POV-Ray : Newsgroups : povray.off-topic : Knot theory Server Time
14 Apr 2026 05:14:35 EDT (-0400)
  Knot theory (Message 1 to 10 of 42)
Subject: Knot theory
Date: 17 Feb 2009 06:45:43
Message: <499aa367$1@news.povray.org>
There now follows a large brain dump concerning knot theory...
At one time, it was briefly theorised that maybe the ~105 elements of
the periodic table were each a little tangle of energy, and different
kinds of tangling gave rise to different chemical properties. This
sparked a great deal of interest in knot theory. Later this idea was
abandoned, and knot theory became unpopular again. But some people still
study it.
(With String Theory, the idea seems to be coming back somewhat. But I
digress...)
So what actually *is* knot theory? Well, it's the study of mathematical
"knots". As you might expect, these abstract entities have properties
similar to but not quite the same as a real knot in a piece of string.
Fundamentally, a "knot" is a *closed loop* of infinitely bendy, stretchy
string. Notice that if you have the free ends of a piece of string, you
can (in principle) always untangle it given sufficient patience. A
mathematical knot has not free ends, and hence cannot be untangled.
That's what makes it a well-defined entity that you can sit down and study.
Two tangled up bits of this hypothetical string are considered "the
same" if you can turn one tangle into the other without cutting the
string or allowing it to pass through itself. (Shrinking parts of the
knot down to 0 size to make them dissappear is also cheating.)
It is a basic result of knot theory that it's often insanely hard to
determine whether or not two given knots are actually the same or not.
The simplest knot is just a circle. This is called the "trivial knot" or
"unknot", since it's completely untangled. Notice that if you take an
elastic band, you can tangle it up really good without actually cutting
it; this is *still* considered isomorphic to the trivial knot. The next
up is the trefoil knot. Again, this can have several appearences,
depending on how you arrange it.
It is useful to think of "the knot", which is an invariant, unchanging
thing, and "projections" of the knot. A knot projection is basically a
2D drawing of a particular configuration of the knot. Any given knot has
an infinite number of possible projections, ranging from the simple to
the utterly convoluted.
Aside from stretching and shrinking the string, a knot projection can be
"changed" in three fundamental ways. These ways are named after a
mathematician who's name is beyond my ability to spell or pronounce.
Remember we're talking about knot projections, that is, 2D drawings of a
particular configuration of a knot.
- A type I move involves taking a strand, making a small loop with it,
and poking it over the top of another strand. (Or, alternatively, under
it.) This makes the projection slightly more complicated (there are now
more crossings), but does not alter the knot itself. The reverse
process, i.e., drawing a loop back over (or under) a strand, simplifies
the projection. (Note that a loop *around* a strand cannot be
so-simplified. Only a loop completely over or completely under.)
- A type II move involves taking a straight strand and twisting it to
form a loop. You have now added one new crossing to the projection.
Alternatively, untwisting the strand to eliminate a loop, thus reducing
the number of crossings. (You can only do this if nothing passes through
the loop, of course.)
- A type III move involves moving a strand from one side of an unrelated
crossing to the other.
These three moves, then, alter the 2D projection of a knot without
actually changing its fundamental structure --- i.e., which knot it is.
One of the ways to attempt to classify knots is by the construction of
"knot invariants". A knot invariant is basically something you can
compute from the projection of a knot, and which is the same for *all*
possible projections of a given knot.
An immediate consequence of this is that if two projections yield
different values for a given invariant, they are provably *not* the same
knot. (However, if they yield the same value, this does not prove that
they *are* the same; that would be too easy. It is however a desirable
property that it should be "unlikely" for different knots to yield the
same value.)
The way to construct an invariant, of course, is to prove that all of
the three moves listed above leave the invariant unchanged.
The details of specific invariants escape me now. Suffice it to say that
several mathematicians have come up with polynomials that can be
constructed from a knot projection. The polynomial itself doesn't
calculate anything interesting, but its formula is derived from the knot
projection. The algebraic properties of polynomials are used in such a
way that the three moves change the subterms, but when you simplify it
all into standard polynomial form, you get the same answer.
I remember one of these polynomials involves recursively splitting the
knot projection into simpler ones, eventually building a trivial
polynomial for each part, and then combining these polynomials back
together according to how the original parts where connected. Shift some
algebra, and at the end every projection of a given knot comes up with
the exact same polynomial.
There are invariants which are *not* polynomials. It's simply that most
of the popular invariants happen to be polynomials.
Invariants are a nice way to compare knot projections in an attempt to
see if they are different. But how to *describe* a knot unambiguously?
Well, several methods have been put forward.
One rather entertaining way goes something like this. (I've probably
screwed up the algorithm; this is from memory.)
- Pick a starting point on the string, and draw an arrow representing a
direction. Doesn't matter what you pick, but stick to it.
- Trace your way around the knot. Each time you reach a crossing, number
it, starting from 1. If the strand you're on goes over the top, use a
positive number. If it goes under, assign a negative number.
- Write down a list of all the pairs of numbers at each crossing.
- Throw away the lowest number in each pair (ignoring sign).
It is possible to completely reconstruct the know from the list you're
left with. As an example, I just tried a figure of eight knot. From
this, I get the list
   -1, +4
   +2, -7
   -3, +6
   -5, +8
Throwing away half the numbers, we get +4, -7, +6, +8, in that order.
To reconstruct the knot, we need to fill in the table:
   ??, +4
   ??, -7
   ??, +6
   ??, +8
Since the *first* column is always in ascending order, and each pair
always contains one + and one -, we can reconstruct quite easily. Once
we have the two-column table, you can imagine taking some bendy plastic
tubing with some crossings taped together and connecting the crossings
in ascending order to reproduce the knot. (1 is connected to 2, 2 is
connected to 3...)
This method, of course, just describes a specific projection of a knot.
There are many ways to project the same knot, and hence many possible
sequences of number to describe it. (Changing the starting point also
alters all the numbers.)
An alternative way to describe knots is by "braid theory".
A "braid" is a series of vertical strands. Initially, they are all
parallel. If you say "+3", that means that strand 3 and strand 4 swap
places, with strand 3 going over the top of strand 4. Alternatively,
"-3" means the same swap, but strand 4 going over the top.
In this way, you can say "-3, +5, +2". This describes a sequence of
strand swaps, starting from the top and working downwards. Something
like this:
   1   2   3   4   5   6
   1   2   3   4   5   6
So that's a braid. Now if you imagine taking this and bending it over so
that the ends at the top connect with the ends at the bottom, this would
make a closed loop. In fact, in this case, the result would be *several*
closed loops. The 1 strand would be an unknot, not connected to anything
else. Strands 5 and 6 would become a single strand, which can then be
untwizzled to make an unknot. And strands 2, 3 and 4 would be connected;
off the top of my head, I'm not sure if this would be a nontrivial knot.
Such a collection of possibly-connected knots is called a "link". In
general, "closing" a braid (i.e., connecting its ends together) produces
a link. Sometimes the whole link consists of one knot (i.e., one
continuous strand), and sometimes several knots that can be seperated.
And occasionally, several knots connected such that you can't seperate
them without cutting.
The fun part, of course, is the algebraic structure of a braid.
Sometimes when you move a twist up or down the sequence, it changes the
resulting link when the braid is closed. And sometimes it doesn't.
Teasing how the relationships for this can get quite interesting.
Best of all: any possible knot or link can be represented as a braid.
(Although working out how usually isn't easy.)
Another method for constructing knots is to use "tangles".
A "tangle" is a section of string or strings that have 4 ends. The ends
are locked in place and can't move, and you can't loop the strands over
those ends. If you imagine drawing a square with one end bolted to each
corner of the square and the strands inside not allowed to leav the
confines of the square, that's roughly what a tangle is.
Again we have an algebra of tangle construction here. (I may well be
getting some lefts/rights mixed up here, but the ideas are essentially
correct.)
We start with the "0 tangle". This is where the two top corners are
linked, and the two bottom corners are linked, and the strands aren't
tangled up in any way.
Then we have the "1 tangle". This is where you take the 0 tangle and
swap round the two right ends, such that the strand from the bottom-left
corner passes over the one from the top-left corner. The "-1 tangle" is
identical, but twisted the opposite way. (I.e., the top-left thread is
on top.)
You can "add" two tangles together by placing them side by side, and
connecting the two right-hand ends of the left tangle to the two
left-hand ends of the right tangle.
If, for example, you add a 0 tangle to a 0 tangle, you get a new 0
tangle. If you add a 1 tangle to a -1 tangle, you also get... a tangle
where one thread moves over the other, and then back again. Performing a
type-I move, this becomes the 0 tangle again.
So, 0 + 0 = 0 and (+1) + (-1) = 0. That's cute. But if you add a 1
tangle to a 2 tangle, you get a tangle where the two threads cross over
each other twice in the same direction - the "2 tangle". (A "-2 tangle"
is defined similarly, but with the twist in the opposite direction.)
So, an N tangle is the 0 tangle twisted N times clockwise, and a -N
tangle is twisted N times anticlockwise. (Assuming you look at it from
the right direction.)
There is also an "infinity tangle", which is like the 0 tangle, rotated
This involves placing one above the over, and joining the corners in
that direction instead.
Here, however, we find that tangle algebra doesn't work *quite* like
number arithmetic; if you multiply the 0 tangle by the 0 tangle, you get
something that isn't even a tangle; it's like a 0 tangle with a trivial
knot floating in the middle of it. And a 1 tangle multiplied by a 1
tangle gives you something that can't be described any other way. (In
particular, *not* a 1 tangle!)
By pairing up the ends of a tangle (either vertically or horizontally -
it makes a difference) you can again construct any possible knot. And
again there's an interesting algebra of operations which are equivilent
and those which are not.
In a similar way, you can "add" regular knots. You take two knots, cut
them both, and join the cut parts. The thing is, depending on exactly
where you cut them, and how you join the ends up, you can make several
different knots in any addition operation. So for general knots,
"adding" isn't very precisely defined. (At least, if you just specify
two knots and that they be added, the result is not well-defined. You
need to specify lots of extra info to make it well-defined. Even the
knot projection might make a difference.)
There are other ways of making knots too. The trefoil is a "toriodal
knot". That is, you can generate it by marking a point on a circle, and
rotating that circle while sweeping it around a perpendicular circle.
(In other words, tracing a path on the surface of a torus.) By varying
the number of rotations of one circle for each rotation of the other,
you can build various different knots, of which the trefoil is just one.
(There is an infinite set of parameters that generate any given toriodal
knot, however.)
Related to this are "cable knots". This involves sweeping a circle not
along a circle but along another knot. Sometimes the result can be
unravelled to be isomorphic to the original knot; sometimes it can't.
(In other words, sometimes it's a genuinely new knot.) You can also
generate links this way by not rotating the circle as it is swept;
sometimes these links are seperable, and sometimes they aren't.
What about knots in 4D instead of just 3D? What would that be like?
Well, it turns out to be pretty boring, actually. In 4D, and knot
composed of a 1D strand can actually be completely untangled. That is,
every knot is equivilent to the trivial knot in 4D. That's not terribly
interesting.
What you *can* do, however, is construct knots out of a 2D "ribbon"
rather than a 1D "string". The result is a family of knots that only
exist in 4D, but it's really *far* too mind-bending to think about.
(Projecting back into 3D can look pretty though...)
While we're on the subject of pretty pictures, there is various software
to perform "knot relaxation". The idea is to take a description of a
knot, and try to "simplify" it by treating the knot as being made out of
bendy, stretchy plastic and doing a small physical simulation. An
intricately tangled length of string is likely to untangle itself given
sufficient energy to escape any local minima and assume a low-energy
final state.
It can be quite interesting to watch, and it's sometimes a useful way to
figure out if two knots are the same. If they are, they typically tend
to assume similar final configurations. (But not always...)
This has been another broadcast brought to you by an under-employed
computer science graduate, for the benefit of similarly over-interested
souls. TTFN!
Subject: Re: Knot theory
Date: 17 Feb 2009 06:48:56
Message: <499aa428@news.povray.org>
...and now to check Wikipedia and find out whether all that stuff I just
wrote is even remotely correct! :-D
Date: 17 Feb 2009 07:23:25
Message: <499aac3d$1@news.povray.org>
An interesting read, are there any real world applications currently?  If I
knit myself a jumper and then join the two lose ends together, what sort of
know is that?  Haha only joking.
OOC did you ever consider doing a PhD in some subject you are interested in?
I get the impression you would really enjoy it and maybe you can do it in
parallel with your current job.
Date: 17 Feb 2009 08:06:13
Message: <499ab645$1@news.povray.org>
> An interesting read
Thank you. I read that while I was a bored teenager.
[Insert comment here about what a bored teenager *should* be doing.]
My memory is a little rusty by now... o_O
Apparently DNA tends to get tangled and knotted, and there's protein
folding. These are both loosely related to knot relaxation. But
hard-core knot theory itself? No, not a huge number of directly
practical applications.
The subject *is*, however, ripe with humour.
"What's your favourit branch of mathematics?"
"Knot theory."
"Me neither."
> If I knit myself a jumper and then join the two lose ends together, what
> sort of knot is that?  Haha only joking.
Smart-arse. :-P
> in? I get the impression you would really enjoy it and maybe you can do
> it in parallel with your current job.
1. I barely passed my BSc. Studying something even harder would seem unwise.
2. AFAIK, you need an MSc before you can even attempt a PhD. Since I
nearly failed a BSc and an MSc is significantly harder, it seems
unlikely that I could get this. (To say nothing of the minor detail of
it requiring tens of thousands of pounds in course fees and several
years of my time.)
3. I severely doubt that I could actually perform a PhD at the same time
as doing a full-time job.
4. I already have a BSc, and it hasn't opened any doors for me. I
seriously doubt a PhD would be any significant help in this direction.
I could continue, but I think that'll do for now.
Date: 17 Feb 2009 08:06:34
Message: <499ab65a$1@news.povray.org>
> study it.
Correct:
http://en.wikipedia.org/wiki/History_of_knot_theory
Wikipedia claims these are "knot diagrams".
Wrong:
http://en.wikipedia.org/wiki/Reidemeister_move
Wrong:
http://en.wikipedia.org/wiki/Alexander_polynomial
http://en.wikipedia.org/wiki/Jones_polynomial
http://en.wikipedia.org/wiki/Alexander-Conway_polynomial
http://en.wikipedia.org/wiki/HOMFLY_polynomial
> left with.
Wrong:
http://en.wikipedia.org/wiki/Dowker_notation
(Note particularly that my algorithm is wrong, and that the notation is
ambiguous in a precise way.)
> like this:
>   1   2   3   4   5   6
>   1   2   3   4   5   6
Wrong:
http://en.wikipedia.org/wiki/Braid_theory
> correct.)
> on top.)
Wrong:
http://en.wikipedia.org/wiki/Tangle_theory
Wrong:
http://en.wikipedia.org/wiki/Knot_sum
(There are only two possible results from a knot sum, and it doesn't
matter where the join is, only the relative orientation of the two knots.)
> knot, however.)
Correct:
http://en.wikipedia.org/wiki/Torus_knot
Wrong:
http://en.wikipedia.org/wiki/Cable_knot
http://en.wikipedia.org/wiki/Satellite_knot
> interesting.
Correct:
http://en.wikipedia.org/wiki/Knot_theory#Higher_dimensions
Date: 17 Feb 2009 08:14:22
Message: <499ab82e$1@news.povray.org>
> unwise.
But let me guess, you did well on some parts but badly on other parts?  If
you could study only the bits you really enjoyed and were good at, you would
do better.
Oh ok, I wasn't aware of that limitation (Engineering degrees are usually
all 4 years so of course this limitation wasn't mentioned to us).
Why not? You could probably do a PhD instead of posting here :-)
Oh I'm sure it would, today almost everyone has some sort of degree, having
a PhD will make you stand out from the crowd, much like having a degree a
few decades ago did.  Besides, you will probably enjoy it, plus it will get
you into an enjoyable job later.
But yes, it could be a bit pricey to fund yourself.
Date: 17 Feb 2009 09:04:10
Message: <499ac3da$1@news.povray.org>
>> unwise.
> If you could study only the bits you really enjoyed and were good at,
> you would do better.
I very much doubt you can actually do a PhD in "doing cool stuff with a
computer". It's a tad vague, eh?
> usually all 4 years so of course this limitation wasn't mentioned to us).
My course was 4 years too, but it was only a BSc. I might be wrong about
the MSc requirement, but that's what I heard.
>> time as doing a full-time job.
LOL! Yeah, right. :-P
Besides, don't you have to, like, spend years searching through the
library to find every piece of work that has ever been written about
your subject, read and memorise it all, and then present a giant summary
of it? Don't you have to trudge across the plains of Tibet to find an
ancient sage to consult on the works on the Ancient Masters to see if
they have anything relevant to add? I don't think I could do that from
my desk at work.
> having a PhD will make you stand out from the crowd, much like having a
> degree a few decades ago did.
Meh. I doubt it. It seems everybody just asks "how many years' coding
experience do you have?" and "what are your customer service skills like?"
> it will get you into an enjoyable job later.
The former, perhaps, the latter, unlikely. (So those jobs still exist?)
Er, yes.
Date: 17 Feb 2009 10:01:05
Message: <op.uph3zvtemn4jds@phils>
And lo On Tue, 17 Feb 2009 11:45:40 -0000, Invisible <voi### [at] devnull> did
spake thusly:
Yay!
> digress...)
Yeah interesting how some ideas can come back from the grave.
Also perhaps worth pointing out it's only one area of study in topology.
<snip>
Okay let's try the trefoil knot.
-1, 4
2, -5
-3, 6
Leaves 4,-5,6. Hmmm? Okay let's try that again following Dowker notation.
1,4
2,5
3,6
As this is an alternating knot, no changes in signs required.
Write out the odd numbers with corresponding entry beneath
1, 3, 5
4, 6, 2
Throw away the top numbers to leave 4,6,2.
> like this:
>    1   2   3   4   5   6
>    1   2   3   4   5   6
Trivial, It's a rubber-band twisted twice.
> souls. TTFN!
Interesting, polish it up and stick it on your blog.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 17 Feb 2009 10:11:51
Message: <499ad3b7$1@news.povray.org>
Phil Cook v2 wrote:
> Yay!
See, that's what I'm talkin bout! :-D
Yeah, but topology is friggin *weird*. Knot theory makes actual sense.
> -1, 4
> 2, -5
> -3, 6
> 1,4
> 2,5
> 3,6
> 1, 3, 5
> 4, 6, 2
See my other reply. I've got the algorithm wrong.
>> like this:
>>    1   2   3   4   5   6
>>    1   2   3   4   5   6
>> so that the ends at the top connect with the ends at the bottom, this
>> would make a closed loop. In fact, in this case, the result would be
>> *several* closed loops. The 1 strand would be an unknot, not connected
>> to anything else. Strands 5 and 6 would become a single strand, which
>> can then be untwizzled to make an unknot. And strands 2, 3 and 4 would
>> be connected; off the top of my head, I'm not sure if this would be a
>> nontrivial knot.
Probably. Actually, wait - there are only 2 crossings. No nontrivial
knot has that few. Yes, it's definitely trivial. *sigh* Rusty...
>> over-interested souls. TTFN!
Now, see, when I spend ages writing something like this, I kinda want
people to go "hey, that's interesting. I had no idea this crap even
existed!" But typically they go "OK, that's nice dear".
I just wish I could find a place where the stuff I know would actually
impress people... *sigh*
Date: 17 Feb 2009 10:16:29
Message: <499ad4cd$1@news.povray.org>
> computer".
Of course you can, just substitute "cool stuff" for a subject that you
actually find cool.
> library to find every piece of work that has ever been written about your
> subject, read and memorise it all, and then present a giant summary of it?
> Don't you have to trudge across the plains of Tibet to find an ancient
> sage to consult on the works on the Ancient Masters to see if they have
> anything relevant to add? I don't think I could do that from my desk at
> work.
Depends on the subject of course, but nowadays I think most journals and
other academic resources are available online.  For a computing related PhD
I would imagine most of your time will be spent at the computer.
If you have a PhD you are not going to be applying for those sorts of jobs,
and more importantly companies are not going to expect you to be a code
monkey 24/7 when you are much more capable than that.
Here's an interesting CV:
http://www.geisswerks.com/ryan/resume_ryan_geiss.doc
See, just write something cool *and actually finish it* and then everyone
wants to employ you!
