POV-Ray : Newsgroups : povray.off-topic : Good paper on non-ACID databases Server Time
18 Jan 2026 20:52:50 EST (-0500)
  Good paper on non-ACID databases (Message 1 to 10 of 11)
Subject: Good paper on non-ACID databases
Date: 10 Mar 2009 19:57:24
Message: <49b6fe64$1@news.povray.org>
http://queue.acm.org/detail.cfm?id=1394128
Does a good job of describing how to go about breaking ACID for eventual
consistency and higher availability.
   My fortune cookie said, "You will soon be
   unable to read this, even at arm's length."
Subject: Re: Good paper on non-ACID databases
Date: 11 Mar 2009 07:43:11
Message: <49b7a3cf$1@news.povray.org>
It seems to me that "BASE" fundamentally requires an ACID-compliant
database. They're only talking about relaxing consistancy requirements
in a few key areas. A completely non-ACID database wouldn't function
properly. (E.g., if the database engine's own metadata became
inconsistent, the database engine wouldn't be able to read the database
any more.)
All I can say is, I hope *I* never have to deal with a database so vast
that I have to risk having it give me gibberish from time to time just
so that it's "fast enough".
Also...
"For constraints to be applied, the tables must reside on a single
database server, precluding horizontal scaling as transaction rates grow."
Um... why?
Still, now Amazon's message service (whatever the hell it's called)
makes sense.
I do feel, though, that the mechanisms described for processing work now
and restoring consistency later by passing messages, and detecting when
consistency has returned and so forth really ought to be part of the
database engine rather than application code...
Date: 11 Mar 2009 16:07:40
Message: <49b81a0c$1@news.povray.org>
>> eventual consistency and higher availability.
> database.
They describe it in terms of that, but no, it doesn't. Because it's the "C"
they're leaving out, you see. They're saying "this is how you build an
unboundedly large BASE database from smaller ACID databases that may or may
not be online at any given time."
> any more.)
Certainly. But that's not what the "C" means in ACID. Lots of people claim
that's what the "C" means, because they don't have the right kind of "C" and
want to claim they do. "I don't corrupt the entire database when the server
crashes" isn't something to brag about, any more than "I don't stall out
driving down the freeway" is a selling point for an automobile.
It's pretty normal, actually. For example, in the credit card world, "real
time" means "we do it every day, instead of waiting for the end of the
billing cycle."  Do you think when the merchant gives you a refund, you can
then go and spend that money at the next store over 5 minutes later?
> Um... why?
A constraint is the "C" kind of consistency. It says you can't update one
table without checking another table it's OK. (Foreign Keys are one kind of
constraint, but there are lots of others.) If the table with the primary key
and the table with the foreign key are on different servers, and the table
with the primary key crashes, you can't check when you insert a row into the
other table that the constraint is still good.
> makes sense.
Uh, sorta. More like Microsoft's queue mechanism, which is a lot like
Amazon's basic mechanism, except the queue messages can interact with the
same transactions that your SQL server and file system are interacting with.
You can do things like create a transaction, update some SQL rows, queue a
couple messages, and rename a couple of files, then decide you want to roll
it all back, and everyone involved will never see the SQL rows, the
messages, or the file name changes.
Amazon's message service is for doing that sort of thing, but it takes a
different approach to the reliability - you peek the message off the front,
which locks it, and then it's a timeout that releases the message. It's
actually pretty poor if you want to do something like queue POV-Ray renders
for which you have no idea how long they'll take.
It is. This is how it does things when you have *multiple* database engines,
and you want to keep going even when the hardware for some of it has burst
into flames.
Lots of systems are built like this internally, too. For example, there are
mail systems where each rule on processing the email[1] winds up pulling the
email off the queue and putting the new one on the end. Same sort of thing.
[1] Like, "if it doesn't have a domain on the from address, put this domain
on it before it leaves the local intranet."
Date: 11 Mar 2009 16:29:40
Message: <49b81f34@news.povray.org>
>> database.
Sure. Because if you use flat files instead, it's *completely possible*
to allow multiple threads to alter the data without completely screwing
it up.
>> They're only talking about relaxing consistancy requirements in a few
>> key areas. A completely non-ACID database wouldn't function properly.
>> (E.g., if the database engine's own metadata became inconsistent, the
>> database engine wouldn't be able to read the database any more.)
Didn't say it was. It's more to do with A, really. (And D of course.)
> when the server crashes" isn't something to brag about, any more than "I
> don't stall out driving down the freeway" is a selling point for an
> automobile.
I wouldn't mind, but this isn't exactly a trivial thing to guarantee.
>> vast that I have to risk having it give me gibberish from time to time
>> just so that it's "fast enough".
> "real time" means "we do it every day, instead of waiting for the end of
> the billing cycle."  Do you think when the merchant gives you a refund,
> you can then go and spend that money at the next store over 5 minutes
> later?
I would presume so, yes. (Not that I actually own a credit card - or
ever spend money, for that matter...)
>> grow."
>> Um... why?
> one table without checking another table it's OK. (Foreign Keys are one
> kind of constraint, but there are lots of others.) If the table with the
> primary key and the table with the foreign key are on different servers,
> and the table with the primary key crashes, you can't check when you
> insert a row into the other table that the constraint is still good.
OK, so if one of the servers is down, you can't do certain things. I'm
still not seeing why constraints can't be applied across several
databases under normal operating conditions.
>> makes sense.
> the same transactions that your SQL server and file system are
> interacting with. You can do things like create a transaction, update
> some SQL rows, queue a couple messages, and rename a couple of files,
> then decide you want to roll it all back, and everyone involved will
> never see the SQL rows, the messages, or the file name changes.
Mmm, interesting. (Especially given that Microsoft is industry-renouned
for their lack of innovation.)
>> now and restoring consistency later by passing messages, and detecting
>> when consistency has returned and so forth really ought to be part of
>> the database engine rather than application code...
> engines, and you want to keep going even when the hardware for some of
> it has burst into flames.
Well, the article in question is just explaining how to implement this
stuff "by hand". But I guess it wouldn't be so hard to build a small
framework to do it for you. (Read: to do it correctly.)
http://blog.orphi.me.uk/
Date: 11 Mar 2009 16:58:27
Message: <49b825f3@news.povray.org>
>>> database.
> it up.
Who said anything about flat files or multiple threads? Heck, who said
anything about files at all? :-)
OK. I have no idea what you're talking about here. Certainly if your
database didn't have A, C, I, or D, then you'd just have a file system that
can get corrupted. :-)  Like old DOS file systems, say.
>> "I don't corrupt the entire database when the server crashes" isn't
>> something to brag about, any more than "I don't stall out driving down
It has been a well-solved problem for decades. Not trivial, but even your
file system manages it nowadays, let alone something designed for crashes.
>> of the billing cycle."  Do you think when the merchant gives you a
>> refund, you can then go and spend that money at the next store over 5
>> minutes later?
Well, you wouldn't think that, for example, the refund would actually have
to be processed back at the bank before you get credit?
Put it another way: when you mail in the payment for your bill, do you
expect it to be credited before you get back to your flat from the mailbox?
Or would you expect it might take a day or two between the time you write
the check in your checkbook until the time the payment shows up in your
account at the electric company?
Under normal conditions, certainly. But the idea is "this is how you make
function beta keep working when function alpha is down." If Beta has
constraints that depend on ALpha being functional, that doesn't work.
Sure, there's no problem if everything's *working*. This is how you make
google search keep working even when the spiders have crashed. Or how you
keep ads being served to people even when the system that lets you sign up
new customers is rebooting.
They do some good stuff at the high end. And it's not really "innovative".
It's just "100% right".  Whereas most folks are happy with 98% right or so.
Right. If you want to do it small, you don't really need the advice. But
yes, generally you encapsulate that sort of thing in "business logic"
layers.  Or, if you want to do it generically, you can use something like
Erlang, which is how they work all that sort of stuff.
Date: 11 Mar 2009 17:17:46
Message: <49b82a7a$1@news.povray.org>
> it up.
BTW, you *are* aware that all modern desktop-level databases store their
data in flat files and use multiple threads?  Are *are* aware that google's
databases are all stored in "flat files"?
It's actually pretty easy - updates go to the end of the file.
I was reading this the other day. It's pretty good.
http://www.relisoft.com/book/tech/8trans.html
Date: 11 Mar 2009 17:35:41
Message: <49b82ead@news.povray.org>
>> possible* to allow multiple threads to alter the data without
>> completely screwing it up.
Yes. But that's why you have a database - to manage the extreme
complexity for you, so you don't have to do it by hand. You seem to be
under the impression that this is somehow "not necessary".
Date: 11 Mar 2009 17:49:40
Message: <49b831f4$1@news.povray.org>
I'm not sure why you think I said that. However, having said that, all you
need is a decent file system. If you put each record in a different file
with a unique name, you can do a fair amount of goodness with message queues
and such without ever worrying about a database manager.
For example, the traditional mechanism for doing this is to create a file
with a .tmp on the end of the name, and then rename it when it's ready to be
processed. If it doesn't matter what order they're processed in, you take a
sufficiently high-resolution clock, plus an IP address of the host, plus the
PID of the process creating the file, and use that as the file name. You can
have a bunch of machines updating the same file system without causing a
problem.
The way CouchDB works it is when they commit work, they write the header
twice, in widely spaced areas of the file, with a timestamp and checksum at
the end of each. If one checksum is bad, they know the other is the right
header. If both checksums are good, they know the one with the later
timestamp is right.
Either of those work for writing messages in a queue, for example. Write the
message as something like XML, where you can tell if it's complete, put a
checksum at the end, and anything with a bad checksum when you start a
recovery didn't get finished.
If you have separate log files that are append-only until they get too full,
and you keep old copies of accounts, and those accounts are only updated
relatively rarely (say, order fulfillment or credit card clearing), you can
recover from failures by looking thru old logs when you come across a
customer file that's corrupt, looking at the previous customer file, and
replaying the transaction(s) since then.  That's basically what the database
does when it crashes.
I'm just saying, it isn't that complex to accomplish "manually". You need an
ACID database - it's just not that hard to build one if you can avoid making
it general. The hard part of something like Oracle is not the ACID, but the
ACID and high performance regardless of what you store on it. If you know
what you're going to store and you code only the ACID properties you need
(for example, hard-coded constraints instead of TRIGGER statements in SQL),
it's pretty easy to do.
BTDTGTTS.
Date: 11 Mar 2009 18:06:29
Message: <49b835e5$1@news.povray.org>
> need an ACID database - it's just not that hard to build one if you can
> avoid making it general. The hard part of something like Oracle is not
> the ACID, but the ACID and high performance regardless of what you store
> on it. If you know what you're going to store and you code only the ACID
> properties you need (for example, hard-coded constraints instead of
> TRIGGER statements in SQL), it's pretty easy to do.
Personally, I take the view that something like Oracle is the product of
many man-centuries of R&D, designed, implemented and tested by more
experts than you can shake a stick at, and there is basically no way in
hell that anything I alone could design will ever come close to the
performance and reliability of a real DB product such as this. In fact,
I'd think I would probably have trouble just designing something that
produces *correct* results, never mind doing it fast.
Subject: Re: Server crashes (was: Good paper on non-ACID databases)
Date: 12 Mar 2009 19:03:23
Message: <49b994ba@news.povray.org>
Are IIS and Exchange designed for crashes?
We're having power outage problems at work. It has always broken at least
one part of the server. Once it took Exchange down, we spent an hour or two
repairing the DB. Two other times it broke IIS (which Exchange depends on),
fixed by restoring a "metabase" backup. Another time it corrupted the DHCP
database (!), solved by dropping the DHCP service and creating it back...
Last night it decided to corrupt the registry. Today I stayed at work like
two hours more than I use to, and we didn't manage to make it *boot*.
Tomorrow will be hell. Designed for crashes?
We have a UPS since about two power outages ago. Looks like the UPS told
Windows to shut down, then for some reason cut power in the middle of the
shutdown process, making it even worse than without the UPS.
But I shall rant more about it on a separate thread...
