POV-Ray : Newsgroups : povray.off-topic : The trick Server Time
19 Oct 2026 00:27:32 EDT (-0400)
  The trick (Message 1 to 32 of 32)
Subject: The trick
Date: 12 Mar 2009 10:22:15
Message: <49b91a97$1@news.povray.org>
OK, so does anybody know the trick to taking a parse tree such as
   (2*(5^2))+((8*6)^(x-1)))
and printing it out *without* several billion brackets?
Printing it with brackets as above, or with no brackets at all, is quite
trivial:
   output expr = case expr of
     Operator n x y = "(" ++ output x ++ n ++ output y ++ ")"
     Variable n     = n
     Constant v     = show v
But how do you "decide" when the brackets can or can't be omitted?
Subject: Re: The trick
Date: 12 Mar 2009 11:55:01
Message: <web.49b92f8abf8b5ceb1ccf29180@news.povray.org>
> trivial:
>      Variable n     = n
>      Constant v     = show v
Just a thought:
if the next operator up the tree defers (has lower precedence) to the current
operator, omit the brackets.
eg:
(2*(5^2))+((8*6)^(x-1))) + defers to * --> omit 2*(5^2)+((8*6)^(x-1)))
(2*(5^2)) : * defers to ^ --> omit (2*5^2)
(8*6)^(x-1): ^ doesn't defer to * or - --> don't omit
Date: 12 Mar 2009 12:21:41
Message: <49b93694@news.povray.org>
  If you have the expression in a parsing tree, then that's trivial:
  When printing out the current node (which is an operator), if a child
node has a lower operator precedence, then print that child node in
parentheses. If the child node has a higher precedence, then you can
omit the parentheses.
  An example (you'd better use a fixed-width font):
    3   *
      4   5
  When printing this tree, you start with the root node, ie. the '+'.
Since the root node has no parent, it doesn't need to be printed in
parentheses.
  Now you recurseively print the left subtree and the right subtree.
The left subtree is not an operator, and thus doesn't need parentheses.
It can be printed as-is. The right subtree is an operator: '*'. Since
'*' has a higher precedence than '+', you don't need to print parentheses
around it. Recursively print the subtrees of this '*' node, and you are done.
You get:
    3+4*5
  Another example:
    3   +
      4   5
  This time when printing the right subtree you notice that '+' has a lower
precedence than '*'. Thus you need to print parentheses around it. Otherwise
everything is the same. Thus you get:
    3*(4+5)
  If a child node has the *same* precedence as the current node, that's
more interesting. Now it depends on whether the operator is associative
or not, and if not, which side of the current node it is. For example
'+' is associative and thus if it has a child node which is also '+',
that child node does not need parentheses. However '-' is not associative,
and if it's the right child node of '+' (or '-'), it requires parentheses.
Date: 12 Mar 2009 12:33:28
Message: <49b93958$1@news.povray.org>
I knew somebody round here would know the answer...
>     3   *
>       4   5
> parentheses.
> You get:
>     3+4*5
>   Another example:
>     3   +
>       4   5
>     3*(4+5)
Hmm. OK.
So... maybe when printing out any given subtree, I make the print
function take the precedence of the parent node as an extra argument?
(And omit brackets at the top-level by starting the function with an
infinitely low precedence?)
Ah yes, associativity is a maddening thing. ;-)
Date: 12 Mar 2009 13:05:36
Message: <49b940e0$1@news.povray.org>
I'd to print the parens (if needed) in the parent call before recursing.
   My fortune cookie said, "You will soon be
   unable to read this, even at arm's length."
Date: 12 Mar 2009 19:25:41
Message: <49B999F7.1020001@hotmail.com>
> trivial:
>     Variable n     = n
>     Constant v     = show v
Why not in (reverse) polish, no brackets at all
Date: 13 Mar 2009 05:01:33
Message: <49ba20ed$1@news.povray.org>
If you think *you* can find a suitable encoding for lambda expressions
in reverse polish notation, be my freakin' guest! :-P
Date: 13 Mar 2009 06:18:20
Message: <49BA32EE.4040304@hotmail.com>
I'd say that polish would be enormously more simple than standard infix.
Date: 13 Mar 2009 06:27:20
Message: <49ba3508@news.povray.org>
Not once you add case expressions, let expressions, type signatures and
so forth.
Date: 13 Mar 2009 06:35:12
Message: <49ba36e0$1@news.povray.org>
Fun thing:
   12+3*
   123+*
These two expressions look different, but are guaranteed to produce the
same answer.
Date: 13 Mar 2009 06:41:48
Message: <49BA386E.2030004@hotmail.com>
>>> expressions in reverse polish notation, be my freakin' guest! :-P
> so forth.
The numerical expressions (which is what your question was about) would
still be more simple and there is no rule that other expressions can not
be implemented in another convenient way.
Date: 13 Mar 2009 06:48:39
Message: <49ba3a07@news.povray.org>
> Fun thing:
>   12+3*
>   123+*
> same answer.
I thought that 12+3* means (1+2)*3 and 123+* means (2+3)*1 ???
Date: 13 Mar 2009 06:55:21
Message: <49BA3B9B.9000006@hotmail.com>
On 13-3-2009 11:35, Invisible wrote:
> Fun thing:
>   12+3*
>   123+*
> same answer.
Until now I had never realized that even reversed polish could be
interpreted in more than one way. Your interpretation might be
consistent,though that might require some checking. I would say that the
two expressions reduce to 9 and 5. Note that if you insist that
parameters are eaten from left to right subexpressions are not substrings.
Date: 13 Mar 2009 06:55:29
Message: <49ba3ba1@news.povray.org>
>> Fun thing:
>>   12+3*
>>   123+*
>> the same answer.
I stand corrected.
I was pretty certain I remember there being a way to modify the exact
order in which operations are performed yet always arrive at the same
answer. However, I am currently unable to construct a valid example.
Perhaps my memory is off...
Date: 13 Mar 2009 06:59:50
Message: <49ba3ca6$1@news.povray.org>
How about these?
ABC+*DE+*F*
ABC+DE+**F*
Date: 13 Mar 2009 07:07:51
Message: <49ba3e87$1@news.povray.org>
> How about these?
> ABC+*DE+*F*
> ABC+DE+**F*
Yes they seem the same to me...
Date: 13 Mar 2009 07:08:49
Message: <49ba3ec1$1@news.povray.org>
scott wrote:
>> How about these?
>> ABC+*DE+*F*
>> ABC+DE+**F*
I'M NOT CRAZY! 6_6
Oh, wait...
Date: 13 Mar 2009 07:13:06
Message: <49BA3FC3.4000309@hotmail.com>
> How about these?
> ABC+*DE+*F*
> ABC+DE+**F*
such rewriting indeed works for any operator $ that satisfies
(A$B)$C=A$(B$C) i.e. AB$C$=ABC$$ in RPN.
BTW Why did you choose this example with such a lot or irrelevant detail?
Date: 13 Mar 2009 07:18:59
Message: <49ba4123$1@news.povray.org>
It's easier to do it the other way around. The function only has to care
what the precedence of the current operator is before recursing. The
recursive call can decide what to do about it.
Using this technique, I was also able to "hack" in support for
associativity. For example, in Haskell function application has the
highest possible precedence, and left associativity (because of curried
functions). So, when recursing from a function application call, it
tells the left subtree that the parent's precedence was 8, but it tells
the right subtree that the parent's precedence was 9.
The result is that if you have
   A   B C   D
it prints out as "A B (C D)", which is correct.
(Although, needless to say, I spent a day confusing myself with what
"higher" precedence means, and mixing up left and right associativity.
It probably doesn't help that the function type constructor is
right-associative because the function application operator is
left-associative...)
What can I say? Apparently I'm not very smart.
Date: 13 Mar 2009 07:24:53
Message: <49ba4285$1@news.povray.org>
>> How about these?
>> ABC+*DE+*F*
>> ABC+DE+**F*
So... any associative operation then?
A quick check confirms that
   ABC*-DE*-F- ==> (A-(B*C))-(D*E)-F   ==> A - BC - DE - F
   ABC*DE*--F- ==> (A-((B*C)-(D*E)))-F ==> A - BC + DE - F
which aren't the same.
My brain is like mush this morning. This was the first correct example I
could find. It's about 10 years ago that I discovered this effect, so I
wasn't even sure if I was remembering right!
(Currently attempting to build a Haskell parser, printer and type
interence engine. This stuff is surprisingly non-trivial. Having an
argument about RPN in parallel with these activities is exceeding my
mental capacity!)
Date: 13 Mar 2009 07:38:49
Message: <49BA45CB.8080007@hotmail.com>
On 13-3-2009 12:24, Invisible wrote:
>>> How about these?
>>> ABC+*DE+*F*
>>> ABC+DE+**F*
yes. because associativity is the property that you are using in the
reordering.
I think that as soon as you find an example you try to reduce it to the
bare essentials and post that. The same actually as when posting a bug.
> interence engine.
One word: why?
> mental capacity!)
Date: 13 Mar 2009 07:41:19
Message: <49ba465f$1@news.povray.org>
> reordering.
I guess most people just instinctively "know" that addition and
multiplication are associative (not to mention commutative) without
thinking about it too deeply.
>>> detail?
>> I could find. It's about 10 years ago that I discovered this effect,
>> so I wasn't even sure if I was remembering right!
Ooo, 2 extra operations. Big deal.
>> interence engine.
> One word: why?
Two words: why not?
Date: 13 Mar 2009 07:50:36
Message: <49BA488D.5040707@hotmail.com>
>> the bare essentials and post that. The same actually as when posting a
>> bug.
three and it hides what is actually going on. If you had done it, you
would have realized that it was about associativity yourself.
>>> interence engine.
>> One word: why?
> Two words: why not?
Because you can spend the same time and intellect on something that does
help you in your career. Some thing that will in the end give you some
credit when you finish it. Not familiar with you open university, but
they or similar institutes might have courses that are just as
interesting as trying to build haskell from the ground up. Granted if
you finish that it might be something interesting on your CV, but what
is the change that you will?
Date: 13 Mar 2009 07:58:11
Message: <49ba4a53$1@news.povray.org>
>>> a bug.
What can I say? It wasn't the primary focus of my concentration. I just
wanted to check that my original hypothesis wasn't completely wrong.
>>>> interence engine.
>>> One word: why?
>> Two words: why not?
Well, yeah, that would be better. If I could think of something.
I have serious doubts that such a thing exists. I realise that's not
especially rational, but when you live for so long never receiving any
credit for anything you do, no matter how hard it was to do it, you
start to wonder whether credit actually exists at all.
I looked. The OU in MK don't have anything remotely interesting.
Somebody else might I guess, but how to find them?
If the guys at Strathclyde get back to me it could be very
interesting... but it's been days now, and I've heard nothing.
> Granted if
> is the chance that you will?
I don't know. Depends on how difficult it turns out to be.
FWIW, I'm not really trying to "build Haskell from the ground up".
Rather, I'm trying to make a tool to help untangle complex compile
errors. Basically, I type in some code, and the program tells me what
types it's inferring, so you can try to figure out where it's going wrong.
Date: 13 Mar 2009 08:25:33
Message: <49BA50BE.6050801@hotmail.com>
On 13-3-2009 12:58, Invisible wrote:
>> Some thing that will in the end give you some credit when you finish it.
Not in business (your boss simply assumes you do what you are paid for)
but in education we normally do.
>> Not familiar with you open university, but they or similar institutes
>> might have courses that are just as interesting as trying to build
Does Open here not mean that you don't have to physically go somewhere?
Because I was thinking about one of those. Or the e-learning type of things.
GIYF? Or ask a friend or ask in some random newsgroup.
>> Granted if you finish that it might be something interesting on your
>> CV, but what is the chance that you will?
that is what you are thinking now.
Date: 13 Mar 2009 08:53:10
Message: <49ba5736$1@news.povray.org>
As I say, I'm used to just going through life in the complete absence of
any kind of success, regardless of effort applied. It does things to
your mind.
> things.
Well, perhaps. Personally I think *going* somewhere might not be such a
bad idea. At least it would get me away from this job...
A very seriously doubt that adding more letters after my name will have
any measurable effect on my career prospects. But being in a more
positive and supportive environment might.
Oh, I can find a few things. But how to apply? I'm afraid I don't really
understand all this stuff.
Meh. Some of the Haskell compilers out there are measured in thousands
of lines of code. Nothing I have ever written is nearly that large. If I
write something and it gets to 1,000 lines, I start trying to find ways
to make it simpler.
Date: 13 Mar 2009 10:14:04
Message: <49BA6A2D.7090801@hotmail.com>
> your mind.
Yeah, I noticed. Which does not mean that I have to accept that.
>> things.
I though that this started out as some advise about doing things while
you were still on the job, but that may be just me.
In the Netherlands even dropping a letter before your name can change a lot.
> But being in a more positive and supportive environment might.
yes, but apparently you first have to move to such a place before you
would even contemplate moving. Well, apparently you enjoy recursive
problems.
Apply? You simply fill in some forms I would expect.
Somewhat related: One of my colleagues is very much involved in an
on-line biomedical engineering curriculum (http://www.evicab.eu/). They
have a signal and imaging analysis course, which might be interesting to
you. I can however not immediately find how you can actually do the
on-line exams without being a student on a university.
> to make it simpler.
Date: 13 Mar 2009 12:27:00
Message: <49ba8954$1@news.povray.org>
> so forth.
FORTH
Date: 13 Mar 2009 12:31:24
Message: <49ba8a5c$1@news.povray.org>
> lot.
I'm not sure what that means?
I have noticed that putting "the" before your name gets you noticed.
"I'd like you to meet Darren New."
    "No no. It's The Darren New."
Date: 13 Mar 2009 12:43:45
Message: <49BA8D42.3030009@hotmail.com>
On 13-3-2009 17:31, Darren New wrote:
>> a lot.
An MSc is a Drs (short for Doctorandus, he who must/will become a
doctor) and a PhD is a Dr (the actual Doctor) and we place the titles in
front of the name. So when I did my thesis I went from Drs. Linnenbank
to Dr. Linnenbank. Note that Drs does not mean more than one doctorate,
a mistake sometimes made by some foreigners.
Date: 13 Mar 2009 13:32:15
Message: <49ba989f$1@news.povray.org>
>>> a lot.
I see. We don't do that here. We don't get any letters before we finish.
Altho some pre-PhD students put "ABT" after their name - All But Thesis. :-)
Date: 13 Mar 2009 14:09:37
Message: <49BAA161.7070809@hotmail.com>
But a Drs is a finished MSc.
