POV-Ray : Newsgroups : povray.off-topic : NP-complete Server Time
18 Oct 2026 23:25:36 EDT (-0400)
  NP-complete (Message 1 to 21 of 21)
Subject: NP-complete
Date: 9 Apr 2009 05:07:35
Message: <49ddbad7$1@news.povray.org>
Hmm, I wonder... If a problem is "NP-complete", does that actually mean
it's impossible to solve? Does it even mean it's necessarily difficult
to solve? I was under the impression that NP-complete merely means it
might take a long time to solve...
Subject: Re: NP-complete
Date: 9 Apr 2009 05:28:52
Message: <49ddbfd4@news.povray.org>
  What makes you think that? Have you even looked at the definition of "NP"?
It's a completely different category from the "non-solvable" category.
Date: 9 Apr 2009 05:50:32
Message: <49ddc4e8@news.povray.org>
Statements like "we use the following heuristic since actually solving
[problem X] is NP-complete". This kind of implies that NP-complete =
impossible to solve.
Yes. Several times. Needless to say, I didn't really understand it very
well.
Date: 9 Apr 2009 09:26:00
Message: <49ddf767@news.povray.org>
  It doesn't imply "impossible to solve". It implies "impossible to solve
in a rational amount of time". People do not have millenia of time to
wait for the program to given a solution.
> well.
  Basically the NP complexity class is composed of those problems for
which the solution cannot, as far as we currently know, be solved in
polynomial time using a deterministic computer (which means that solving
the problem requires at least exponential time), but if a solution is
given, the solution can be verified in polynomial time.
  A problem is "NP-complete" if it can be transformed in polynomial time
into any other NP problem. What this means in practice is that if you ever
find a polynomial-time solution to some specific NP-complete problem, that
exact same solution can be used to solve *all* NP problems in polynomial
time.
  (Note that a solution to an NP-complete problem might not be usable as
a solution to the so-called NP-hard problems, so it makes a difference
whether a problem is NP or NP-hard.)
Date: 9 Apr 2009 12:05:00
Message: <web.49de1baeb57439ee805d39df0@news.povray.org>
I would have thought this would really have driven the point home:
http://xkcd.com/287
 - Ricky
Date: 9 Apr 2009 13:23:50
Message: <49de2f26@news.povray.org>
triple_r <nomail@nomail> wrote:
> http://xkcd.com/287
  Except that the problem depicted there is not NP. It's O(1).
  (It would be NP as a generic problem with unlimited input. With a fixed
input and a fixed goal, it becomes O(1).)
Date: 9 Apr 2009 14:23:26
Message: <49de3d1e$1@news.povray.org>
It's a minor quibble, but I don't think this bit of reasoning holds.
Integer factorization, for instance, has no known polynomial time
algorithm but there are known sub-exponential algorithms.  Also (as I'm
sure you know, but Andrew may not) polynomial time algorithms are
considered part of the NP class, just as far as we know they're disjoint
from the NP-complete class.
I found this picture handy in describing this relationship:
http://upload.wikimedia.org/wikipedia/commons/a/a0/P_np_np-complete_np-hard.svg
One other point which I have messed up before and had Warp correct me
on.  The NP and NP-complete complexity classes are for *decision
problems* only.  That is algorithms which only return a boolean as their
result.  If you want to refer to complexity classes for algorithms which
  return more complicated results, the correct terms are FP (instead of
P) and FNP (instead of NP).
Date: 9 Apr 2009 16:59:07
Message: <49de619b@news.povray.org>
In practice, you should interpret a problem being NP-complete to mean
that any known algorithm will have an exponential worst-case running
time.  This does not necessarily mean that you can't efficiently solve
the problem instances you encounter in practice, or that it's impossible
to quickly solve for an approximate solution.  What sorts of efficiency
gains are possible over the worse-case behavior of an exact algorithm
will depend on the particulars of the problem and the domain to which
you're applying it.
Date: 11 Apr 2009 18:40:05
Message: <49e11c45@news.povray.org>
>> http://xkcd.com/287
Yes, but "General solutions get you a 50% tip", according to the comic
tooltip :D
Date: 14 Apr 2009 04:47:08
Message: <49e44d8c@news.povray.org>
Really? I was under the impression that just recently - ah, wait. No,
they found a polynomial-time primality test, but factorisation. Oh well.
> problems* only.
Yeah, I thought that was the case...
Date: 14 Apr 2009 04:48:50
Message: <49e44df2@news.povray.org>
> you're applying it.
The paper I'm looking at has several places where the program has to
guess a solution that is "good enough" because finding the perfect
solution is "NP-complete". Makes it sound like solving such a problem is
somehow "impossible" - but as you say, all it really means is that it's
slow. (Or at least, *potentially* slow.)
Date: 14 Apr 2009 10:42:48
Message: <49e4a0e8$1@news.povray.org>
Yeah, that's basically correct.  It's a pretty well justified approach
though since often NP-complete problems will take too long to solve
practically in the average case as well as the worst case.
If you haven't done so before, it can be enlightening to write a program
to solve some NP-complete problem by brute force, and then get a feel
for how quickly its running time explodes on larger problems.  It's easy
to rationally know what `exponential' means, but I've known many people
to still be surprised when they see for themselves what that entails in
real life.
What's the paper for out of curiosity?
Date: 14 Apr 2009 10:46:03
Message: <49e4a1ab$1@news.povray.org>
>> is somehow "impossible" - but as you say, all it really means is that
>> it's slow. (Or at least, *potentially* slow.)
> real life.
GraphViz paper on graph layout.
For example, finding a global arrangement of all graph nodes that
minimises the number of edges that cross each other is meant to be
NP-complete.
In this instance, the point is that finding *the* minimum number of
crossings isn't hugely important, so long as the number can be kept
reasonably small. But it's just the implication that this is impossibly
difficult that bothered me. How long can it possibly take to try all
possible permutations of 10 nodes?
Date: 14 Apr 2009 11:03:25
Message: <49e4a5bd$1@news.povray.org>
Really, try implementing a brute force algorithm and see for yourself
how it scales.  Ten nodes may work, but what about twenty?  This is an
important point since if you only have ten nodes you often don't really
need a graph drawing program to visualize it.  It's when the graph
becomes larger that it becomes really useful to automatically draw a
nice picture of it.
If I remember correctly you wanted to draw trees though?  Edge crossings
certainly wouldn't be a problem there.
Date: 14 Apr 2009 11:08:10
Message: <49e4a6da$1@news.povray.org>
>> But it's just the implication that this is impossibly difficult that
>> bothered me. How long can it possibly take to try all possible
Ah, I see. So you mean the problem is that *other people* might try to
draw big graphs with it?
Trees that occasionally have nodes pointing back to their ancesters,
yes. ;-)
Weirdly, GraphViz manages to come up with some *really* strange layouts
- and refuses to obey my hints to lay the graph out the way I actually
want it...
Date: 14 Apr 2009 11:22:30
Message: <49e4aa36@news.povray.org>
Heh, yeah I suppose that's the idea.  I think that "works with graphs of
up to 12 nodes!" is maybe not the best feature for a piece of software
to have.
>> crossings certainly wouldn't be a problem there.
> yes. ;-)
Ahh, that makes sense.  If I remember you didn't want to order of the
nodes to be able to change, in which case you really don't have as much
choice
> want it...
I haven't actually used the program, so I unfortunately can't be of much
help here.  Since you have a small graph and pretty specific formatting
requirements, what happened with the app you were writing yourself to do
the layout?  You could also just draw it in inkscape of course if you
want a really exact layout.
Date: 14 Apr 2009 11:30:04
Message: <49e4abfc$1@news.povray.org>
> to have.
I wonder how big the graphs they use it for are? I mean, you can only
fit a small number of nodes in a single drawing anyway...
>> yes. ;-)
> choice
Yeah, I basically already know the relative XY positions of the nodes, I
just need to put in appropriate spacing and draw the edges nicely. (I
haven't figured out how to control font selection with Cairo yet!)
>> layouts - and refuses to obey my hints to lay the graph out the way I
>> actually want it...
> the layout?
I think I'm going to reimplement it in light of what I've learned from
GraphViz. (E.g., it uses invisible nodes that don't show up on the
drawing, but *do* help it to route edges so they don't collide. I can
copy that easily enough.)
Date: 14 Apr 2009 11:42:22
Message: <49e4aede$1@news.povray.org>
I'd guess that a few tens to a few hundred nodes is not too uncommon.  I
have seen some graph drawings with millions of nodes, but generally
these aren't DAGs and are thus drawn with a different technique.
I'll be interested to see how it looks.  I assume you'll also be
dropping the bounding box for collision avoidance? :)
Date: 14 Apr 2009 16:34:49
Message: <49e4f369$1@news.povray.org>
...Jesus Christ! o_O
OK, sure, you definitely don't want to use an NP-complete algorithm. :-}
Yeah, I'm not overly worried about a few lines crossing. I may or may
not need to do something about avoiding one path being partially on top
of another for any great length though...
http://blog.orphi.me.uk/
Date: 14 Apr 2009 16:43:53
Message: <49e4f589$1@news.povray.org>
Orchid XP v8 wrote:
> I may or may
Assuming you're using invisible nodes to route long edges I don't think
it's possible to have coincident edges, so unless I'm mistaken this
shouldn't be an issue.
Date: 14 Apr 2009 17:01:49
Message: <49e4f9bd$1@news.povray.org>
>> I may or may not need to do something about avoiding one path being
>> partially on top of another for any great length though...
Hmm. If you ensure that all routing is from one row to the adjacent row,
then no, it shouldn't be possible. Good point! (Should also be
impossible for an edge to cross a node.)
