I don't believe it.
Our manager is asking why half his network drives are missing. On
investigation, I discover the reason: somebody has replaced his existing
logon script with a brand new one. Written in VB.
You may recall me explaining how the other sites have hundred-line VB
scripts that do absurd amounts of processing at logon. Well, it seems
from this latest development that they intend to push this suboptimal
"solution" onto everybody.
I am so damned *angry* that they would **** around with my systems
without even bothering to warn me. And the thing is, their fancy, whizzy
logon script doesn't *work* properly! And that leaves me with two choices:
1. Wade through a few miles of VB in an attempt to figure out why their
overcomplicated script is broken.
2. Revert it back to the 3-line logon script that I wrote which works
properly.
Option #1 is clearly unsatisfactory, and option #2 is likely to get me
yelled at. I love my job...
Lol, I'd be in the wars at your place. :)
Just change it back to your script.
~Steve~
Make your boss earn his money. Ask for an executive decision.
Regards
Clearly they changed it to add a new drive. If I change it back, we'll
lose that drive. (Although I can easily add it to my script.)
It just makes me angry that they can just silently *change* stuff like
this without warning me. Now when somebody's login script falls over, I
have *no clue* what the problem is. Thanks, guys.
I'm also currently fighting a procedure document problem. Our director
of IT has noticed that I recently revised two local UK procedure
documents, so he wants those to be "retired immediately".
Still, our QA manager suggested that he was going to reply to that
particular request in two words - only one of which is inoffensive.
(After all, there's nothing wrong with "off"...) It seems I'm not the
only one who's irritated.
You're talking about a man who has a packet of sunflower seeds next to
his desk. (I'm not making this up.) Can you spell "bird brain"?
In fact, I take that back. It would be an insult to the birds...
I think my plan of action is to not actually *do* anything at this
point, just ask IT why this was done.
"The IT directory must be made aware of all audit findings relating to
IT so that a proper audit response can be produced."
...because I'm not capable of producing a "proper audit response" all by
myself?
I'm sorry, maybe I *imagined* that last 6 years... but I could have
sworn I've been writing "proper audit responses" since before you were
even employed by this company! :-P
MUST...STOP...TYPING...>_<
Fortunately, I *removed* that comment from my email before I sent it...
Use that to your advantage. Seriously. That the QA manager is upset
about this as well gives you additional leverage to say "this is what my
procedures are supposed to prevent, but nobody follows them and now the
users are being affected by these random changes being introduced into
the systems by the other admins without them telling me about it".
Jim
> myself?
Provide them with copies of your previous audit responses and reports.
Jim
> properly.
3. Tell your boss hackers broke into the system and you need to shut
everything down and clean up the damage done.
My fortune cookie said, "You will soon be
unable to read this, even at arm's length."
Can't you change the passwords used to get into the systems there? If not,
you need to put into writing that you can't be responsible for the systems
if you can't control them.
>> I have *no clue* what the problem is. Thanks, guys.
No. They have all the master passwords; I don't even know what those
are. So they can lock me out, but not the reverse.
> If
> not, you need to put into writing that you can't be responsible for the
> systems if you can't control them.
Heh, yeah. Something like that...
If you have the passwords for the routers, then you have the passwords. :-)
>> If not, you need to put into writing that you can't be responsible for
>> the systems if you can't control them.
Seriously. You should write up what's going on and send it to your boss, his
boss, and so on up the line. Explain they're crashing your systems and you
have no control over it, and ask them what the appropriate procedure should
be for violation of procedures.
> I am so damned *angry* that they would **** around with my systems without
Why don't you try and do something about this rather than just writing on
here what's going on? If your boss isn't listening go higher up until
someone does listen. If nobody listens, document it and do your own thing
(ie block them from modifying your systems), then they will be forced to
listen to you.
But I *don't* have the passwords for the routers.
> his boss, and so on up the line. Explain they're crashing your systems
> and you have no control over it, and ask them what the appropriate
> procedure should be for violation of procedures.
Nobody will care. If I say "they did X, which caused a problem",
everybody will assume I don't know what I'm talking about.
http://blog.orphi.me.uk/
> on here what's going on? If your boss isn't listening go higher up
> until someone does listen. If nobody listens, document it and do your
> own thing (ie block them from modifying your systems), then they will be
> forced to listen to you.
1. Nobody with any authority cares about my opinion. The general
assumption is that I know nothing about anything.
2. How did such technically unskilled people get into senior IT
positions? They did it by being good at company politics. If I try to
play that game, they will beat me.
3. I have no power to block anything.
On Thu, 26 Feb 2009 22:37:20 +0100, Orchid XP v8 <voi### [at] dev null> wrote:
>> passwords. :-)
If you have physical access to the routers, then you make the passwords.
>> boss, his boss, and so on up the line. Explain they're crashing your
>> systems and you have no control over it, and ask them what the
>> appropriate procedure should be for violation of procedures.
It does not matter what they assume or even what they choose to do about
it. What matters is creating a paper trail to cover your own ass.
FE
>> be forced to listen to you.
As fredrik said, and he is the Nth to do so (N>5), you need a paper
trail. Part of your job is to look out for violations of the protocols.
If you don't report them you can be held responsible because you were
not doing your job. If you report and they choose to ignore that, it is
their problem.
It is not about politics, it is about whether your company is violating
the law or not.
You do, but you choose not to use them.
>>> passwords. :-)
Exactly what I was going to say.
Andy, write the damn paper trail already!
Jim
It's a fact that, when hired to do a job, you have the authority to
perform it (assuming the person hiring you had the authority to hire
you, of course).
If they get in the way, do your job anyway, and document it.
If they get mad at you for making necessary changes, even to the point
of firing you, keep the paper trail for future reference (other
employers will ask about what happened... having it documented is
absolutely vital).
...Chambers
www.pacificwebguy.com
>>>> passwords. :-)
> Jim
he has - it's right here... too bad it isn't anything official.
>>>>>> those are. So they can lock me out, but not the reverse.
>>>>> passwords. :-)
>>> passwords.
>>> about it. What matters is creating a paper trail to cover your own
>>> ass.
>> Jim
Yeah, that would make it a bit difficult to use in court. "Yes, I'm
'Invisible', and 'Orchid XP v3', m'lud."
Jim
>>> me yelled at. I love my job...
Don't care about that, just send him an email explaining this all,
writing it as easy and self-explaining to read as possible. Make him do
the decision - you can tell him your opinion, but make sure it's his
call to decide. If you ask from him, you're doing it right, making sure
you're not violating (new) company policies yourself. And do it via
email to make sure it's written down, not just spoken.
Follow these two steps and you are fine:
Step 1: save your own ass properly
Step 2: be profitable for the company
-Aero
