POV-Ray : Newsgroups : povray.off-topic : Stupid question of the week Server Time
2 Nov 2026 14:32:52 EST (-0500)
  Stupid question of the week (Message 1 to 25 of 25)
Subject: Stupid question of the week
Date: 10 May 2009 16:04:04
Message: <4a073334$1@news.povray.org>
OK, so here goes...
Under Unix, you can type a shell command and end it with "&" (IIRC), and
it runs in the background. Is there any way of doing this under Windows?
Also, Unix as "sudo". Does Windows have anything similar?
(I just discovered that on Vista, you can't install Haskell packages
because the installer doesn't have permission to write the files. But
how the hell do you *give* it permission??)
http://blog.orphi.me.uk/
Subject: Re: Stupid question of the week
Date: 10 May 2009 16:15:19
Message: <op.utqc7szg7bxctx@e6600>
On Sun, 10 May 2009 22:04:09 +0200, Orchid XP v8 <voi### [at] devnull> wrote:
As far as I know there is no way to run several concurrent processes in a
single command window, but you can use the "start" command to give the new
process its own window.
Yes, "runas".
Right-click the installer and select "Run as administrator".
FE
Date: 10 May 2009 16:25:53
Message: <4a073851@news.povray.org>
>> and it runs in the background. Is there any way of doing this under
>> Windows?
> a single command window, but you can use the "start" command to give the
> new process its own window.
This is what I was looking for. Thanks.
> Yes, "runas".
OK, I'll give that a try.
Hmm. I'd have to compile the installer first. (Usually you just run the
installation program through the Haskell interpretter...)
Presumably I can use runas to give myself a command prompt with admin
access. (?)
Date: 10 May 2009 17:20:48
Message: <4a074530$1@news.povray.org>
Note that this is also the command equivalent for "nice".
Start the haskell interpreter that way. Note that you're really running as
administrator, so files created will be owned by administrator, etc. Sudo
only changes part of your identity.
> access. (?)
Or right-click on the command prompt icon and pick "run as administrator".
   There's no CD like OCD, there's no CD I knoooow!
Date: 11 May 2009 04:15:16
Message: <4a07de94@news.povray.org>
What does "nice" do?
>> the installation program through the Haskell interpretter...)
> as administrator, so files created will be owned by administrator, etc.
> Sudo only changes part of your identity.
I don't think file ownership will be a problem. The permissions on the
folder are set correctly, so I think it'll work.
(I wonder how you get it to do the thing where it *asks* for permission
to do stuff?)
Interestingly, the other day I tried to unzip a file into Program Files
and 7zip couldn't do it. However, Windows Explorer could. (It asked for
permission.) Interesting, eh? :-.
>> access. (?)
This works on XP, but under Vista I couldn't see an option for that...
Date: 11 May 2009 10:25:32
Message: <4a08355c$1@news.povray.org>
	Allows you to run processes at a lower (or higher) priority.
DO NOT REMOVE THIS TAG (UNDER PENALTY OF LAW)
                   /  \/  \ u e e n     /  \/  a w a z
                       >>>>>>mue### [at] nawazorg<<<<<<
                                   anl
Date: 11 May 2009 10:55:16
Message: <4a083c54$1@news.povray.org>
Ah, I see. (Why the heck is it called "nice" then?)
I hadn't noticed the priority options to the "start" command...
Date: 11 May 2009 11:21:02
Message: <4a08425e@news.povray.org>
  Because when you write "nice program" in unix, it will start the program
at a lower priority, so that it will act nicer (ie. consume less resources).
  This comes from the principle that unix is a multiuser system, and one
user hogging all the CPU is not nice, so it was always recommended to
start long-running CPU-heavy programs with "nice".
Date: 11 May 2009 11:58:52
Message: <4a084b3c$1@news.povray.org>
Yeah.  NTFS has a better permissions model than UNIX does, so it's easier to
make sure files in a directory end up properly permissioned.
> to do stuff?)
There's a flag in the header of the executable. Alternately, ...
... you try, you fail with a "permission denied" message, and you put up a
prompt saying "would you like to try again as administrator?"
>> administrator".
Open the start menu (with a left click), navigate until you see the command
prompt icon on the menu, and right click it. The second option should be
"run as administrator". It's the one with the security shield icon next to it.
Alternately, start a command prompt and see if it already says
"administrator" in the title bar, in which case you've already configured
your machine to bypass all the security stuff. :-)
Date: 11 May 2009 13:19:07
Message: <4a085e0b@news.povray.org>
A nice process shares more resources with the rest.
Date: 11 May 2009 13:30:13
Message: <4a0860a5$1@news.povray.org>
Note that "nice" is being used as a verb, as in "make this process nice."
Date: 11 May 2009 13:34:04
Message: <4a08618c@news.povray.org>
  I like how you are comparing a file system to an operating system, like
they were the same type of thing, comparable to each other.
  (One thing I really fail to understand about NTFS: Since NTFS has so
many fancy features, why doesn't WinXP support them? And by support I mean
it doesn't offer any kind of user interface to handle them, not even for
power users, who could benefit from it.
  Is Vista any better in this regard? Knowing Microsoft, I wouldn't be
surprised if it wasn't.)
Date: 11 May 2009 13:35:35
Message: <4a0861e6@news.povray.org>
  Compare to "renice", which changes the priority of an already running
process.
Date: 11 May 2009 14:20:48
Message: <4a086c80$1@news.povray.org>
If UNIX permissions systems suck, you're not going to be able to write a
decent file system permissions mechanism, unless you go outside the realm of
UNIX.  (E.g., SQL has a sophisticated permissions system implemented under
UNIX, but you can't access it via the normal UNIX mechanisms. The same holds
for GFS.)
Just like if your file system sucks, it doesn't matter how good your
permission system is in the OS, it's not going to work on the files. (e.g.,
FAT under NT sucks permissions-wise.)
NTFS only runs under NT/XP/Vista/etc.  NTFS under UNIX has a suckful
permission system, indeed even worse than ext under UNIX. But I knew if I
said XP has a better permission system, someone would gripe about FAT under
XP being worse than UNIX, so I phrased it the way I did very carefully. The
thing holding back good permissions for a file system on Windows is the file
system (FAT sucks, NTFS is good). The thing holding back good permissions
for a file system on UNIX is the kernel (all FS's suck equally, because the
infrastructure needed just isn't in the kernel). Hence the comparison.
Unless you have an example of a UNIX file system whose permissions are
comparable to NTFS's? If you do, let me know, because that would be awesome.
Like what is lacking?  A lot of the more sophisticated features don't make
sense to use without the backing of particular software. For example, it
doesn't make sense to provide a detailed user interface for offlined files
if you don't have any backup software installed that creates offlined files.
The only NTFS feature I'm aware of that doesn't come with some GUI built
into explorer somewhere to handle it is hard and soft links.
It depends what features you're talking about, but generally, yes.
Date: 11 May 2009 15:26:08
Message: <op.utr5luhe7bxctx@e6600>
>> to do stuff?)
Is there? I thought this was configured in the manifest.
FE
Date: 11 May 2009 16:12:57
Message: <4a0886c9$1@news.povray.org>
>>> permission to do stuff?)
I was sloppy. I should have said "it's a flag in the metadata in the
executable".  Better? :-)
Date: 12 May 2009 16:03:28
Message: <4a09d610@news.povray.org>
> awesome.
There ARE ACL systems for Unix.
Date: 12 May 2009 16:54:13
Message: <4a09e1f5$1@news.povray.org>
>> awesome.
Yes, but still based on the UID, on root having all access, and so on. And
as far as I can tell, no per-file encryption, no inherited permissions.
For example, when I can unplug a USB drive off one Unix system and plug it
into a different one and Fred (uid 1002) can't get to Jane's files (also uid
1002) on the USB drive, I'll be pleasantly surprised. Is there anything
already in Linux or whatever to make that work?
Does the Linux equivalent of "active directory" (which was Kerberos last I
looked) interact with the local file system well?
Date: 12 May 2009 17:05:15
Message: <4a09e48b$1@news.povray.org>
> it into a different one and Fred (uid 1002) can't get to Jane's files
> (also uid 1002) on the USB drive, I'll be pleasantly surprised. Is there
> anything already in Linux or whatever to make that work?
Windows does this by assigning to every PC and every domain a large
random number which is hopefully "unique". Every user account created on
a specific PC has that PC's number as part of the account number.
Similarly, every domain user account has the domain number as part of
the account number.
If, by some freak of nature, two machines had the same ID, you could
indeed to weird stuff like what you're suggesting. It's just rather
unlikely. (Cloning a harddrive image and forgetting to randomise the ID
afterwards is about the only way...)
> I looked) interact with the local file system well?
Last I checked, Active Directory uses the (pre-existing) Kerberos
network protocol for authentication.
As I understand it, Kerberos defines the wire protocol for how an
arbitrary client connects to an arbitrary server and authenticates
itself. What kind of security model you build using this is completely
up to you.
In the case of MS, they built the domain model. [Or, more exactly, took
their existing domain model and replaced the horribly broken LANMAN
subsystem with Kerberos.]
Kerberos says nothing about what happens on the local machine. The MS
domain security model does.
Date: 12 May 2009 21:53:01
Message: <4a0a27fd@news.povray.org>
Right. And my basic question there was whether the UNIX stuff underlying the
kerberos can distinguish uid 1002 on one machine from uid 1002 on another
machine.
Date: 12 May 2009 22:16:54
Message: <4a0a2d96$1@news.povray.org>
> And as far as I can tell, no per-file encryption, no inherited
> permissions.
Novell Storage System (NSS) on Linux isn't based on this at all.  ACLs
are completely eDirectory-dependent and root (while they might be able to
see stuff in the filesystem) doesn't automatically have all rights to the
files.
Jim
Date: 12 May 2009 22:54:05
Message: <4a0a364c@news.povray.org>
> the kerberos can distinguish uid 1002 on one machine from uid 1002 on
> another machine.
In the same way a Windows domain has globally-unique UIDs shared between
systems, I guess you could network-mount or in some other way
keep /etc/passwd synced across computers. Then a username will mean the
same UID in any machine.
Date: 12 May 2009 23:10:31
Message: <4a0a3a27@news.povray.org>
How does NSS know who is trying to access the files?  Do you have to use a
non-Linux login to connect to the storage system or something?
Date: 12 May 2009 23:12:31
Message: <4a0a3a9f$1@news.povray.org>
Only if they're all network connected from the start.  I can't take two
already-set-up UNIX machines and connect them both to the same NFS drives
and not expect problems, for example.
Windows manages to make this work even without a domain or network
connectivity.  Sure, you can get around it with work, but the default isn't
to confuse two accounts as one just because they come from different machines.
Date: 13 May 2009 12:57:48
Message: <4a0afc0c@news.povray.org>
> a non-Linux login to connect to the storage system or something?
Yes, you login through eDirectory.
The eDirectory user can be a LUM (Linux User Management) enabled user,
which uses the LDAP integration to authenticate local users to the
directory, but yeah, it can be configured to be entirely independent of
the OS' use of UID.
Jim
