It's now actually welded to
the sil; I can't move it at all.
Do you have any idea what the hell temperature parafin wax melts at?
Friggin' ADVANCED! o_O
http://blog.orphi.me.uk/
Subject: Re: Advanced
Date: 30 May 2009 19:33:03
Message: <4a21c22f$1@news.povray.org>
Paraffin is a by-product of oil refinement.
Essentially it's just solids from mineral oil.
Typically, paraffin used to seal canning jars melts
at a little lower temperature than "candle wax".
Those cheap tea-light candles are mostly paraffin
too, I think. A good bees-wax candle will melt
at a higher temperature, so it will also burn longer.
Taper candles are dipped by the wick. I think
sometimes the center starter wax in a taper
is more paraffin than the outside colored waxes.
Xylene, http://en.wikipedia.org/wiki/Xylene
(aka Goof Off, http://www.goof-off.com/)
should be able to remove what's left after you
chip off the majority of the mess. I'm not sure
what brand that goes by in the UK.
Date: 31 May 2009 15:15:01
Message: <web.4a22d67257ec7d9a34d207310@news.povray.org>
Viscosity will be a continuous function of temperature, and not a step one. A
week at temps above comfortable room temperature might give similar amount of
flow as a few seconds at "melting temperature."
I got a B in a graduate level engineering class on viscosity of glasses.
<retching emoticon>
Date: 1 Jun 2009 04:19:45
Message: <4a238f21@news.povray.org>
> <retching emoticon>
As I understand it, for a pure substance it's a step function, and for a
mixture it tends to be less abrupt. But hey, what would I know about
anything?
Date: 1 Jun 2009 13:24:28
Message: <4a240ecc@news.povray.org>
  Somewhere around 40 degrees celsius.
Date: 1 Jun 2009 13:29:22
Message: <4a240ff2$1@news.povray.org>
Really?
Well, that explains it then. I thought paraffin wax melts at a few
hundred degrees, not merely 40. It could easily have reached that
temperature in my bedroom.
Date: 1 Jun 2009 14:14:21
Message: <4a241a7d@news.povray.org>
> Really?
  Wikipedia seems to confirm my experience:
http://en.wikipedia.org/wiki/Paraffin#Wax
