POV-Ray : Newsgroups : povray.off-topic : Very interesting color resolution examples Server Time
18 Oct 2026 22:09:01 EDT (-0400)
  Very interesting color resolution examples (Message 1 to 26 of 26)
Subject: Very interesting color resolution examples
Date: 26 Apr 2009 14:08:58
Message: <49f4a33a$1@news.povray.org>
http://nfggames.com/games/ntsc/visual.shtm
Summary: You really don't see blue very well.
   There's no CD like OCD, there's no CD I knoooow!
Subject: Re: Very interesting color resolution examples
Date: 26 Apr 2009 14:29:26
Message: <49f4a806@news.povray.org>
Would that still hold true in a blue-shaded scene? :P
Date: 26 Apr 2009 16:20:40
Message: <49f4c218$1@news.povray.org>
Give it a try and post the resulting images.  I'm betting that, yes, it
would still hold true.
...Chambers
www.pacificwebguy.com
Date: 26 Apr 2009 17:43:58
Message: <49f4d59e$1@news.povray.org>
"nemesis" <nam### [at] nospam-gmailcom> wrote in message
news:49f4a806@news.povray.org...
http://nfggames.com/games/ntsc/traci_blue3.png
Date: 26 Apr 2009 17:50:05
Message: <49f4d70d@news.povray.org>
Funny, but you know that's just a component.
Date: 26 Apr 2009 17:55:16
Message: <49f4d844$1@news.povray.org>
Well, turns out it's true, yes:
http://www.fileshost.com/download.php?id=BF214D771
It's a gimp file with a decomposed image of a bird in additive layers.
You may select which ones to view.
Very counter-intuitive.  OTOH, it's kind of comforting it is not in our
nature to feel blue. ;)
Date: 26 Apr 2009 18:20:23
Message: <49f4de27@news.povray.org>
news:49f4d70d@news.povray.org...
It may be a component, but it also is an _image_ with only blues...
Date: 27 Apr 2009 02:37:54
Message: <49f552c2@news.povray.org>
I wonder if it is more that you don't see *colour* very well compared to
brightness, not blue compared to green?  It just so happens that the green
channel carries almost all of the brightness information compared to blue.
To test this out you could split into Yuv colour space (or similar) and
reduce the resolution of the u and v channels, I suspect then you could get
away with compressing green colours just as much as blue ones, so long as
the Y (brightness) channel remained at the original quality.
Date: 27 Apr 2009 07:20:00
Message: <web.49f594358b0909c76dd25f0b0@news.povray.org>
I remember once seeing the sun's power spectrum compared to the eye's response
spectrum, possibly at uni. The eye's spectrum follows the sun's very closely -
not suprising considering we evolved under its glare. This of course means that
we are far more sensitive to green light than red or blue, which are at the far
extremes of the visible range. I can't seem to find any refs for this
comparison, but there is a phototopic luminosity function on w'pedia:
http://en.wikipedia.org/wiki/Luminosity_function
....so this probably isn't cutting-edge news... still interesting to see it
demonstrated this way though.
Date: 27 Apr 2009 08:32:11
Message: <49f5a5cb$1@news.povray.org>
And hence is much much darker than an image with only greens.
Try adjusting the brightness of the green one to match the blue (I found
multiplying by 0.3 did it here), then compare side-by-side, now there's not
so much visible difference...
Date: 27 Apr 2009 16:48:25
Message: <49f61a19@news.povray.org>
Gee, do you think this could be somehow related to the fact that only 7%
of the light receptors in your eye are tuned to blue?
Actually, you know what? Screw that... Where can I find this "Traci"??
http://blog.orphi.me.uk/
Date: 28 Apr 2009 00:20:01
Message: <web.49f683368b0909c7f50167bc0@news.povray.org>
Just pondering that evolutionary adaptation is fascinating. I wonder if it came
about from the fact that we descended from tree-or-forest-dwelling animals,
where the predominant color was green? Not that the *entire* earth was
forested, but a good portion of it.  Does it also mean that we humans can now
see subtle gradations of green better than subtle gradations of red or blue?
KW
Date: 28 Apr 2009 04:37:18
Message: <49f6c03e$1@news.povray.org>
The question is... why are leaves green in the first place? Wouldn't
they work so much better if they were black??
Date: 28 Apr 2009 04:57:08
Message: <49f6c4e4$1@news.povray.org>
http://www.sciam.com/article.cfm?id=evolution-of-primate-color-vision
Might be of interest...
Date: 28 Apr 2009 07:31:26
Message: <49f6e90e$1@news.povray.org>
I think it's a given that if the list of links at the bottom had one to
more pix of Traci, that link would get the lion's share of the hits.
John
Date: 28 Apr 2009 10:35:53
Message: <49f71448@news.povray.org>
Kenneth <kdw### [at] earthlinknet> wrote:
> [-- text/plain, encoding 8bit, charset: iso-8859-1, 17 lines --]
  No, it's because of the surface temperature of the Sun. Both leaves and
best vision is at the green amplitude for a common reason.
Date: 28 Apr 2009 12:13:57
Message: <49f72b45$1@news.povray.org>
Leaves are green because water passes green light (to a first approximation).
First plants evolved just below the surface of the water, with purple (red
and blue) color. I.e., the first plants absorbed the abundant green color
while reflecting both the infrared and ultraviolet that was dangerous. You
still see some plants and most photosynthetic anaerobic single-cell
organisms with this coloring. It's also the stuff in your eyes that lets you
see better after 10 minutes in the dark.
Then oxygen-creating photosynthesis evolved in bacteria that lived *under*
the layer of purple algae, which absorbed the purple reflected from that
algae, and hence looks green.
Date: 28 Apr 2009 12:14:37
Message: <49f72b6d$1@news.povray.org>
If green was the best color for light absorbtion, the leaves wouldn't be
*reflecting* green. :-)
Date: 28 Apr 2009 13:05:01
Message: <web.49f736a48b0909c7f50167bc0@news.povray.org>
Cool!  Thanks for that. I need to get that issue of SCIENTIFIC AMERICAN; not
only does it discuss this very topic, but also 'dark energy.' Being a closet
cosmologist at heart, the issue should keep me fascinated for weeks!
KW
Date: 28 Apr 2009 13:25:00
Message: <web.49f73abc8b0909c7f50167bc0@news.povray.org>
I wonder why WE can't see into the ultraviolet (and the infrared?) That
SCIENTIFIC AMERICAN article points out that some existing creatures can see at
least somewhat into the UV spectrum. So their retinas(?) must have developed
some kind of protection that we don't (currently!) have. "Man is the superior
being.": Bah, humbug.
And if we could see into the infrared, then Traci would be looking *oh* so much
nicer.  ;-P
KW
Date: 28 Apr 2009 13:35:01
Message: <web.49f73dfd8b0909c769f956610@news.povray.org>
> nicer.  ;-P
You might say she'd be looking even hotter.
Date: 28 Apr 2009 16:29:18
Message: <49f7671e@news.povray.org>
Le 28/04/2009 18:14, Darren New nous fit lire :
In fact... leaves are not reflecting green... they are reflecting light which YOU
perceive
as green.
Not the same thing.
Take any satellite view in IR or UV, and you will see (in false colors) that all
plants
are not the same "green" (as well as providing information about water-need, it's also
changing from species to species: some smart agency detects drugs-fields that way).
As leaves in autumns show, they have various pigments to react with the light.
Chlorophyll (the whole family) works less with green. Hence the green of leaves.
But in the family, some are more efficient on different red/IR/blue/UV.
Date: 28 Apr 2009 16:46:05
Message: <49f76b0d$1@news.povray.org>
> which YOU perceive as green.
Well, true. Green, amongst others. :-)
> light.
Is that really where the colors come from? Other cholorphyll-related chemicals?
Date: 29 Apr 2009 09:52:54
Message: <49f85bb6$1@news.povray.org>
On 4/28/2009 10:02 AM, Kenneth wrote:
> Being a closet cosmologist at heart, the issue should keep me fascinated for weeks!
Dude, did you just come out of the closet on the POV-Ray newsgroups? :o
...Chambers
Date: 29 Apr 2009 13:45:00
Message: <web.49f891068b0909c7f50167bc0@news.povray.org>
weeks!
Yes, it's true, I can finally admit it:  I AM a wanna-be cosmologist!!
Ah, that felt good. Now I don't have to hide my true feelings from my friends
any longer.
KW
Date: 30 Apr 2009 13:07:32
Message: <49f9dad4@news.povray.org>
Well, they can detect UVA, yes, which is mostly harmless. It's UVB that
causes burns and cancer.
And some people can see just barely into the IR band. I'm one that on
certain IR remotes, I can just barely see the die light up. It's
probably very long wave red that I'm actually seeing, though.
~Mike
