POV-Ray : Newsgroups : povray.off-topic : Epic failure #342 [31KB] Server Time
18 Jan 2026 22:28:49 EST (-0500)
  Epic failure #342 [31KB] (Message 1 to 9 of 9)
Subject: Epic failure #342 [31KB]
Date: 19 Feb 2009 05:14:23
Message: <499d30ff@news.povray.org>
I LOL'd at the fuel consumption of a basic Audi A3 from the UK site.
It seems they just replaced "litres per 100 km" with "miles per gallon"
without bothering to convert the actual numbers!
Download 'image1.jpg' (31 KB)
Preview of image 'image1.jpg'
Subject: Re: Epic failure #342 [31KB]
Date: 20 Feb 2009 04:34:46
Message: <499e7936$1@news.povray.org>
6 MPG? For a big, powerful car like that?
Sounds about right to me! :-D
Date: 20 Feb 2009 05:37:22
Message: <499e87e2@news.povray.org>
What, the Audi A3, it's only a baby (125 BHP weighing 1260 kg)! The A6 or A8
fair enough...
Well the actual figure seems to be 45.6 mpg combined, which is ok-ish for a
petrol car like that (i know of faster and heavier petrol cars that have a
similar figure, and diesel ones that trash it).
Date: 20 Feb 2009 05:51:35
Message: <499e8b37$1@news.povray.org>
> or A8 fair enough...
It looks pretty huge in the picture. ;-)
Mind you, have you ever noticed how when you buy a cake in a shop, the
thing on the box always looks huge, while the contents generally don't
resemble it closely?
> for a petrol car like that (i know of faster and heavier petrol cars
> that have a similar figure, and diesel ones that trash it).
That's almost identical to my Renault Megan. (Although it's been
decreasing lately...)
Date: 20 Feb 2009 06:02:38
Message: <499e8dce$1@news.povray.org>
Renault Megane 4295 x 1808 x 1471 mm
Audi A3 4328 x 1765 x 1421 mm
Seem about the same to me...
I find that usually when the shop is much bigger than your house.  Like when
my mum bought this sofa set from a shop (which is obviously vastly larger
than her living room, and probably our whole road), when she got it home it
looked like twice the size as the one in the shop!
Mine depends how fast I drive, for one whole tank I went on uber-economy
mode and got 55 mpg, most of the time I get around 48-52.
I also found out that turning the air-con off reduced the fuel consumption
by about 3 mpg during normal driving, I wouldn't have expected quite that
much, but there you go.
Date: 20 Feb 2009 06:16:22
Message: <499e9106@news.povray.org>
OK. I guess it just "looks" large then.
It's a bit like how the new mini somehow "looks" small, even though it's
actually bigger than almost every car on the road! o_O
> when my mum bought this sofa set from a shop (which is obviously vastly
> larger than her living room, and probably our whole road), when she got
> it home it looked like twice the size as the one in the shop!
Heh, yeah. But usually the picture on a cake box shows the cake on a
tiny plate, with lots of small things next to it, to make it look really
big. ;-)
Also, at work we often have these magazines like "Perfect Interiors" and
stuff. And you look at the front page and think "yeah, if my house was
that big, *I* could probably make it look good too!" :-P
> Mine depends how fast I drive.
Well, yes. And the terrain and so on. But remember, I drive the same
route every day, at approximately the same speed. Driving along the
motorway really is drastically more efficient. (Except the M45; that's
uphill.)
> consumption by about 3 mpg during normal driving, I wouldn't have
> expected quite that much, but there you go.
I haven't measured any difference.
What I *have* measured is that for the past several weeks, my fuel
efficiency has been slowly decreasing. I recently had the car serviced
(it was overdue) and it's gone up somewhat, but it's still not quite as
high as it used to be.
Date: 20 Feb 2009 07:54:52
Message: <499ea81c@news.povray.org>
> Well, yes. And the terrain and so on. But remember, I drive the same route
> every day, at approximately the same speed. Driving along the motorway
> really is drastically more efficient. (Except the M45; that's uphill.)
Assuming you don't drive faster than 70mph or so, the most important factor
is how often you brake.  Braking wastes energy and is what reduces your fuel
economy.  Driving around towns and off motorways you tend to brake a lot, on
motorways you don't.  When you're driving, try to anticipate when you will
have to brake and take your foot off the accelerator earlier, your target
should be to brake as little as possible!
> efficiency has been slowly decreasing. I recently had the car serviced (it
> was overdue) and it's gone up somewhat, but it's still not quite as high
> as it used to be.
Could be any number of things, air temperature, clogged air filter, leaky
exhaust, old oil, tyre pressures, how often you use headlights/heater/heated
windscreen.
Date: 20 Feb 2009 08:02:58
Message: <499eaa02$1@news.povray.org>
>> uphill.)
> factor is how often you brake.
Yeah. In a town, every 200 yards you arrive at yet another junction. ;-)
>> as high as it used to be.
> leaky exhaust, old oil, tyre pressures, how often you use
> headlights/heater/heated windscreen.
Well, the service involves replacing the air filter, oil filter and oil,
as well as checking all the tyre pressures.
Maybe it's just because it's winter?
Date: 21 Feb 2009 04:04:45
Message: <499fc3ad$1@news.povray.org>
It does effect. When the temperature changes from 0C to -15C, my fuel
consumption raises from ~5,4l/100km (43,5mpg) to ~6l/100km (39,2mpg),
having the avg speed roughly the same (~95km/h).
-Aero
