POV-Ray : Newsgroups : povray.off-topic : Interesting dice problem Server Time
18 Oct 2026 20:52:54 EDT (-0400)
  Interesting dice problem (Message 1 to 20 of 20)
Subject: Interesting dice problem
Date: 14 May 2009 11:32:45
Message: <4a0c399d@news.povray.org>
The rock-paper-scissors game between two people can substitute coin-tossing:
It's played until one of them wins, and that's equivalent to tossing a coin
to see who wins. (Let's forget about the slight non-randomness of human
behavior in this context. It's not the point here.)
  This method of deciding between two things at random between to people
(or two groups of people, eg. teams) is often used when there's no proper
equipment available (in this case a coin).
  Another way of putting it: Two people playing rock-paper-scissors once
(ie. until one of them wins) is equivalent to rolling a 1d2: If the first
person wins, it's like rolling a 1, and if the second person wins, it's
like rolling a 2.
  This gave me an idea for a small thinking problem:
- How should two people play rock-paper-scissors in such way that it's
completely equivalent to rolling a 1d6? Or is it theoretically even
possible?
- How about other die sizes, such as rolling a 1d10 or a 1d20? How about
more difficult sizes, such as 1d3 or 1d5? Is it possible to achieve a
perfect equivalent with rock-paper-scissors?
- How should they play to get the equivalent of throwing multiple dice?
For example, the equivalent of rolling 2d6? How about 3d6 or 4d6? How
about even more complicated situations, such as 2d20 or 3d20?
- Would the problem become easier if there were more than two people
available?
- Would the problem become easier if a more complicated variant of the
rock-paper-scissors game would be used (eg. one with five options, each
option beating two others and being beaten by the remaining two)?
  (If you don't understand dice notation, consult the
http://en.wikipedia.org/wiki/Dice_notation page.)
Subject: Re: Interesting dice problem
Date: 14 May 2009 12:06:33
Message: <4a0c4189@news.povray.org>
I was so enthralled in writing about my idea that I forgot to mention one
important detail:
  Of course the idea in the problem is whether those things can be done
*more efficiently* (ie. with less rounds) using rock-paper-scissors than
by coin-tossing. (Since RPS is completely equivalent to coin-tossing, then
all the problems can be solved in the exact same way as with coin-tossing,
so the RPS element itself would become irrelevant in that way. However, the
whole idea is whether there's a more efficient/faster way of solving the
problems given that RPS is more complicated and has more options than
coin-tossing.)
Date: 14 May 2009 14:36:27
Message: <4a0c64ab$1@news.povray.org>
> possible?
Both people show a number of fingers between 0 and N-1, if we're both
showing the same number I win, otherwise you win.  Then the chance of me
winning assuming best play is 1/N.  You can easily tweak this to get any
rational number.
If you use toes as well as fingers, then sure.
> available?
I think it's highly unlikely.
Yup!
The next (and more difficult question) that follows is this:  Given a
die/dice which we want to mimic, what's the smallest number of options
that the players can be given in a rock-paper-scissors variant which
gives the same odds of winning?  I don't have an answer for this offhand.
Date: 14 May 2009 14:43:54
Message: <4a0c6669@news.povray.org>
> > possible?
> rational number.
  But the idea is to get a random number between 1 and 6.
  Note that rolling a 2d6 is *not* the same as rolling a 1d12 (or, more
precisely, 1d11+1).
Date: 14 May 2009 15:05:00
Message: <web.4a0c6ae21d068a6acac4259f0@news.povray.org>
Still ignoring that RPS isn't completely random:  This wouldn't seem very
efficient to me but it's definitely possible to simulate a die with any number
of sides playing Rock-Paper-Scissors.  For each player generate a binary number
based on RPS wins or losses against any other person (opponent or not*).
Discard the entire set and re-do if the result is zero or exceeds the number of
die-sides simulated.
*An opponent's dice-rolling score must not be affected by your dice-rolling, nor
should your own second die be affected by your first, so a series of RPS rounds
must be played independently for each virtual "die".
For example, Player_A "rolls" a virtual six sided die by playing three rounds of
Rock-Paper-Scissors against  Player_B or anybody else, and takes that score if
the result is in the range 1 - 6.
On a somewhat different note, and actually a little more inefficient, I've
always liked the beauty of selecting between three items (or more by
elimination) using coin flips.  Flip a coin for each item, odd flip wins.  If
all three are the same, start over.
Charles
Date: 14 May 2009 15:10:17
Message: <4a0c6c99$1@news.povray.org>
> precisely, 1d11+1).
I should have read the dice notation page before I posted.  In that
case, if you have N players you can all play rick-paper-scissors at
once, and the winner (if there's no tie) is the person who wins the most
of the pairwise games.  This should be like a 1dN dice roll.  I suppose
you could always play multiple rounds to mimic a MdN roll.
If you're limited to two players it's a bit trickier, but I think it's
still pretty easy to mimic a 1dN roll with the following game:  Both
players pick a number between 0 and N-1, then you add the numbers mod N
and use the result as the value of the "roll".
Date: 14 May 2009 15:15:01
Message: <web.4a0c6ca71d068a6acac4259f0@news.povray.org>
> important detail:
> coin-tossing.)
I think coin tossing between two players has something inherently more efficient
than RPS.  Namely with RPS, there's no way to avoid ties where you have to re-do
the round.  With coin tossing, it doesn't really matter who calls it - it's
called before the toss and there is no tie short of the coin landing on its
edge.
Charles
Date: 14 May 2009 15:24:56
Message: <4a0c7008$1@news.povray.org>
> edge.
This is true only if you're talking about standard rock-paper-scissors,
which Warp isn't.  He's talking about two-player games of the same
nature which are allowed to have different rules, and it's pretty easy
to construct such a game that doesn't allow for ties.  For instance,
both players show zero or one fingers, if the result is even player 1
wins, but if the result is odd player 2 wins.  Assuming best play,
either player wins with 50% probability and there are no ties.
Date: 14 May 2009 16:01:56
Message: <4a0c78b4$1@news.povray.org>
Not having thought too hard, I would say you could basically number the
hands, so rock=0, scissors=1, paper=2, and have people throw. The modulo sum
or difference could be a number between 0 and 2, so you get more bits per throw.
Too busy at the moment to try to deveop the idea further, but if it's
acceptable to just throw fingers (i.e., from 0 to 5 fingers), there's your
1d6 in one throw right there.
   There's no CD like OCD, there's no CD I knoooow!
Date: 14 May 2009 16:04:32
Message: <4a0c7950$1@news.povray.org>
Except in the Big Bang Theory tv show. :-)
(A TV series I highly recommend if you can watch it. Very funny.)
Date: 14 May 2009 16:15:46
Message: <4a0c7bf2$1@news.povray.org>
Turns out it's easy to extend this to a MdN throw by having each player
choose a number between 0 and N^M-1, taking the sum mod N^M and then
using the digits when written in base N as the values for each of the M
die.  It's also possible to get the same result with somewhat fewer
moves per player by mapping the result to "bins" in the distribution
function of the MdN roll.
I think the much more interesting question is weather there's games
smaller than this which can give the same result.  All the examples I've
come up with so far rely on the best strategy being uniformly random,
but if you consider other strategies it might be possible to get a
simpler game.
Date: 14 May 2009 17:29:48
Message: <4a0c8d4c@news.povray.org>
> > edge.
  There's also one rather big difference between coin-tossing and RPS:
The latter allows generating a random number between 1 and 3 (with even
distribution), while with coin-tossing it's more difficult.
Date: 14 May 2009 17:35:12
Message: <4a0c8e90@news.povray.org>
  The problem with only one person doing it is that the roll is not fair:
If the person "doing the roll" has something to gain from a certain result,
he will obviously be biased and deliberately roll the number he wants.
  The whole idea of rock-paper-scissors between two people is that the
result is fair to both, as neither can affect the outcome. It's purely
random.
Date: 14 May 2009 17:43:46
Message: <4a0c9092@news.povray.org>
  But I think it could be made more efficient by noting that RPS can actually
be used to roll random numbers between 1 and 3...
Date: 14 May 2009 18:23:48
Message: <4a0c99f4$1@news.povray.org>
I had meant to imply that the restrictions of the first paragraph apply to
the second paragraph. So each of two people throw out zero to five fingers,
you add them and take the result mod 6, to get another 0 to 5.  The RPS
would just assign 0,1,2 to the three shapes and ignore who "won" the toss.
Date: 15 May 2009 02:21:31
Message: <4a0d09eb@news.povray.org>
  Adding random numbers doesn't give an even distribution.
Date: 15 May 2009 02:42:50
Message: <4a0d0eea$1@news.povray.org>
I think the distribution is even after the modulo. The probabilities of 0
through 5 are the opposite of the probabilities of 6 through 11, so when you
treat the 6 as a 0 and the 11 as a 5, it evens out.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 15 May 2009 03:12:53
Message: <4a0d15f5@news.povray.org>
Darren is indeed correct here (as you might guess I'd claim, since I
suggest the same game).  The optimal strategy in this game is for both
players to play randomly, and thus it gives a number from 0-5 with all
the properties that you find desirable in RPS.
Date: 15 May 2009 03:40:00
Message: <web.4a0d1bc51d068a6acac4259f0@news.povray.org>
I suppose base 3 would run up the many-sided-die quicker than base 2.  ...Using
those ties to be more efficient.  There's some irony there. :-)
Charles
Date: 15 May 2009 20:40:49
Message: <4a0e0b91$1@news.povray.org>
> like rolling a 2.
> possible?
Take the first three results from RPS, represented as A or B, and follow
the rules as given here:
A-A-A:  generate a 1 from a 1d6.
A-A-B:  Continue to play until one player repeats as a winner (including
the result from the third game just played).  If A wins, the 1d6 result
is 1.  If B wins, the 1d6 result is 2.
A-B-A:  Continue to play until one player repeats.  If A repeats, the
1d6 result is 2.  If B repeats, the result is 3.
A-B-B: The 1d6 result is 3.
B-A-A: The 1d6 result is 4.
B-A-B: Continue until one player repeats.  If A repeats, the 1d6 result
is 4.  If B repeats, the 1d6 result is 5.
B-B-A: Continue until one player repeats.  If A repeats, the 1d6 result
is 5.  If B repeats, the 1d6 result is 6.
B-B-B:  The 1d6 result is 6.
The theory behind this is that the various ranges of probability from a
1d6 can be represented as fractions with a radix of 2, giving a lowest
value of .0000~ (infinitely repeating zeros) .1111~ (infinitely
repeating ones).  Generate random zeros and ones until the resulting
fraction definitely falls into one of the ranges in question.
This is easily generalized to 1d10, 1d20, and so on.  1d4 and 1d8 are,
of course, trivial, ending after a finite number of games.
As for generating multiple dice combinations, the simplest solution is
to generate separate die rolls and combine them; or, you could calculate
the different binary representations of the probability ranges for each
possible sum, and generate the values from one stream of RPS results.
John
