POV-Ray : Newsgroups : povray.off-topic : Standard libraries Server Time
14 Apr 2026 02:32:09 EDT (-0400)
  Standard libraries (Message 1 to 10 of 108)
Subject: Standard libraries
Date: 4 Mar 2009 09:38:08
Message: <49ae9250$1@news.povray.org>
Haskell's array libraries... are a mess. Specifically, there is now
about half a dozen of them.
When I suggested that we should sort this stuff out and make one
consistent library for handling arrays, the general reaction was "no,
we're not going to do that. This is open-source. Competition is good.
We're building a bazaar, not a cathederal."
Um, WTF? I just want to write a program that involves arrays. I
shouldn't have to spent a week examining a dozen libraries that all
provide similar-yet-slightly-different implementations of the same
thing. Not if you want people to take Haskell seriously, at any rate...
I presume the remark is referring to the "cathederal and the bazaar"
that is sometimes referenced in connection with OSS. Does anybody know
what it says? (Presumably it claims that proprietry software is like a
cathederal and OSS is like a bazaar or something...)
Subject: Re: Standard libraries
Date: 4 Mar 2009 11:30:00
Message: <web.49aeab9d2cf0312763a1b7c30@news.povray.org>
My most profound apologies, but
http://tinyurl.com/d6sjjd
 - Ricky
Date: 4 Mar 2009 12:08:02
Message: <49aeb572@news.povray.org>
  WiyF: http://en.wikipedia.org/wiki/The_Cathedral_and_the_Bazaar
Date: 5 Mar 2009 02:26:58
Message: <49af7ec2$1@news.povray.org>
> Haskell's array libraries... are a mess. Specifically, there is now about
Not so different with C and all its derivatives (C++, C++ STL, C++ .net),
there are many different array handling "libraries", fun if you work with
code that uses all sorts of different approaches :-)
Date: 5 Mar 2009 03:41:20
Message: <49af9030@news.povray.org>
  Really? C has no array handling libraries whatsoever (standard C, that is).
The core language has exactly one type of array. (Ok, two if you count
dynamically allocated and statically allocated arrays as distinct, although
they behave basically in the exact same way.)
  The C++ standard libraries have two data containers which could be
considered "arrays" (std::vector and std::deque). Perhaps three if you
count std::string. They are pretty straightforward and well-defined.
Date: 5 Mar 2009 04:30:18
Message: <49af9baa$1@news.povray.org>
> .net), there are many different array handling "libraries", fun if you
> work with code that uses all sorts of different approaches :-)
Yeah. It's a hoot. You use one library that uses array-X, and another
library that uses array-Y, and now your program must waste time
converting from one to the other. Great fun. :-/
It wouldn't be so bad if we were talking about complete libraries that
differ stylistically or something. But we're not. We're talking about
several libraries, each of which only covers about 20% of what you might
like to do. But each library covers a different 20%. Which means you're
virtually *forced* to use several of them at once... *sigh*
Apparently everybody else thinks this is "perfectly OK".
Date: 5 Mar 2009 04:46:13
Message: <49af9f65$1@news.povray.org>
> is).
> although
Yep, and then when you start using .net managed C++ there is the original
.net way of creating arrays, and then the new way...
The problem is when using pre-written code and you're not sure which method
it's using, you have to search back for statements like this:
String[,,] s = new String[5, 3, 10];
vector<int> iV(x, y);
array<int>^myIntArray = {1,2,3,4,5};
Then try and work out what's going on...
Date: 5 Mar 2009 07:08:05
Message: <49afc0a5@news.povray.org>
  But .NET is not standard C++.
Date: 5 Mar 2009 07:46:40
Message: <49afc9b0$1@news.povray.org>
What bit of "Not so different with C and all its derivatives" did you not
get?
Date: 5 Mar 2009 08:23:15
Message: <49afd242@news.povray.org>
> get?
  Check the thread topic.
