POV-Ray : Newsgroups : povray.off-topic : Numeric performance Server Time
2 Nov 2026 17:55:02 EST (-0500)
  Numeric performance (Message 1 to 26 of 26)
Subject: Numeric performance
Date: 15 Feb 2009 12:50:33
Message: <499855e9$1@news.povray.org>
How slow is converting between floating-point representation and integer
representation?
I'm seeing a very large performance hit when I do this, and I'm trying
to figure out whether this is just one of the performance
characteristics of a typical CPU, or a software bug.
http://blog.orphi.me.uk/
Subject: Re: Numeric performance
Date: 15 Feb 2009 12:52:44
Message: <4998566c$1@news.povray.org>
> representation?
Which language? Any example of the code that shows what you are actually
doing?
Severi Salminen
http://www.iki.fi/severi
Date: 15 Feb 2009 14:15:03
Message: <499869b7$1@news.povray.org>
> doing?
If I add up a few thousand 32-bit signed integers, it takes 20 seconds.
If I use double-precision floating-point, it takes 43 seconds.
If I use double-precision, and then convert each number to an integer,
and then add it to the total, it takes 6 minutes.
I'm wondering whether the hardware is actually that slow, or whether
this is a performance bug in Haskell's number libraries.
Date: 15 Feb 2009 14:59:28
Message: <49987420@news.povray.org>
  What are you using? A 8086? In fact, I think even a 8086 could sum
a lot more than a few thousands of integers in 20 seconds.
  Out of curiosity, I tried a small test program in my computer which
creates an array of integers, then goes through it and calculates the
sum of all the integers. I had to use an array of 100 million integers
before I got even some measurable delay, and that was 0.7 seconds.
  I bet most of the time was caused by cache misses because of the
humongous array (taking 400 megabytes of memory) rather than the summing
process.
  I think there's something else fundamentally wrong with the system you
are using than summing integers or converting between floats and ints.
Date: 15 Feb 2009 15:12:19
Message: <49987723$1@news.povray.org>
>> doing?
I tried adding up 1e10 (10 billion, using Finnish  meaning of "billion"
:) floats to a float variable (in 2 nested for loops). It took around
10s. Adding up 1e10 floats to an int variable took 30s. So the
conversion took some time. I tried with C++ with no optimizations at all.
But I agree with Warp. Adding up few thousand integers should definitely
not take 20s.
Severi Salminen
Date: 15 Feb 2009 15:13:28
Message: <49987768$1@news.povray.org>
news:49987420@news.povray.org...
> are using
Fundamentally wrong? Of course. He already mentioned Haskell, didn't he?
Date: 15 Feb 2009 15:15:25
Message: <499877dd$1@news.povray.org>
You understand that when I said "a few thousand", I just meant "a lot",
right? I wasn't being rigorous about the number.
Actually the number I'm using is 10^8, which is... er, let me see... 100
million?
> process.
Uhuh. And are you by any chance running this on an AMD Mobile AlthonXP
1400+?
I hacked into the numeric library and called the low-level C primop
directly, and runtime dropped to 68 seconds, rather than 6 minutes. I
believe this clearly demonstrates that there is something Very Wrong
with the default numeric implementation...
Date: 15 Feb 2009 15:46:23
Message: <49987f1e@news.povray.org>
> million?
  20 seconds to add up 100 million integers is still quite a lot.
  I find it ironic that you constantly comment on the "unfounded" prejudices
relating to the speed of Haskell in the other group, yet time after time you
demonstrate in practice how Haskell is orders of magnitude slower than a
simple C++ program. This isn't the first time that I remember.
> > process.
> 1400+?
  I have hard time believing my computer is 30 times faster than that.
Twice or three times as fast I could still maybe swallow, but not 30 times.
(Athlons are rather notorious for being much faster than the Pentium4 line
with the same clockrates.)
Date: 15 Feb 2009 16:12:12
Message: <4998852c$1@news.povray.org>
Well, you look at Haskell and how it's used, and it "looks" like it
should be insanely slow. (E.g., recursion is used everywhere.) It's easy
to think it has no performance at all.
And yet, when you look at things like the Great Language Shootout,
Haskell beats several supposedly "superior" languages. Last time I
checked, it's near the very top of the main scoreboard.
OK, well I just wrote a small C program to do the same thing... and it
segfaulted at me.
So then I looked up the printf() manpage to find out what the correct
magic code is, and tried again... 0.8 seconds to do the integer sum.
Based in this information, I conceed defeat. I have no idea what's gone
wrong here.
PS. I just changed the Haskell program. It now takes 0.5 seconds - which
is even faster than C. But I still have no idea why the first version
wasn't this fast, so that's not much comfort.
Date: 15 Feb 2009 16:22:28
Message: <49988794$1@news.povray.org>
So maybe it's because I'm using this version of the compiler that I
built myself, and it's broken in some way?
Er, no. Just tried it with the release version. The numbers are a
fraction of a second slower still. Either way, two equivilent
formulations of the program have wildly different runtimes.
Interestingly, on my much more powerful desktop PC [with yet another
version of the compiler], the "slow" version only takes 2 seconds. But
the "fast" version is too quick to time, so something is still wrong.
Ah, the bitter taste of utter defeat.
Date: 15 Feb 2009 16:35:24
Message: <49988a9c@news.povray.org>
> segfaulted at me.
  I give up. For some reason trying to teach you something seems
completely pointless.
Date: 15 Feb 2009 17:57:22
Message: <49989dd2$1@news.povray.org>
> wrong here.
I was going to suggest earlier "maybe he's evaluating the stuff lazily and
doesn't realize it", but then I deleted it half-written thinking "surely I'm
not going to guess better than Andrew what his Haskell code is doing." :-)
   "Ouch ouch ouch!"
   "What's wrong? Noodles too hot?"
   "No, I have Chopstick Tunnel Syndrome."
Date: 15 Feb 2009 17:59:17
Message: <49989e45$1@news.povray.org>
Now now. He *did* say he got it working. :-)  And you must admit, printf()
isn't the most intuitive way of printing something.
   "Ouch ouch ouch!"
Date: 15 Feb 2009 18:26:18
Message: <4998a49a@news.povray.org>
> Er, no. Just tried it with the release version. The numbers are a fraction
> of a second slower still. Either way, two equivilent formulations of the
What's the difference between them?
 - Slime
 [ http://www.slimeland.com/ ]
Date: 16 Feb 2009 04:54:57
Message: <499937f1@news.povray.org>
> printf() isn't the most intuitive way of printing something.
No, it seems Warp is right.
I have conclusively demonstrated that Haskell is many orders of
magnitude slower than C even for a trivial program.
After all these years of using Haskell, I thought I understood how it
worked. I read all the papers about all the sophisticated optimisations
the compiler performs. And I felt sure I knew what I was doing. But,
clearly, I don't.
I have wasted 4 years of my life on Haskell. It is so beautiful and
eligant, I wanted it to be the answer, and I blindly believed that it
would be. Clearly it isn't.
The irony, the sheer irony of it, is that the whole reason I was timing
this stuff in the first place was that I was just about to reach into
the source code of the compiler to try to tweak its performance. It is
obvious to me now that I shouldn't be let anywhere near an actual
compiler. Better to leave that to the real experts.
It seems I've been deluding myself. All these years, I thought I was
some kind of master programmer. What, just because I've been writing
programs for 20 years, that makes me an expert? Just because I wrote
some trivial raytracer and it kinda worked, that means I'm good at
programming? Who the hell am I kidding?
I am now the laughing stock of this forum. Nobody is ever doing to take
anything I say about Haskell seriously ever again. Even better, when I
asked about this in the Haskell forum, I got yelled at for being a
troll. (Again.)
So, not only do I fail at programming, I fail at human interaction. It
seems everywhere I do, people yell at me for being immature and
outspoken. Maybe I should just take myself away somewhere and figure out
WTF is *wrong* with me. I fail at life.
I'm sorry.
Date: 16 Feb 2009 05:33:54
Message: <49994112@news.povray.org>
Nah, he's just fed up.  That happens with people, but we love him[1] anyway!
No, you haven't.  What you *have* demonstrated is that your particular
program runs slower than an alternative implementation in a completely
different environment.
I can't say what the slowdown is, or why it's occurring, unless I saw
your actual Haskell code.  Most likely there's a very good reason for
the performance hit.
"When you're a hammer, the whole world looks like a nail."
The fact is that Haskell, like every other language out there, is a tool
- a tool that helps you get things done.  It doesn't do the same things
C does, or do things the same way, because it *isn't* C.  It's good at
(and for) different things[2].
Sometimes, you need C.  Sometimes you need Haskell.  Spending your time
learning it and using it doesn't mean you've wasted your time.
Stephen R Donaldson is fond of quoting, "When you become a master of one
thing, you become a master of all things."  This isn't to say that by
learning Haskell you're a master programmer in any language; but the act
of mastering something so complex teaches you how to master anything you
set yourself to.
Never count the mastery of a skill as a waste, even if it's a skill you
never end up using.
Actually, that's a great idea.  There's no better way to learn than by
doing.
Do you know what an "expert" really is?  An "ex" is a has-been, and a
"spert" is a drip under pressure!
Anyway, how do you think the "experts" got to be that way?  By doing
exactly what you're doing right now!
Well, you might have been deluding yourself in that, yes.  But there's
nothing wrong with aspirations :)
No, you're not.  You're our friend and, yes, sometimes we laugh at you -
but we laugh at pretty much everyone.  As Scott Adams says, "Everyone is
an idiot at something."  That means that everyone gets to be laughed at
:)  Take it in stride, and join in the laughter yourself - you might
find it cathartic.
They yell at you for being immature?  Doesn't that make them... immature?
> I fail at life.
Not yet, you haven't.  Everyone has minor stumbling blocks, but they
really are minor.
Besides, if you're talking about failing at something you love, then
you're in good company.  Do you know why Henry Ford's first automobile
company was dissolved?  It was because the car they made was lower
quality and higher price than he liked.  In other words, it was a
question of optimization ;)
Anyway, it's late here, & I should get some sleep.
[1]See the thread titled "you & me right now, warp"
[2]If Haskell can be embedded, I'm thinking it would make a great patch
for POV-Ray.  Something like this:
#declare h_func = haskell { "..." }
#declare val = h_func(1,2,3)
Anywhere POV takes functions, it could use a Haskell function.
...Chambers
www.pacificwebguy.com
Date: 16 Feb 2009 06:48:58
Message: <0lkip4hskcrrlsgbr41m4i06fpsgvpp597@4ax.com>
But what about non trivial problems?
I'm sure that Haskell was not developed for adding lots of numbers. (Not
counting the fact that is what all computers do ;) ) What does it do well, why
not try checking it against C++ with something it is designed for?
As for wasting you time, if you enjoyed yourself the time was not wasted.
Remember the old saying. Don't get depressed, get even.
Regards
Date: 16 Feb 2009 09:53:51
Message: <49997dff$1@news.povray.org>
>> 1400+?
P4 Core2 Duo here,
1 billion iterations, C#
1000000000 Int Sum Time: 00:00:02.2499280
1000000000 Double Sum Time: 00:00:03.3905165
1000000000,1000000000 Double Convert Time: 00:00:03.7655045
^^ Interestingly the float to int conversion uses an MMX instruction.
Apparently it is very costly to do it without MMX, the CLR JIT uses the
MMX instruction regardless, so I have no comparison for the non-MMX
instruction. But, the difference is negligible between floating point
operations and integer.
~Mike
Date: 16 Feb 2009 11:22:59
Message: <499992e3@news.povray.org>
  I was not talking about Haskell vs. the world in my comment quoted
above. I was talking about you trying to do it in *C* and having your
program crash, after all the trouble I have gone in the past to try to
teach you safe programming practices in C++, as a better alternative to C.
  I got exasperated because I thought that maybe, just maybe you had
learned something about the C/C++ family of languages, and perhaps learned
to make working programs in C++ with less effort (than in C, that is).
But no. When you want to try something with something else than Haskell,
you go once again back to C and have your program crash on you. It feels
like all my teaching efforts went completely to waste.
Date: 16 Feb 2009 16:22:43
Message: <4999d923$1@news.povray.org>
One relies on automatic list fusion, the other is hand-fused. It turns
out GHC doesn't automatically fuse left folds. Since the entire program
is a left fold, I guess that'll be the problem then...
If my assumption that all list operations do get fused had been correct,
the two programs *would* be almost completely equivilent. (One with more
overloading than the other, possibly contributing to a few percent
overhead.)
This is what happens when you *assume* you know what you're talking
about; you get caught out.
Date: 16 Feb 2009 17:04:54
Message: <4999E305.4030602@hotmail.com>
> million?
note to self: never lend money to that guy.
Date: 17 Feb 2009 04:25:27
Message: <499a8287$1@news.povray.org>
> troll. (Again.)
Last night, I wrote a carefully worded reply to the Haskell mailing
list. As of now, the moderators still haven't released the message yet.
So to everybody on the list, it looks like I posted a bunch of
misinformation, got called on it, and just didn't bother to reply. Yay
for me. :-(
Date: 17 Feb 2009 04:38:57
Message: <499a85b1$1@news.povray.org>
"GHC currently does not fuse left folds."
Since my entire program was a simple left fold, that'll be the problem.
(This also explains why the hand-fused version runs much faster -
although I'm still not sure how it manages to be *faster* than C...)
> doing.
Sure. Like anybody is going to accept a compiler modification from a
"troll". Like any of the compiler developers are going to be eager to
help one out. Indeed, the person who yelled at me was the very guy I
wanted to ask for help from; he's the one who reported the issue I was
looking at fixing.
Well, we're talking about people such as the legendary Simon Peyton
Jones, one of the original PhDs who *invented* Haskell. People who know
what "denotional semantics" actually means, and what "the lambda cube"
is. They didn't get to where they are by blindly poking around somebody
else's source code. They did it by spending decades in research and
development on programming language design, compiler architecturing,
applied mathematics, and things I'd never understand in my wildest dreams.
There's nothing wrong with *wanting* to become a master. There's
everything wrong with believing you *are* a master in the complete
absence of any evidence for this.
> find it cathartic.
Well, let me put it this way: Next time I say "Haskell is fast", nobody
is going to believe me for even a split second. So basically what I've
been saying all these years is nonesense.
Well, I say "yell" at me... Of course they put it more professionally
than that. But the gist of it is that they think I'm a troll and they
don't want me around.
I'm not sure that would be such a hot idea.
   #declare angleR = angleD / 180 * pi;
   #declare angleR = haskell{"fromIntegral angleD / 180 * pi"};
   #declare center = <1, 2, 3>;
   #declare center = haskell{Vector3 1 2 3};
   #declare T1 = texture {pigment {red 1} finish {ambient 0}}
   #declare T1 = haskell{default_texture {pigment = PSolid {colour =
ColourRGB 1 0 0}, finish = Finish {ambient = ColourRGB 0 0 0}}};
Not so great, eh?
What you *could* do - and what I attempted to do a while back - is
design a domain-specific language for scene description/construction. It
would be completely incompatible with POV-Ray's current SDL, but it
might be quite nice.
OTOH, if you were going to do that, everybody would want an
object-oritented language rather than a functional one.
Date: 17 Feb 2009 10:06:35
Message: <499ad27b$1@news.povray.org>
On 2/17/2009 1:25 AM, Invisible wrote:
>> take anything I say about Haskell seriously ever again. Even better,
>> when I asked about this in the Haskell forum, I got yelled at for
>> being a troll. (Again.)
> for me. :-(
Ah, the joys of moderated groups :(
...Chambers
Date: 17 Feb 2009 10:07:47
Message: <499ad2c3$1@news.povray.org>
>> for me. :-(
That's the fun thing. It's *not* a moderated group. (So... why are my
posts being moderated??)
Date: 17 Feb 2009 14:41:29
Message: <499b12e9$1@news.povray.org>
Well look at that... I sent an email to the list administrator, and
*within minutes* several emails a sent a few days ago have suddenly
appeared on the mailing list! How "interesting"... :-P
