Getting real annoyed with the "spam filter" here. Is there a way to set
the bloody thing so that all email received from a group of senders is
"accepted", without hitting the filter, like "*@*mysite.com"? Nearly all
the email I get is non-spam, and it tends to come from Linden Labs
message system, but some of them are getting marked as spam, even when
they have the same subject, like "City of Lost Angels - The Vanguard".
Its damned annoying to have one get through, then a second, just because
it has a few flag words in it that the filter spots, get tossed in the
spam bin. :(
Thanks.
void main () {
If Schrödingers_cat is alive or version > 98 {
if version = "Vista" {
call slow_by_half();
call DRM_everything();
call functional_code();
else
call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Tools->Message Filters.
Add a new one, then set
"From contains mysite.com"
Perform action:
Set junk status to Not Junk.
Take the opportunity to filter it into its own folder, too. :-)
My fortune cookie said, "You will soon be
unable to read this, even at arm's length."
> Perform action:
Uh.. Thanks. And here I thought I would try something "silly" like doing
what "every online system" and other clients do, and just add
"*lindenlab.com" to my address book or a "these are OK" list. :p But,
yeah. Need to look at that. It would be so much easier though if it let
me do what the others do, and mark something as a "group" mailing,
without using a) mailing lists (sorry, this isn't how those groups
work), or b) let me use an email address that isn't in the x@y.z format,
which doesn't work in this case.
Personally, I think its a glaring omission, given the number of Yahoo
Groups, SL group mail, and other similar "everything from this place is
valid" stuff you have around today. You are not longer mass mailing such
groups, using usenet for them all the time, or looking for one clear and
"specific" address. :(
void main () {
else
You can do that. There's a checkbox to say "people in my address book never
send spam." I don't think you can wildcard the addresses in your address book.
Maybe there's a way to whitelist specific addresses.
Yes. For mailing lists, I set "if it's to or cc the mailing list, or it's
from the mailing list, then whitelist it." Note that you have a "contains"
option, so you can see if it "contains @yadda.com" for example.
I also usually sign up for things with different email addresses, so my
erlang mailing list subscription is to dnew+erl### [at] san rr com which makes it
easy to filter.
There's no obvious whitelist other than that or marking them as "not junk"
until you've trained the filter it isn't junk.
> add "*lindenlab.com" to my address book or a "these are OK" list.
A wildcard address on an address book? That makes no sense.
>> doing what "every online system" and other clients do, and just add
> never send spam." I don't think you can wildcard the addresses in your
> address book.
Yeah, I know. Problem is that a) yes, it refuses to wildcard it, and b)
I can't be sure that it is "always" going to be the same address. In
fact, I am fairly sure its not. The originating addresses from linden
are like <group/object name>@<URI key>.lindenlab.com, or something like
that. So, every different object or group is likely to have a
"different" email address, with the only "common" source being the
"lindenlab" part. Needless to say, that makes Thunderbird's absolute
refusal to allow such wildcard addresses a pain in the fracking ass. lol
void main () {
else
So does having no way to use one, as a "accept anything from this
domain" type setting, imho. Oddly, if you create a "mailing list", it
will quite happily "create" such an entry, via the "add this person"
system in that dialog, it just won't work at all. :(
void main () {
else
No. "From contains lindenlab.com" should do the trick. You don't need to
wildcard the whole address. You'll occasionally get spam from
spa### [at] frank lindenlab com co uk or something, but it'll be rare. ;-)
