POV-Ray : Newsgroups : povray.off-topic : Science Server Time
2 Nov 2026 13:23:07 EST (-0500)
  Science (Message 1 to 26 of 26)
Subject: Science
Date: 15 May 2009 10:07:29
Message: <4a0d7721$1@news.povray.org>
Question: Does acetone disolve backup tape?
Answer: Not very quickly.
Subject: Re: Science
Date: 15 May 2009 10:31:30
Message: <4a0d7cc2$1@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:4a0d7721$1@news.povray.org...
   No, the answer is 'Yes'.  :oP
     ~Steve~
Date: 15 May 2009 10:33:02
Message: <4a0d7d1e@news.povray.org>
Question: Which one of us is currently soaking a backup tape in acetone?
Which one of us, therefore, has the experimental data to backup their
position?
(Ya see what I did there?)
Date: 15 May 2009 10:39:47
Message: <4a0d7eb3@news.povray.org>
news:4a0d7d1e@news.povray.org...
> position?
   Erm, no, but while you're doing this experiment, tell me what the backup
tape is made of. Would you say it's the same material as an old 45 or LP
record?
   What happens if you lift the backup tape out of the acetone? Is the
material floppy?
        ~Steve~
Date: 15 May 2009 10:43:48
Message: <4a0d7fa4$1@news.povray.org>
>> position?
> record?
No idea what's it's made of. Some sort of extremely thin yet absurdly
strong plastic, but beyond that I couldn't say.
> material floppy?
The spool is developing a kind of "cracked earth" pattern on its
surface, and there's some ferric oxide floating in the liquid now. But
beyond that, the spool and tape both seem as rock-solid as ever.
Perhaps I need to actually unwind the tape from the spool. That'll take
a seriously long time though; IIRC, there's about 8 km of tape in there! o_O
Date: 15 May 2009 10:56:02
Message: <4a0d8282$1@news.povray.org>
news:4a0d7fa4$1@news.povray.org...
      See below.
>> material floppy?
> The spool is developing a kind of "cracked earth" pattern on its surface,
> and there's some ferric oxide floating in the liquid now. But beyond that,
      Could you lift that ferric oxide out with a magnet?
> Perhaps I need to actually unwind the tape from the spool. That'll take a
     Ah, I see. I've never seen one of these tapes so thought it was either
like a camera film or something more solid like a plastic disc. I would
imagine that if you unravel it, it would dissolve far quicker.
      ~Steve~
Date: 15 May 2009 11:07:02
Message: <4a0d8515@news.povray.org>
> position?
  You didn't ask how long it takes for it to dissolve. You only asked if
it dissolves.
Date: 15 May 2009 11:40:05
Message: <4a0d8cd5$1@news.povray.org>
> it dissolves.
Yes, my mistake.
I implicitly meant "does it disolve faster than the polar icecaps?"
Date: 15 May 2009 11:41:15
Message: <4a0d8d1b@news.povray.org>
news:4a0d8cd5$1@news.povray.org...
>> it dissolves.
> Yes, my mistake.
     I doubt it... ;)
    ~Steve~
Date: 15 May 2009 11:44:01
Message: <4a0d8dc1$1@news.povray.org>
> tape is made of.
Wikipedia suggests it might be Mylar (i.e., polyethylene terephthalate).
I still don't know how to make it disolve though. So far we've tried:
- Acetone
- Hexane
- Butyle acetate
We don't have any other really cheap solvents in our lab...
Oh well, I guess I could try using mineral acid to disolve the iron
coating. :-S
Date: 15 May 2009 12:02:54
Message: <4a0d922e$1@news.povray.org>
news:4a0d8dc1$1@news.povray.org...
>> backup tape is made of.
> Wikipedia suggests it might be Mylar (i.e., polyethylene terephthalate). I
> - Acetone
> - Hexane
> - Butyle acetate
> coating. :-S
    Hmm, interesting that acetone isn't doing the job. I think what you
really need is Cellulose thinners.
       ~Steve~
Date: 15 May 2009 12:08:30
Message: <4a0d937e@news.povray.org>
That's a moving target.
Date: 15 May 2009 12:10:01
Message: <web.4a0d93abb34e56df708085d0@news.povray.org>
> - Acetone
> - Hexane
> - Butyle acetate
> coating. :-S
Just a quick question: *Why* would you want to dissolve it in the first place?
If it is only about rendering it unusable, how about a nice oscillating magnetic
field? Microwave oven? Using a strong hole punch axially on the spool to convert
it to confetti? Cutting the spool in two halves using a strong paper cutter? ...
Or is this a new attempt at data compression - dissolving the bits, to later
distill them into a concentrated powder? :P
Date: 15 May 2009 12:40:47
Message: <4a0d9b0f@news.povray.org>
Dip a Styrofoam cup into some acetone. Hours of fun.. fumy... fumy...
fuuuuuuunnnnnn... with a squishy (and fumy) ball of what was plastic
before. the fumes... they're quite intoxicating... aren't they?
~Mike
Date: 15 May 2009 12:45:25
Message: <4a0d9c25@news.povray.org>
> - Acetone
> - Hexane
> - Butyle acetate
Slow day at the lab? XD
~Mike
Date: 15 May 2009 13:19:10
Message: <4a0da40e$1@news.povray.org>
<SNOOOOORT!>    I'm so smart now!
   There's no CD like OCD, there's no CD I knoooow!
Date: 15 May 2009 14:32:02
Message: <4a0db522$1@news.povray.org>
Butyl acetate does that all by itself... smells like peardrops...
only... stronger. x_x
http://blog.orphi.me.uk/
Date: 15 May 2009 14:33:07
Message: <4a0db563$1@news.povray.org>
Mike Raiford wrote:
>> terephthalate). I still don't know how to make it disolve though. So
>> far we've tried:
>> - Acetone
>> - Hexane
>> - Butyle acetate
...you noticed? :-}
Date: 15 May 2009 14:35:41
Message: <4a0db5fd$1@news.povray.org>
How do you prove that the magnetic field was strong enough to erase it
properly, all the way through? OTOH, if you cut it to ribbons or
dissolve it, there's little doubt that it's destroyed.
Microwave oven would be a tad hazardous, I suggest.
I have tried using a saw to cut it in half, but it's slow, hard work,
and if you don't manually tease the fragments apart, they tend to latch
on to each other at their friad ends, so you can still reconstruct the
correct sequencing. But it takes *ages* to seperate them all by hand...
I also tried the shredder. But it's like trying to shred clingfilm.
Date: 15 May 2009 14:37:03
Message: <4a0db64f$1@news.povray.org>
An individual strand of tape is very weak. However, get a few of them,
and it rapidly becomes *absurdly* strong. Scissors simply won't cut it -
and I have fairly meaty scissors.
Date: 15 May 2009 14:55:04
Message: <op.utzit2hy7bxctx@e6600>
On Fri, 15 May 2009 20:35:46 +0200, Orchid XP v8 <voi### [at] devnull> wrote:
Will it blend?
FE
Date: 15 May 2009 14:56:55
Message: <4a0dbaf7$1@news.povray.org>
Here in the US at least, most companies that provide confidential
document shredding will take magnetic media to be destroyed as well.
Does your company use such a service?
Jim
Date: 15 May 2009 16:06:59
Message: <4a0dcb63$1@news.povray.org>
This could get rid of it and your boss too.
http://www.hurikanincinerators.com/hurikan150e.asp
And it's EU emmision compliant. I bet you could
save up a pile of junk and then rent one for a day.
Date: 15 May 2009 21:10:35
Message: <4a0e128b$1@news.povray.org>
Orchid XP v8 wrote:
>> first place?
>> to convert
>> cutter? ...
Bah.. Thermite!
void main () {
   If Schrödingers_cat is alive or version > 98 {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 15 May 2009 21:59:06
Message: <4a0e1dea$1@news.povray.org>
On Fri, 15 May 2009 18:10:31 -0700, Patrick Elliott wrote:
> Bah.. Thermite!
Shiny. :-)
Jim
Date: 17 May 2009 04:25:01
Message: <web.4a0fc98cb34e56df50167bc0@news.povray.org>
> > tape is made of.
> - Acetone
> - Hexane
> - Butyle acetate
If it's polyethylene of some sort, then it's practically indestructible! Well,
almost.
Looked up 'polyethylene' in wikipeadia; here's what it says:
"Polyethylene (other than cross-linked polyethylene) usually can be dissolved at
elevated temperatures in aromatic hydrocarbons such as toluene or xylene, or in
chlorinated solvents such as trichloroethane or trichlorobenzene."
Mmm, what yummy cancer-causing chemicals!
BTW, it also says that 60 million tons of polyethylene are produced each
year--so all of it will probabably still be around in landfills long after the
human race has died out!
KW
