"Hello, Customer! (not Customer? click here)"
"Widescreen LCDs are easier to make."
Um, WTF? Why would *that* be??
Also... I just touched my desk and got a static shock. (Like I always
do, several times per day.) But this time, my LCD monitor went black for
a second just as I got the shock. WTF?! o_O
I've had too many bad experiences with dell. Fans and other random hardware
dying on a consistant basis.
Thats why all of my comps at home are HP. Haven't had a single problem with
them since my old 8370 circa 1998.
Back then they blew about as much as the imac I tried. I went through 6
mobos and 4 monitors with that accursed machine. It wasn't even first
gen...it turned me off completely to all things mac.
My next comp will probably be a Cray CX1. Those look sweeeet!
The only way I'm getting that one though is if funding for this biofuels
startup comes through.
One never knows with those things though...I've been involved in enough tech
startups to not beleive anything until I see the money in my account. ;-D
ian
"Invisible" <voi### [at] dev null> wrote in message
news:49b7a362@news.povray.org...
> Also... I just touched my desk and got a static shock. (Like I always do,
> several times per day.) But this time, my LCD monitor went black for a
They wouldn't be _my_ first choice either, frankly.
HP probably would be. And hey, I gather there are moves afoot for the
company to eventually switch from Dell to HP. But for now... I'm stuck
with Dell.
O_O
Uh, yeah... enjoy that one.
news:49b7ad8a$1@news.povray.org...
>> hardware dying on a consistant basis.
>> with them since my old 8370 circa 1998.
> with Dell.
Yeah...never underestimate the effect of commercials on the CIO...
> O_O
They aren't *too* terribly expensive, especially considering what you get.
http://www.cray.com/Products/CX1.aspx
I think that computer, close to maxed out, could hold my interest for a few
years at least. As long as it plays DOOM, right? ;-D
>> tech startups to not beleive anything until I see the money in my
>> account. ;-D
Yeah, its been interesting so far. A decent amount of cash has come my way
in the last few months. I'm just glad that it isn't MY startup...someone
else can deal with all of the annoying crap. I'm just in it for the $$$,
beyond that I couldn't give less of a crap.
ian
Yes. Unlike the IT experts, the commercials use small words that a CIO
can actually understand. :-P
>> O_O
OK, let me get this straight: USD $10,079.00 for a *bare* system??
$91.00 for the POWER CORD?!
Are you mental?? For that money, I could buy three HP DL380s! :-P
Mind you, put 4 CT5401 blades in it, and we have USD $44,795.00. That's
a lot of CPU and GPU, right there... And still less than the price of my
mum's house.
Er, yeah. My freakin *laptop* can do that while running Linux UNDER
SOFTWARE EMULATION! :-P
news:49b7b3b7$1@news.povray.org...
> Yes. Unlike the IT experts, the commercials use small words that a CIO can
;-D
>>> O_O
>> get.
lol...I'm sure its a nice cord. :-p
> Mind you, put 4 CT5401 blades in it, and we have USD $44,795.00. That's a
> mum's house.
Product Information
Model CRAY CX1
Total Processors 12 CPUs
Total Memory 272 GB RAM
Total Storage 2000 GB
Configuration Detail
Item Type Description Quantity SKU
CX1 Enclosure CXC108 1
System CXC108 Chassis 1 CXC108
Active Noise Cancellation Device Active Noise Cancellation Device 1 CX1ANCD
Power Supplies Single Phase Hot Swap Power Module 4 CX1SPHSPM
Gigabit Ethernet Kit Gigabit Ethernet Switch 16 Ports 1 CX1GESW16
Warranty CXC108 - 3 Years Onsite NBD - 24 x 7 Tel Support (World Zone 1) 1
CXC1083YNBD24X7WW1
CX1 Nodes CN5400 4
CN5400 Compute Node CN5400 (Dual Processor) 1 (4) CN5400
Processor Xeon Quad-Core E5472 3.0GHz 12M 1600 MHz 2 (8) H5472
Memory 8GB FBDIMM DDR2 800MHz ECC/Reg. 8 (32) 8GF8
Hard Drive 320GB 7.2K RPM SATA 3Gbps 2.5" 1 (4) 320725
Warranty CX1 Node - 3 Years Onsite NBD - 24 x 7 Call Center Support (WW1) 1
(4) CX1N3YNBD24X7WW1
Gigabit Ethernet Kit Gigabit Ethernet Cable 1 (4) CX1GEC
CX1 Nodes CT5401 1
CT5401 GPU Node CT5401 (DP - 1 x GPU) 1 CT5401
Processor Xeon Quad-Core E5462 2.8GHz 12M 1600 MHz 2 H5462
Memory 2GB FBDIMM DDR2 800MHz ECC/Reg. 4 2GF8
Hard Drive 120GB 7.2K RPM SATA 3Gbps 2.5" 1 120S725
GPU NVIDIA TESLA C1060 1 NVTC1060
Gigabit Ethernet Kit Gigabit Ethernet Cable 1 CX1GEC
CX1N3YNBD24X7WW1
CX1 Nodes CS5404 1
CS5404 Storage Node CS5404 (DP - 4 x HS HDD) 1 CS5404
Processor Xeon Quad-Core E5472 3.0GHz 12M 1600 MHz 2 H5472
Internal Fixed Hard Drive 120GB 7.2K RPM SATA 3Gbps 2.5" 1 120S725
Raid Controller RAID controller LSI SAS/SATA 8704EM2 4 ports, 3GB/s 1
LSI8704EM2
Hot-Swap Hard Drives 120GB 7.2K RPM SATA 3Gbps 2.5" Extended Duty 4
120S725EX
CX1N3YNBD24X7WW1
Rack-Mount Rail Kit Rack-Mount Rail Kit 1 CX1RMRK
Power Cord (kit of 2) CX1 Power Cord USA/JP 2.5M 2 CX1PC2
Packaging Standard Packaging 1 CX1BOX
Quantity 1
Total Price (USD) $101,591.00
Now, THATS a config. :-D
A little more than I want...but hell if I won't get it like that should the
oppertunity arise. :-D
>> few years at least. As long as it plays DOOM, right? ;-D
:-D
Sorry...old meme... :-p
ian
I can think of a few reasons, but none significant enough to actually make a
comment like that. For the backlight it's better to have a longer edge to
inject the light, it's more efficient. For the electrical design having a
longer edge to make connections is better, plus having a shorter distance
top to bottom makes the driver circuits simpler (the left/right drivers just
switch the pixel transistors on/off, the top/bottom drivers actually send
the data so are much more sensitive to the capicitance and resistance in the
lines).
Hehe, we have an ESD gun here for doing exactly that test, hold it on the
screen or on one of the connectors and fire! Usually it does what you say
at the higher voltages, blanks out until it can reset (customers don't like
seeing garbled random data on the screen while the drivers try to reset).
There's a hidden assumption, and I'd change easier to cheaper: Widescreen
LCDs are cheaper to make (for a given diagonal size & ppi, or for a given
diagonal size and horizontal resolution).
I can make 100 20" monitors out of my single 24" monitor (ok the aspect
ratio would be 1000:1 but, hey!) :-)
> the screen or on one of the connectors and fire! Usually it does what
> you say at the higher voltages, blanks out until it can reset (customers
> don't like seeing garbled random data on the screen while the drivers
> try to reset).
I had a notebook computer that had a loose connection between the
controller and the LCD. Every once in a while, you'd tilt the screen and
get a very strange garbled display...
~Mike
> > try to reset).
I knocked an entire can of beer onto my MacBook a couple of years ago. You
should see the interesting brightness pattern the screen now exhibits... :-\
On Wed, 11 Mar 2009 09:13:48 -0500, Mike Raiford <"m[raiford]!at"@gmail.com>
Mine is like that ATM. It is still under warranty but I don't want to waste
rendering time sending it back for repair.
Regards
> make a comment like that. For the backlight it's better to have a
> longer edge to inject the light, it's more efficient. For the
> electrical design having a longer edge to make connections is better,
> plus having a shorter distance top to bottom makes the driver circuits
> simpler (the left/right drivers just switch the pixel transistors
> on/off, the top/bottom drivers actually send the data so are much more
> sensitive to the capicitance and resistance in the lines).
19-inch 4:3 aspect LCD monitor: £159.
19-inch 16:9 aspect LCD monitor: £113.
WTF-O-Meter: 4.6
>> for a second just as I got the shock. WTF?! o_O
> try to reset).
The part I can't figure out is... how is the monitor electrically
connected to the metal beam on the underside of my desk? (The desk
itself is wood. And the monitor housing is plastic.) So how the hell did
the charge get into the LCD??
Hey, *I* am old enough to remember green-screen ATMs. :-P (Complete with
"insert card" burned into the screen...)
Resolution, brightness, contrast, panel technology, etc?
Also, do you think they are just simply making more widescreen monitors now,
so of course the price will be cheaper?
> connected to the metal beam on the underside of my desk? (The desk itself
> is wood. And the monitor housing is plastic.) So how the hell did the
Charge doesn't only go through conductors, one of the tests we do is to
apply a discharge to the plastic casing of the display and to the front
surface (which is definitely not a conductor), it makes its way fine to the
electronics :-)
> now, so of course the price will be cheaper?
Given that the lead time for one is 3-4 days and the other is 3-4
*weeks*... I'm guessing this has far more to do with market forces than
any technological difference in how "easy" it is to make 'em. ;-)
>> did the charge get into the LCD??
> the electronics :-)
o_O
I guess if you apply a few thousand volts to something, life finds a way...
...wait...
Oh, please .. I'm old enough to remember when credit cards had no
magnetic stripe, and credit transactions required carbon paper. :-P
~Mike
On Wed, 11 Mar 2009 10:09:58 -0500, Mike Raiford <"m[raiford]!at"@gmail.com>
I'm old enough to remember... Damn! I forgot. ;)
Regards
news:49b7cfed$1@news.povray.org...
> WTF-O-Meter: 4.6
Makes perfect sense (ceteris peribus). I'm surprised you cannot figure out
why .
I'm involved with prizecapital.net if you are interested in that. Sort of
like X-Prize for biofuel start-ups.
My fortune cookie said, "You will soon be
unable to read this, even at arm's length."
And I'm old enough to have actually collected money that way. :-)
Along with the big book they sent you once a month with all the stolen card
numbers.
> WTF-O-Meter: 4.6
Isn't a 19-inch 16:9 smaller than a 19" 4:3? They're measured on the
diagonal, yes? So the smallest 19" monitor would be a 19:1 monitor?
>> WTF-O-Meter: 4.6
Well let's see now...
4:3 would be 15.2 x 11.4 inches = 173.28 in^2.
16:9 would be 16.55 x 9.31 inches = 154.08 in^2.
Given the miniscule difference, I don't think that has much to do with
it. (I am, however, baffled as to why there's an area difference at all...)
http://blog.orphi.me.uk/
> card numbers.
Touché
Wow, So.... how likely was it that someone would be caught with a stolen
card then? Oh, and no electronic means to check credit limits...
~Mike
>> card numbers.
> Touché
Interesting.
I had always assumed that credit cards exist *because* of electronic
banking. :-P
> banking. :-P
I remember getting utility bills on tractor feed paper, presumably
printed by some huge line printer...
~Mike
Mike Raiford wrote:
>> banking. :-P
I remember being in the office where they *printed* that stuff.
In 1996.
What can I say? County councils aren't the most technologically forward
organisations.
> banking. :-P
Bank cards exist because of electronic banking.
Before electronic authorization, it was mostly things like cards for
particular gas stations or particular stores. You didn't have "mastercard"
or "visa" or (the original) "diner's club." You had "Exxon" cards or
"Texaco" cards.
It was hard to go over your credit limit when gas was $0.30/gallon and
that's all you could buy on the card. :-)
I never caught a bad card, and I think it only happened once or twice the
whole time my Dad owned the gas station. Or, to put it another way, we got
robbed more often than we saw bad credit cards. I think you just either
took the card away or refused to accept it, I don't know which. Most of the
customers using cards were regulars anyway.
There were a bunch of other security features too. Like you couldn't swipe
the same card twice, because the blanks were numbered and the gas company
would turn it down, figuring you put two blanks into the machine and had the
guy sign it. So when someone showed up with a fleet of trucks to get filled
up, we had to change the date on the machine up and down so we didn't get
turned down.
The best was when I handed the paper to the guy to sign, and he writes VOID
across it. I'm like "Excuse me?" He says "Look at the card." Issued to
Henry Void. "Oh, very good Mr Void. Have a nice day." I imagine he has a
worse time than "Mr New" does with that sort of stuff.
On Wed, 11 Mar 2009 15:48:40 -0500, Mike Raiford <"m[raiford]!at"@gmail.com>
wrote:
>> banking. :-P
When I opened my first cheque book account I had to sign an agreement that had a
physical stamp on it. Signifying that stamp duty had been paid and the document
was legal. I should have had my own "Boston Tea Party". :)
Regards
You're baffled as to why two different rectangles with different side
lengths but equivalent diagonals have different areas?
...Chambers
www.pacificwebguy.com
>> all...)
Yes. I was under the impression that the square of the diagonal was
equal to the sum of the squares of the sides, which _should_ mean that
as one side gets shorter, the other side gets longer by exactly the same
amount, holding the area constant.
> >> all...)
That would mean that if one of the sides had zero length, then the other
side would have the same length of the diagonal and the area would still
be the same. Which is obviously impossible.
You are confusing the sum of the squares of the side lengths with the
product of the side lengths. Obviously they are different things.
Yes. Obviously I am wrong, since the actual results do not match my
expectations. All I said was that I am surprised. ;-)
Ironically, I'm currently reading
http://www.apa.org/journals/features/psp7761121.pdf
I guess I'm too stupid to realise how stupid I am... :-/
I'm not sure inflated self-assessment is your main problem right now ;-)
Vincent
Well, I don't know either. I have little to compare against. :-\
I'm not personally authorized to make any kind of official
statement/commitment, but I will talk to the founder today; the board and
partners may be interested as well.
I will let you know.
ian
"Darren New" <dne### [at] san rr com> wrote in message
news:49b81d05@news.povray.org...
>> to apply a discharge to the plastic casing of the display and to the
>> front surface (which is definitely not a conductor), it makes its way
>> fine to the electronics :-)
> o_O
"Lec 1 | MIT 8.02 Electricity and Magnetism, Spring 2002"
http://www.youtube.com/watch?v=3omwHv3Cmog&feature=PlayList&p=C2CEECFD938FD494&index=1
Tor Olav
http://subcube.com
