POV-Ray : Newsgroups : povray.off-topic : Good Cookie v2.0 Server Time
22 Mar 2026 13:24:56 EDT (-0400)
  Good Cookie v2.0 (Message 1 to 10 of 10)
Subject: Good Cookie v2.0
Date: 5 Apr 2009 13:12:18
Message: <49d8e672@news.povray.org>
Some of you may remember the first time I posted this recipe .... well fresh
out of the lab version 2.0 is REALLY good, so I thought I'd share. It's
especially good with a cup of coffee.
Enjoy Jim
Chocolate Mocha Pecan Cookie
Ingredients:
2 tablespoons vanilla
1 large egg
3 tablespoons cocoa
4 rounded teaspoons instant coffee crystals (freeze dried)
2 teaspoons water
for 45 seconds to soften, then add the following:
3 tablespoons of cocoa
1 large egg
In a separate cup dissolve the 4 rounded teaspoons of instant coffee in 2
teaspoons of water. Pour it into the bowl with the above ingredients. Mix
pecans and mix them in well. If your hand isn't tired you didn't mix it
enough. Now preheat oven to 350.
2 teaspoons each). Roll them into a ball with your hands. You should get two
dozen good sized cookies. It's okay to make the a bit small. It's easier to
add more to the smaller ones than to take away from the bigger ones.
for about 5 or 6 minutes before you transfer them to a cooling rack.
About the measures:
teaspoon = the spoon you stir your coffee with
tablespoon = a soup spoon
Subject: Re: Good Cookie v2.0
Date: 6 Apr 2009 11:20:41
Message: <49da1dc9$1@news.povray.org>
Jim Holsenback wrote:
> About the measures:
This is very important.
My mum bought one of those automatic bread maker things. Basically it's
a metal box, you put some flour, sugar, salt and of course yeast into
it, press a button on the front, and a metal paddle mixes the stuff
around, leaves it for a while, mixes it some more, and then a heater
element turns on and bakes the dough.
Except that when my mum tried to work it herself, rather than baking a
delicious load of freash bread, it baked something resembling cement. I
was consulted to analyse the fault. So I chiselled some of the
brick-hard stuff out and tasted it. It tasted like pure salt.
Apparently my mother put 0.5 tablespoons of salt in rather than 0.5
teaspoons. Hence the no rising and the burned wheat result. Gah! >_<
Date: 6 Apr 2009 11:32:14
Message: <49da207e@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:49da1dc9$1@news.povray.org...
> > About the measures:
I tend to use pinch of this pinch of that method .....
never did much bread making or things like that. I DO know that baking soda,
baking powder and salt measurements are a bit more critical for baking bread
.... not enough yeast you get hard flat bread .... too much baking soda or
baking powder gives that saltly taste. I don't generally use salt but if she
used 1/2 table instead of 1/2 teaspoon that's about 4 times too much. so no
wonder it didn't turn out.
the cookie recipe is very easy and yes Andrew even you can make it ;-)
Date: 6 Apr 2009 11:37:13
Message: <49da21a9@news.povray.org>
Heh. Ever tried to weigh out 0.5 mg of a crystaline substance? It's not
easy. ;-)
Hey, *I* know the difference between the two. ;-) Didn't take me long to
find out the problem... Those poor yeast cells. They must have been
crushed by the extreme osmotic pressure. Why, they probably autolysed
themselves!
Date: 6 Apr 2009 12:53:44
Message: <49da3398$1@news.povray.org>
That tends to work for cooking, but not baking.  Baking depends on
specific proportions of things being in the dough or it won't produce the
proper chemical reactions.
Jim
Date: 6 Apr 2009 18:16:17
Message: <49da7f31$1@news.povray.org>
"Jim Henderson" <nos### [at] nospamcom> wrote in message
news:49da3398$1@news.povray.org...
haha .... you are absolutely correct ..... tried making some sour dough
bread once. It was a miserable failure.
I guess that I should add, through trial and error I'm able to get
consistently good cookie dough. It's more like a ratio of dry to wet
ingredients. The dough should almost appear dry but forms a ball when you
roll it in your hand.
Jim
Date: 6 Apr 2009 19:59:48
Message: <49da9774$1@news.povray.org>
>> the proper chemical reactions.
One of these days I want to try bread.  Or pizza dough.  I've got the
recipes, but in Salt Lake City the altitude and humidity mean that the
recipes need some adjusting.
> you roll it in your hand.
Yeah, pasta dough is somewhat similar - if it's too wet, it sticks to the
roller. :-)
Jim
Date: 6 Apr 2009 21:36:29
Message: <49daae1d$1@news.povray.org>
news:49da21a9@news.povray.org...
> easy. ;-)
Why 0.5mg? I'm pretty sure if a recipe calls for 0.5mg of salt, anything
between 0mg and 3mg will work just fine, depending on your taste. Just add
roughly the same amount of salt you'd add to similar volumeof soup, salad...
etc. We are not trying to land on the moon here. Reminds me of the oft
stated "objection" to switching to metric units: "What, I'm going to have to
ask for 0.4539 kg of tomatoes from now on?"
Date: 7 Apr 2009 02:27:48
Message: <49daf264$1@news.povray.org>
>> easy. ;-)
Erm, no. I was talking about watching one of the lab technitions
weighing out a chemical reagent. (Do you have any idea how tiny 0.5mg is??)
http://blog.orphi.me.uk/
Date: 7 Apr 2009 16:00:24
Message: <49dbb0d8$1@news.povray.org>
>>> easy. ;-)
Ha, you try weigh out several *micro*grams and then tell me the mg is
difficult ;-)
