I told you these would be coming :-)
OK so I have a table like this (there are other columns, but these are the
important 2):
ExpID EventID
1 1
1 3
1 3
1 6
2 1
2 2
2 7
3 2
3 2
3 3
3 4
Where ExpID is the number of an experiment and EventID signifies some event
has happened during that experiment. Note that events can happen more than
once for each experiment.
My goal is to calculate, for example, the % of experiments that have had a
certain EventID happen one or more times.
I have got this far (for counting experiments where EventID 1 happened):
SELECT ExpID FROM Table WHERE EventID=1 GROUP BY ExpID
This gives me a list of ExpIDs where eventID 1 has happened. I can manually
count the rows, but how do I write the SQL to just return the number of
rows? I've tried all sorts of COUNT but it won't work (either returns 1 or
an error).
Also is there any way to calculate the % of experiments (result from that
query above divided by the total number of experiments) in one SQL
statement, or do I have to do that by hand after issuing two statements?
> a certain EventID happen one or more times.
> manually count the rows, but how do I write the SQL to just return the
> number of rows? I've tried all sorts of COUNT but it won't work (either
> returns 1 or an error).
I don't have an SQL engine in front of me, but I would have expected
SELECT ExpID, COUNT(*) FROM Table WHERE EventID=1 GUOP BY ExpID;
to do what you want.
> that query above divided by the total number of experiments) in one SQL
Again, off the top of my head, I would suggest that
SELECT ExpID, COUNT(*) / Total
FROM Table, (SELECT COUNT(*) as Total FROM Table2)
GOUP BY ExpID;
or similar ought to do it. (As you can see, you can run a query inside
another query to generate the total.)
I think I tried that and got back something like:
ExpID Count
1 1
2 1
BTW does it matter if I drop the ExpID after the SELECT, I'm not interested
in any experimentID, just the count of them that have an ID=1 event.
I will try later to see if I actually did try that or not (the code and
database is on another machine).
> GOUP BY ExpID;
Oh ok cool, will experiment with that sort of syntax.
The reason I want it all in one SQL function is that I'm thinking of making
some external text-based file that lists all the possible queries people
might want to run on the data, so then the code will be much simpler (no
repeats of lots of SQL code and associated fluff) and I can change the
queries without modifying the actual code. That way, the user can simply
choose "% failed due to Event blah blah" and the code will get the
associated query from the text file and run it automatically. Someone has
probably already invented a much better way to do this sort of thing, but
hey this is my first database app!
> ExpID Count
> 1 1
> 2 1
Mmm, OK. I'm a little rusty with this stuff. It's been a while. ;-)
> interested in any experimentID, just the count of them that have an ID=1
> event.
OK, what *precisely* are you trying to count?
1. The number of times event X occurred in each experiment?
2. The number of experiments where event X occurred at least once?
If there's one thing you quickly learn about SQL, it's that you need to
have a very clear picture in your brain of exactly what you're answer
you're trying to get. And if you ask people for help, you need to be
very careful about explaining to them what you're after. ;-)
>> GOUP BY ExpID;
That or something like that ought to do it, I believe.
> making some external text-based file that lists all the possible queries
> people might want to run on the data, so then I can
> change the queries without modifying the actual code.
Makes sense.
> Someone has probably already invented a much better way
> to do this sort of thing, but hey this is my first database app!
Well, you could always store the SQL in the database itself! ;-)
This one ^ the number of experiments where event X occurred at least once.
In my first post I said what I had got already:
This gives me a list of unique ExpIDs where event X occurred at least once.
I simply want it to return the count of those returned rows rather than the
rows themselves, so I just want a single number returned. This will then be
divided by the total number of experiments in the database, to give a % of
experiments where event X occurred one or more times.
Cunning :-) Although it would need to be a separate database, as currently
I'm keeping the option open for the user to specify database file to create
and use, so if they want they can keep several separate databases and my app
just works on one of them at a time.
> once. I simply want it to return the count of those returned rows rather
> than the rows themselves, so I just want a single number returned.
In that case, I think you can just do
SELECT count(ExpID) FROM Table WHERE EventID=1 GROUP BY ExpID;
I could be wrong on that though...
> This
> will then be divided by the total number of experiments in the database,
> to give a % of experiments where event X occurred one or more times.
Right. OK.
> currently I'm keeping the option open for the user to specify database
> file to create and use, so if they want they can keep several separate
> databases and my app just works on one of them at a time.
Ah, I see.
Apparently the way the "big boys" do it is with "prepaired statements".
Basically the database contains something like
SELECT count(*) FROM Table WHERE EventID=%X% GROUP BY ExpID;
and each time you use the statement, you get to say what %X% should be.
(This means the database can parse the text of the statement, build a
query plan, optimise it and so forth just once - when the statement is
"prepaired" - and then each time you execute it, it just reuses the
execution plan with the new variable value.) Of course, that's more of
an issue if you're trying to run Amazon.com or something. ;-)
<Clippy> It looks like you're trying to use a relational database! </Clippy>
Seriously, the problem you're running into is that you're using something
that's only mostly relational, without enforcing the
one-identical-row-per-table rule. In particular, you're using "group by" to
eliminate duplicates. But enough theory.
I don't know what database engine you're using, but under MySql, you can say
select distinct expid from exp where eventid=1;
and it'll throw out the duplicate expid's. Then you can say
select count(distinct expid) from exp where eventid=1;
and you'll get just the number of rows.
Of course, the same without the "where" will give you the number of
experiments, so just divide them.
Other servers use the term "unique" instead of "distinct". Check your
documentation.
You can probably assign the results of the two counts to two variables and
then return the ratio all in one transaction without too much trouble. I
don't remember ever coming up with a way of having two "where" statements
easily in one final result.
Another way might be to do something really messy with outer joins on a
table so you get something with an eventid column that's either "1" or NULL,
turn the NULLs into 0's, and then find the AVG(), but it's probably way, way
easier to do two SQL statements, even if you wind up using temp variables
and doing the math on the server.
My fortune cookie said, "You will soon be
unable to read this, even at arm's length."
MS SQL CE, I think you pointed me to that one :-)
> documentation.
Hmmm, SELECT DISTINCT expid works, but SELECT COUNT(DISTINCT expid) throws a
parse error at "DISTINCT" from SQL CE at runtime. Actually I got this
before when I was semi-experimenting the other night and couldn't work out
why that didn't work.
<googling>
OK it seems that SQL CE doesn't support DISTINCT inside COUNT, great. They
suggest workarounds, and this works:
SELECT COUNT(*) FROM (SELECT DISTINCT expid FROM exp WHERE eventid=1) AS T
Finally!
So I take it using SELECT DISTINCT X ... is better than using SELECT X ...
GROUP BY X for what I want to do?
> NULL, turn the NULLs into 0's, and then find the AVG(), but it's probably
> way, way easier to do two SQL statements, even if you wind up using temp
> variables and doing the math on the server.
OK thanks for the tips, I think I will try and get the basic queries working
neatly and fast first :-)
OK, so this is weird.
When I call COUNT(*) FROM (SELECT X ... GROUP BY X) on my test data set
(about 100k eventID rows) it runs in 0.25s. That's a bit slow, but hmm ok.
If I change the SQL statement to COUNT(*) FROM (SELECT DISTINCT X ... ) it
takes 11.27s. Huh?
Also, with the DISTINCT method, as I repeatedly execute the query the
database size seems to have grown from 7MB to 14MB then to 31MB... HUH? The
database size goes up by 4x just by executing a query a few times? Maybe
it's optimising something for future queries, but it doesn't seem to get any
faster the 2nd or 3rd time...
"scott" <sco### [at] scott com> wrote in message
news:49b7765e$1@news.povray.org...
This probably won't help too much following the context established by some
other posts, but if you were just attempting to analyze the data from within
an app you could try C# aggregate functions... You can do % and count, as
well as many other things with those:
saleTotalValueNet_label.Text =
Convert.ToString((decimal)newDataSet.SaleItems.Compute("SUM([totalWithTax])",
Some solution based on this sort of thing would not work as quickly as a
TSQL statement, but I seriously doubt it would increase your DB size either.
If you had a partially narrowed down dataSet, you could just perform the
requisite calculations with aggregate functions (and their output) once to
get the values you are looking for. I don't know what the scope of analysis
or refresh interval might be, and both of which will affect your selection
of an acceptable compound solution.
Just a half-asleep thought...
ian
> ... GROUP BY X for what I want to do?
I don't know. I'd say it's more "correct" in some abstract theoretical
sense, since the only reason you're grouping is to get unique rows. And it
works in the case you're trying. :-)
If you wanted to know how many different types of events each experiment
yielded, you'd do something like
select expid, count(eventid) from exp group by expid
or something like that. (Not gonna fire up SQL to try it.)
But you see what I'm saying there.
> it takes 11.27s. Huh?
I'm guessing when you do a SELECT DISTINCT, it's internally creating a
temporary table.
Do you have an option to compact the database again and see if it shrinks?
Did you perchance close the connection to the database between queries so it
frees up temporary tables? (I'm just guessing here.)
Do these questions not even make sense for the compact edition? :-)
> it frees up temporary tables? (I'm just guessing here.)
Yes they make sense, but I haven't tried that because the speed penalty
seems bad anyway so won't use the distinct method for now.
Yeh I see what you're saying, I'll have to work on importing more realistic
data as my test data is a bit artificial. But the speed so far seems fine
and I'm pretty confident that SQL CE will be capable of doing everything I
need. If I had known it was this easy to set up and work with .net I might
have used it for some other projects too rather than struggling with
filtering and sorting arrays and other data containers!
What indexes have you defined? If you define an index over expid, you may
see a speed increase. 11 seconds seems a bit long for any query on a table
with indexes.
> with indexes.
I had an index on expid already, but looking at it again I think the test
case I used was artificial because almost all of the data was from just one
expid. Using the query for this one, where 99% of records were for this ID,
it took the 11 seconds, but when querying for other expids (where they took
up less than 1% of the table) was way way faster, like 0.1 seconds or
something. I guess if the intermediate result somewhere consists of almost
the whole table it causes some slowdown...
> consists of almost the whole table it causes some slowdown...
That it will do, yes! I suspect "unique" and "group by" are doing things
differently, with "group by" accumulating results and "unique"
post-processing them.
You definitely want a realistic data set before you worry about speed.
