POV-Ray : Newsgroups : povray.off-topic : Infinite sequences and probability Server Time
2 Nov 2026 14:29:20 EST (-0500)
  Infinite sequences and probability (Message 1 to 29 of 29)
Subject: Infinite sequences and probability
Date: 28 Apr 2009 00:17:08
Message: <49f68344@news.povray.org>
Let's say that instead of a 2 sided coin, I have a three state
random generator, which generates each state with equal probability.
        Now I had already shown that the likelihood of getting a
_particular_ infinite sequence was the same as getting a _particular_
value between 0 and 1. (That is, the likelihood is zero - I'm arguing
purely mathematically - let's put the "real" world aside).
        Intuitively, that's because a point is infinitely smaller than
the interval [0,1].
        In fact, if I were to ask the probability of getting a rational
number, the answer is still 0. While the set of rationals is infinite,
it's still infinitely smaller than the unit interval - the latter is of
a higher infinity.
        So how about this one: In my three state random sequence
generator, what is the probability of getting *any* sequence that
doesn't have one of the states? If I were to label the states 0, 1 and
2, the question would be: What is the probability of getting a sequence
that doesn't have 1 in it?
        Now this is equivalent to asking: What is the probability that
if I pick any number at random from [0,1], the number will not have a 1
in it when written with a base 3 expansion?
        It may not be obvious what the solution is. The set of all such
sequences may appear small, but in one sense it isn't: It has the same
cardinality as the real line (it is of the same infinity as [0,1]).
        In point of fact, it's the Cantor set (i.e. what is the
probability that a number you pick will be from the Cantor set?):
http://en.wikipedia.org/wiki/Cantor_set
        Now I'll re-emphasize: While the Cantor set _appears_ to be
small, it is of the same cardinality as [0,1].
        It turns out this set has "measure" 0. And any integral of a
function (the uniform distribution in this case) over a set of measure
zero is 0.
        So the probability of getting any infinite sequence that doesn't
have one of the states is zero. I'm willing to bet that this generalizes
to any base.
        I think it's a cool result - shows that probability theory is at
least consistent.
Guitar for sale. Very cheap. No strings attached.
                   /  \/  \ u e e n     /  \/  a w a z
                       >>>>>>mue### [at] nawazorg<<<<<<
                                   anl
Subject: Re: Infinite sequences and probability
Date: 28 Apr 2009 00:53:52
Message: <49f68be0$1@news.povray.org>
> to any base.
According to wikipedia, any algorithmically random sequence of 'b' symbols
forms a normal number in base 'b'.
http://en.wikipedia.org/wiki/Normal_number
So, yeah. :-) That's really a fascinating page. :-)
   There's no CD like OCD, there's no CD I knoooow!
Date: 28 Apr 2009 01:56:14
Message: <49f69a7e$1@news.povray.org>
I think that it's unfortunately a touch more involved than that.  For
instance:
0.200000....
0.122222....
I think represent the same number on the real line, but one would be in
the set and one wouldn't.  Nevertheless I do think that the Cantor set
is a really intuitively useful visualization in this case, and certainly
works perfectly well for all finite sequences.
 > to any base.
It does, but the proof is probably easier if you compute the limit as
the sequence length goes to infinity rather than visualize it geometrically:
     lim_{n->inf} a^n = 0 if 0 <= a < 1
 > shows that probability theory is at least consistent.
This sort of thing is actually way more subtle than it might appear at
first, but in a very very interesting way.  I've attempted to construct
an example to illustrate this, but I might have botched something so
fair warning:
We'll just consider infinite binary sequences.  First, we'll define an
equivalence relation R on these sequences.  Say that R(x,y) iff y =
xor(x,q) for some sequence q which eventually starts repeating.  Since R
is a relation we can use it to partition the set of infinite binary
sequences into equivalence classes.
Then create a set S with one member of each equivalence class. What's
the probability that a random sequence will be in S?
Now for why this is tricky. Let's say that the probability that a random
sequence is in S is some number, call it p.  You can (if I haven't
messed it up) show that p+p+p+... = 1, which is pretty clearly impossible.
To do this, we'll define an infinite sequence of sets.  First, note that
there's only countably many infinite binary sequences which eventually
repeat, so we can put them in correspondence with the integers.  For
each integer k let's then define q(k) to be the k'th sequence in this order.
Now we'll define an infinite sequence of sets, one for each integer k.
Let S_k be the set of infinite sequences such that S_k = {xor(s,q(k)) :
s in S}.  First note that these sets are all disjoint by virtue of our
definition of S.  Next, note that for any infinite binary sequence, u,
you can find some S_k which contains it by noting that s will have some
representative, s, in S and thus for some k xor(u,q(k)) = s.
Now something very odd has happened here.  We assumed before that the
probability a random sequence was in S was p.  Since each S_k has the
same `measure' as S the chance that a random sequence lies in any S_k is
still p.  Since the S_k sets are pairwise disjoint the chance that a
sequence will be in the union of n them can be found by n*p.  But we
have infinitely many S_k sets and the probability that a sequence is in
their union is one, so we have
1 = sum_{0:inf} p
Since no real number has this property, p cannot exist.  Thus there is
no probability (zero or otherwise) that a random sequence is in S.  Said
in more standard terminology: S has no measure.
This same sort of thing underlies the famous Banach-Tarski paradox, if
you're interested in more.
Date: 28 Apr 2009 06:22:17
Message: <49f6d8d9$1@news.povray.org>
> least consistent.
I don't know if it's just me, but I find certain areas of mathematics
fascinating, and others utterly boring.
For example, take DSP. You've got impulse responses and convolution.
You've got correlation, the Fourier transform, and related transforms.
You've got Fourier duals, trigonometric identities, IIR filters, the
Laplace transform, the Z-transform, transfer functions, the fast Fourier
transform, filter kernel windows, autocorrelation...
Then you have set theory. The entire theory seems to be about nitpicking
and pointless questions such as "are there more rational than irrational
algebraic numbers?" I mean, like, *who cares*?
...and then I spend 2 hours drawing squares and cubes, and shifting
algebra around to painstakingly derive [a special case of] the binomial
theorum from first principles. The euphoria of finally figuring out the
hidden pattern is topped only by the frustration at discovering that
somebody else already figured this out - several thousand years ago.
I guess some questions are just more interesting than others. Certain
areas of mathematics seem to abound with interesting concepts and
beautiful ideas. And other areas seem to involve only splitting hairs
and irritating technicalities.
Date: 28 Apr 2009 07:37:58
Message: <49f6ea96$1@news.povray.org>
Actually, I kinda like the idea of *knowing* that a certain formula,
derived by someone else, is correct, and that I am not simply taking it
on faith.
John
Date: 28 Apr 2009 07:46:09
Message: <49f6ec81$1@news.povray.org>
> zero is 0.
I understand that the Dirac delta function,
http://en.wikipedia.org/wiki/Dirac_delta_function
is an exception to this.
John
Date: 28 Apr 2009 08:23:08
Message: <49f6f52c$1@news.povray.org>
>> binomial theorum from first principles. The euphoria of finally
>> figuring out the hidden pattern is topped only by the frustration at
>> discovering that somebody else already figured this out - several
>> thousand years ago.
> on faith.
Well, it's not so much that. Obviously I suck at math and there are
several centuries (if not millennia) of mathematicians far more clever
than me to check it. It's more that I'm curios to know *why* it works.
(For example, if you have a group of size X, it has subgroups of every
size that is a factor of X - including 1 and X itself. I still don't
completely understand why, but it's still cool.)
Date: 28 Apr 2009 10:39:43
Message: <49f7152f$1@news.povray.org>
> instance:
> 0.200000....
> 0.122222....
	That's only a technicality that I was hoping no one would notice.
Strictly speaking, the Cantor set is the set of all numbers that _can_
be written without a 1 in the base 3 expansion (as in your case) - as
opposed to just numbers that *must* be written without a 1. The
important point is that there are only a countably infinite number of
such "exceptions", and so those exceptions are "tiny" compared to the
whole Cantor set, because the Cantor set has the cardinality of the reals.
	Put another way, I showed that the even if I allow some sequences with
a single 1 to sneak in, the probability is still 0.
	One would be in the set of sequences we're interested in, and the other
wouldn't. In terms of the Cantor set, they're both in it as they are the
same number.
>> to any base.
> geometrically:
	Well, we all know *that*.<G> I was pointing out a different way of
looking at it.
	(Incidentally, I'm not sure I understand your limit. What is 'a' and
why is it fixed?
> 1 = sum_{0:inf} p
	I didn't read the whole thing - xors make my head hurt. But I got the
general idea, having seen similar arguments before. When I was learning
integration theory using measures, I noticed that integrals were always
defined over _measurable_ sets.
	Moral of the story: Don't apply probability to problems constructed
using the axiom of choice.<G>
                                   anl
Date: 28 Apr 2009 10:44:31
Message: <49f7164f$1@news.povray.org>
How quotable is that? :-D
Date: 28 Apr 2009 11:25:12
Message: <49f71fd8@news.povray.org>
To muddy the waters further:
http://en.wikipedia.org/wiki/Almost_surely
                                   anl
Date: 28 Apr 2009 11:31:12
Message: <49f7213f@news.povray.org>
  Seems like my claims about the monkeys and Shakespeare were not, after all,
completely ridiculous.
Date: 28 Apr 2009 12:00:19
Message: <49f72813$1@news.povray.org>
"Mueen Nawaz" <m.n### [at] ieeeorg> wrote in:
So, a probability of 1 doesn't mean 'always', and a probability of 0 doesn't
mean 'never' when there's infinity involved.  Was that so hard?
Tim Cook
http://empyrean.freesitespace.net
Date: 28 Apr 2009 12:35:38
Message: <49f7305a$1@news.povray.org>
I never thought they were completely ridiculous. Just unconvincing. :-)
It's still up in the air for me as to who is right. :-)
Date: 28 Apr 2009 13:22:43
Message: <49f73b62@news.povray.org>
> the interval [0,1].
> a higher infinity.
I think this is relevant:
Date: 28 Apr 2009 13:25:00
Message: <49f73beb@news.povray.org>
And I should learn to read the rest of the thread before posting a reply.
Date: 28 Apr 2009 13:45:26
Message: <49f740b6@news.povray.org>
>> zero is 0.
	Well, it's not exactly a function.
Every hard drive I've ever bought has been larger than all my previous
hard drives combined. And this is without even trying.
--Seen on Slashdot.org
                                   anl
Date: 28 Apr 2009 14:33:45
Message: <49f74c09$1@news.povray.org>
Oh yeah, I certainly wasn't debating the accuracy of the result.  It
appears that you already considered this detail anyway, so my
nit-picking was entirely unnecessary.
I did like the Cantor set analogy by the way.  I didn't forsee it when I
was reading your post and was delighted when you pointed it out.
> same number.
Yeah, that's what I meant.
> why is it fixed?
For base m a would be (m-1)/m -- the probability that a single given
digit of the random sequence doesn't contain a 1 in base m.
>> 1 = sum_{0:inf} p
In that case I'll spare you the trouble of being tempted to read it
later.  I just adapted the construction of a Vitali set from the real
line to infinite binary sequences by replacing addition with xor.  A few
small things changed as a result, but nothing major.
I'm enveious you had an integration theory class that got into measure
theory.  I don't recall such a course being available back when I was
taking math classes, but it would have been pretty fun had there been.
Date: 28 Apr 2009 14:46:14
Message: <49f74ef6@news.povray.org>
I assume by "group" you actually mean to say "cyclic group"?  If not
that might explain why it's proving hard to understand.
Date: 28 Apr 2009 15:23:38
Message: <49f757ba$1@news.povray.org>
I was under the impression the result applies to all groups - which is
why the groups of prime order are always cyclic.
http://blog.orphi.me.uk/
Date: 28 Apr 2009 15:24:24
Message: <49f757e8@news.povray.org>
That is almost surely correct. ;-)
Date: 28 Apr 2009 15:58:53
Message: <49f75ffd$1@news.povray.org>
It is true that every subgroup of a finite group has an order which
divides that of the group (this result has actually been around longer
than group theory itself).  This implies that all prime order groups are
cyclic.
The converse, however, does not hold.  Some finite groups do not have
any subgroups corresponding to some of their order's divisors.
Date: 28 Apr 2009 16:05:00
Message: <49f7616c$1@news.povray.org>
> cyclic.
Ah, right. I guess I missed that technicallity.
Of course, intuitively, it totally makes sense that the order of a
subgroup would have to be a factor of the group's order. I just thought
that every group could be split into subgroups. So I guess there are
large non-prime groups that don't have any [nontrivial] subgroups then?
Date: 28 Apr 2009 16:13:24
Message: <49f76364$1@news.povray.org>
This is not actually true either.  If a group G is of order n, then G
does have a subgroup of every order which is a *prime* factor of n.
It's just that there's no guarantee for composite factors.
Date: 28 Apr 2009 16:15:04
Message: <49f763c8$1@news.povray.org>
>> thought that every group could be split into subgroups. So I guess
>> there are large non-prime groups that don't have any [nontrivial]
>> subgroups then?
> does have a subgroup of every order which is a *prime* factor of n. It's
So, in summary, G *definitely* has subgroups for every prime factor, and
*might* have subgroups for some or all of the composite factors as well?
Date: 28 Apr 2009 16:25:59
Message: <49f76657@news.povray.org>
I believe that is correct.  In addition I think that G must have a
subgroup for every prime power which still divides the order of G.
Weather or not the composite factors have associated subgroups will
indeed depend on the particular group G represents.
As an example consider the group of rotations of a tetrahedron.  It has
12 elements but no subgroup of order 6.
Date: 28 Apr 2009 18:06:48
Message: <49f77df8$1@news.povray.org>
	It popped into my head while reading Darren and Tim argue in the other
thread. Delighted me too to see the relationship.
>> why is it fixed?
	Ah, I get it.
	Well, I think it's standard in the first semester of analysis at the
grad level. Some good schools probably do it at the undergrad. I learned
this stuff only recently - learning as I go along.
Lisa: Oedipus killed his father and married his mother.
Homer: Who payed for THAT wedding?
                                   anl
Date: 29 Apr 2009 05:38:40
Message: <49f82020$1@news.povray.org>
>> and *might* have subgroups for some or all of the composite factors as
>> well?
http://en.wikipedia.org/wiki/Lagrange%27s_theorem_(group_theory)
It seems that for a *commutative* group, my original statements are
correct. I found many other interesting properties, but failed to find
any confirmation of your assertion about prime subgroup orders...
Date: 29 Apr 2009 05:39:10
Message: <49f8203e@news.povray.org>
Wait a minute... this isn't finite sequences and probability! o_O
Date: 29 Apr 2009 05:43:40
Message: <49f8214c$1@news.povray.org>
>>> as well?
>> has 12 elements but no subgroup of order 6.
Wait, here we go:
http://en.wikipedia.org/wiki/Sylow%27s_theorem
